I try to build https://github.com/hellesvik-nordic/samples_for_nrf_connect_sdk/tree/main/bootloader_samples/smp/mcuboot_smp_ble. But west build failed with a lot of undefined symbols.
D:\ncs\v2.4.0\bootloader\mcuboot\samples\zephyr\mcuboot_smp_ble>west build -b nrf5340dk_nrf5340_cpuapp
-- Application: D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble
-- CMake version: 3.20.5
-- Using NCS Toolchain 2.4.0 for building. (D:/ncs/toolchains/31f4403e35/cmake)
-- Found Python3: D:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: D:/ncs/v2.4.0/zephyr/.cache
-- Zephyr version: 3.3.99 (D:/ncs/v2.4.0/zephyr)
-- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.0 (D:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.0 (D:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found Dtc: D:/ncs/toolchains/31f4403e35/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: D:/ncs/v2.4.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/build/zephyr/dts.cmake
warning: BT_CTLR_DATA_LENGTH_MAX (defined at
D:/ncs/v2.4.0/nrf\samples\common\mcumgr_bt_ota_dfu/Kconfig:124,
D:/ncs/v2.4.0/nrf\subsys\bluetooth\services\fast_pair/Kconfig.fast_pair:95,
subsys/bluetooth\controller/Kconfig:439) was assigned the value '251' but got the value ''. Check
these unsatisfied dependencies: (NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP || (BT_FAST_PAIR_GATT_SERVICE
&& BT_FAST_PAIR && BT) || (BT_CTLR_DATA_LENGTH && BT_CONN && BT_CTLR && BT_HCI && BT)) (=n). See
docs.zephyrproject.org/.../kconfig.html and/or look up
BT_CTLR_DATA_LENGTH_MAX in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: MCUMGR (defined at subsys/mgmt/mcumgr/Kconfig:5) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: ZCBOR (=n). See
docs.zephyrproject.org/.../kconfig.html D:/ncs/v2.4.0/zephyr/Kconfig
Loaded configuration 'D:/ncs/v2.4.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf'
_MCUMGR and/or look up MCUMGR in the
menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf:3: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_SMP_UART
D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf:4: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_CMD_IMG_MGMT
D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf:5: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_CMD_OS_MGMT
D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf:13: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_SMP_BT
D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf:14: warning: attempt to assign the value 'n' to the undefined symbol MCUMGR_SMP_BT_AUTHEN
D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf:15: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_SMP_BT_CONN_PARAM_CONTROL
D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf:29: warning: attempt to assign the value 'y' to the undefined symbol MCUMGR_SMP_REASSEMBLY_BT
D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf:30: warning: attempt to assign the value '2475' to the undefined symbol MCUMGR_BUF_SIZE
D:/ncs/v2.4.0/bootloader/mcuboot/samples/zephyr/mcuboot_smp_ble/prj.conf:31: warning: attempt to assign the value 'y' to the undefined symbol OS_MGMT_MCUMGR_PARAMS
error: Aborting due to Kconfig warnings
CMake Error at D:/ncs/v2.4.0/zephyr/cmake/modules/kconfig.cmake:339 (message):
command failed with return code: 1
D:/ncs/v2.4.0/nrf/cmake/modules/kconfig.cmake:29 (include)
D:/ncs/v2.4.0/zephyr/cmake/modules/zephyr_default.cmake:115 (include)
D:/ncs/v2.4.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
D:/ncs/v2.4.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:5 (find_package)
FATAL ERROR: command exited with status 1: 'D:\ncs\toolchains\31f4403e35\opt\bin\cmake.EXE' '-DWEST_PYTHON=D:\ncs\toolchains\31f f4403e35\opt\bin\python.exe' '-BD:\ncs\v2.4.0\bootloader\mcuboot\samples\zephyr\mcuboot_smp_ble\build' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp '-SD:\ncs\v2.4.0\bootloader\mcuboot\samples\zephyr\mcuboot_smp_ble'
Procedures to reproduce this issue is as follows.
1. Unzipping mcuboot_smp_ble.zip to D:\ncs\v2.4.0\bootloader\mcuboot\samples\zephyr folder.
2. cd D:\ncs\v2.4.0\bootloader\mcuboot\samples\zephyr\mcuboot_smp_ble
3. west build -b nrf5340dk_nrf5340_cpuapp
