Hi everyone,
I started playing around with the PPI interface and I'm facing some Issues. The idea is to create a hardware impuls counter. A gpio pin is set as output for the PPI and a hardware timer is set as input. The Timer is set into counter mode, so every time an impuls is registered the timer counts one up. I managed to connect a LED and a button to turn on and off when switched. The timer however doesn't seem to be increasing its counter value.
Following code has been written:
/* * Copyright (c) 2019 Nordic Semiconductor ASA * * SPDX-License-Identifier: Apache-2.0 */ #include <zephyr/kernel.h> #include "impuls_counter.h" #include <nrfx_gpiote.h> #include <helpers/nrfx_gppi.h> #if defined(DPPI_PRESENT) #include <nrfx_dppi.h> #else #include <nrfx_ppi.h> #endif #include <zephyr/logging/log.h> #include <zephyr/irq.h> #include <nrfx_timer.h> #include <hal/nrf_timer.h> #include <nrfx_timer.h> #define INPUT_PIN DT_GPIO_PIN(DT_ALIAS(id1), gpios) #define OUTPUT_PIN DT_GPIO_PIN(DT_ALIAS(led1), gpios) const uint32_t rising_edge_pin = INPUT_PIN; const uint32_t falling_edge_pin = INPUT_PIN; LOG_MODULE_REGISTER(nrfx_sample, LOG_LEVEL_INF); static const nrfx_timer_t timer = NRFX_TIMER_INSTANCE(0); void timer_event_handler(nrf_timer_event_t event_type, void *p_context) { printk("Called\n"); } static void gpiote_event_handler(nrfx_gpiote_pin_t pin, nrf_gpiote_polarity_t action) { if (pin == falling_edge_pin) { /* Read out timer CC register and clear it */ // uint32_t timer_cc_val = nrf_timer_cc_read(timer.p_reg, 0); uint32_t timer_cc_val = timer.p_reg->CC[0]; printk("Raw timer val: %x\n", timer_cc_val); /* Calculate pulse length, 16M base freq */ uint32_t pulse_len_us = (timer_cc_val >> 4) - 1; uint32_t pulse_len_ms = pulse_len_us / 1000; printk("ms: %d\n", pulse_len_ms); printk("us: %d\n", pulse_len_us); nrfx_timer_clear(&timer); } else { printk("Unknown pin. Check your button configuration\n"); } } static void button_event_handler(nrfx_gpiote_pin_t pin, nrfx_gpiote_trigger_t trigger, void *context) { LOG_INF("GPIO input event callback"); } static void gpiote_init(void) { nrfx_gpiote_in_config_t falling_edge = {0}; nrfx_gpiote_in_config_t rising_edge = {0}; falling_edge.hi_accuracy = 1; falling_edge.pull = NRF_GPIO_PIN_PULLUP; falling_edge.sense = NRF_GPIOTE_POLARITY_LOTOHI; rising_edge.hi_accuracy = 1; rising_edge.pull = NRF_GPIO_PIN_PULLUP; rising_edge.sense = NRF_GPIOTE_POLARITY_HITOLO; uint32_t err = nrfx_gpiote_in_init(rising_edge_pin, &rising_edge, NULL); if (err != NRFX_SUCCESS) { printk("gpiote1 err: %x", err); return; } err = nrfx_gpiote_in_init(falling_edge_pin, &falling_edge, gpiote_event_handler); if (err != NRFX_SUCCESS) { printk("gpiote2 err: %x", err); return; } nrfx_gpiote_in_event_enable(rising_edge_pin, 1); nrfx_gpiote_in_event_enable(falling_edge_pin, 1); } void Impuls_Counter_nrfx_init(void) { uint8_t in_channel, out_channel; uint8_t ppi_channel; nrfx_err_t err; nrfx_timer_config_t timer_config = NRFX_TIMER_DEFAULT_CONFIG; timer_config.bit_width = 3; timer_config.mode = TIMER_MODE_MODE_LowPowerCounter; err = nrfx_timer_init(&timer, &timer_config, timer_event_handler); if (err != NRFX_SUCCESS) { LOG_ERR("Failed to init timer, error: 0x%08X", err); return; } IRQ_DIRECT_CONNECT(DT_IRQN(DT_NODELABEL(gpiote)), 0, nrfx_gpiote_irq_handler, 0); irq_enable(DT_IRQN(DT_NODELABEL(gpiote))); gpiote_init(); err = nrfx_gpiote_channel_alloc(&in_channel); if (err != NRFX_SUCCESS) { LOG_ERR("Failed to allocate in_channel, error: 0x%08X", err); return; } err = nrfx_gpiote_channel_alloc(&out_channel); if (err != NRFX_SUCCESS) { LOG_ERR("Failed to allocate out_channel, error: 0x%08X", err); return; } // Initialize input pin to generate event on high to low transition // (falling edge) and call button_handler() static const nrfx_gpiote_input_config_t input_config = { .pull = NRF_GPIO_PIN_PULLUP, }; const nrfx_gpiote_trigger_config_t trigger_config = { .trigger = NRFX_GPIOTE_TRIGGER_HITOLO, .p_in_channel = &in_channel, }; static const nrfx_gpiote_handler_config_t handler_config = { .handler = button_event_handler, }; err = nrfx_gpiote_input_configure(INPUT_PIN, &input_config, &trigger_config, &handler_config); if (err != NRFX_SUCCESS) { LOG_ERR("nrfx_gpiote_input_configure error: 0x%08X", err); return; } // Initialize output pin. SET task will turn the LED on, // CLR will turn it off and OUT will toggle it. static const nrfx_gpiote_output_config_t output_config = { .drive = NRF_GPIO_PIN_S0S1, .input_connect = NRF_GPIO_PIN_INPUT_DISCONNECT, .pull = NRF_GPIO_PIN_NOPULL, }; const nrfx_gpiote_task_config_t task_config = { .task_ch = out_channel, .polarity = NRF_GPIOTE_POLARITY_TOGGLE, .init_val = 1, }; err = nrfx_gpiote_output_configure(OUTPUT_PIN, &output_config, &task_config); if (err != NRFX_SUCCESS) { LOG_ERR("nrfx_gpiote_output_configure error: 0x%08X", err); return; } nrfx_gpiote_trigger_enable(INPUT_PIN, true); nrfx_gpiote_out_task_enable(OUTPUT_PIN); LOG_INF("nrfx_gpiote initialized"); // Allocate a (D)PPI channel. err = nrfx_gppi_channel_alloc(&ppi_channel); if (err != NRFX_SUCCESS) { LOG_ERR("nrfx_gppi_channel_alloc error: 0x%08X", err); return; } // Configure endpoints of the channel so that the input pin event is // connected with the output pin OUT task. This means that each time // the button is pressed, the LED pin will be toggled. nrfx_gppi_channel_endpoints_setup(ppi_channel, nrfx_gpiote_in_event_addr_get(INPUT_PIN), nrfx_gpiote_out_task_addr_get(OUTPUT_PIN)); nrfx_gppi_channel_endpoints_setup(ppi_channel, nrfx_gpiote_in_event_addr_get(INPUT_PIN), nrfx_timer_task_address_get(&timer, NRF_TIMER_TASK_COUNT)); // Enable the Channel nrfx_gppi_channels_enable(BIT(ppi_channel)); while (true) { uint32_t value = nrfx_timer_capture_get(&timer, NRF_TIMER_CC_CHANNEL0); printk("Value %i\n", value); k_sleep(K_MSEC(1000)); } }
Prj.conf
# GPIO Configurations CONFIG_NFCT_PINS_AS_GPIOS=y # Configurations for timer driver CONFIG_GPIO=y CONFIG_SERIAL=y CONFIG_STDOUT_CONSOLE=y CONFIG_NRFX_GPIOTE=y CONFIG_NRFX_TIMER0=y # Used for timer driver CONFIG_COMPILER_OPT="-DGPIOTE_IRQn=GPIOTE1_IRQn -DNRFX_TIMER_ENABLED=1 -DNRFX_GPIOTE_ENABLED=1 -DNRFX_TIMER0_ENABLED=1"
I know its a bit messy. Your help is highly appreciated.
Best regards
Maikel
