Changing DIS information at runtime (specifically CONFIG_BT_DIS_SERIAL_NUMBER_STR)
I have a custom board with an nRF52832.  The build environment is nRF Connect 2.3.0.  I have configured DIS and it works as expected, however, I need the serial number of the device to be populated at runtime since it is stored when the board is manufactured.
I tried: settings_runtime_set("bt/dis/serial",CONFIG_BT_DIS_SERIAL_NUMBER_STR,sizeof(intserial)); but it returns a -22.  I am not sure where the string "bt/dis/serial" comes from, i found it in another post and they wanted to do the same thing.
In general (other than this) I am not using settings, the serial number is stored in UICR 0x10001080 and I can easily get that out.  can you please point me in the correct direction? I looked at peripheral_dis and it does a lot of setting:
#if defined(CONFIG_BT_DIS_SERIAL_NUMBER)
sizeof(CONFIG_BT_DIS_SERIAL_NUMBER_STR));
Unfortunately it did not work for me.  ITs very possible I missed something....Thanks for the help
