Hi all,
I'm quite new in Zephyr. Just to let you know ;P
I'm developing a code based on the nRF52832 in a custom board and I'd like to measure the voltage of two separate batteries.
These batteries are connected to a resistor voltage divider which is enabled or disabled by a digital switch. Here is the schema
* packEn: 1 --> enables the two voltage dividers, 0--> disables the connection to the batteries
* Vpack1 --> Connected to AIN4
* Vpack2 --> Connected to AIN5
I'm using the nRF Connect SDK v2.4.1 with VS code.
In the main loop I read periodically the Vpack1 and Vpack2, but the values I get are random in most of the cases.
I'm sure that it's a configuration issue in the ADC, but I cannot find it, so I hope you can give a hand to find out what's the problem. Thank you.
This is my code:
#define HW_MAP_BAT_ENABLE_PIN NRF_GPIO_PIN_MAP(0, 30) #define HW_MAP_BAT_R1_DIVIDER_VALUE 150000.0f // Value in ohm #define HW_MAP_BAT_R2_DIVIDER_VALUE 100000.0f // Value in ohm #define DRV_BAT_PACKS 2 typedef struct { bool valid; struct { bool present; int16_t voltage; }pack[DRV_BAT_PACKS]; }drvBat_st; static const struct device *adcDev = DEVICE_DT_GET(DT_NODELABEL(adc)); #define DRV_BAT_ADC_RESOLUTION 12 #define DRV_BAT_ADC_GAIN ADC_GAIN_1_3 #define DRV_BAT_ADC_REFERENCE ADC_REF_INTERNAL #define DRV_BAT_ADC_ADQUISITION_TIME ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 40) #define DRV_BAT_ADC_PRIMARY_CHANNEL_ID 4 #define DRV_BAT_ADC_PRIMRAY_CHANNEL_INPUT NRF_SAADC_INPUT_AIN4 #define DRV_BAT_ADC_SECONDARY_CHANNEL_ID 5 #define DRV_BAT_ADC_SECONDARY_CHANNEL_INPUT NRF_SAADC_INPUT_AIN5 static const struct adc_channel_cfg primary = { .gain = DRV_BAT_ADC_GAIN, .reference = DRV_BAT_ADC_REFERENCE, .acquisition_time = DRV_BAT_ADC_ADQUISITION_TIME, .channel_id = DRV_BAT_ADC_PRIMARY_CHANNEL_ID, .differential = 0, #if defined(CONFIG_ADC_CONFIGURABLE_INPUTS) .input_positive = DRV_BAT_ADC_PRIMRAY_CHANNEL_INPUT, #endif }; static const struct adc_channel_cfg secondary = { .gain = DRV_BAT_ADC_GAIN, .reference = DRV_BAT_ADC_REFERENCE, .acquisition_time = DRV_BAT_ADC_ADQUISITION_TIME, .channel_id = DRV_BAT_ADC_SECONDARY_CHANNEL_ID, .differential = 0, #if defined(CONFIG_ADC_CONFIGURABLE_INPUTS) .input_positive = DRV_BAT_ADC_SECONDARY_CHANNEL_INPUT, #endif }; static drvBat_st bat; rc_t drvBat_Init (void) { // // Init the ADC channel configuration needed // static bool init = false; if ( true == init ) { return RC_SUCCESS; } // Configure adc channels used to measure battery voltage if ( 0 != adc_channel_setup(adcDev, &primary) ) { return RC_ERROR; } if ( 0 != adc_channel_setup(adcDev, &secondary) ) { return RC_ERROR; } // Init battery power control nrfx_gpiote_out_config_t config = NRFX_GPIOTE_CONFIG_OUT_SIMPLE(false); nrfx_gpiote_out_init (HW_MAP_BAT_ENABLE_PIN, &config); // Configure battery control pin init = true; return RC_SUCCESS; } rc_t drvBat_Measure (void) { // // // int16_t samples[2]; const struct adc_sequence sequence = { .channels = BIT(DRV_BAT_ADC_PRIMARY_CHANNEL_ID) | BIT(DRV_BAT_ADC_SECONDARY_CHANNEL_ID) , .buffer = samples, .buffer_size = sizeof(samples), .resolution = DRV_BAT_ADC_RESOLUTION, .oversampling = 0, // don't oversample .calibrate = false // calibrate }; nrfx_gpiote_out_set(HW_MAP_BAT_ENABLE_PIN); // Enable the voltage divider k_msleep(DRV_BAT_ENABLE_TIMEOUT); // Little wait to ensure that voltage is stable before performing an adc read if ( 0 != adc_read(adcDev, &sequence) ) { return RC_ERROR; } nrfx_gpiote_out_clear(HW_MAP_BAT_ENABLE_PIN); // Disable the voltage divider for (uint8_t i=0; i<DRV_BAT_PACKS; i++) { int32_t raw = (int32_t)samples[i]; if ( 0 != adc_raw_to_millivolts(DRV_BAT_ADC_REFERENCE, DRV_BAT_ADC_GAIN, DRV_BAT_ADC_RESOLUTION, &raw) ) { return RC_ERROR; } bat.pack[i].present = false; bat.pack[i].voltage = (int16_t)(raw / DRV_BAT_DIVIDER_FACTOR); if ( 0 > bat.pack[i].voltage ) { bat.pack[i].voltage = 0; } if ( DRV_BAT_MIN_VOLTAGE <= bat.pack[i].voltage ) { bat.pack[i].present = true; } } return RC_SUCCESS; }
Thank you so much for your help
Ragards,
David
