verifying 32kHz crystal accuracy
We have a custom board that is using the RTC with an external 32.768kHz crystal.  I would like to verify the accuracy and tune the capacitors if necessary.  I want to verify that what I am doing is reasonable.
We are using Zephyr.  I have set up
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
static struct k_timer mTimer;
static void on_timer(struct k_timer *timer)
    pin_traces_auto_toggle(tp_pin_7);
   // pin_traces_toggle(tp_pin_6,k_is_in_isr());
    __ASSERT_NO_MSG(log_initialize());
    __ASSERT_NO_MSG(pin_traces_initialize());
    k_timer_init(&mTimer, on_timer, NULL);
    k_timer_start(&mTimer, K_SECONDS(1), K_SECONDS(1));
    return 0;
This timer will be based on the 32.768kHz crystal, correct?  I am watching the GPIO signal on what we have defined as test point 7 over a long period to verify the accuracy.  I get (basically) a 1 second toggle off this pin.  Is it reasonable to use this for checking crystal accuracy?
