I try to use Gazell and USB HID to remote wake up my computer. But after compter turns into sleep, the callback function on the Gazell Host Device doesn't being called back anymore. The callback function will start work again after I wake my computer up.
I don't know whether it is the problem of the Gazell Timer. The gazell will use Timer0 of the nrf52840.
/** @name Gazell callback function definitions. */
* @brief RX data ready callback.
* @details
void nrf_gzll_host_rx_data_ready(uint32_t pipe, nrf_gzll_host_rx_info_t rx_info)
uint32_t data_payload_length = NRF_GZLL_CONST_MAX_PAYLOAD_LENGTH;
// Pop packet and write first byte of the payload to the GPIO port.
bool result_value = nrf_gzll_fetch_packet_from_rx_fifo(pipe,
m_data_payload,
&data_payload_length);
if (!result_value)
NRF_LOG_ERROR("RX fifo error ");
if (data_payload_length > 0)
output_present(m_data_payload);
// Read buttons and load ACK payload into TX queue.
m_ack_payload[0] = custom_LED_state_get(&m_app_hid_kbd); // Button logic is inverted.
result_value = nrf_gzll_add_packet_to_tx_fifo(pipe, m_ack_payload, TX_PAYLOAD_LENGTH);
if (!result_value)
NRF_LOG_ERROR("TX fifo error ");
LED_On(LED1);
* @brief Gazelle callback.
* @warning Required for successful Gazell initialization.
void nrf_gzll_device_tx_success(uint32_t pipe, nrf_gzll_device_tx_info_t tx_info)
void nrf_gzll_device_tx_failed(uint32_t pipe, nrf_gzll_device_tx_info_t tx_info)
void nrf_gzll_disabled()
void usb_init()
ret_code_t ret;
static const app_usbd_config_t usbd_config = {
.ev_state_proc = usbd_user_ev_handler,
ret = nrf_drv_clock_init();
APP_ERROR_CHECK(ret);
// nrf_drv_clock_lfclk_request(NULL);
// while (!nrf_drv_clock_lfclk_is_running())
// /* Just waiting */
ret = app_usbd_init(&usbd_config);
app_usbd_class_inst_t const *class_inst_kbd;
class_inst_kbd = app_usbd_hid_kbd_class_inst_get(&m_app_hid_kbd);
ret = app_usbd_class_append(class_inst_kbd);
// NRF_LOG_INFO("USBD HID composite example started.");
if (USBD_POWER_DETECTION)
ret = app_usbd_power_events_enable();
// NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
app_usbd_enable();
app_usbd_start();
for (uint32_t i = 0; i < 200000; i++)
app_usbd_event_queue_process();
* @brief Main function.
* @return ANSI required int return type.
int main()
Pin_Cfg();
// Set up the user interface.
ui_init();
// Initialize Gazell.
bool result_value = nrf_gzll_init(NRF_GZLL_MODE_HOST);
GAZELLE_ERROR_CODE_CHECK(result_value);
// set Time Slot Period
nrf_gzll_set_timeslot_period(900);
result_value = nrf_gzll_set_base_address_1(0xbc010827);
result_value = nrf_gzll_set_address_prefix_byte(PIPE_NUMBER, 0x27);
// set frequency hopping
nrf_gzll_set_channel_table(Channel_Table, Channel_Table_Size);
nrf_gzll_set_timeslots_per_channel(3);
nrf_gzll_set_timeslots_per_channel_when_device_out_of_sync(20);
nrf_gzll_set_device_channel_selection_policy(NRF_GZLL_DEVICE_CHANNEL_SELECTION_POLICY_USE_CURRENT);
nrf_gzll_set_sync_lifetime(45);
// Load data into TX queue.
result_value = nrf_gzll_add_packet_to_tx_fifo(PIPE_NUMBER, m_data_payload, TX_PAYLOAD_LENGTH);
if (!result_value)
// NRF_LOG_ERROR("TX fifo error ");
NRF_LOG_FLUSH();
usb_init();
// Enable Gazell to start sending over the air.
result_value = nrf_gzll_enable();
NRF_LOG_INFO("Gzll ack payload host example started.");
//nrfx_timer_enable(&TIMER_KBD);
while (true)
// NRF_LOG_FLUSH();
if(nrf_gzll_is_enabled())
LED_On(LED0);
LED_Off(LED0);
LED_Off(LED1);
__WFE();
