Device tree error for USB CDC on custom board
Hello everyone,
I working on the device tree of a custom board based on nRF5340. My starting point was the Thingy:53 device tree.
When I try to enable USB CDC for console and shell, I got the following building error with zephyr usb console sample:
/home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/console/libdrivers__console.a(uart_console.c.obj): in function `uart_console_init':
/home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/v2.4.0/zephyr/drivers/console/uart_console.c:613: undefined reference to `__device_dts_ord_123'
/home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/console/libdrivers__console.a(uart_console.c.obj): in function `console_out':
/home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/v2.4.0/zephyr/drivers/console/uart_console.c:110: undefined reference to `__device_dts_ord_123'
Extract of build/zephyr/include/generated/devicetree_generated.h:
 *   122 /soc/peripheral@50000000/usbd@36000
 *   123 /soc/peripheral@50000000/usbd@36000/cdc_acm_uart0
 *   124 /soc/peripheral@50000000/usbd@36000/cdc_acm_uart1
My device tree:
erl_nrf5340.zip
The only way to successfully build is to disabled uart0 and uart1 in the device tree, but its not acceptable because they will be used in final application.
Thank you for your help.
  • Hey Benoit,
    Can you share the zephyr.dts and .config files from your build folder?
    BR,
  • It's MCUBoot that fails to build :
    === child image mcuboot -  begin ===
    loading initial cache file /home/bgorostidi/Workspace/Projects/Iot/nrf53_test/console_usb/build_erl/mcuboot/child_image_preload.cmake
    -- Application: /home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/v2.4.0/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.20.5
    -- Found Python3: /home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/toolchains/1f9b40e71a/usr/local/bin/python3.8 (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: /home/bgorostidi/.cache/zephyr
    -- Zephyr version: 3.3.99 (/home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/v2.4.0/zephyr)
    -- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
    -- Board: erl_nrf5340_cpuapp
    -- Found host-tools: zephyr 0.16.0 (/home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/toolchains/1f9b40e71a/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.0 (/home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/toolchains/1f9b40e71a/opt/zephyr-sdk)
    -- Found Dtc: /home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/toolchains/1f9b40e71a/usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/bgorostidi/Workspace/Projects/Iot/nrf53_test/console_usb/boards/arm/erl_nrf5340/erl_nrf5340_cpuapp.dts
    -- Found devicetree overlay: /home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/v2.4.0/bootloader/mcuboot/boot/zephyr/app.overlay
    -- Generated zephyr.dts: /home/bgorostidi/Workspace/Projects/Iot/nrf53_test/console_usb/build_erl/mcuboot/zephyr/zephyr.dts
    You need to make sure you set the proper configs for the MCUBoot child image. See bootloader\mcuboot\boot\zephyr\boards\thingy53_nrf5340_cpuapp.conf for an example.
  • I looked to MCUBoot conf and put recommended conf into child_image/mcuboot.conf without external flash config. I also updated custom dts to add mcuboot Led/Button:
    		mcuboot-button0 = &button0;
    		mcuboot-led0 = &blue_led;
    I'm now getting errors relating to Partition Manager.
    Special question for my knowledge: Why my custom board, used on a sample project without 'CONFIG_BOOTLOADER_MCUBOOT=y' build an mcuboot image?
    0116.files.zip
  • From erl_nrf5340\Kconfig.defconfig:11
    config BOOTLOADER_MCUBOOT
    	default y if !MCUBOOT
    I suggest you base your custom board of the nRF5340-DK instead of the Thingy53, because Thingy53's board configuration files are not that easy to understand.
  • I create a new custom device tree based on NRF5340-DK. Without CONFIG_BOOTLOADER_MCUBOOT,  build succes. But, if I enable MCUBoot, "undefined reference to `__device_dts_ord_123'" error come back.
    My solution to avoid this error was to add child_image/mcuboot.conf with this conf:
    # Enable MCUboot Serial Recovery
    CONFIG_MCUBOOT_SERIAL=y
    CONFIG_UART_CONSOLE=n
    # Point Serial Recovery to CDC_ACM
    CONFIG_BOOT_SERIAL_CDC_ACM=y
    Thank you for your support.
  • It should be possible to get console for the bootloader as well, but I guess that is a bad use-case. Anyways, I'm glad you've solved the issue.
