Any instructions or link I can follow to do this instead of having to use an iOS or Android mobile device with the nRF Connect mobile app?
Yes, that's correct. I followed the instructions in the link provided for the bootloader settings page, but can't seem to find the bootloader version in the nrf_dfu_type.h file. See below. A search in the bootloader project itself also turned up nothing.
As for using an nRF DK or dongle, that's not an option as the custom board has only a SWD i/f.
C:\nRF5_SDK_15.3.0_59ac345\components\libraries\bootloader\dfu\nrf_dfu_types.h (9 hits)
Line 70: #define INIT_COMMAND_MAX_SIZE_v1 256 /**< Maximum size of the init command in settings version 1. */
Line 230: #define NRF_DFU_PEER_DATA_LEN 64 /**< The length in bytes of nrf_dfu_peer_data_t expected by tools manipulating the settings page. Do not change without changing the settings page version. */
Line 231: #define NRF_DFU_ADV_NAME_LEN 28 /**< The length in bytes of nrf_dfu_adv_name_t expected by tools manipulating the settings page. Do not change without changing the settings page version. */
Line 306: uint32_t settings_version; /**< Version of the current DFU settings struct layout. */
Line 307: uint32_t app_version; /**< Version of the last stored application. */
Line 308: uint32_t bootloader_version; /**< Version of the last stored bootloader. */
kishanjsing said:Yes, that's correct. I followed the instructions in the link provided for the bootloader settings page, but can't seem to find the bootloader version in the nrf_dfu_type.h file. See below. A search in the bootloader project itself also turned up nothing.
The bootloader version is a number you pick, versioning your bootloader, and you provide it when you make the bootloader settings page and when you make a DFU oackage (if that contains a new bootloader). So you could start with 1, then 2 if you update it, etc. (That is used primarily for down-grade prevention.)
kishanjsing said:As for using an nRF DK or dongle, that's not an option as the custom board has only a SWD i/f.
Then DFU from a desktop computer is not an option unless you make the DFU master software yourself. I anyway does not seem to make much sense here, as doing production programming over SWD (and programming the whole firmware, not just the bootloader and SoftDevice) makes a lot more sense in production programming in general, where time and reliability is typically essential.
Thanks. Conclusion is then combo of mergehex and nrfutil to program over SWD. I haven't had time yet to investigate if this path works as indicated.
Yes,
You need 4 hex files to begin with:
All these 4 can be combined into a single hex file using mergehex. Then you have a single hex file that you program via SWD in your production programming, and that is it.
Hi Einar,
I was able to successfully follow the steps in the links you pointed to. Thanks for all your help. One suggestion: it will help other novices like myself, tremendously if it is all contained in a single document, such as the one attached here that I wrote up for my reference. Feel free to share it in the blog. This support ticket can be closed.
