nrf52840dk external supply or coin cell battery not supported when using uart app?
hi i currently using nrf52840dk
and i downloaded uart nus function to my dk.
when connected to usb power (J2)
everything works well
but when i use coin cell battry or external supply,
my dk won't turn on.
every my switch is in default state
i found link that has same issue with me
 Problems with coin cell and li-po battery
says when uart enabled, only J2 power is valid
does it still hold now?
if i use uart function on my dk, can i only power my dk to J2?
if so, why is that?
  • hi naeem
    yeah it seems that NCS with VS Code is widely used currently
    i need practice to handle with it
    BTW i misuploaded my code
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "bsp.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_delay.h"
    #include "nrf_temp.h"
    #include "app_button.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    //start of saadc
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "nrf_drv_clock.h"
    #include "nrf_drv_rtc.h"
    uint16_t USER_uart_tx(char *_str);
    //end of gpt
           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_CONN_CFG_TAG            1
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                2048                                      /**< UART TX buffer size.  original 256*/
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3 ;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static uint8_t m_data[] = "Button Pressed\r\n";
    static uint8_t m_data_1[] = "ADC started\r\n";
    static uint8_t m_data_2[] = "ADC stopped\r\n";
    // saadc start
    #define SAMPLES_IN_BUFFER 8
    int time=0;
    float ms=0;
    int ss=0;
    uint16_t cnt=0;
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(1);
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    #define SAADC_OVERSAMPLE NRF_SAADC_OVERSAMPLE_8X
    static volatile bool         saadc_aborted = false;
    void saadc_sampling_event_enable(void);
    void saadc_sampling_event_disable(void);
    int ADC_CH0[2]={0};
    int ADC_CH1[2]={0};
    uint16_t adc_index=0;
    uint16_t rtc_index=0;
    int i=0;
    //saadc end
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
        if (p_evt->type == BLE_NUS_EVT_RX_DATA) //is event rx data?
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]); //output string to interface function
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
         //   m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
            //case BSP_EVENT_KEY_2:
            //            err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAMPLES_IN_BUFFER);
            //            APP_ERROR_CHECK(err_code);
            //            saadc_sampling_event_enable();
            //            saadc_aborted = false;
            //            break;
            //case BSP_EVENT_KEY_3:
            //            saadc_sampling_event_disable();
            //            saadc_aborted = true;
            //            nrf_drv_saadc_abort();
            //            break;
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                            err_code = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle); //send data
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Application main function.
     //saadc function start
     void timer_handler(nrf_timer_event_t event_type, void * p_context)
     //   err_code = nrf_drv_timer_init(&m_timer, &timer_cfg, timer_handler);
        /* setup m_timer for compare event every 400ms */
        uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer,500);  //for 2 channel 50 is fastest limit  //10 possible for 1 channel
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
        //float val;
        //if (p_event->type == NRF_DRV_SAADC_EVT_DONE)
        //    ret_code_t err_code;
        //    err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        //    int i;
        //    NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        //    for (i = 0; i < SAMPLES_IN_BUFFER; i++)
        //        NRF_LOG_INFO("sample value %d", p_event->data.done.p_buffer[i]);
        //        val= p_event->data.done.p_buffer[i]*3.6/4096;
        //        NRF_LOG_INFO("voltage read:"NRF_LOG_FLOAT_MARKER"\r\n",NRF_LOG_FLOAT(val));
        //    m_adc_evt_counter++;
            uint16_t adc_value;
            uint8_t value[SAMPLES_IN_BUFFER*2];
            uint16_t bytes_to_send;
            float adc1,adc2,adc3,adc4;
            // set buffers
            if(!saadc_aborted)
            // print samples on hardware UART and parse data for BLE transmission
         //   NRF_LOG_INFO("ADC event number: %d\r\n",(int)m_adc_evt_counter);
            for (int i = 0; i < SAMPLES_IN_BUFFER; i++)
               //NRF_LOG_INFO("event number %d\r\n", p_event->data.done.p_buffer[i],ss,ms);
                adc_value = p_event->data.done.p_buffer[i];
                value[i*2] = adc_value;
                value[(i*2)+1] = adc_value >> 8;
            // Send data over BLE via NUS service. Create string from samples and send string with correct length.
            uint8_t nus_string[20];
            //bytes_to_send = sprintf(nus_string,
            //                        "CH0:%d   CH1:%d  CH2:%d    CH3:%d\r\n",
            //                        p_event->data.done.p_buffer[0],
            //                        p_event->data.done.p_buffer[1],
            //                        p_event->data.done.p_buffer[2],
            //                        p_event->data.done.p_buffer[3]);
            //err_code = ble_nus_data_send(&m_nus, nus_string, &bytes_to_send, m_conn_handle);
            //if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
            //adc1= p_event->data.done.p_buffer[0]*3.6/4096;
            //adc2= p_event->data.done.p_buffer[1]*3.6/4096;
            //adc3= p_event->data.done.p_buffer[2]*3.6/4096;
            //adc4= p_event->data.done.p_buffer[3]*3.6/4096;
      //      index_0=index_0*SAMPLES_IN_BUFFER;
            //bytes_to_send = sprintf(nus_string,"%d %.3f\r\n" ,p_event->data.done.p_buffer[0],ms);
            ADC_CH0[adc_index]=p_event->data.done.p_buffer[0];
            ADC_CH1[adc_index]=p_event->data.done.p_buffer[1];
            adc_index+=1;
            cnt+=1;
            if(adc_index>1)
               adc_index=0;
            i+=1;
    void saadc_init(void)
        //ret_code_t err_code;
        //nrf_saadc_channel_config_t channel_config =
        //  NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
        //err_code = nrf_drv_saadc_init(NULL, saadc_callback);
        //APP_ERROR_CHECK(err_code);
        //err_code = nrf_drv_saadc_channel_init(0, &channel_config);
        //err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
        //err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
        nrf_drv_saadc_config_t saadc_config;
        nrf_saadc_channel_config_t channel_config0;
        nrf_saadc_channel_config_t channel_config1;
        nrf_saadc_channel_config_t channel_config2;
        nrf_saadc_channel_config_t channel_config3;
        //Configure SAADC
        saadc_config.resolution = NRF_SAADC_RESOLUTION_14BIT;                                 //Set SAADC resolution to 12-bit. This will make the SAADC output values from 0 (when input voltage is 0V) to 2^12=2048 (when input voltage is 3.6V for channel gain setting of 1/6).
        saadc_config.oversample = SAADC_OVERSAMPLE;                                           //Set oversample to 4x. This will make the SAADC output a single averaged value when the SAMPLE task is triggered 4 times.
        saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;                               //Set SAADC interrupt to low priority.
        //Initialize SAADC
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);                         //Initialize the SAADC with configuration and callback function. The application must then implement the saadc_callback function, which will be called when SAADC interrupt is triggered
        //Configure SAADC channel
        channel_config0.reference = NRF_SAADC_REFERENCE_INTERNAL;                              //Set internal reference of fixed 0.6 volts
        channel_config0.gain = NRF_SAADC_GAIN1_6;                                              //Set input gain to 1/6. The maximum SAADC input voltage is then 0.6V/(1/6)=3.6V. The single ended input range is then 0V-3.6V
        channel_config0.acq_time = NRF_SAADC_ACQTIME_3US;                                     //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
        channel_config0.mode = NRF_SAADC_MODE_SINGLE_ENDED;                                    //Set SAADC as single ended. This means it will only have the positive pin as input, and the negative pin is shorted to ground (0V) internally.
        channel_config0.pin_p = NRF_SAADC_INPUT_AIN0;                                          //Select the input pin for the channel. AIN0 pin maps to physical pin P0.02.
        channel_config0.pin_n = NRF_SAADC_INPUT_DISABLED;                                      //Since the SAADC is single ended, the negative pin is disabled. The negative pin is shorted to ground internally.
        channel_config0.resistor_p = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pullup resistor on the input pin
        channel_config0.resistor_n = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pulldown resistor on the input pin
        channel_config0.burst  = NRF_SAADC_BURST_ENABLED;
        channel_config1.reference = NRF_SAADC_REFERENCE_INTERNAL;                              //Set internal reference of fixed 0.6 volts
        channel_config1.gain = NRF_SAADC_GAIN1_6;                                              //Set input gain to 1/6. The maximum SAADC input voltage is then 0.6V/(1/6)=3.6V. The single ended input range is then 0V-3.6V
        channel_config1.acq_time = NRF_SAADC_ACQTIME_3US;                                     //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
        channel_config1.mode = NRF_SAADC_MODE_SINGLE_ENDED;                                    //Set SAADC as single ended. This means it will only have the positive pin as input, and the negative pin is shorted to ground (0V) internally.
        channel_config1.pin_p = NRF_SAADC_INPUT_AIN1;                                          //Select the input pin for the channel. AIN0 pin maps to physical pin P0.02.
        channel_config1.pin_n = NRF_SAADC_INPUT_DISABLED;                                      //Since the SAADC is single ended, the negative pin is disabled. The negative pin is shorted to ground internally.
        channel_config1.resistor_p = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pullup resistor on the input pin
        channel_config1.resistor_n = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pulldown resistor on the input pin
        channel_config1.burst  = NRF_SAADC_BURST_ENABLED;
        channel_config2.reference = NRF_SAADC_REFERENCE_INTERNAL;                              //Set internal reference of fixed 0.6 volts
        channel_config2.gain = NRF_SAADC_GAIN1_6;                                              //Set input gain to 1/6. The maximum SAADC input voltage is then 0.6V/(1/6)=3.6V. The single ended input range is then 0V-3.6V
        channel_config2.acq_time = NRF_SAADC_ACQTIME_3US;                                     //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
        channel_config2.mode = NRF_SAADC_MODE_SINGLE_ENDED;                                    //Set SAADC as single ended. This means it will only have the positive pin as input, and the negative pin is shorted to ground (0V) internally.
        channel_config2.pin_p = NRF_SAADC_INPUT_AIN2;                                          //Select the input pin for the channel. AIN0 pin maps to physical pin P0.02.
        channel_config2.pin_n = NRF_SAADC_INPUT_DISABLED;                                      //Since the SAADC is single ended, the negative pin is disabled. The negative pin is shorted to ground internally.
        channel_config2.resistor_p = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pullup resistor on the input pin
        channel_config2.resistor_n = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pulldown resistor on the input pin
        channel_config2.burst = NRF_SAADC_BURST_ENABLED;
        channel_config3.reference = NRF_SAADC_REFERENCE_INTERNAL;                              //Set internal reference of fixed 0.6 volts
        channel_config3.gain = NRF_SAADC_GAIN1_6;                                              //Set input gain to 1/6. The maximum SAADC input voltage is then 0.6V/(1/6)=3.6V. The single ended input range is then 0V-3.6V
        channel_config3.acq_time = NRF_SAADC_ACQTIME_3US;                                     //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
        channel_config3.mode = NRF_SAADC_MODE_SINGLE_ENDED;                                    //Set SAADC as single ended. This means it will only have the positive pin as input, and the negative pin is shorted to ground (0V) internally.
        channel_config3.pin_p = NRF_SAADC_INPUT_AIN3;                                          //Select the input pin for the channel. AIN0 pin maps to physical pin P0.02.
        channel_config3.pin_n = NRF_SAADC_INPUT_DISABLED;                                      //Since the SAADC is single ended, the negative pin is disabled. The negative pin is shorted to ground internally.
        channel_config3.resistor_p = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pullup resistor on the input pin
        channel_config3.resistor_n = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pulldown resistor on the input pin
        channel_config3.burst        = NRF_SAADC_BURST_ENABLED;
        //Initialize SAADC channel
        err_code = nrf_drv_saadc_channel_init(0, &channel_config0);                            //Initialize SAADC channel 0 with the channel configuration
        err_code = nrf_drv_saadc_channel_init(1, &channel_config1);                            //Initialize SAADC channel 0 with the channel configuration
        err_code = nrf_drv_saadc_channel_init(2, &channel_config2);                            //Initialize SAADC channel 0 with the channel configuration
        err_code = nrf_drv_saadc_channel_init(3, &channel_config3);                            //Initialize SAADC channel 0 with the channel configuration
        nrfx_saadc_channel_uninit(2);
        nrfx_saadc_channel_uninit(3);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAMPLES_IN_BUFFER);    //Set SAADC buffer 1. The SAADC will start to write to this buffer
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAMPLES_IN_BUFFER);    //Set SAADC buffer 2. The SAADC will write to this buffer when buffer 1 is full. This will give the applicaiton time to process data in buffer 1.
        ret_code_t err_code = nrf_drv_ppi_channel_disable(m_ppi_channel);
     //saadc function end
    void conn_evt_len_ext_set(void)
        ble_opt_t  opt;
        memset(&opt, 0x00, sizeof(opt));
        opt.common_opt.conn_evt_ext.enable = 1;
        err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
    //rtc
    const nrfx_rtc_t rtc=NRFX_RTC_INSTANCE(2); //rtc 2 handle
    static void lfclk_config(void)
    static void rtc_handler( nrfx_rtc_int_type_t int_type )
        uint8_t str[20] ;
        float volt_0,volt_1;
        uint16_t length_rtc = 0;
        if(int_type == NRFX_RTC_INT_TICK )
          //  time+=1;  //increase time value every 1ms
            ms+=0.0001;
            //ss=time/1000;
            //sprintf(str,"%d:%d\r\n" , ss,ms);
            //length=USER_uart_tx(str);
            //ble_nus_data_send(&m_nus, str, &length, m_conn_handle);
            if( saadc_aborted==false )
                if( rtc_index == adc_index )
                else if( rtc_index!=adc_index )
                    volt_0=ADC_CH0[adc_index]*3.6/4096;
                    volt_1=ADC_CH1[adc_index]*3.6/4096;
                    sprintf(str,"%d %.4f\r\n", ADC_CH0[adc_index],ADC_CH1[adc_index],ms);
                    length_rtc=USER_uart_tx(str);
                    ble_nus_data_send(&m_nus,str, &length_rtc, m_conn_handle);
                    rtc_index = adc_index;
            else if( saadc_aborted==true )
    static void rtc_config(void)
        uint32_t err_code;
        nrfx_rtc_config_t rtc_config = NRFX_RTC_DEFAULT_CONFIG;
        rtc_config.prescaler = 2.2768 ; //tick=32768/(31.768+1) ==1000hz  500hz
        err_code = nrfx_rtc_init(&rtc, &rtc_config , rtc_handler );
        nrfx_rtc_tick_enable(&rtc, true);
        nrfx_rtc_enable(&rtc);
    // rtc end
        int flag=0;
        int init_flag=1;
        char temperature[50];
        int32_t temp;
        bool erase_bonds;
        uint32_t     err_code;
        uint16_t length =0;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
     //   conn_evt_len_ext_set();
        advertising_init();
        conn_params_init();
        lfclk_config();
        rtc_config();
        // Start execution.
        advertising_start();
        NRF_LOG_INFO("SAADC HAL simple example started.");
        // Enter main loop.
        while(1)
            //if(bsp_board_button_state_get(BSP_BOARD_BUTTON_1)==1 && flag==0 )
            //      length=USER_uart_tx(m_data);
            //      err_code = ble_nus_data_send(&m_nus, m_data, &length, m_conn_handle); //send data
            //      if ((err_code != NRF_ERROR_INVALID_STATE) &&
            //          (err_code != NRF_ERROR_RESOURCES) &&
            //          (err_code != NRF_ERROR_NOT_FOUND))
            //      nrf_delay_ms(100);
            if(bsp_board_button_state_get(BSP_BOARD_BUTTON_2)==1 &&flag==0)
                  if( init_flag==1 )
                      saadc_init();
                      saadc_sampling_event_init();
                      init_flag=0;
                      flag=1;
                  else if(init_flag==0)
                      ms=0;
                      flag=1;
                      length=USER_uart_tx(m_data_1);
                      // err_code = ble_nus_data_send(&m_nus, m_data_1, &length, m_conn_handle); //send data
                      time=0;
            else if(bsp_board_button_state_get(BSP_BOARD_BUTTON_3)==1 && flag==1)
                  flag=0;
                  length=USER_uart_tx(m_data_2);
                  //err_code = ble_nus_data_send(&m_nus, m_data_2, &length, m_conn_handle); //send data
            idle_state_handle();
            //flag=bsp_board_button_state_get(BSP_BOARD_BUTTON_1);
         //   temp start
            //sd_temp_get(&temp);
            //temp=temp/4;
            //sprintf(temperature, "Temperature is %d\r\n", temp);
            //length=USER_uart_tx(temperature);
            //ble_nus_data_send(&m_nus, temperature, &length, m_conn_handle);
            //nrf_delay_ms(500);
        //    NRF_LOG_FLUSH();
            ////temp end
    	uint16_t i;
    	for(i = 0 ; i < 1000  ; i++   )
    		if(_str[i] == 0)
            return i;
    thank you
    Best regards
    Lee
  • i found the article about this issue from below link
     nRf52833-DK doesn't start up with coin cell battery when running ble_app_uart example.
    according to this solution,
    i connected P0.08 to VDD
    and my board finally responded to coin cell battery
    thanks for your reply naeem
    best regards
    Lee
