I switched from NCS v2.3.0 to NCS v2.4.0. My code was building correctly with mcuboot and flash disk with NCS v2.3.0, but now I am getting the following error with newer SDK:
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:484:1: error: return type defaults to 'int' [-Werror=implicit-int]
484 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_CACHE)
C:/Backup/ncs-workspace/zephyr/drivers/disk/flashdisk.c: In function 'PM_FOREACH_AFFILIATED_TO_disk':
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:523:30: error: storage class specified for parameter 'flash_disks'
523 | static struct flashdisk_data flash_disks[] = {
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:523:15: error: parameter 'flash_disks' is initialized
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:524:39: error: 'DEFINE_FLASHDISKS_DEVICE' undeclared (first use in this function)
524 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_DEVICE)
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:524:39: note: each undeclared identifier is reported only once for each function it appears in
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:533:1: error: expected declaration specifiers before 'PM_FOREACH_AFFILIATED_TO_disk'
533 | PM_FOREACH_AFFILIATED_TO_disk(VERIFY_CACHE_SIZE_IS_NOT_ZERO_IF_NOT_READ_ONLY)
In file included from C:\Backup\ncs-workspace\zephyr\include\zephyr\toolchain\gcc.h:92,
from C:\Backup\ncs-workspace\zephyr\include\zephyr\toolchain.h:50,
from C:\Backup\ncs-workspace\zephyr\lib\libc\minimal\include\string.h:13,
from C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:8:
C:\Backup\ncs-workspace\zephyr\include\zephyr\init.h:125:44: error: storage class specified for parameter '__init_disk_flash_init'
125 | #define Z_INIT_ENTRY_NAME(init_id) _CONCAT(__init_, init_id)
C:\Backup\ncs-workspace\zephyr\include\zephyr\init.h:190:17: note: in expansion of macro 'Z_INIT_ENTRY_NAME'
190 | Z_INIT_ENTRY_NAME(name) = { \
C:\Backup\ncs-workspace\zephyr\include\zephyr\init.h:172:9: note: in expansion of macro 'SYS_INIT_NAMED'
172 | SYS_INIT_NAMED(init_fn, init_fn, level, prio)
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:563:1: note: in expansion of macro 'SYS_INIT'
563 | SYS_INIT(disk_flash_init, APPLICATION, CONFIG_KERNEL_INIT_PRIORITY_DEFAULT);
C:\Backup\ncs-workspace\zephyr\include\zephyr\init.h:188:42: error: parameter '__init_disk_flash_init' is initialized
188 | static const Z_DECL_ALIGN(struct init_entry) \
C:\Backup\ncs-workspace\zephyr\include\zephyr\init.h:125:44: error: section attribute not allowed for '__init_disk_flash_init'
C:\Backup\ncs-workspace\zephyr\include\zephyr\init.h:188:42: warning: 'used' attribute ignored [-Wattributes]
C:\Backup\ncs-workspace\zephyr\include\zephyr\init.h:125:44: error: alignment may not be specified for '__init_disk_flash_init'
In file included from C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:14:
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:563:10: error: 'disk_flash_init' undeclared (first use in this function)
C:\Backup\ncs-workspace\zephyr\include\zephyr\init.h:191:45: note: in definition of macro 'SYS_INIT_NAMED'
191 | .init_fn = {.sys = (init_fn_)}, \
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:484:1: error: type of 'DEFINE_FLASHDISKS_CACHE' defaults to 'int' [-Werror=implicit-int]
C:\Backup\ncs-workspace\zephyr\include\zephyr\init.h:125:44: error: declaration for parameter '__init_disk_flash_init' but no such parameter
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:523:30: error: declaration for parameter 'flash_disks' but no such parameter
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:565: error: expected '{' at end of input
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:565: warning: control reaches end of non-void function [-Wreturn-type]
C:/Backup/ncs-workspace/zephyr/drivers/disk/flashdisk.c: At top level:
C:\Backup\ncs-workspace\zephyr\drivers\disk\flashdisk.c:415:37: warning: 'flash_disk_ops' defined but not used [-Wunused-const-variable=]
415 | static const struct disk_operations flash_disk_ops = {
cc1.exe: some warnings being treated as errors
For generate the above error, please add below configuration in smp_svr sample:
#USB related configs CONFIG_USB_DEVICE_STACK=y CONFIG_USB_DEVICE_PRODUCT="Zephyr MSC sample" CONFIG_LOG=y CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y CONFIG_USB_MASS_STORAGE=y CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y CONFIG_USB_MASS_STORAGE_LOG_LEVEL_ERR=y CONFIG_APP_MSC_STORAGE_FLASH_LITTLEFS=y
Please help to solve this build issue with ncsv2.4.0.
