What is the pinout labels for each of the pins on P19?
I have found this on the forum but the 10 pin port header is facing to the left instead of the right. Is this still the exact pinout for P19?
issue solved, pinout is reversed when using the 10 pin cable. VTref starts at 10 and so forth
What PCA100xx dev kit are you using and what is the REV. # On the white label. rev 3.0.0 and above have a slightly different pin out. They both will work...
This is version 3
and this was pre-rev 3
