Infrared send driver time length is not correct sometimes, why ?
I use example ble_app_uart, SoftDevice sdk 6.2.1, when receive data from bluetooth, then drive IO pin 18 to send infrared wave. received data is Infrared raw formate, which means IO output pin send wave time length (micro second), the odd data is 'mark' time length, the even data is 'space' time length. receive data is:
Blockquote
8976 4556 600 1696 612 1688 608 540
604 544 608 540 604 544 600 1700
608 1688 608 544 600 544 608 540
604 1696 600 1700 600 548 604 544
600 1700 608 544 608 540 604 544
612
Blockquote
I call sendRaw function below to send infrared wave,The forty one data length is 612 us,however, I capture the wave time length by logic analyzer, result is 1380 us, other data is correct,why this happed, and how to fix it ? Or is there any other infrared send driver ? Thank you ! image description
below is the driver using time 1 and timer 2(time 1 to generate carrier, timer 2 to control time length)
     static   void timer_delay(volatile uint32_t usecond){
    	 //delay for usecond
        NRF_TIMER2->TASKS_CLEAR = 1;
        NRF_TIMER2->PRESCALER =7;
        NRF_TIMER2->MODE      = TIMER_MODE_MODE_Timer;
        NRF_TIMER2->BITMODE   = TIMER_BITMODE_BITMODE_16Bit;
    	NRF_TIMER2->CC[0]     = (usecond>>3);
        NRF_TIMER2->TASKS_START=1;
        while(NRF_TIMER2->EVENTS_COMPARE[0] == 0)
    	   //wait
    	  NRF_TIMER2->EVENTS_COMPARE[0]=0;
    	  NRF_TIMER2->TASKS_SHUTDOWN=1;
   static  void Mark(uint32_t time){
      // send carrier
        nrf_gpio_cfg_output(GPIO_OUTPUT_PIN_NUMBER);
    	nrf_gpiote_task_config(3, GPIO_OUTPUT_PIN_NUMBER, \
                               NRF_GPIOTE_POLARITY_TOGGLE, GPIOTE_CONFIG_OUTINIT_Low);
    	  // Clear TIMER1
        NRF_TIMER1->TASKS_CLEAR = 1;
        NRF_TIMER1->PRESCALER =4;
        NRF_TIMER1->CC[0]     =26;
        NRF_TIMER1->CC[1]     = 9;
        NRF_TIMER1->MODE      = TIMER_MODE_MODE_Timer;
        NRF_TIMER1->BITMODE   = TIMER_BITMODE_BITMODE_16Bit;
        NRF_TIMER1->SHORTS    = (TIMER_SHORTS_COMPARE0_CLEAR_Enabled <<    TIMER_SHORTS_COMPARE0_CLEAR_Pos);
    	NRF_TIMER1->TASKS_START = 1;
    	timer_delay(time);
    	  NRF_TIMER1->TASKS_SHUTDOWN = 1;
    	  NRF_GPIOTE->CONFIG[3] = (GPIOTE_CONFIG_MODE_Disabled   << GPIOTE_CONFIG_MODE_Pos);
       	NRF_GPIO->OUTCLR = (1UL << GPIO_OUTPUT_PIN_NUMBER);
      static void sendRaw(volatile uint16_t buf[], int len, int hz)
       // send driver
      for (int i = 0; i < len; i++) {
        if (i &1) {
            timer_delay(buf[i]);
        else {
            Mark(buf[i]);
    void gpiote_init_Midea(){
        // init gpiote
    void ppi_init_Midea(){
         //init ppi
		ppi_enable_channel(4,&(NRF_TIMER1->EVENTS_COMPARE[0]),&(NRF_GPIOTE->TASKS_OUT[3]));
		ppi_enable_channel(5,&(NRF_TIMER1->EVENTS_COMPARE[1]),&(NRF_GPIOTE->TASKS_OUT[3]));
        static void ppi_enable_channel(uint32_t ch_num, volatile uint32_t *event_ptr, volatile uint32_t *task_ptr)
       uint32_t err_code;
       uint32_t error;
      err_code =  sd_ppi_channel_assign(ch_num, event_ptr, task_ptr);
    	 if( err_code != NRF_SUCCESS ){
    					error = err_code;
      err_code =  sd_ppi_channel_enable_set(1 << ch_num);
    					error = err_code;
