How to change the data length of BLE notification
The maximum data length of a characteristic is 9, and I use the follow function to send the notification to a client
uint32_t dxs_send(dr_ble_dxs_t * p_dxs, uint8_t * p_data, uint16_t length)
	uint32_t ret_code;
	ble_gatts_hvx_params_t hvx_params;
	if (p_dxs == NULL)
			return NRF_ERROR_NULL;
	if ((p_dxs->conn_handle == BLE_CONN_HANDLE_INVALID) || (!p_dxs->is_notification_enabled_ctrl))
	memset(&hvx_params, 0, sizeof(hvx_params));
	hvx_params.handle = p_dxs->ctrl_handles.value_handle;
	hvx_params.p_data = p_data;
	hvx_params.p_len  = &length;
	hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
	ret_code = sd_ble_gatts_hvx(p_dxs->conn_handle, &hvx_params);
	return ret_code;
The problem is I always get notification with length of 9 on the client side, even though the input argument "length" is smaller than 9. Is there a way to change the length of notification data?
  • In ATT, an attribute can have either fixed or variable length. This implies that the client you are sending notifications to need to have configured the characteristic value attribute with variable length.
    When you create the characteristic of which you are sending the value, make sure you set the property Variable Length to 1.
