nRF52840 dongle isnt showing up in the connected devices section on VS code.
I've been trying to connect the nRF53480 dongle to VS Code. I have followed the necessary tutorials and ensured I have compatible and updated nrf Connect SDK and toolchain versions. However, the toolchain installation is always stuck on loading on VS code (amber colour) and always fails to connect. Subsequently, I don't see any device connected in connected devices. I know it is not a hardware problem, as the dongle turns either green or red when i connect it and in the RSSI viewer, I can see the live connection as well. I am unsure what to do next.
I have also reinstalled and installed it multiple times from scratch, but it doesn't seem to fix the problem.
The purpose of my work right now is to run a continuous wave through the dongle and be able to visualize it, but I am unable to get past the configuration/setting up stage.
Any ideas on how I can fix this?
  • Hi, given that table not many OS support the SDK. What do you recommend then in terms of the optimal OS. My purpose for using the nrf52480 is to program it for app development and would therefore require the SDK to make necessary modifications.
  • Hi Emaan,
    As per the table, all major OS (Windows, Linux, and macOS) are supported for x64 architecure.
    But at the same time not all their versions are supported.
    I am using windows10 and most of other customers are also using windows10.
    I have seen some people using windows11 as well.
    I am not sure about their experience, but yes, as per the table the support is of "Tier3" which means it may or may not work.
    Recommendation could be to use windows10 (if you are windows user), or use Ubuntu (20.04 LTS) if you are linux user.
    BR, Naeem
