gpiote event -> ppi -> gpiote task latency
Hi, I have a gpiote event setup that triggers a gpiote task via ppi,  this is the relevant code
NRF_POWER->TASKS_CONSTLAT = 1;
nrf_gpio_cfg_input(GPIO_OC,GPIO_PIN_CNF_PULL_Pullup);
nrf_gpiote_event_configure(GPIOTE_OC,GPIO_OC,comparator_idle_low?NRF_GPIOTE_POLARITY_LOTOHI:NRF_GPIOTE_POLARITY_HITOLO);
nrf_gpiote_event_enable(GPIOTE_OC);
nrf_gpiote_task_configure(GPIOTE_FET,GPIO_FET,NRF_GPIOTE_POLARITY_TOGGLE,NRF_GPIOTE_INITIAL_VALUE_LOW);
nrf_gpiote_task_enable(GPIOTE_FET);
NRF_GPIO->PIN_CNF[GPIO_FET] = (GPIO_PIN_CNF_DRIVE_H0H1 << GPIO_PIN_CNF_DRIVE_Pos);
nrf_ppi_channel_and_fork_endpoint_setup(ch,
(uint32_t)&(NRF_GPIOTE->EVENTS_IN[GPIOTE_OC]),
(uint32_t)&(NRF_PPI->TASKS_CHG[PPI_GROUP_RUN].DIS),//disregard this, the group has nothing to do with this i think
(uint32_t)&(NRF_GPIOTE->TASKS_CLR[GPIOTE_FET])
From rising edge on IO "GPIO_OC" to falling edge of "GPIO_FET" i get about 380ns
what can i do to lower this?
  • or am i limited by gpio (1cycle) + gpiote (1cycle) + ppi (1cycle) + gpiote (1cycle) + gpio (1cycle) = 5-6 cycles = 380ns?
  • Yes, it is the path that the signal needs to take and to be sampled. The best case scenario is 1 clock cycle propagation of the event in interest thought a peripheral and worst case is 2 cycles.
    I think I have seen similar propagation/sampling delays similar to your configuration in this thread. Try to see if enabling the constant latency in the power have any better results in your case.
  • hi, thanks for your awnser, constant latency is the first line of my code.
    is there anything else i must to to enable constant latency?
    i can not get under 360-380ns
    i also tested this:
    *(volatile uint32_t *)(NRF_GPIOTE_BASE + 0x600 + (4 * GPIOTE_OC)) = 1;
    now it is one clock cycle faster (~330ns), is there any way i could get any documentation of these type of "hidden" registers?
    how does errata [156] play in to this?
    I tried to use only odd, only even and changed tasks_clr -> tasks_out but no change in latency.
    I can do not see any difference with constant latency or with low power. the fact that those are the same implies that i do not enter both, right? can i see what mode the nrf52805 is in?
    Unfortunately there is no documentation that describes the path delay for events between peripherals.
    It is very likely that this errata is effecting in your case as you are using TASK_CLR. Are you seeing any power consumption increase? if not, then this errata does not effect you.
    victor passe said:
    i also tested this:
    I do not have access to hidden registers that are not published. Using them in any other way than the way published is very dangerous and can cause unpredictable behavior.
