zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH'
I'm attempting to re-build my application to run on an Adafruit Feather nRF52840 Express instead of the nRF52840DK that I have. When I build the application targeting the nRF52840DK it builds fine, but when I target the Feather I get the following error:
region `FLASH' overflowed by 350472 bytes
Other than the boards being different, the only differences between the two builds that I can think of are in the overlays. The nrf52840dk_nrf52840.overlay is as follows:
/* Copyright (c) 2021 Nordic Semiconductor ASA
	chosen {
		nordic,pm-ext-flash = &mx25r64;
	buttons {
		factoryreset {
			gpios = <&gpio0 29 (GPIO_PULL_DOWN)>;
	* In some default configurations within the nRF Connect SDK,
	* e.g. on nRF52840, the chosen zephyr,entropy node is &cryptocell.
	* This devicetree overlay ensures that default is overridden wherever it
	* is set, as this application uses the RNG node for entropy exclusively.
	chosen {
		zephyr,entropy = &rng;
/* Disable unused peripherals to reduce power consumption */
&adc {
	status = "disabled";
&uart1 {
&i2c0 {
    mysensor: mysensor@70{
        compatible = "i2c-device";
        status = "okay";
        reg = < 0x70 >;
&pwm0 {
&spi1 {
&spi3 {
&usbd {
the adafruit_feather_nrf52840.overlay is as follows:
	buttons {
		factoryreset {
&adc {
&uart1 {
&i2c0 {
        status = "okay";
        reg = < 0x70 >;
&pwm0 {
&spi1 {
&spi3 {
&usbd {
I'm assuming the missing link is that external memory, but I'm not sure what options I have to cut down on the memory. I've tried flipping a few things in the config, but it's only shaved off a few bytes. The fact that the overflow is so huge also makes me feel like something else is happening here. This is the project.conf I'm using:
# Copyright (c) 2021 Nordic Semiconductor ASA
# This sample uses Kconfig.defaults to set options common for all
# samples. This file should contain only options specific for this sample
# or overrides of default values.
# Enable CHIP
CONFIG_CHIP=y
CONFIG_CHIP_ENABLE_PAIRING_AUTOSTART=y
CONFIG_CHIP_PROJECT_CONFIG="src/chip_project_config.h"
# 32768 == 0x8000 (example Product ID added temporaly,
# but it must be changed with proper PID from the list:
# https://github.com/project-chip/connectedhomeip/blob/482e6fd03196a6de45465a90003947ef4b86e0b1/docs/examples/discussion/PID_allocation_for_example_apps.md)
CONFIG_CHIP_DEVICE_PRODUCT_ID=32768
CONFIG_STD_CPP14=y
# Add support for LEDs and buttons on Nordic development kits
CONFIG_DK_LIBRARY=y
# Bluetooth Low Energy configuration
CONFIG_BT_DEVICE_NAME="MatterTemplate"
# Other settings
CONFIG_THREAD_NAME=y
CONFIG_MPU_STACK_GUARD=y
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_CHIP_LIB_SHELL=y
# Disable NFC commissioning
CONFIG_CHIP_NFC_COMMISSIONING=n
# Reduce application size
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_I2C=y
Any advice or insight would be appreciated.
