bt_mesh_transport: Out of segment buffers
hi all i use vendor model to send data on mesh, i send data from one nrf52840 DK to one else and receive data correctly until a while after that sometimes data isn't send and the Out of segment buffers error occur when i increase BT_MESH_SEG_BUFS just more time later the error occur like buffer overflowing , i program in VScode and nRFconnect extentions. thanks for any helps
int bt_mesh_gap2mesh_message_send(struct bt_mesh_gap2mesh *gap2mesh,
				  const uint8_t *msg)
    struct net_buf_simple *buf = gap2mesh->model->pub->msg;
    bt_mesh_model_msg_init(buf, BT_MESH_GAP2MESH_OP_MESSAGE);
    size_t msg_len = strnlen(msg, CONFIG_BT_MESH_GAP2MESH_MESSAGE_LENGTH);
    if (msg_len > 0) {
        net_buf_simple_add_mem(buf, msg, msg_len);
		net_buf_simple_add_u8(buf, '\0');
    } else {
        // If the message is empty, return an error or handle it accordingly
        return -EINVAL;
# Copyright (c) 2021 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
# Deffered logging helps improve LPN power consumption
# when friendship is established.
CONFIG_LOG_MODE_DEFERRED=y
CONFIG_LOG_BUFFER_SIZE=4096
# General configuration
CONFIG_LOG=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_HWINFO=y
CONFIG_DK_LIBRARY=y
CONFIG_PM_SINGLE_IMAGE=y
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000
# Bluetooth configuration
CONFIG_BT=y
CONFIG_BT_COMPANY_ID=0x0059
CONFIG_BT_DEVICE_NAME="MESH NET"
CONFIG_BT_L2CAP_TX_MTU=69
CONFIG_BT_L2CAP_TX_BUF_COUNT=20
CONFIG_BT_OBSERVER=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_SETTINGS=y
CONFIG_BT_EXT_ADV=y
CONFIG_BT_EXT_ADV_MAX_ADV_SET=20
CONFIG_BT_MAX_CONN=3
# Disable unused Bluetooth features
CONFIG_BT_CTLR_DUP_FILTER_LEN=0
CONFIG_BT_CTLR_LE_ENC=n
CONFIG_BT_DATA_LEN_UPDATE=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_CTLR_CHAN_SEL_2=n
CONFIG_BT_CTLR_MIN_USED_CHAN=n
CONFIG_BT_CTLR_PRIVACY=n
# Bluetooth mesh configuration
CONFIG_BT_MESH=y
CONFIG_BT_MESH_RELAY=y
CONFIG_BT_MESH_FRIEND=y
CONFIG_BT_MESH_ADV_BUF_COUNT=60
CONFIG_BT_MESH_RX_SEG_MAX=32
CONFIG_BT_MESH_TX_SEG_MAX=32
CONFIG_BT_MESH_PB_GATT=y
CONFIG_BT_MESH_GATT_PROXY=y
CONFIG_BT_MESH_PROXY_USE_DEVICE_NAME=y
CONFIG_BT_MESH_DK_PROV=y
# Bluetooth mesh models
CONFIG_BT_MESH_ONOFF_SRV=y
# Enable the LBS service
#CONFIG_BT_LBS=y
#CONFIG_BT_LBS_POLL_BUTTON=y
# my additional
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_BT_RX_STACK_SIZE=8192
# CONFIG_BT_MESH_ADV_STACK_SIZE=1024
CONFIG_BT_MESH_TX_SEG_MSG_COUNT=255
CONFIG_BT_MESH_RX_SEG_MSG_COUNT=255
CONFIG_BT_MESH_SEG_BUFS=32
CONFIG_BT_MESH_TX_SEG_RETRANS_COUNT=2
# CONFIG_BT_HOST_CRYPTO=n
CONFIG_BT_MESH_ADV_LEGACY=n
# CONFIG_BT_HCI_HOST=y
# CONFIG_BT_HCI=y
CONFIG_BT_RPC_STACK=n
CONFIG_GPIO=y
CONFIG_POSIX_API=y
