hci_num_completed_packets - packet count mismatch
OS: nRF Connect SDK v2.3.0
HW: nRF5340 running on a custom board
SW: Custom BLE Peripheral based off of the BLE Throughput sample
I'm running into an issue where I see an error message stating "packets count mismatch" in hci_num_completed_packets in hci_core.c. I was hoping someone could shed some light on why this might be happening. The app sends notifications (approx. 240 bytes) to a connected central device every 15 ms. The issue usually occurs about an hour after the notifications start. Once I see the error message the central device stops seeing notifications.
I know this isn't a lot to go on but I'm just looking for some sort of guidance.
Austin
  • Hi Austin,
    Could you let me know if you are using the Softdevice controller or the Zephyr controller ?
    Do you see the same problem when testing with the throughput example ?
    Is there anything else the application does besides sending notification every 15ms ?
    It seems like there is a mismatch between the number of completed packets between the host and the controller.
  • Hi Hung,
    I believe I'm using the Softdevice controller (CONFIG_BT_LL_SOFTDEVICE=y).
    The app is doing quite a bit.
    • I have SPIM4 set up to read data from 8x daisy-chained ADCs via DMA at a rate of 16K samples per second (Sps).
      • A Timer peripheral is used as a counter to manage a ping-pong buffer and posts a semaphore once the ping/pong portion is full.
    • A thread (K_PRIO_PREEMPT(4)) that pends on the above semaphore is set up to average the ADC samples down to 1K Sps. The averaged samples are then put into a FIFO.
    • A second thread (K_PRIO_COOP(6)) runs every 15 ms and offloads at most 120 samples. The samples are then sent as a notification to the central device.
    That being said, I have not tried the throughput example.
  • Hi Austin,
    Could you share  build/zephyr/.config file ?
    And run
    west list -f '{name:20} {path:40} {sha:40} {url}' > west.list"
    in your NCS workspace and share the resulting west.list
    it's for getting the exact configuration and repo versions so we can try to debug
  • Hi Hung,
    My project is in a freestanding workspace so the west command doesn't work but here is my .config file.
    CONFIG_GPIO=y
    # CONFIG_KSCAN is not set
    # CONFIG_WIFI is not set
    CONFIG_SPI=y
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_WATCHDOG is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    # CONFIG_I2C is not set
    CONFIG_SENSOR=y
    CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
    CONFIG_BT_HCI_VS_EXT=y
    CONFIG_BOARD="ech975a605_nrf5340_cpuapp"
    CONFIG_FLASH_LOAD_SIZE=0x40000
    CONFIG_SRAM_SIZE=448
    CONFIG_FLASH_LOAD_OFFSET=0x10000
    CONFIG_MBOX_NRFX_IPC=y
    CONFIG_HEAP_MEM_POOL_SIZE=4096
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_CTLR is not set
    # CONFIG_BT_ECC is not set
    CONFIG_SOC="nRF5340_CPUAPP_QKAA"
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_NUM_IRQS=69
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_ROM_START_OFFSET=0
    CONFIG_PINCTRL=y
    # CONFIG_RESET is not set
    CONFIG_CLOCK_CONTROL=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_PM=y
    # CONFIG_PM_DEVICE is not set
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_SERIAL_INIT_PRIORITY=55
    # CONFIG_FPU is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    CONFIG_TINYCRYPT=y
    CONFIG_SERIAL=y
    CONFIG_MAIN_STACK_SIZE=1024
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_BT_USER_PHY_UPDATE=y
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_HAS_DTS=y
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_CYPRESS_CY15B004Q_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_LINEAR_LTC2955_ENABLED=y
    CONFIG_DT_HAS_MAXIM_MAX7317_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CC312_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_FORWARDER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_TEST_PINS_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (D:/Nordic/v2.3.0/nrf)
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_LOG_BUFFER_SIZE=1024
    CONFIG_INIT_STACKS=y
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_MCUMGR_BUF_SIZE=500
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    # CONFIG_ENTROPY_GENERATOR is not set
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE is not set
    # CONFIG_NCS_SAMPLE_EMPTY_NET_CORE_CHILD_IMAGE is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set
    # CONFIG_MCUMGR_SMP_BT_AUTHEN is not set
    # CONFIG_IMG_ERASE_PROGRESSIVELY is not set
    # CONFIG_OS_MGMT_MCUMGR_PARAMS is not set
    # CONFIG_MCUMGR_GRP_ZEPHYR_BASIC is not set
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
    CONFIG_BT_L2CAP_TX_MTU=498
    CONFIG_BT_BUF_ACL_TX_SIZE=502
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_NRF53_ENFORCE_IMAGE_VERSION_EQUALITY is not set
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_MAX_CONN=1
    CONFIG_BT_HCI_TX_STACK_SIZE=1024
    CONFIG_BT_RX_STACK_SIZE=2200
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_FW_REV=y
    CONFIG_BT_DIS_FW_REV_STR="Zephyr Firmware"
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    CONFIG_BT_DRIVERS=y
    # CONFIG_BT_RPC_STACK is not set
    # CONFIG_BT_CENTRAL is not set
    CONFIG_BT_PERIPHERAL=y
    # CONFIG_BT_OBSERVER is not set
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    # CONFIG_BT_EXT_ADV is not set
    CONFIG_BT_DIS_SETTINGS=y
    CONFIG_BT_DIS_STR_MAX=21
    CONFIG_BT_DIS_MODEL="975A600"
    CONFIG_BT_DIS_MANUF="Hi-Techniques Inc."
    # CONFIG_BT_DIS_PNP is not set
    CONFIG_BT_DIS_SERIAL_NUMBER=y
    CONFIG_BT_DIS_SERIAL_NUMBER_STR="001"
    CONFIG_BT_DIS_HW_REV=y
    CONFIG_BT_DIS_HW_REV_STR="AA"
    CONFIG_BT_DIS_SW_REV=y
    CONFIG_BT_DIS_SW_REV_STR="Zephyr Software"
    CONFIG_BT_BAS=y
    # CONFIG_BT_BAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAS_LOG_LEVEL_WRN is not set
    CONFIG_BT_BAS_LOG_LEVEL_INF=y
    # CONFIG_BT_BAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_BAS_LOG_LEVEL=3
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_IAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_LOG_LEVEL_WRN is not set
    CONFIG_BT_IAS_LOG_LEVEL_INF=y
    # CONFIG_BT_IAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_IAS_LOG_LEVEL=3
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_ACL_RX_COUNT=6
    CONFIG_BT_BUF_EVT_RX_SIZE=68
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=65
    CONFIG_BT_HAS_HCI_VS=y
    # CONFIG_BT_HCI_VS_EVT is not set
    # CONFIG_BT_HCI_VS_FATAL_ERROR is not set
    # CONFIG_BT_HCI_VS_EXT_DETECT is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_LOG is not set
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_STACK_SIZE=1300
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=1
    # CONFIG_BT_RECV_BLOCKING is not set
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_AUDIO is not set
    CONFIG_BT_HOST_CRYPTO=y
    CONFIG_BT_HOST_CRYPTO_PRNG=y
    CONFIG_BT_SETTINGS=y
    CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
    CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
    CONFIG_BT_SETTINGS_USE_PRINTK=y
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_MAX=10
    # CONFIG_BT_AUTO_PHY_UPDATE is not set
    CONFIG_BT_USER_DATA_LEN_UPDATE=y
    # CONFIG_BT_AUTO_DATA_LEN_UPDATE is not set
    # CONFIG_BT_REMOTE_INFO is not set
    # CONFIG_BT_SMP is not set
    CONFIG_BT_L2CAP_TX_BUF_COUNT=10
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    CONFIG_BT_L2CAP_LOG_LEVEL=3
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    CONFIG_BT_ATT_ENFORCE_FLOW=y
    CONFIG_BT_ATT_PREPARE_COUNT=2
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    CONFIG_BT_GATT_DYNAMIC_DB=y
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    # CONFIG_BT_GATT_CLIENT is not set
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    # CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS is not set
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
    CONFIG_BT_MAX_PAIRED=0
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
    CONFIG_BT_DEVICE_NAME="975A600 Bridge"
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_ID_MAX=1
    # CONFIG_BT_DF is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_BREDR is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    CONFIG_BT_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_ESB_LOG_LEVEL_OFF is not set
    # CONFIG_ESB_LOG_LEVEL_ERR is not set
    # CONFIG_ESB_LOG_LEVEL_WRN is not set
    CONFIG_ESB_LOG_LEVEL_INF=y
    # CONFIG_ESB_LOG_LEVEL_DBG is not set
    CONFIG_ESB_LOG_LEVEL=3
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_ALERTS is not set
    # CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_WRN is not set
    CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_INF=y
    # CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_PPI_TRACE is not set
    # CONFIG_CPU_LOAD is not set
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # CONFIG_SHELL_IPC is not set
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    CONFIG_MPSL_LOG_LEVEL_INF=y
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL=3
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
    CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
    CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x4000
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # Libraries
    # Binary libraries
    # end of Binary libraries
    # CONFIG_ADP536X is not set
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
    CONFIG_FPROTECT_BLOCK_SIZE=0x4000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CUSTOM_CMD is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_MODEM_INFO is not set
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_HW_CC3XX=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR_SIM is not set
    # CONFIG_SENSOR_STUB is not set
    # CONFIG_PMW3360 is not set
    # CONFIG_PAW3212 is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # CONFIG_IPC_UART is not set
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (D:/Nordic/v2.3.0/nrf)
    # hostap (D:/Nordic/v2.3.0/modules/lib/hostap)
    CONFIG_POSIX_MAX_FDS=4
    CONFIG_ZEPHYR_HOSTAP_MODULE=y
    # end of hostap (D:/Nordic/v2.3.0/modules/lib/hostap)
    # mbedtls (D:/Nordic/v2.3.0/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_MBEDTLS_BUILTIN=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    # end of mbedtls (D:/Nordic/v2.3.0/modules/crypto/mbedtls)
    # trusted-firmware-m (D:/Nordic/v2.3.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (D:/Nordic/v2.3.0/modules/tee/tf-m/trusted-firmware-m)
    # cjson (D:/Nordic/v2.3.0/modules/lib/cjson)
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (D:/Nordic/v2.3.0/modules/lib/cjson)
    # azure-sdk-for-c (D:/Nordic/v2.3.0/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (D:/Nordic/v2.3.0/modules/lib/azure-sdk-for-c)
    # memfault-firmware-sdk (D:/Nordic/v2.3.0/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (D:/Nordic/v2.3.0/modules/lib/memfault-firmware-sdk)
    # cirrus-logic (D:/Nordic/v2.3.0/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (D:/Nordic/v2.3.0/modules/hal/cirrus-logic)
    # openthread (D:/Nordic/v2.3.0/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (D:/Nordic/v2.3.0/modules/lib/openthread)
    # canopennode (D:/Nordic/v2.3.0/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (D:/Nordic/v2.3.0/modules/lib/canopennode)
    # chre (D:/Nordic/v2.3.0/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (D:/Nordic/v2.3.0/modules/lib/chre)
    # fatfs (D:/Nordic/v2.3.0/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (D:/Nordic/v2.3.0/modules/fs/fatfs)
    # hal_nordic (D:/Nordic/v2.3.0/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    CONFIG_NRFX_DPPI=y
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    # CONFIG_NRFX_I2S is not set
    CONFIG_NRFX_IPC=y
    # CONFIG_NRFX_NFCT is not set
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    CONFIG_NRFX_PWM=y
    CONFIG_NRFX_PWM0=y
    CONFIG_NRFX_PWM1=y
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC is not set
    # CONFIG_NRFX_QSPI is not set
    CONFIG_NRFX_RTC=y
    CONFIG_NRFX_RTC0=y
    # CONFIG_NRFX_RTC1 is not set
    CONFIG_NRFX_SAADC=y
    CONFIG_NRFX_SPIM=y
    # CONFIG_NRFX_SPIM0 is not set
    CONFIG_NRFX_SPIM1=y
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    CONFIG_NRFX_SPIM4=y
    # CONFIG_NRFX_SYSTICK is not set
    CONFIG_NRFX_TIMER=y
    CONFIG_NRFX_TIMER0=y
    CONFIG_NRFX_TIMER1=y
    CONFIG_NRFX_TIMER2=y
    # CONFIG_NRFX_TWIM0 is not set
    # CONFIG_NRFX_TWIM1 is not set
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_UARTE2 is not set
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_USBD is not set
    # CONFIG_NRFX_USBREG is not set
    # CONFIG_NRFX_WDT0 is not set
    # CONFIG_NRFX_WDT1 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of nrfx drivers
    # end of hal_nordic (D:/Nordic/v2.3.0/modules/hal/nordic)
    # liblc3 (D:/Nordic/v2.3.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (D:/Nordic/v2.3.0/modules/lib/liblc3)
    # littlefs (D:/Nordic/v2.3.0/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (D:/Nordic/v2.3.0/modules/fs/littlefs)
    # loramac-node (D:/Nordic/v2.3.0/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (D:/Nordic/v2.3.0/modules/lib/loramac-node)
    # lvgl (D:/Nordic/v2.3.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (D:/Nordic/v2.3.0/modules/lib/gui/lvgl)
    # lz4 (D:/Nordic/v2.3.0/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (D:/Nordic/v2.3.0/modules/lib/lz4)
    # nanopb (D:/Nordic/v2.3.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (D:/Nordic/v2.3.0/modules/lib/nanopb)
    # picolibc (D:/Nordic/v2.3.0/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (D:/Nordic/v2.3.0/modules/lib/picolibc)
    # TraceRecorder (D:/Nordic/v2.3.0/modules/debug/TraceRecorder)
    CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
    # end of TraceRecorder (D:/Nordic/v2.3.0/modules/debug/TraceRecorder)
    # uoscore-uedhoc (D:/Nordic/v2.3.0/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (D:/Nordic/v2.3.0/modules/lib/uoscore-uedhoc)
    # zcbor (D:/Nordic/v2.3.0/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    CONFIG_ZCBOR=y
    # CONFIG_ZCBOR_CANONICAL is not set
    # CONFIG_ZCBOR_STOP_ON_ERROR is not set
    # CONFIG_ZCBOR_VERBOSE is not set
    CONFIG_ZCBOR_ASSERT=y
    # end of zcbor (D:/Nordic/v2.3.0/modules/lib/zcbor)
    # zscilib (D:/Nordic/v2.3.0/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (D:/Nordic/v2.3.0/modules/lib/zscilib)
    # mcuboot (D:/Nordic/v2.3.0/bootloader/mcuboot)
    # MCUboot
    CONFIG_SIGN_IMAGES=y
    # CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set
    # CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set
    # CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set
    CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y
    CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0+0"
    CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    # CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
    # CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS is not set
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (D:/Nordic/v2.3.0/bootloader/mcuboot)
    # nrfxlib (D:/Nordic/v2.3.0/nrfxlib)
    # Nordic nrfxlib
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_CRYPTOCELL_CC312_USABLE=y
    CONFIG_CRYPTOCELL_USABLE=y
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    # CONFIG_HW_CC3XX_INTERRUPT is not set
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # CONFIG_CC3XX_HW_MUTEX_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # nrf_security module
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # end of nrf_security module
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_LC3_PLC_DISABLED is not set
    CONFIG_LC3_ENC_CHAN_MAX=1
    CONFIG_LC3_DEC_CHAN_MAX=1
    # Encoder sample rates
    CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Encoder sample rates
    # Decoder sample rates
    CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Decoder sample rates
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (D:/Nordic/v2.3.0/nrfxlib)
    # connectedhomeip (D:/Nordic/v2.3.0/modules/lib/matter)
    # CONFIG_CHIP is not set
    # CONFIG_CHIP_LOG_SIZE_OPTIMIZATION is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (D:/Nordic/v2.3.0/modules/lib/matter)
    # Optional modules. Make sure they're installed, via the project manifest.
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_NN is not set
    CONFIG_LIBMETAL=y
    CONFIG_LIBMETAL_SRC_PATH="libmetal"
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    CONFIG_OPENAMP=y
    CONFIG_OPENAMP_SRC_PATH="open-amp"
    CONFIG_OPENAMP_MASTER=y
    CONFIG_OPENAMP_SLAVE=y
    # CONFIG_SOF is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCBOR is not set
    # CONFIG_TINYCRYPT_CTR_PRNG is not set
    CONFIG_TINYCRYPT_SHA256=y
    CONFIG_TINYCRYPT_SHA256_HMAC=y
    CONFIG_TINYCRYPT_SHA256_HMAC_PRNG=y
    # CONFIG_TINYCRYPT_ECC_DH is not set
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    CONFIG_TINYCRYPT_AES=y
    # CONFIG_TINYCRYPT_AES_CBC is not set
    # CONFIG_TINYCRYPT_AES_CTR is not set
    # CONFIG_TINYCRYPT_AES_CCM is not set
    CONFIG_TINYCRYPT_AES_CMAC=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF=y
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
    CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # end of Modules
    CONFIG_BOARD_REVISION="$BOARD_REVISION"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_ECH975A605_NRF5340_CPUAPP=y
    # CONFIG_BOARD_ECH975A605_NRF5340_CPUAPP_NS is not set
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC_APP=y
    CONFIG_BOARD_ENABLE_DCDC_NET=y
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    CONFIG_BOARD_ENABLE_CPUNET=y
    CONFIG_DOMAIN_CPUNET_BOARD="ech975a605_nrf5340_cpunet"
    # end of Board Options
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC1701X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    # CONFIG_SOC_SERIES_NRF52X is not set
    CONFIG_SOC_SERIES_NRF53X=y
    # CONFIG_SOC_SERIES_NRF91X is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_CTRLAP=y
    CONFIG_HAS_HW_NRF_DCNF=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_MUTEX=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_OSCILLATORS=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_PWM1=y
    CONFIG_HAS_HW_NRF_REGULATORS=y
    CONFIG_HAS_HW_NRF_RESET=y
    CONFIG_HAS_HW_NRF_RTC0=y
    CONFIG_HAS_HW_NRF_RTC1=y
    CONFIG_HAS_HW_NRF_SPIM1=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TIMER0=y
    CONFIG_HAS_HW_NRF_TIMER1=y
    CONFIG_HAS_HW_NRF_TIMER2=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_USBREG=y
    CONFIG_HAS_HW_NRF_VMC=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_NRF_HW_RTC1_RESERVED=y
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # CONFIG_SOC_NRF5340_CPUNET_QKAA is not set
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
    CONFIG_SOC_DCDC_NRF53X_APP=y
    CONFIG_SOC_DCDC_NRF53X_NET=y
    CONFIG_SOC_DCDC_NRF53X_HV=y
    CONFIG_SOC_NRF_GPIO_FORWARDER_FOR_NRF5340=y
    CONFIG_SOC_ENABLE_LFXO=y
    # CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_LFXO_CAP_INT_6PF is not set
    CONFIG_SOC_LFXO_CAP_INT_7PF=y
    # CONFIG_SOC_LFXO_CAP_INT_9PF is not set
    CONFIG_SOC_HFXO_CAP_DEFAULT=y
    # CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_HFXO_CAP_INTERNAL is not set
    CONFIG_NRF_ENABLE_CACHE=y
    CONFIG_NRF53_SYNC_RTC=y
    # CONFIG_SYNC_RTC_LOG_LEVEL_OFF is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_ERR is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_WRN is not set
    CONFIG_SYNC_RTC_LOG_LEVEL_INF=y
    # CONFIG_SYNC_RTC_LOG_LEVEL_DBG is not set
    CONFIG_SYNC_RTC_LOG_LEVEL=3
    CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY=90
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=1
    CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP=y
    CONFIG_NRF53_SYNC_RTC_IPM_OUT=7
    CONFIG_NRF53_SYNC_RTC_IPM_IN=8
    CONFIG_IPM_MSG_CH_8_ENABLE=y
    CONFIG_IPM_MSG_CH_8_RX=y
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    CONFIG_SOC_LOG_LEVEL_INF=y
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
    CONFIG_CPU_CORTEX_M=y
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_GEN_ISR_TABLES=y
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_ZERO_LATENCY_LEVELS=1
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_ARM_TRUSTZONE_M=y
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_STACK_GUARD is not set
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    CONFIG_ARCH_LOG_LEVEL_INF=y
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    CONFIG_MPU_LOG_LEVEL_INF=y
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    CONFIG_KERNEL_LOG_LEVEL_INF=y
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    CONFIG_THREAD_MONITOR=y
    CONFIG_THREAD_NAME=y
    CONFIG_THREAD_MAX_NAME_LEN=32
    CONFIG_INSTRUMENT_THREAD_SWITCHING=y
    CONFIG_THREAD_RUNTIME_STATS=y
    # CONFIG_THREAD_RUNTIME_STATS_USE_TIMING_FUNCTIONS is not set
    CONFIG_SCHED_THREAD_USAGE=y
    # CONFIG_SCHED_THREAD_USAGE_ANALYSIS is not set
    CONFIG_SCHED_THREAD_USAGE_ALL=y
    CONFIG_SCHED_THREAD_USAGE_AUTO_ENABLE=y
    # end of Kernel Debugging and Metrics
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    CONFIG_POLL=y
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    # end of General Kernel Options
    # Device Options
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    # Bluetooth HCI Driver Options
    # CONFIG_BT_H4 is not set
    # CONFIG_BT_H5 is not set
    CONFIG_BT_RPMSG=y
    # CONFIG_BT_SPI is not set
    # CONFIG_BT_STM32_IPM is not set
    # CONFIG_BT_ESP32 is not set
    # CONFIG_BT_B91 is not set
    # CONFIG_BT_NO_DRIVER is not set
    # CONFIG_LORA is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    CONFIG_UART_CONSOLE_INPUT_EXPIRED=y
    CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    CONFIG_ETH_INIT_PRIORITY=80
    # CONFIG_MDIO is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    CONFIG_UART_LOG_LEVEL_INF=y
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL=3
    CONFIG_UART_USE_RUNTIME_CONFIGURE=y
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_0_NRF_UARTE=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_ENHANCED_POLL_OUT=y
    CONFIG_NRF_UARTE_PERIPHERAL=y
    # Interrupt Controllers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    CONFIG_INTC_LOG_LEVEL_INF=y
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    # CONFIG_INTC_ESP32 is not set
    # end of Interrupt Controllers
    # Timer Drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer Drivers
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    CONFIG_GPIO_LOG_LEVEL_INF=y
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    CONFIG_GPIO_NRFX=y
    # CONFIG_FXL6408_LOG_LEVEL_OFF is not set
    # CONFIG_FXL6408_LOG_LEVEL_ERR is not set
    # CONFIG_FXL6408_LOG_LEVEL_WRN is not set
    CONFIG_FXL6408_LOG_LEVEL_INF=y
    # CONFIG_FXL6408_LOG_LEVEL_DBG is not set
    CONFIG_FXL6408_LOG_LEVEL=3
    # CONFIG_SPI_ASYNC is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=70
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    CONFIG_SPI_LOG_LEVEL_INF=y
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL=3
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_1_NRF_SPIM=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    # CONFIG_SDHC is not set
    # CONFIG_I3C is not set
    # CONFIG_I2S is not set
    # CONFIG_DAI is not set
    CONFIG_PWM=y
    # CONFIG_PWM_LOG_LEVEL_OFF is not set
    # CONFIG_PWM_LOG_LEVEL_ERR is not set
    # CONFIG_PWM_LOG_LEVEL_WRN is not set
    CONFIG_PWM_LOG_LEVEL_INF=y
    # CONFIG_PWM_LOG_LEVEL_DBG is not set
    CONFIG_PWM_LOG_LEVEL=3
    CONFIG_PWM_INIT_PRIORITY=50
    # CONFIG_PWM_CAPTURE is not set
    CONFIG_PWM_NRFX=y
    # CONFIG_PINMUX is not set
    # CONFIG_ADC is not set
    # CONFIG_DAC is not set
    # CONFIG_W1 is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_IPM is not set
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH=y
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    CONFIG_FLASH_LOG_LEVEL_INF=y
    # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_FLASH_LOG_LEVEL=3
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_SOC_FLASH_NRF=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # CONFIG_SENSOR_LOG_LEVEL_OFF is not set
    # CONFIG_SENSOR_LOG_LEVEL_ERR is not set
    # CONFIG_SENSOR_LOG_LEVEL_WRN is not set
    CONFIG_SENSOR_LOG_LEVEL_INF=y
    # CONFIG_SENSOR_LOG_LEVEL_DBG is not set
    CONFIG_SENSOR_LOG_LEVEL=3
    CONFIG_SENSOR_INIT_PRIORITY=90
    # CONFIG_SENSOR_INFO is not set
    # Device Drivers
    CONFIG_TMP112_FULL_SCALE_RUNTIME=y
    CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y
    # CONFIG_COUNTER is not set
    # CONFIG_DMA is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LED is not set
    # CONFIG_CAN is not set
    # CONFIG_AUDIO is not set
    # CONFIG_NEURAL_NET_ACCEL is not set
    # CONFIG_HWINFO is not set
    # CONFIG_ESPI is not set
    # CONFIG_PS2 is not set
    # CONFIG_VIDEO is not set
    # CONFIG_EEPROM is not set
    # CONFIG_PECI is not set
    # CONFIG_PECI_INTERRUPT_DRIVEN is not set
    # CONFIG_REGULATOR is not set
    # CONFIG_MEMC is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_EDAC is not set
    # CONFIG_PM_CPU_OPS is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # end of Miscellaneous Drivers
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_CACHE is not set
    # CONFIG_SYSCON is not set
    # CONFIG_BBRAM is not set
    # CONFIG_FPGA is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    CONFIG_PINCTRL_LOG_LEVEL_INF=y
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    CONFIG_MBOX=y
    CONFIG_MBOX_INIT_PRIORITY=50
    # CONFIG_MBOX_LOG_LEVEL_OFF is not set
    # CONFIG_MBOX_LOG_LEVEL_ERR is not set
    # CONFIG_MBOX_LOG_LEVEL_WRN is not set
    CONFIG_MBOX_LOG_LEVEL_INF=y
    # CONFIG_MBOX_LOG_LEVEL_DBG is not set
    CONFIG_MBOX_LOG_LEVEL=3
    # CONFIG_MM_DRV is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    CONFIG_USBC_LOG_LEVEL_INF=y
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_FUEL_GAUGE is not set
    # C Library
    CONFIG_SUPPORT_MINIMAL_LIBC=y
    CONFIG_PICOLIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC=y
    # CONFIG_PICOLIBC is not set
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_MINIMAL_LIBC_NON_REENTRANT_FUNCTIONS=y
    CONFIG_MINIMAL_LIBC_MALLOC=y
    CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0
    CONFIG_MINIMAL_LIBC_CALLOC=y
    CONFIG_MINIMAL_LIBC_REALLOCARRAY=y
    # CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
    CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE=y
    # CONFIG_MINIMAL_LIBC_RAND is not set
    CONFIG_MINIMAL_LIBC_TIME=y
    # CONFIG_MINIMAL_LIBC_STRING_ERROR_TABLE is not set
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # Additional libraries
    # OS Support Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_CRC=y
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_REBOOT=y
    # CONFIG_UTF8 is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF=y
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_GETOPT is not set
    # CONFIG_POSIX_API is not set
    # CONFIG_POSIX_CLOCK is not set
    CONFIG_MAX_TIMER_COUNT=5
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_EVENTFD is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # Util libraries
    # CONFIG_FNMATCH is not set
    # end of Util libraries
    # CONFIG_SMF is not set
    # end of Additional libraries
    # Sub Systems and OS Services
    CONFIG_BT=y
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    CONFIG_BT_LOG_LEVEL_INF=y
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_PER_ADV_SYNC_TRANSFER_RECEIVER is not set
    # CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER is not set
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # end of Bluetooth Host
    # CONFIG_BT_SHELL is not set
    CONFIG_BT_COMPANY_ID=0x05F1
    # Controller Area Network (CAN) bus subsystem
    # CONFIG_ISOTP is not set
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_CPLUSPLUS is not set
    # System Monitoring Options
    CONFIG_THREAD_ANALYZER=y
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_OFF is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_ERR is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_WRN is not set
    CONFIG_THREAD_ANALYZER_LOG_LEVEL_INF=y
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_DBG is not set
    CONFIG_THREAD_ANALYZER_LOG_LEVEL=3
    # CONFIG_THREAD_ANALYZER_USE_LOG is not set
    CONFIG_THREAD_ANALYZER_USE_PRINTK=y
    CONFIG_THREAD_ANALYZER_ISR_STACK_USAGE=y
    CONFIG_THREAD_ANALYZER_RUN_UNLOCKED=y
    # CONFIG_THREAD_ANALYZER_AUTO is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    CONFIG_ASSERT=y
    CONFIG_ASSERT_LEVEL=2
    CONFIG_SPIN_VALIDATE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    CONFIG_DEBUG_THREAD_INFO=y
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_FCB is not set
    CONFIG_NVS=y
    # CONFIG_NVS_LOOKUP_CACHE is not set
    # CONFIG_NVS_LOG_LEVEL_OFF is not set
    # CONFIG_NVS_LOG_LEVEL_ERR is not set
    # CONFIG_NVS_LOG_LEVEL_WRN is not set
    CONFIG_NVS_LOG_LEVEL_INF=y
    # CONFIG_NVS_LOG_LEVEL_DBG is not set
    CONFIG_NVS_LOG_LEVEL=3
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    CONFIG_IPC_SERVICE=y
    CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
    CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
    CONFIG_IPC_SERVICE_RPMSG=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS_ALIGNMENT=4
    # CONFIG_IPC_SERVICE_ICMSG is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_WRN is not set
    CONFIG_IPC_SERVICE_LOG_LEVEL_INF=y
    # CONFIG_IPC_SERVICE_LOG_LEVEL_DBG is not set
    CONFIG_IPC_SERVICE_LOG_LEVEL=3
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_SWO is not set
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
    CONFIG_LOG_BACKEND_UART_AUTOSTART=y
    CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_DOMAIN_ID=0
    CONFIG_LOG_USE_VLA=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    # CONFIG_DSP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    CONFIG_MCUMGR=y
    # CONFIG_MCUMGR_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_LOG_LEVEL_WRN is not set
    CONFIG_MCUMGR_LOG_LEVEL_INF=y
    # CONFIG_MCUMGR_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_LOG_LEVEL=3
    CONFIG_MCUMGR_SMP_WORKQUEUE_STACK_SIZE=2048
    CONFIG_MCUMGR_SMP_WORKQUEUE_THREAD_PRIO=3
    # CONFIG_MGMT_VERBOSE_ERR_RESPONSE is not set
    CONFIG_MGMT_MAX_MAIN_MAP_ENTRIES=15
    CONFIG_MGMT_MIN_DECODING_LEVELS=2
    CONFIG_MGMT_MIN_DECODING_LEVEL_2=y
    CONFIG_MGMT_MAX_DECODING_LEVELS=2
    # CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set
    # Command Handlers
    CONFIG_MCUMGR_CMD_IMG_MGMT=y
    # CONFIG_IMG_MGMT_USE_HEAP_FOR_FLASH_IMG_CONTEXT is not set
    CONFIG_IMG_MGMT_UPDATABLE_IMAGE_NUMBER=1
    # CONFIG_IMG_MGMT_VERBOSE_ERR is not set
    # CONFIG_IMG_MGMT_DUMMY_HDR is not set
    # CONFIG_IMG_MGMT_DIRECT_IMAGE_UPLOAD is not set
    # CONFIG_IMG_MGMT_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set
    # CONFIG_IMG_MGMT_FRUGAL_LIST is not set
    # CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_WRN is not set
    CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_INF=y
    # CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL=3
    CONFIG_MCUMGR_CMD_OS_MGMT=y
    CONFIG_OS_MGMT_RESET_MS=250
    # CONFIG_OS_MGMT_TASKSTAT is not set
    CONFIG_OS_MGMT_ECHO=y
    # CONFIG_MCUMGR_GRP_OS_INFO is not set
    # end of Command Handlers
    # Transports and Transport Related Configuration Options
    CONFIG_MCUMGR_BUF_COUNT=4
    CONFIG_MCUMGR_BUF_USER_DATA_SIZE=8
    # CONFIG_MCUMGR_SMP_DUMMY is not set
    CONFIG_MCUMGR_SMP_BT=y
    # CONFIG_MCUMGR_SMP_REASSEMBLY_BT is not set
    # CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL is not set
    # CONFIG_MCUMGR_SMP_UART is not set
    # end of Transports and Transport Related Configuration Options
    # CONFIG_MCUMGR_SMP_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_SMP_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_SMP_LOG_LEVEL_WRN is not set
    CONFIG_MCUMGR_SMP_LOG_LEVEL_INF=y
    # CONFIG_MCUMGR_SMP_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_SMP_LOG_LEVEL=3
    # CONFIG_HAWKBIT is not set
    # CONFIG_UPDATEHUB is not set
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # Networking
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    CONFIG_NET_BUF_LOG_LEVEL_INF=y
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Portability
    # end of Portability
    # Power Management
    # CONFIG_PM_LOG_LEVEL_OFF is not set
    # CONFIG_PM_LOG_LEVEL_ERR is not set
    # CONFIG_PM_LOG_LEVEL_WRN is not set
    CONFIG_PM_LOG_LEVEL_INF=y
    # CONFIG_PM_LOG_LEVEL_DBG is not set
    CONFIG_PM_LOG_LEVEL=3
    # CONFIG_PM_S2RAM is not set
    CONFIG_PM_POLICY_DEFAULT=y
    # CONFIG_PM_POLICY_CUSTOM is not set
    # end of Power Management
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_SD_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
    CONFIG_IMG_MANAGER_LOG_LEVEL_INF=y
    # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
    CONFIG_IMG_MANAGER_LOG_LEVEL=3
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    # end of Random Number Generators
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    CONFIG_STREAM_FLASH=y
    # CONFIG_STREAM_FLASH_ERASE is not set
    # CONFIG_STREAM_FLASH_PROGRESS is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL_INF=y
    # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL=3
    # end of Storage
    CONFIG_SETTINGS=y
    # CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
    CONFIG_SETTINGS_LOG_LEVEL_INF=y
    # CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
    CONFIG_SETTINGS_LOG_LEVEL=3
    CONFIG_SETTINGS_RUNTIME=y
    CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
    CONFIG_SETTINGS_NVS=y
    # CONFIG_SETTINGS_NVS_NAME_CACHE is not set
    # CONFIG_SETTINGS_CUSTOM is not set
    # CONFIG_SETTINGS_NONE is not set
    CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT=1
    CONFIG_SETTINGS_NVS_SECTOR_COUNT=8
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_RTIO is not set
    # CONFIG_ZBUS is not set
    # end of Sub Systems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_15=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    CONFIG_USE_DT_CODE_PARTITION=y
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    # end of Linker Sections
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_NATIVE_APPLICATION is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    CONFIG_FORTIFY_SOURCE_NONE=y
    # CONFIG_FORTIFY_SOURCE_COMPILE_TIME is not set
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    CONFIG_OUTPUT_DISASSEMBLY=y
    # CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    CONFIG_BUILD_OUTPUT_BIN=y
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    CONFIG_BUILD_OUTPUT_META=y
    # CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE=""
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
    # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
    # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_COMPAT_INCLUDES=y
    # end of Compatibility
    # CONFIG_LEGACY_INCLUDE_PATH is not set
    CONFIG_INCLUDE_NET_CORE_IMAGE=y
    # CONFIG_TX_TYPE_975A600 is not set
    CONFIG_TX_TYPE_975A605=y
    CONFIG_TX_TYPECODE=78
    CONFIG_TX_CHAN_COUNT=8
  • Hi Austin,
    Thanks for the file.
    Can you provide the git hash of your sdk-nrf repo?
