What parameters to use for disconnect command and to "listen" for in disconnected event (nrf8001)?
The nrf8001 datasheet seems to mention that there should be no connections when sleep command is sent. So I wanted to call aci_disconnect first. But what reason do I use? There is only 2 you can send: remote user terminated connection and unacceptable connection timing. Neither really makes sense. I am using ported adafruit code to atmel gcc toolchain and I try to catch disconnect event in poll function. If I get a generic disconnect then I want to advertise again just like default adafruit code. But if I get specific event then I want to disable bluetooth by sleeping. And the Disconnect Event info didn't coincide with anything related to reason mentioned above. So then:
Can you sleep the nrf8001 while it is connected or advertising?
If not (which is what I thought) then what reason should I use and more importantly what will be in the acistatus and btlestatus parameters of the disconnected event?
Thanks
Edited to change "since" to sense above.
