When configuration options CONFIG_SEGGER_SYSTEMVIEW=y and CONFIG_TRACING=y are added to my prj.conf the following build errors are shown:
followed by many other errors.
Any suggestions how to solve this?
Elbert
Elbert
Which application sample did you try to build?
Dejan
Perhaps you can verify difference between v2.2.0 and v2.3.0 or newer?
The build target is nrf9160dk_nrf9160_ns.
Hi Elbert,
I have reproduced your issue in NCS v2.2.0 and v2.3.0. However, the issue was not present in NCS v2.4.1. You could try to update your NCS version to v2.4.1.
Dejan
We were planning to only do the major updates like 2.3.0 to 2.4.0, etc. But in this case I might need to update to v2.4.1 to test Segger SystemView.
At the moment I'm in the middle of things so this is something to be done in future.
I will keep you informed. Thanks for your help so far.
Hi Elbert,
Elbert said:I will keep you informed.
This would be great. Thank you.
Dejan
Old case, status with current used SDK v2.4.0 version unknown, so will be closed.
Elbert
Elbert
