CONFIG_BOOTLOADER_MCUBOOT setting cause block in lfclk_spinwait
Hello I'm in trouble with nRF52833 module MDBT50Q-DB-33(with no 32kXtal)
in nrf connect sdk v2.3.0
I remove the 32k clock for new designed board and test with MDBT50Q-DB-33.
I use peripheral_sc_only and when I add
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y
and it's ok , can use bluetooth, can connect from nRF Connect for Desktop.
but I try DFU and I add
CONFIG_BOOTLOADER_MCUBOOT,
then it don't get out of "lfclk_spinwait". no come to main.
why this happened and how to solve it?
I trace with debugger and can not detect difference(means looks same code).
and now I noticed in "lfclk_spinwait", debugger said...
HFCLKSTARTED not 1(= not started) and LFCLKSRC =Xtal
when set CONFIG_BOOTLOADER_MCUBOOT
I just want clock setting is
and want use finally DFU
Could you please help me to specify correct LFCLK setting on MCUBOOT(for DFU)
thanks
