i have these aliases setup in the .dts file.
Using underscore in devicetree aliases is not allowed. Instead, you should use a hyphen (-):
aliases { red-led = &led0; grn-led = &led1; blu-led = &led2; ... red-pwm = &pwm_led0; grn-pwm = &pwm_led1; blu-pwm = &pwm_led2; }; };
In DT_ALIAS you should still use underscore:
#define PWM_RED_LED DT_ALIAS(red_pwm)
Marte
so change it to this
Did you delete the build directory before rebuilding? When making changes to devicetree, you should delete the build directory completely.
I am not able to reproduce the error using your aliases and code. If you still get the error after deleting the build directory, can you upload a project where this can be reproduced so I can test it on my side?
Marte
build directory ?
if you delete that, then the build configuration disappears
ok i seem to have the issue, VSC had more than one instance of my board file even though i renamed it...... deleting the back copy and then deleting the build folder fixed this.
