Interesting Issue with board configuration - application wont start unless "kickstarted" by RTT or debugger.
nRF Connect SDK version 2.2.0
I have a custom board with a Fanstel BC840 pre-certified module. The components for the low-voltage DCDC converter are included in that package - and I have included the components to enable the high voltage DCDC regulator, and enabled both of them in the board configuration.
I do not have a 32kHz external crystal - and instead have enabled the 32kHz source to be the RC oscillator with:
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
After flashing the board - absolutely nothing expected happens (bluetooth advertising, UICR to 3.3v, ect). Cycling the supply does nothing either, neither does debugger probe reset.
The second I either start a debugging session, or connect via RTT - the board suddenly comes to life and works as expected, I can even fully disconnect the debugger from the board and everything works as it should.
If I power cycle or reset the board, it stops working again until RTT is connected.
Things I think i've ruled out:
- Issue with power supply - if this were the case, I doubt the board would work after I disconnected the debugger entirely.
- Issue with HFC in the module - for the same reason as above, bluetooth works great as long as its "kickstarted" by the debugger.
custom_board_definition.zip0435.prj.conf
  • We have very similar issues with our design with a nRF52832 and have come to similar conclusions based on our testing. If this ticket gets moved to private, we'd be interested to know if a solution is found. Also, if we find a solution for us, we'll report it back here as well.
  • Are you using MCUBoot?
    I found this suspect line in "mcuboot/zephyr/.config" in the build output directory.
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    If MCU boots settings are overriding project.conf (or project.conf settings failing to override MCUBoot settings) it would make sense with the symptoms (debugger side-steps or uses internal clock) then post-boot it works with the RC oscillator source.
    I had an old board revision laying around with an LFC crystal as the only schematic change - and it booted right up.
  • I have confirmed that that line is the culprit - disabling MCUBoot entirely causes the application to start working again.
    Would definitely like some guidance from Nordic on how I can use MCUBoot with only the internal RC oscilator - as our application requires buttonless DFU support.
    could go in and try messing with the MCUBoot settings in the /opt/nordic directory - but everyone working on the firmware would have to modify their MCUBoot config the same way, and redo it every time we reinstall or update the SDK.
    You might need to include this configuration line:
    CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=0
    You can get more information by reading about this Zephyr issue and relevant PR.
    Dejan
  • Yep - I saw that thread - I believe that is a different issue - MCUBoot builds fine. I tried it anyways, and had no effect. The built
    .config file remained unchanged and still was referencing a (non-existent) external crystal.
