I have an example based on v2.4.1\nrf\samples\bluetooth\peripheral_lbs
This is my prj.conf
# Flash CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y # Bluetooth CONFIG_BT=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME="Intonavi" # FOTA CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_SECURE_BOOT=y CONFIG_SB_SIGNING_KEY_FILE="d:/NordicSemiconductor/apps/ble_ota2/priv-ecdsa.pem"
this is my pm_static.yml, this is copy from file: build/partitions.yml
EMPTY_0: address: 0x15200 end_address: 0x16000 placement: before: - s1_pad region: flash_primary size: 0xe00 EMPTY_1: address: 0x22200 end_address: 0x23000 placement: before: - mcuboot_pad region: flash_primary size: 0xe00 EMPTY_2: address: 0xf5000 end_address: 0xf6000 placement: after: - mcuboot_secondary region: flash_primary size: 0x1000 app: address: 0x23200 end_address: 0x8c000 region: flash_primary size: 0x68e00 app_image: address: 0x23200 end_address: 0x8c000 orig_span: &id001 - app region: flash_primary size: 0x68e00 span: *id001 b0: address: 0x0 end_address: 0x8000 placement: after: - start region: flash_primary size: 0x8000 b0_container: address: 0x0 end_address: 0x9000 orig_span: &id002 - b0 - provision region: flash_primary size: 0x9000 span: *id002 mcuboot: address: 0x9200 end_address: 0x15200 placement: before: - mcuboot_primary region: flash_primary sharers: 0x1 size: 0xc000 mcuboot_pad: address: 0x23000 end_address: 0x23200 placement: align: start: 0x1000 before: - mcuboot_primary_app region: flash_primary sharers: 0x2 size: 0x200 mcuboot_primary: address: 0x23000 end_address: 0x8c000 orig_span: &id003 - mcuboot_pad - app region: flash_primary sharers: 0x1 size: 0x69000 span: *id003 mcuboot_primary_app: address: 0x23200 end_address: 0x8c000 orig_span: &id004 - app region: flash_primary size: 0x68e00 span: *id004 mcuboot_secondary: address: 0x8c000 end_address: 0xf5000 placement: after: - mcuboot_primary align: start: 0x1000 region: flash_primary share_size: - mcuboot_primary size: 0x69000 provision: address: 0x8000 end_address: 0x9000 placement: after: - b0 align: start: 0x1000 region: flash_primary size: 0x1000 s0: address: 0x9000 end_address: 0x15200 orig_span: &id005 - s0_pad - mcuboot region: flash_primary size: 0xc200 span: *id005 s0_image: address: 0x9200 end_address: 0x15200 orig_span: &id006 - mcuboot region: flash_primary size: 0xc000 span: *id006 s0_pad: address: 0x9000 end_address: 0x9200 placement: after: - b0_container align: start: 0x1000 region: flash_primary share_size: - mcuboot_pad size: 0x200 s1: address: 0x16000 end_address: 0x22200 orig_span: &id007 - s1_pad - s1_image region: flash_primary size: 0xc200 span: *id007 s1_image: address: 0x16200 end_address: 0x22200 placement: after: - s1_pad - s0 region: flash_primary share_size: - mcuboot size: 0xc000 s1_pad: address: 0x16000 end_address: 0x16200 placement: after: - s0 align: start: 0x1000 region: flash_primary share_size: - mcuboot_pad size: 0x200 settings_storage: address: 0xf6000 end_address: 0xf8000 placement: align: start: 0x1000 region: flash_primary size: 0x2000 sram_primary: address: 0x20000000 end_address: 0x20040000 region: sram_primary size: 0x40000 storage_partition: address: 0xf8000 end_address: 0x100000 region: flash_primary size: 0x8000
I init parametres for settings_storage of flash
#define DATA_PARTITION_OFFSET FIXED_PARTITION_OFFSET (settings_storage) #define DATA_PARTITION_DEVICE FIXED_PARTITION_DEVICE (settings_storage)
Now i do the following:
Build, Flash, with flash_erease, flash_write and flash_read. This is my console log
Flash is ready
Test 1: Flash erase page at 0xf6000
Flash erase succeeded!
Attempted to write 12c at 0xf6000
Data read: 12c | 300, at 0xf6000
Attempted to write 64 at 0xf6004
Data read: 64 | 100, at 0xf6004
Attempted to write 1 at 0xf6008
Data read: 1 | 1, at 0xf6008
Attempted to write 2 at 0xf600c
Data read: 2 | 2, at 0xf600c
Next step. Comment flash_erease and flash_write, only flash_read is active. Build and Flash device. This is my console log
Flash is ready
Data read: b8397b06 | -1204192506, at 0xf6000
Data read: 689acd9a | 1754975642, at 0xf6004
Data read: 615433a5 | 1632908197, at 0xf6008
Data read: 4293d3ff | 1116984319, at 0xf600c
Why values are different?
When I use storage_partition and hard address 0xf8000 everyfing is ok, after write all next reads have corrected values.
