I would like to control SPI chip selection pin. Is it possible to control SPI CS pin with Zephyr GPIO API?
Is there anything specific you want to do? You can control the pin with the GPIO API
Regards
Runar
Thanks for your reply! Which GPIO API do you suggest to control SPI CS pin to high or low?
Yes, it is possible to control the SPI chip select (CS) pin with the Zephyr GPIO API. The Zephyr GPIO API provides a set of functions for configuring and controlling GPIO pins on a microcontroller.
To control the CS pin of an SPI device using the GPIO API, you would need to first configure a GPIO pin as an output pin using the gpio_pin_configure() function. Once the pin is configured, you can set its value to high or low using the gpio_pin_set() or gpio_pin_clear() functions, respectively.
Here's an example of how you could use the GPIO API to control the CS pin of an SPI device:
#include <zephyr.h> #include <device.h> #include <drivers/gpio.h> // Define the CS pin #define CS_PIN 10 // Configure the CS pin as an output const struct device *gpio_dev; gpio_pin_configure(gpio_dev, CS_PIN, GPIO_OUTPUT); // Set the CS pin low to select the SPI device gpio_pin_clear(gpio_dev, CS_PIN); // Perform SPI transactions here... // Set the CS pin high to deselect the SPI device gpio_pin_set(gpio_dev, CS_PIN);
In this example, we first define the CS pin as CS_PIN, and then configure it as an output using the gpio_pin_configure() function. We then set the CS pin low using gpio_pin_clear() to select the SPI device and perform SPI transactions. Finally, we set the CS pin high using gpio_pin_set() to deselect the SPI device.
I hope this helps!
Thanks for your great support!
