Interesting Issue with board configuration - application wont start unless "kickstarted" by RTT or debugger.
nRF Connect SDK version 2.2.0
I have a custom board with a Fanstel BC840 pre-certified module. The components for the low-voltage DCDC converter are included in that package - and I have included the components to enable the high voltage DCDC regulator, and enabled both of them in the board configuration.
I do not have a 32kHz external crystal - and instead have enabled the 32kHz source to be the RC oscillator with:
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
After flashing the board - absolutely nothing expected happens (bluetooth advertising, UICR to 3.3v, ect). Cycling the supply does nothing either, neither does debugger probe reset.
The second I either start a debugging session, or connect via RTT - the board suddenly comes to life and works as expected, I can even fully disconnect the debugger from the board and everything works as it should.
If I power cycle or reset the board, it stops working again until RTT is connected.
Things I think i've ruled out:
- Issue with power supply - if this were the case, I doubt the board would work after I disconnected the debugger entirely.
- Issue with HFC in the module - for the same reason as above, bluetooth works great as long as its "kickstarted" by the debugger.
custom_board_definition.zip0435.prj.conf
  • I can confirm this also occurs with the newest nRF SDK version (2.4.1) with the newest toolchain (2.4.0), the xtal crystal is y selected - preventing boot when not connected to a debugger.
    In case you use nrf52840-DK, XTAL needs to be disabled. This can be done with CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n. You could try adding this option to your prj.conf file.
    Could you show how (non-existent) external crystal is referenced in your .config file?
    Dejan
  • with these values in the prj.conf:
    Fullscreen
    1
    2
    3
    4
    5
    6
    # LFC oscilator
    CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=0
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    These values end up in the (build output directory)/mcuboot/zephyr/.config
    Fullscreen
    1
    2
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    I would expect the built MCUBoot to defer to the prj.conf on its clock source - I couldnt find any MCUBoot configuration options to explicitly specify its LFC source.
    This issue is impossible to functionally test on a DK - as the DK has the external crystal hardware on board. It will always boot on a DK because MCUBoot will use the external crystal, and then the application will use the RC oscillator.
    To surface this issue on a DK you would need to desolder the 32kHz external crystal.
    What can be seen without access to a board without a 32kHZ clock is the build artifacts that are referencing an external clock when the external clock has been explicitly disabled by the prj.conf.
  • Minimal reproducible example here:
    NCS 2.4.1
    Hello world example
    added
    CONFIG_BOOTLOADER_MCUBOOT=y
    to prj.conf
    Built MCUBoot has:
    In its .config.
    3386.hello_world.zip
    You could try adding CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n to your MCUboot configuration file.
    Dejan
1 2
