Hi All,
I'm trying to get an additional UART functioning on the Asset Tracker v2 sample project, built for the nRF9160DK.
I've successfully implemented UART0 (console off) and UART1 on the nRF9160DK; successfully changed the analog switch from VCOM to physical pins on the nRF52840; and successfully rerouted RX and TX pins to spare pins on the DK. These are implemented in an example project attached (uart_basics.zip) and have been physically validated.1325.uart_basics.zip
However when I try the same implementation in the Asset Tracker v2 sample project on my nRF9160DK, my nRF9160 resets as soon as the uart_tx function is called.
#include <zephyr/device.h> #include <zephyr/drivers/uart.h> const struct device *uart= DEVICE_DT_GET(DT_NODELABEL(uart1));
I embedded this function in one of the modules in the init state.
if (!device_is_ready(uart)){
LOG_DBG("UART device not ready\r\n");
uint32_t err_code;
err_code = uart_tx(uart, tx_start_msg, sizeof(tx_start_msg), SYS_FOREVER_MS);
I've read about users struggling to implement UART on the asset tracker project in this post and this post, but those seem to have been resolved at some point. I tried following the suggestions for proj.conf, but get a build error when using CONFIG_UART_1_NRF_UARTE=y.
Error: UART_1_NRF_UARTE (defined at drivers/serial/Kconfig.nrfx:119) is assigned in a configuration file, but is not directly user-configurable (has no prompt). It gets its value indirectly from other symbols.
If I use the latter 2 configurations (the first commented out), my program runs without resetting, but I get error code -134 on the uart_tx function. I haven't been able to figure out what this error means.
#CONFIG_UART_1_NRF_UARTE=y CONFIG_UART_1_ASYNC=y CONFIG_UART_1_INTERRUPT_DRIVEN=n
I'd really appreciate any assistance or advice on this issue!
My questions are:
- Am I using the correct UART function calls for the project which uses the Application Event Manager (AEM)?
- Am I using the correct proj_conf configurations?
- I understand that AEM is time sensitive on task handling - should I be implementing a different timeout other than SYS_FOREVER_MS as seen in the above code, or implementing it in the module thread?
- Can anyone post a link to the nRF Connect SDK Error code descriptions?
Thanks in advance!
