Did Worker Process die? on Flash
Hi, while working with the nRF9160DK i get this Error a lot of times, I can't say "Yes" or something else and have to wait until the progress bar fills completely. Even if I disconnect the DK.
It really takes some time on a workday because this happens a lot. I hope there is a fix,
Greetings,
Philipp
  • (.venv) yat033@WICHITA-PH workspace % nrfjprog -v
    nrfjprog version: 10.24.0 external
    JLinkARM.dll version: 7.94e
    Custom hardware and a SEGGER j-link Ultra+.
    Flashing the binary (bootloader + application) in seperate parts works fine, combined it consistently fails.
    Doing a full chip erase with `nrfjprog --recover` and then flashing without `--sectorerase` also works fine.
    My suspicion is that with `--sectorerase` and a large binary, the erase component of the job takes too long (12 seconds) and thus the job times out. Is there perhaps a 10 second internal timeout on the erase operation?
    Does it work if you do it directly from cmd line using west? If not, what does it say/output/log?
  • It doesn't make a difference whether it is run through west or directly with `nrfjprog`.
    I have also attached the generated log file.
    (.venv) yat033@WICHITA-PH workspace % west flash -d build/taurus/egrazor
    -- west flash: rebuilding
    [0/13] Performing build step for 'nrf_secure_boot'
    ninja: no work to do.
    [3/3] Completed 'nrf_secure_boot'
    -- west flash: using runner nrfjprog
    -- runners.nrfjprog: reset after flashing requested
    Using board 505102200
    -- runners.nrfjprog: Flashing file: build/taurus/egrazor/zephyr/merged.hex
    Timed out waiting for progress updates.sing non-volatile memory - block 2 of 2
    Did worker process die?
    [ #################### ]   9.899s | Erase file - Done erasing
    ERROR: An internal error has occurred, please try again.
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    FATAL ERROR: command exited with status 63: nrfjprog --program build/taurus/egrazor/zephyr/merged.hex --sectorerase --verify -f NRF91 --snr 505102200
    8130.log.log
  • I see.
    I don't think that nrfjprog would time out if everything is working as expected. I see there are some errors in the log, so it suggests that something else has happened, other than a timeout of ~10 seconds.
    Is it possible to upload the .hex file that you are trying to program? Perferably both the merged and separated ones.
    Have you tried on a different computer than the M2 Mac?
    I will forward the log to our nrfjprog team, and see if they can make sense of it.
    Edvin
  • What errors are you referring to? `JLINK_HasError()` is just a check that is being called after every operation, and I can't see anything else.
    Hopefully the information I have already provided is enough, as I am finishing up at my current job tomorrow and are therefore not in a position to upload binaries or perform additional checks.
    If I run into the same problem again in the future I will be sure to open another ticket Slight smile
