Advertising processing too long => crash
I do connections between nRF51 in my application.
When the central detect an advertising frame, it ask to a server is the device is allowed (few ms). When server response is late, the central crash on connection try. Is there any way to have a longer connection window ? Avoid crashing ?
Thank you.
  • I assume you are using a softdevice in your nRF51 application.
    I'm not sure that I understand the problem, is the CONNECT_REQ packet send too late?
    The softdevice will not issue the CONNECT packet immediately after the 'sd_ble_gap_connect' call is performed. It will make sure to time the packet correctly (150 micro seconds after ADV).
    Do you have a sniffer trace?
