Chip tool debugging device error
I have a problem, please help me, I can't see where is the problem 。
refer to
Working with the CHIP Tool — Matter documentation (nRF Connect SDK) (nordicsemi.com)
Environment:
Raspberry Pie (Border Router)
router
PC (Win10) - VirtualBox (Ubuntu 22.04)
Board (Light_Blub)
Chih TooL:
Using pre compiled, version 2.4.1
Releases · nrfconnect/sdk-connectedhomeip (github.com)
The error is as follows:
yd@yd-VirtualBox:~/chip-tool-linux_x64$ ./chip-tool-debug pairing ble-thread 1 hex:0e08000000000001000035060004001fffe00708fd5ea4308ad9f2d40c0402a0f7f8051000112233445566778899aabbccddeeff03104f70656e5468726561644d61747465720410b02285723920d515813e00fa447e4ec7000300000f0208111111112222222201021234 20202021 3840
[1693281548.188769][5543:5543] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1693281548.194245][5543:5543] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1693281548.194434][5543:5543] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1693281548.194632][5543:5543] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1693281548.195042][5543:5543] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-rNwByq)
[1693281548.196393][5543:5543] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1693281548.196433][5543:5543] CHIP:DL: NVS set: chip-counters/reboot-count = 2 (0x2)
[1693281548.196860][5543:5543] CHIP:DL: Got Ethernet interface: enp0s3
[1693281548.197063][5543:5543] CHIP:DL: Found the primary Ethernet interface:enp0s3
[1693281548.197721][5543:5543] CHIP:DL: Failed to get WiFi interface
[1693281548.197791][5543:5543] CHIP:DL: Failed to reset WiFi statistic counts
[1693281548.198828][5543:5543] CHIP:IN: UDP::Init bind&listen port=0
[1693281548.198960][5543:5543] CHIP:IN: UDP::Init bound to port=34870
[1693281548.198969][5543:5543] CHIP:IN: UDP::Init bind&listen port=0
[1693281548.199010][5543:5543] CHIP:IN: UDP::Init bound to port=47444
[1693281548.199017][5543:5543] CHIP:IN: BLEBase::Init - setting/overriding transport
[1693281548.199020][5543:5543] CHIP:IN: TransportMgr initialized
[1693281548.199040][5543:5543] CHIP:FP: Initializing FabricTable from persistent storage
[1693281548.206252][5543:5543] CHIP:TS: Last Known Good Time: 2023-07-11T07:57:00
[1693281548.212065][5543:5543] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0xC3F8DB39D71B1829, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1693281548.216526][5543:5543] CHIP:ZCL: Using ZAP configuration...
[1693281548.220250][5543:5543] CHIP:DL: Avahi client registered
[1693281548.221826][5543:5543] CHIP:CTL: System State Initialized...
[1693281548.223314][5543:5543] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1693281548.223357][5543:5543] CHIP:CTL: Setting attestation nonce to random value
[1693281548.223375][5543:5543] CHIP:CTL: Setting CSR nonce to random value
[1693281548.223642][5543:5545] CHIP:DL: CHIP task running
[1693281548.223761][5543:5545] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
[1693281548.223893][5543:5545] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1693281548.224037][5543:5545] CHIP:CTL: Setting attestation nonce to random value
[1693281548.224061][5543:5545] CHIP:CTL: Setting CSR nonce to random value
[1693281548.229926][5543:5545] CHIP:CTL: Generating NOC
[1693281548.236726][5543:5545] CHIP:FP: Validating NOC chain
[1693281548.276048][5543:5545] CHIP:FP: NOC chain validation successful
[1693281548.276157][5543:5545] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1693281548.276350][5543:5545] CHIP:TS: Last Known Good Time: 2023-07-11T07:57:00
[1693281548.276435][5543:5545] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1693281548.276440][5543:5545] CHIP:TS: Retaining current Last Known Good Time
[1693281548.279811][5543:5545] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1693281548.283222][5543:5545] CHIP:TS: Committing Last Known Good Time to storage: 2023-07-11T07:57:00
[1693281548.285262][5543:5545] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: C3F8DB39D71B1829)
[1693281548.297085][5543:5545] CHIP:CTL: Setting thread operational dataset from parameters
[1693281548.297371][5543:5545] CHIP:CTL: Setting attestation nonce to random value
[1693281548.297960][5543:5545] CHIP:CTL: Setting CSR nonce to random value
[1693281548.297977][5543:5545] CHIP:CTL: Commission called for node ID 0x0000000000000001
[1693281548.310807][5543:5544] CHIP:DL: TRACE: Bus acquired for name C-15a7
[1693281573.317555][5543:5544] CHIP:DL: FAIL: Error getting object manager client: Error calling StartServiceByName for org.bluez: Timeout was reached
[1693281573.318147][5543:5545] CHIP:DL: PlatformBlueZInit init success
[1693281573.318165][5543:5545] CHIP:DIS: Closing all BLE connections
[1693281573.318194][5543:5545] CHIP:BLE: No adapter available for new connection establishment
[1693281573.318201][5543:5545] CHIP:DL: Long dispatch time: 25021 ms, for event type 2
[1693281668.226041][5543:5543] CHIP:CTL: Shutting down the commissioner
[1693281668.226358][5543:5543] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1693281668.226458][5543:5543] CHIP:CTL: Shutting down the controller
[1693281668.226471][5543:5543] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1693281668.226476][5543:5543] CHIP:FP: Forgetting fabric 0x1
[1693281668.226488][5543:5543] CHIP:TS: Pending Last Known Good Time: 2023-07-11T07:57:00
[1693281668.226557][5543:5543] CHIP:TS: Previous Last Known Good Time: 2023-07-11T07:57:00
[1693281668.226561][5543:5543] CHIP:TS: Reverted Last Known Good Time to previous value
[1693281668.226573][5543:5543] CHIP:CTL: Shutting down the commissioner
[1693281668.226576][5543:5543] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1693281668.226579][5543:5543] CHIP:CTL: Shutting down the controller
[1693281668.226582][5543:5543] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1693281668.227063][5543:5543] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1693281668.227191][5543:5543] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1693281668.227207][5543:5543] CHIP:FP: Shutting down FabricTable
[1693281668.227214][5543:5543] CHIP:TS: Pending Last Known Good Time: 2023-07-11T07:57:00
[1693281668.227252][5543:5543] CHIP:TS: Previous Last Known Good Time: 2023-07-11T07:57:00
[1693281668.227257][5543:5543] CHIP:TS: Reverted Last Known Good Time to previous value
[1693281668.227409][5543:5543] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-ed2AOW)
[1693281668.228819][5543:5543] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1693281668.228932][5543:5543] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1693281668.228943][5543:5543] CHIP:DL: Inet Layer shutdown
[1693281668.228947][5543:5543] CHIP:DL: BLE shutdown
(process:5543): GLib-GObject-CRITICAL **: 12:01:08.228: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[1693281668.229205][5543:5543] CHIP:DL: System Layer shutdown
[1693281668.229612][5543:5543] CHIP:TOO: Run command failure: examples/chip-tool/commands/common/CHIPCommand.cpp:537: CHIP Error 0x00000032: Timeout
  • Are you able to run basic Bluetooth samples on the module?
    Andreas
  • Thank you for your help. I feel closer to solving the problem.
    I tested using the Bluetooth example and it was not connected, as follows:
    Tool: nRF connect for Mobile (Android phone), "Bluetooth: Peripheral Status ";
    It has the following error prompt (nRF RTT terminal):
    I: Identity: CC:68:EF:6F:CF:85 (random)
    I: HCI: version 5.4 (0x0d) revision 0x1077, manufacturer 0x0059
    I: LMP: version 5.4 (0x0d) subver 0x1077
    Advertising successfully started
    Connected
    Disconnected (reason 62)
    I think it is necessary for me to explain the download process and confirm if I am missing any steps:
    1. Vs code “Open an exiting application”, to select "“Bluetooth: Peripheral Status”"
    2. Add the RTT enable command to the file prj.conf:
    # Reduce application size
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    3. "Edit Build configuration" ,and build
    1.
    4
    4. "Flash"and “Connect RTT”
  • Complete prompt:
    SEGGER J-Link V7.88j - Real time terminal output
    SEGGER J-Link V10.1, SN=600105955
    Process: JLinkExe
    *** Booting Zephyr OS build v3.3.99-ncs1-1 ***
    Starting Bluetooth Peripheral Status example
    I: 8 Sectors of 4096 bytes
    I: alloc wra: 0, ea0
    I: data wra: 0, 11c
    I: SoftDevice Controller build revision:
    I: e0 7e 2e c1 5e 05 85 23 |.~..^..#
    I: 46 15 dc fa 8e 29 7d 70 |F....)}p
    I: 10 93 a5 fc             |....
    I: HW Platform: Nordic Semiconductor (0x0002)
    I: HW Variant: nRF52x (0x0002)
    I: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
    I: No ID address. App must call settings_load()
    Bluetooth initialized
    Connected
  • Hi, please allow me to update again.
    I have successfully connected, but I don't understand why I am doing this:
    I referred to the link: nRF5340 Peripheral BLE connections always fail with reason 0x3e (62)
    I have added the following content to prjconf:
    CONFIG_SOC_ENABLE_LFXO=n
    Bluetooth example successfully connected, I will add
    this content to the subject, Light_ Blub;
    The connection was also successful!
    I can check the customer board on the border router。
    The following is the distribution network information.
    Was it successful?
    Could you briefly explain the reason to me?
  • ~/chip-tool/chip-tool-linux_x64$ ./chip-tool-debug pairing ble-thread 1 hex:0e08000000000001000035060004001fffe00708fd8cbda7fa852afe0c0402a0f7f8051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f0410445f2b5ca6f2a93a55ce570a70efeecb000300000f0208111111112222222201021234 20202021 3840
    [1694055304.311745][30046:30046] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1694055304.311808][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_kvs-TFU4T8)
    [1694055304.311855][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_kvs)
    [1694055304.312594][30046:30046] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1694055304.312636][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-fxxXQ9)
    [1694055304.312674][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1694055304.312699][30046:30046] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1694055304.312730][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_config.ini-7js789)
    [1694055304.312764][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
    [1694055304.312787][30046:30046] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1694055304.312817][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-78No39)
    [1694055304.312851][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1694055304.312907][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-gBsRT8)
    [1694055304.313003][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1694055304.313016][30046:30046] CHIP:DL: NVS set: chip-factory/unique-id = "B71EC24242E794D6"
    [1694055304.313053][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-KF2589)
    [1694055304.313145][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1694055304.313159][30046:30046] CHIP:DL: NVS set: chip-factory/vendor-id = 65521 (0xFFF1)
    [1694055304.313196][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-UQMZy7)
    [1694055304.313292][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1694055304.313307][30046:30046] CHIP:DL: NVS set: chip-factory/product-id = 32769 (0x8001)
    [1694055304.313342][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-NXIlra)
    [1694055304.313418][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1694055304.313431][30046:30046] CHIP:DL: NVS set: chip-counters/reboot-count = 1 (0x1)
    [1694055304.313469][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-BRijE6)
    [1694055304.313554][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1694055304.313567][30046:30046] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1694055304.313604][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-SYYNf7)
    [1694055304.313693][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1694055304.313706][30046:30046] CHIP:DL: NVS set: chip-counters/boot-reason = 0 (0x0)
    [1694055304.313738][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_config.ini-Ubeqt7)
    [1694055304.313813][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
    [1694055304.313825][30046:30046] CHIP:DL: NVS set: chip-config/regulatory-location = 0 (0x0)
    [1694055304.313864][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_config.ini-xp0AD7)
    [1694055304.313947][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
    [1694055304.313959][30046:30046] CHIP:DL: NVS set: chip-config/location-capability = 2 (0x2)
    [1694055304.314156][30046:30046] CHIP:DL: Got Ethernet interface: enp4s0
    [1694055304.314300][30046:30046] CHIP:DL: Found the primary Ethernet interface:enp4s0
    [1694055304.314445][30046:30046] CHIP:DL: Got WiFi interface: wlp5s0
    [1694055304.314599][30046:30046] CHIP:DL: Found the primary WiFi interface:wlp5s0
    [1694055304.314848][30046:30046] CHIP:IN: UDP::Init bind&listen port=0
    [1694055304.314875][30046:30046] CHIP:IN: UDP::Init bound to port=35683
    [1694055304.314883][30046:30046] CHIP:IN: UDP::Init bind&listen port=0
    [1694055304.314904][30046:30046] CHIP:IN: UDP::Init bound to port=37388
    [1694055304.314910][30046:30046] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1694055304.314916][30046:30046] CHIP:IN: TransportMgr initialized
    [1694055304.314943][30046:30046] CHIP:FP: Initializing FabricTable from persistent storage
    [1694055304.314982][30046:30046] CHIP:TS: Last Known Good Time: [unknown]
    [1694055304.314990][30046:30046] CHIP:TS: Setting Last Known Good Time to firmware build time 2023-07-11T07:53:58
    [1694055304.315774][30046:30046] CHIP:ZCL: Using ZAP configuration...
    [1694055304.317972][30046:30046] CHIP:DL: Avahi client registered
    [1694055304.318770][30046:30046] CHIP:CTL: System State Initialized...
    [1694055304.318994][30046:30046] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1694055304.319015][30046:30046] CHIP:CTL: Setting attestation nonce to random value
    [1694055304.319023][30046:30046] CHIP:CTL: Setting CSR nonce to random value
    [1694055304.319101][30046:30048] CHIP:DL: CHIP task running
    [1694055304.319152][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1694055304.319287][30046:30048] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1694055304.319298][30046:30048] CHIP:CTL: Setting attestation nonce to random value
    [1694055304.319305][30046:30048] CHIP:CTL: Setting CSR nonce to random value
    [1694055304.319361][30046:30048] CHIP:CTL: Couldn't get ExampleOpCredsCAKey from storage: src/controller/ExamplePersistentStorage.cpp:93: CHIP Error 0x000000A0: Value not found in the persisted storage
    [1694055304.324020][30046:30048] CHIP:CTL: Couldn't get ExampleOpCredsICAKey from storage: src/controller/ExamplePersistentStorage.cpp:93: CHIP Error 0x000000A0: Value not found in the persisted storage
    [1694055304.331714][30046:30048] CHIP:CTL: Generating RCAC
    [1694055304.364204][30046:30048] CHIP:CTL: Generating ICAC
    [1694055304.372494][30046:30048] CHIP:CTL: Generating NOC
    [1694055304.378598][30046:30048] CHIP:FP: Validating NOC chain
    [1694055304.395899][30046:30048] CHIP:FP: NOC chain validation successful
    [1694055304.396447][30046:30048] CHIP:FP: Added new fabric at index: 0x1
    [1694055304.396454][30046:30048] CHIP:FP: Assigned compressed fabric ID: 0xE6F06EAE27CA3AAD, node ID: 0x000000000001B669
    [1694055304.396461][30046:30048] CHIP:TS: Last Known Good Time: 2023-07-11T07:53:58
    [1694055304.396465][30046:30048] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1694055304.396469][30046:30048] CHIP:TS: Retaining current Last Known Good Time
    [1694055304.416159][30046:30048] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1694055304.417830][30046:30048] CHIP:TS: Committing Last Known Good Time to storage: 2023-07-11T07:53:58
    [1694055304.419126][30046:30048] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: E6F06EAE27CA3AAD)
    [1694055304.434606][30046:30048] CHIP:CTL: Setting thread operational dataset from parameters
    [1694055304.434627][30046:30048] CHIP:CTL: Setting attestation nonce to random value
    [1694055304.434639][30046:30048] CHIP:CTL: Setting CSR nonce to random value
    [1694055304.434650][30046:30048] CHIP:CTL: Commission called for node ID 0x0000000000000001
    [1694055304.434669][30046:30048] CHIP:DL: Long dispatch time: 116 ms, for event type 2
    [1694055304.437492][30046:30047] CHIP:DL: TRACE: Bus acquired for name C-755e
    [1694055304.440943][30046:30048] CHIP:DL: PlatformBlueZInit init success
    [1694055304.443443][30046:30047] CHIP:BLE: BLE removing known devices.
    [1694055304.444067][30046:30047] CHIP:BLE: BLE initiating scan.
    [1694055304.591694][30046:30048] CHIP:DL: Long dispatch time: 157 ms, for event type 2
    [1694055304.613099][30046:30047] CHIP:BLE: New device scanned: EE:05:FD:CE:F6:42
    [1694055304.613146][30046:30047] CHIP:BLE: Device discriminator match. Attempting to connect.
    [1694055304.774978][30046:30047] CHIP:DL: ConnectDevice complete
    [1694055305.865716][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.865829][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.865908][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0001
    [1694055305.865968][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866026][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0001
    [1694055305.866074][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866128][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0001
    [1694055305.866175][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866246][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0001
    [1694055305.866301][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866367][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0001
    [1694055305.866425][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866477][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0001
    [1694055305.866523][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866590][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866645][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866683][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866760][30046:30047] CHIP:DL: Char1 /org/bluez/hci0/dev_EE_05_FD_CE_F6_42/service0010
    [1694055305.866832][30046:30047] CHIP:DL: New BLE connection 0x7fba540481d0, device EE:05:FD:CE:F6:42, path /org/bluez/hci0/dev_EE_05_FD_CE_F6_42
    [1694055305.866993][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
    [1694055305.867040][30046:30048] CHIP:DIS: Closing all BLE connections
    [1694055305.867161][30046:30048] CHIP:IN: BleConnectionComplete: endPoint 0x556a9a5ce3c0
    [1694055305.867897][30046:30048] CHIP:IN: SecureSession[0x7fba4c010d00]: Allocated Type:1 LSID:28753
    [1694055305.867960][30046:30048] CHIP:SC: Assigned local session key ID 28753
    [1694055305.868093][30046:30048] CHIP:EM: <<< [E:3655i S:0 M:112192125] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
    [1694055305.868134][30046:30048] CHIP:IN: (U) Sending msg 112192125 to IP address 'BLE'
    [1694055305.868156][30046:30048] CHIP:IN: Message appended to BLE send queue
    [1694055305.868172][30046:30048] CHIP:SC: Sent PBKDF param request
    [1694055306.303696][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055306.396397][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
    [1694055306.396454][30046:30048] CHIP:BLE: subscribe complete, ep = 0x556a9a5ce3c0
    [1694055306.396670][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055306.396764][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055306.396797][30046:30048] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
    [1694055306.396823][30046:30048] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
    [1694055306.396843][30046:30048] CHIP:BLE: local and remote recv window size = 5
    [1694055306.397447][30046:30048] CHIP:IN: BLE EndPoint 0x556a9a5ce3c0 Connection Complete
    [1694055306.483798][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055306.486673][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055306.486798][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055306.486929][30046:30048] CHIP:EM: >>> [E:3655i S:0 M:199762175] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
    [1694055306.486975][30046:30048] CHIP:EM: Found matching exchange: 3655i, Delegate: 0x7fba4c00ce00
    [1694055306.487031][30046:30048] CHIP:SC: Received PBKDF param response
    [1694055306.487150][30046:30048] CHIP:SC: Peer assigned session ID 6457
    [1694055306.487202][30046:30048] CHIP:SC: Found MRP parameters in the message
    [1694055306.544764][30046:30048] CHIP:EM: <<< [E:3655i S:0 M:112192126] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
    [1694055306.544806][30046:30048] CHIP:IN: (U) Sending msg 112192126 to IP address 'BLE'
    [1694055306.545076][30046:30048] CHIP:SC: Sent spake2p msg1
    [1694055306.618920][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055308.241525][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055308.241844][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055308.241995][30046:30048] CHIP:EM: >>> [E:3655i S:0 M:199762176] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
    [1694055308.242038][30046:30048] CHIP:EM: Found matching exchange: 3655i, Delegate: 0x7fba4c00ce00
    [1694055308.242098][30046:30048] CHIP:SC: Received spake2p msg2
    [1694055308.291965][30046:30048] CHIP:EM: <<< [E:3655i S:0 M:112192127] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
    [1694055308.291998][30046:30048] CHIP:IN: (U) Sending msg 112192127 to IP address 'BLE'
    [1694055308.292345][30046:30048] CHIP:SC: Sent spake2p msg3
    [1694055308.373586][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055308.375558][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055308.375869][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055308.376017][30046:30048] CHIP:EM: >>> [E:3655i S:0 M:199762177] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1694055308.376056][30046:30048] CHIP:EM: Found matching exchange: 3655i, Delegate: 0x7fba4c00ce00
    [1694055308.376191][30046:30048] CHIP:SC: SecureSession[0x7fba4c010d00]: Moving from state 'kEstablishing' --> 'kActive'
    [1694055308.376220][30046:30048] CHIP:IN: SecureSession[0x7fba4c010d00]: Activated - Type:1 LSID:28753
    [1694055308.376241][30046:30048] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:28753 PSID:6457!
    [1694055308.376270][30046:30048] CHIP:CTL: Remote device completed SPAKE2+ handshake
    [1694055308.376289][30046:30048] CHIP:TOO: Pairing Success
    [1694055308.376306][30046:30048] CHIP:TOO: PASE establishment successful
    [1694055308.376369][30046:30048] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
    [1694055308.376399][30046:30048] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
    [1694055308.376420][30046:30048] CHIP:CTL: Sending request for commissioning information
    [1694055308.376505][30046:30048] CHIP:DMG: SendReadRequest ReadClient[0x7fba4c011800]: Sending Read Request
    [1694055308.376721][30046:30048] CHIP:EM: <<< [E:3656i S:28753 M:35424720] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    [1694055308.376769][30046:30048] CHIP:IN: (S) Sending msg 35424720 on secure session with LSID: 28753
    [1694055308.377241][30046:30048] CHIP:DMG: MoveToState ReadClient[0x7fba4c011800]: Moving to [AwaitingIn]
    [1694055308.463560][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055308.468810][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055308.469094][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055308.556265][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055308.556591][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055308.556733][30046:30048] CHIP:EM: >>> [E:3656i S:28753 M:262639350] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
    [1694055308.556777][30046:30048] CHIP:EM: Found matching exchange: 3656i, Delegate: 0x7fba4c011810
    [1694055308.556923][30046:30048] CHIP:DMG: ReportDataMessage =
    [1694055308.556953][30046:30048] CHIP:DMG: {
    [1694055308.556975][30046:30048] CHIP:DMG:     AttributeReportIBs =
    [1694055308.557016][30046:30048] CHIP:DMG:     [
    [1694055308.557040][30046:30048] CHIP:DMG:         AttributeReportIB =
    [1694055308.557079][30046:30048] CHIP:DMG:         {
    [1694055308.557108][30046:30048] CHIP:DMG:             AttributeDataIB =
    [1694055308.557136][30046:30048] CHIP:DMG:             {
    [1694055308.557162][30046:30048] CHIP:DMG:                 DataVersion = 0x9849a6e4,
    [1694055308.557181][30046:30048] CHIP:DMG:                 AttributePathIB =
    [1694055308.557208][30046:30048] CHIP:DMG:                 {
    [1694055308.557237][30046:30048] CHIP:DMG:                     Endpoint = 0x0,
    [1694055308.557268][30046:30048] CHIP:DMG:                     Cluster = 0x31,
    [1694055308.557297][30046:30048] CHIP:DMG:                     Attribute = 0x0000_0003,
    [1694055308.557324][30046:30048] CHIP:DMG:                 }
    [1694055308.557358][30046:30048] CHIP:DMG:
    [1694055308.557393][30046:30048] CHIP:DMG:                 Data = 20,
    [1694055308.557419][30046:30048] CHIP:DMG:             },
    [1694055308.557456][30046:30048] CHIP:DMG:
    [1694055308.557476][30046:30048] CHIP:DMG:         },
    [1694055308.557523][30046:30048] CHIP:DMG:
    [1694055308.557547][30046:30048] CHIP:DMG:         AttributeReportIB =
    [1694055308.557586][30046:30048] CHIP:DMG:         {
    [1694055308.557606][30046:30048] CHIP:DMG:             AttributeDataIB =
    [1694055308.557629][30046:30048] CHIP:DMG:             {
    [1694055308.557654][30046:30048] CHIP:DMG:                 DataVersion = 0x90b177e9,
    [1694055308.557675][30046:30048] CHIP:DMG:                 AttributePathIB =
    [1694055308.557700][30046:30048] CHIP:DMG:                 {
    [1694055308.557723][30046:30048] CHIP:DMG:                     Endpoint = 0x0,
    [1694055308.557747][30046:30048] CHIP:DMG:                     Cluster = 0x28,
    [1694055308.557775][30046:30048] CHIP:DMG:                     Attribute = 0x0000_0004,
    [1694055308.557797][30046:30048] CHIP:DMG:                 }
    [1694055308.557825][30046:30048] CHIP:DMG:
    [1694055308.557852][30046:30048] CHIP:DMG:                 Data = 32773,
    [1694055308.557876][30046:30048] CHIP:DMG:             },
    [1694055308.557912][30046:30048] CHIP:DMG:
    [1694055308.557936][30046:30048] CHIP:DMG:         },
    [1694055308.557979][30046:30048] CHIP:DMG:
    [1694055308.557997][30046:30048] CHIP:DMG:         AttributeReportIB =
    [1694055308.558028][30046:30048] CHIP:DMG:         {
    [1694055308.558047][30046:30048] CHIP:DMG:             AttributeDataIB =
    [1694055308.558068][30046:30048] CHIP:DMG:             {
    [1694055308.558090][30046:30048] CHIP:DMG:                 DataVersion = 0x90b177e9,
    [1694055308.558111][30046:30048] CHIP:DMG:                 AttributePathIB =
    [1694055308.558133][30046:30048] CHIP:DMG:                 {
    [1694055308.558155][30046:30048] CHIP:DMG:                     Endpoint = 0x0,
    [1694055308.558179][30046:30048] CHIP:DMG:                     Cluster = 0x28,
    [1694055308.558202][30046:30048] CHIP:DMG:                     Attribute = 0x0000_0002,
    [1694055308.558223][30046:30048] CHIP:DMG:                 }
    [1694055308.558249][30046:30048] CHIP:DMG:
    [1694055308.558273][30046:30048] CHIP:DMG:                 Data = 65521,
    [1694055308.558293][30046:30048] CHIP:DMG:             },
    [1694055308.558321][30046:30048] CHIP:DMG:
    [1694055308.558339][30046:30048] CHIP:DMG:         },
    [1694055308.558380][30046:30048] CHIP:DMG:
    [1694055308.558398][30046:30048] CHIP:DMG:         AttributeReportIB =
    [1694055308.558428][30046:30048] CHIP:DMG:         {
    [1694055308.558446][30046:30048] CHIP:DMG:             AttributeDataIB =
    [1694055308.558467][30046:30048] CHIP:DMG:             {
    [1694055308.558489][30046:30048] CHIP:DMG:                 DataVersion = 0x37aa8bc9,
    [1694055308.558509][30046:30048] CHIP:DMG:                 AttributePathIB =
    [1694055308.558531][30046:30048] CHIP:DMG:                 {
    [1694055308.558553][30046:30048] CHIP:DMG:                     Endpoint = 0x0,
    [1694055308.558576][30046:30048] CHIP:DMG:                     Cluster = 0x30,
    [1694055308.558600][30046:30048] CHIP:DMG:                     Attribute = 0x0000_0003,
    [1694055308.558620][30046:30048] CHIP:DMG:                 }
    [1694055308.558647][30046:30048] CHIP:DMG:
    [1694055308.558670][30046:30048] CHIP:DMG:                 Data = 0,
    [1694055308.558690][30046:30048] CHIP:DMG:             },
    [1694055308.558718][30046:30048] CHIP:DMG:
    [1694055308.558736][30046:30048] CHIP:DMG:         },
    [1694055308.558776][30046:30048] CHIP:DMG:
    [1694055308.558794][30046:30048] CHIP:DMG:         AttributeReportIB =
    [1694055308.558825][30046:30048] CHIP:DMG:         {
    [1694055308.558843][30046:30048] CHIP:DMG:             AttributeDataIB =
    [1694055308.558864][30046:30048] CHIP:DMG:             {
    [1694055308.558886][30046:30048] CHIP:DMG:                 DataVersion = 0x37aa8bc9,
    [1694055308.558906][30046:30048] CHIP:DMG:                 AttributePathIB =
    [1694055308.558928][30046:30048] CHIP:DMG:                 {
    [1694055308.558950][30046:30048] CHIP:DMG:                     Endpoint = 0x0,
    [1694055308.558973][30046:30048] CHIP:DMG:                     Cluster = 0x30,
    [1694055308.558996][30046:30048] CHIP:DMG:                     Attribute = 0x0000_0002,
    [1694055308.559017][30046:30048] CHIP:DMG:                 }
    [1694055308.559043][30046:30048] CHIP:DMG:
    [1694055308.559068][30046:30048] CHIP:DMG:                 Data = 0,
    [1694055308.559087][30046:30048] CHIP:DMG:             },
    [1694055308.559115][30046:30048] CHIP:DMG:
    [1694055308.559134][30046:30048] CHIP:DMG:         },
    [1694055308.559177][30046:30048] CHIP:DMG:
    [1694055308.559195][30046:30048] CHIP:DMG:         AttributeReportIB =
    [1694055308.559228][30046:30048] CHIP:DMG:         {
    [1694055308.559247][30046:30048] CHIP:DMG:             AttributeDataIB =
    [1694055308.559268][30046:30048] CHIP:DMG:             {
    [1694055308.559289][30046:30048] CHIP:DMG:                 DataVersion = 0x37aa8bc9,
    [1694055308.559310][30046:30048] CHIP:DMG:                 AttributePathIB =
    [1694055308.559346][30046:30048] CHIP:DMG:                 {
    [1694055308.559375][30046:30048] CHIP:DMG:                     Endpoint = 0x0,
    [1694055308.559411][30046:30048] CHIP:DMG:                     Cluster = 0x30,
    [1694055308.559441][30046:30048] CHIP:DMG:                     Attribute = 0x0000_0001,
    [1694055308.559465][30046:30048] CHIP:DMG:                 }
    [1694055308.559504][30046:30048] CHIP:DMG:
    [1694055308.559529][30046:30048] CHIP:DMG:                 Data =
    [1694055308.559552][30046:30048] CHIP:DMG:                 {
    [1694055308.559576][30046:30048] CHIP:DMG:                     0x0 = 60,
    [1694055308.559601][30046:30048] CHIP:DMG:                     0x1 = 900,
    [1694055308.559624][30046:30048] CHIP:DMG:                 },
    [1694055308.559643][30046:30048] CHIP:DMG:             },
    [1694055308.559675][30046:30048] CHIP:DMG:
    [1694055308.559693][30046:30048] CHIP:DMG:         },
    [1694055308.559737][30046:30048] CHIP:DMG:
    [1694055308.559756][30046:30048] CHIP:DMG:         AttributeReportIB =
    [1694055308.559786][30046:30048] CHIP:DMG:         {
    [1694055308.559805][30046:30048] CHIP:DMG:             AttributeDataIB =
    [1694055308.559826][30046:30048] CHIP:DMG:             {
    [1694055308.559847][30046:30048] CHIP:DMG:                 DataVersion = 0x37aa8bc9,
    [1694055308.559867][30046:30048] CHIP:DMG:                 AttributePathIB =
    [1694055308.559889][30046:30048] CHIP:DMG:                 {
    [1694055308.559912][30046:30048] CHIP:DMG:                     Endpoint = 0x0,
    [1694055308.559936][30046:30048] CHIP:DMG:                     Cluster = 0x30,
    [1694055308.559959][30046:30048] CHIP:DMG:                     Attribute = 0x0000_0000,
    [1694055308.559980][30046:30048] CHIP:DMG:                 }
    [1694055308.560006][30046:30048] CHIP:DMG:
    [1694055308.560030][30046:30048] CHIP:DMG:                 Data = 0,
    [1694055308.560049][30046:30048] CHIP:DMG:             },
    [1694055308.560077][30046:30048] CHIP:DMG:
    [1694055308.560096][30046:30048] CHIP:DMG:         },
    [1694055308.560136][30046:30048] CHIP:DMG:
    [1694055308.560154][30046:30048] CHIP:DMG:         AttributeReportIB =
    [1694055308.560185][30046:30048] CHIP:DMG:         {
    [1694055308.560210][30046:30048] CHIP:DMG:             AttributeDataIB =
    [1694055308.560234][30046:30048] CHIP:DMG:             {
    [1694055308.560263][30046:30048] CHIP:DMG:                 DataVersion = 0x9849a6e4,
    [1694055308.560290][30046:30048] CHIP:DMG:                 AttributePathIB =
    [1694055308.560357][30046:30048] CHIP:DMG:                 {
    [1694055308.560389][30046:30048] CHIP:DMG:                     Endpoint = 0x0,
    [1694055308.560417][30046:30048] CHIP:DMG:                     Cluster = 0x31,
    [1694055308.560449][30046:30048] CHIP:DMG:                     Attribute = 0x0000_FFFC,
    [1694055308.560474][30046:30048] CHIP:DMG:                 }
    [1694055308.560507][30046:30048] CHIP:DMG:
    [1694055308.560535][30046:30048] CHIP:DMG:                 Data = 2,
    [1694055308.560557][30046:30048] CHIP:DMG:             },
    [1694055308.560588][30046:30048] CHIP:DMG:
    [1694055308.560609][30046:30048] CHIP:DMG:         },
    [1694055308.560640][30046:30048] CHIP:DMG:
    [1694055308.560660][30046:30048] CHIP:DMG:     ],
    [1694055308.560767][30046:30048] CHIP:DMG:
    [1694055308.560792][30046:30048] CHIP:DMG:     SuppressResponse = true,
    [1694055308.560815][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055308.560834][30046:30048] CHIP:DMG: }
    [1694055308.562315][30046:30048] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
    [1694055308.562378][30046:30048] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
    [1694055308.562399][30046:30048] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
    [1694055308.562419][30046:30048] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
    [1694055308.562455][30046:30048] CHIP:CTL: Arming failsafe (60 seconds)
    [1694055308.562522][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055308.562559][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055308.562646][30046:30048] CHIP:EM: <<< [E:3657i S:28753 M:35424721] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055308.562683][30046:30048] CHIP:IN: (S) Sending msg 35424721 on secure session with LSID: 28753
    [1694055308.563122][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055308.643142][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055308.645444][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055308.645637][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055308.645748][30046:30048] CHIP:EM: >>> [E:3657i S:28753 M:262639351] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055308.645783][30046:30048] CHIP:EM: Found matching exchange: 3657i, Delegate: 0x7fba5404ae38
    [1694055308.645814][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055308.645859][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055308.645876][30046:30048] CHIP:DMG: {
    [1694055308.645894][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055308.645912][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055308.645951][30046:30048] CHIP:DMG:     [
    [1694055308.645972][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055308.646004][30046:30048] CHIP:DMG:         {
    [1694055308.646023][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055308.646046][30046:30048] CHIP:DMG:             {
    [1694055308.646066][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055308.646093][30046:30048] CHIP:DMG:                 {
    [1694055308.646116][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055308.646139][30046:30048] CHIP:DMG:                     ClusterId = 0x30,
    [1694055308.646162][30046:30048] CHIP:DMG:                     CommandId = 0x1,
    [1694055308.646185][30046:30048] CHIP:DMG:                 },
    [1694055308.646213][30046:30048] CHIP:DMG:
    [1694055308.646234][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055308.646269][30046:30048] CHIP:DMG:                 {
    [1694055308.646298][30046:30048] CHIP:DMG:                     0x0 = 0,
    [1694055308.646331][30046:30048] CHIP:DMG:                     0x1 = "" (0 chars),
    [1694055308.646357][30046:30048] CHIP:DMG:                 },
    [1694055308.646375][30046:30048] CHIP:DMG:             },
    [1694055308.646404][30046:30048] CHIP:DMG:
    [1694055308.646427][30046:30048] CHIP:DMG:         },
    [1694055308.646456][30046:30048] CHIP:DMG:
    [1694055308.646470][30046:30048] CHIP:DMG:     ],
    [1694055308.646502][30046:30048] CHIP:DMG:
    [1694055308.646520][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055308.646537][30046:30048] CHIP:DMG: },
    [1694055308.646606][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1694055308.646650][30046:30048] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1694055308.646669][30046:30048] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
    [1694055308.646682][30046:30048] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
    [1694055308.646704][30046:30048] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
    [1694055308.646717][30046:30048] CHIP:CTL: Setting Regulatory Config
    [1694055308.646730][30046:30048] CHIP:CTL: Device does not support configurable regulatory location
    [1694055308.646777][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055308.646798][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055308.646854][30046:30048] CHIP:EM: <<< [E:3658i S:28753 M:35424722] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055308.646881][30046:30048] CHIP:IN: (S) Sending msg 35424722 on secure session with LSID: 28753
    [1694055308.647205][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055308.647262][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055308.733608][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055308.736452][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055308.736756][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055308.736944][30046:30048] CHIP:EM: >>> [E:3658i S:28753 M:262639352] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055308.737002][30046:30048] CHIP:EM: Found matching exchange: 3658i, Delegate: 0x7fba4c011408
    [1694055308.737051][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055308.737130][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055308.737168][30046:30048] CHIP:DMG: {
    [1694055308.737205][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055308.737240][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055308.737294][30046:30048] CHIP:DMG:     [
    [1694055308.737329][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055308.737380][30046:30048] CHIP:DMG:         {
    [1694055308.737412][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055308.737453][30046:30048] CHIP:DMG:             {
    [1694055308.737486][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055308.737531][30046:30048] CHIP:DMG:                 {
    [1694055308.737570][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055308.737608][30046:30048] CHIP:DMG:                     ClusterId = 0x30,
    [1694055308.737647][30046:30048] CHIP:DMG:                     CommandId = 0x3,
    [1694055308.737682][30046:30048] CHIP:DMG:                 },
    [1694055308.737727][30046:30048] CHIP:DMG:
    [1694055308.737765][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055308.737802][30046:30048] CHIP:DMG:                 {
    [1694055308.737845][30046:30048] CHIP:DMG:                     0x0 = 0,
    [1694055308.737889][30046:30048] CHIP:DMG:                     0x1 = "" (0 chars),
    [1694055308.737944][30046:30048] CHIP:DMG:                 },
    [1694055308.737998][30046:30048] CHIP:DMG:             },
    [1694055308.738046][30046:30048] CHIP:DMG:
    [1694055308.738079][30046:30048] CHIP:DMG:         },
    [1694055308.738131][30046:30048] CHIP:DMG:
    [1694055308.738164][30046:30048] CHIP:DMG:     ],
    [1694055308.738211][30046:30048] CHIP:DMG:
    [1694055308.738248][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055308.738278][30046:30048] CHIP:DMG: },
    [1694055308.738396][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
    [1694055308.739071][30046:30048] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
    [1694055308.739131][30046:30048] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
    [1694055308.739181][30046:30048] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
    [1694055308.739214][30046:30048] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
    [1694055308.739243][30046:30048] CHIP:CTL: Sending request for PAI certificate
    [1694055308.739274][30046:30048] CHIP:CTL: Sending Certificate Chain request to 0x7fba4c00cdb0 device
    [1694055308.739355][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055308.739881][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055308.740023][30046:30048] CHIP:EM: <<< [E:3659i S:28753 M:35424723] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055308.740077][30046:30048] CHIP:IN: (S) Sending msg 35424723 on secure session with LSID: 28753
    [1694055308.740758][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055308.740844][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055308.822701][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055308.826684][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055308.826728][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055308.916207][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055308.916344][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055309.004404][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055309.004579][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055309.004687][30046:30048] CHIP:EM: >>> [E:3659i S:28753 M:262639353] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055309.004716][30046:30048] CHIP:EM: Found matching exchange: 3659i, Delegate: 0x7fba5404ae38
    [1694055309.004742][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055309.004773][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055309.004784][30046:30048] CHIP:DMG: {
    [1694055309.004797][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055309.004808][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055309.004827][30046:30048] CHIP:DMG:     [
    [1694055309.004837][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055309.004856][30046:30048] CHIP:DMG:         {
    [1694055309.004867][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055309.004881][30046:30048] CHIP:DMG:             {
    [1694055309.004892][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055309.004909][30046:30048] CHIP:DMG:                 {
    [1694055309.004922][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055309.004935][30046:30048] CHIP:DMG:                     ClusterId = 0x3e,
    [1694055309.004949][30046:30048] CHIP:DMG:                     CommandId = 0x3,
    [1694055309.004960][30046:30048] CHIP:DMG:                 },
    [1694055309.004975][30046:30048] CHIP:DMG:
    [1694055309.004987][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055309.005001][30046:30048] CHIP:DMG:                 {
    [1694055309.005013][30046:30048] CHIP:DMG:                     0x0 = [
    [1694055309.005145][30046:30048] CHIP:DMG:                             0x30, 0x82, 0x01, 0xcb, 0x30, 0x82, 0x01, 0x71, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x56, 0xad, 0x82, 0x22, 0xad, 0x94, 0x5b, 0x64, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0f, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x41, 0x9a, 0x93, 0x15, 0xc2, 0x17, 0x3e, 0x0c, 0x8c, 0x87, 0x6d, 0x03, 0xcc, 0xfc, 0x94, 0x48, 0x52, 0x64, 0x7f, 0x7f, 0xec, 0x5e, 0x50, 0x82, 0xf4, 0x05, 0x99, 0x28, 0xec, 0xa8, 0x94, 0xc5, 0x94, 0x15, 0x13, 0x09, 0xac, 0x63, 0x1e, 0x4c, 0xb0, 0x33, 0x92, 0xaf, 0x68, 0x4b, 0x0b, 0xaf, 0xb7, 0xe6, 0x5b, 0x3b, 0x81, 0x62, 0xc2, 0xf5, 0x2b, 0xf9, 0x31, 0xb8, 0xe7, 0x7a, 0xaa, 0x82, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x06, 0x03, 0x55, 0x1d, 0x
    [1694055309.005191][30046:30048] CHIP:DMG:                     ] (463 bytes)
    [1694055309.005207][30046:30048] CHIP:DMG:                 },
    [1694055309.005219][30046:30048] CHIP:DMG:             },
    [1694055309.005236][30046:30048] CHIP:DMG:
    [1694055309.005281][30046:30048] CHIP:DMG:         },
    [1694055309.005305][30046:30048] CHIP:DMG:
    [1694055309.005317][30046:30048] CHIP:DMG:     ],
    [1694055309.005333][30046:30048] CHIP:DMG:
    [1694055309.005342][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055309.005354][30046:30048] CHIP:DMG: },
    [1694055309.005401][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1694055309.005422][30046:30048] CHIP:CTL: Received certificate chain from the device
    [1694055309.005445][30046:30048] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
    [1694055309.005459][30046:30048] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
    [1694055309.005474][30046:30048] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
    [1694055309.005491][30046:30048] CHIP:CTL: Sending request for DAC certificate
    [1694055309.005504][30046:30048] CHIP:CTL: Sending Certificate Chain request to 0x7fba4c00cdb0 device
    [1694055309.005553][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055309.005570][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055309.005633][30046:30048] CHIP:EM: <<< [E:3660i S:28753 M:35424724] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055309.005656][30046:30048] CHIP:IN: (S) Sending msg 35424724 on secure session with LSID: 28753
    [1694055309.005971][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055309.006018][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055309.094359][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055309.097803][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055309.098080][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055309.232576][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055309.232862][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055309.365160][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055309.365432][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055309.365627][30046:30048] CHIP:EM: >>> [E:3660i S:28753 M:262639354] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055309.365684][30046:30048] CHIP:EM: Found matching exchange: 3660i, Delegate: 0x7fba5404b198
    [1694055309.365733][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055309.365808][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055309.365846][30046:30048] CHIP:DMG: {
    [1694055309.365868][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055309.365895][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055309.365930][30046:30048] CHIP:DMG:     [
    [1694055309.365962][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055309.365997][30046:30048] CHIP:DMG:         {
    [1694055309.366026][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055309.366063][30046:30048] CHIP:DMG:             {
    [1694055309.366091][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055309.366128][30046:30048] CHIP:DMG:                 {
    [1694055309.366160][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055309.366209][30046:30048] CHIP:DMG:                     ClusterId = 0x3e,
    [1694055309.366247][30046:30048] CHIP:DMG:                     CommandId = 0x3,
    [1694055309.366283][30046:30048] CHIP:DMG:                 },
    [1694055309.366326][30046:30048] CHIP:DMG:
    [1694055309.366360][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055309.366394][30046:30048] CHIP:DMG:                 {
    [1694055309.366435][30046:30048] CHIP:DMG:                     0x0 = [
    [1694055309.366625][30046:30048] CHIP:DMG:                             0x30, 0x82, 0x01, 0xe8, 0x30, 0x82, 0x01, 0x8e, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x6f, 0xdc, 0xb6, 0xed, 0x06, 0xf3, 0x58, 0xf9, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x53, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x2f, 0x30, 0x78, 0x38, 0x30, 0x30, 0x35, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x35, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x7e, 0xf2, 0xf1, 0x08, 0x2b, 0x2a, 0x56, 0x4a, 0x05, 0x44, 0xc0, 0xa6, 0x13, 0xd2, 0x1b, 0x15, 0x75, 0x00, 0x55, 0x2d, 0x03, 0x5f, 0x23, 0x02, 0x25, 0x2f, 0xce, 0xe8, 0x1d, 0x6e, 0xc6, 0x74, 0x17, 0x34, 0x18, 0xa9, 0x4a, 0x88, 0xdb, 0x
    [1694055309.366775][30046:30048] CHIP:DMG:                     ] (492 bytes)
    [1694055309.366804][30046:30048] CHIP:DMG:                 },
    [1694055309.366834][30046:30048] CHIP:DMG:             },
    [1694055309.366876][30046:30048] CHIP:DMG:
    [1694055309.366897][30046:30048] CHIP:DMG:         },
    [1694055309.366937][30046:30048] CHIP:DMG:
    [1694055309.366969][30046:30048] CHIP:DMG:     ],
    [1694055309.367015][30046:30048] CHIP:DMG:
    [1694055309.367046][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055309.367070][30046:30048] CHIP:DMG: },
    [1694055309.367182][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1694055309.367229][30046:30048] CHIP:CTL: Received certificate chain from the device
    [1694055309.367261][30046:30048] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
    [1694055309.367293][30046:30048] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
    [1694055309.367326][30046:30048] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
    [1694055309.367344][30046:30048] CHIP:CTL: Sending Attestation Request to the device.
    [1694055309.367358][30046:30048] CHIP:CTL: Sending Attestation request to 0x7fba4c00cdb0 device
    [1694055309.367411][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055309.367436][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055309.367512][30046:30048] CHIP:EM: <<< [E:3661i S:28753 M:35424725] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055309.367544][30046:30048] CHIP:IN: (S) Sending msg 35424725 on secure session with LSID: 28753
    [1694055309.368228][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055309.368272][30046:30048] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
    [1694055309.368377][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055309.453601][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055309.457920][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055309.458202][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055309.548042][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055309.548183][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055309.637599][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055309.637880][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055309.638054][30046:30048] CHIP:EM: >>> [E:3661i S:28753 M:262639355] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055309.638108][30046:30048] CHIP:EM: Found matching exchange: 3661i, Delegate: 0x7fba5404b588
    [1694055309.638150][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055309.638219][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055309.638249][30046:30048] CHIP:DMG: {
    [1694055309.638277][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055309.638296][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055309.638325][30046:30048] CHIP:DMG:     [
    [1694055309.638342][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055309.638369][30046:30048] CHIP:DMG:         {
    [1694055309.638386][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055309.638425][30046:30048] CHIP:DMG:             {
    [1694055309.638451][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055309.638481][30046:30048] CHIP:DMG:                 {
    [1694055309.638502][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055309.638522][30046:30048] CHIP:DMG:                     ClusterId = 0x3e,
    [1694055309.638542][30046:30048] CHIP:DMG:                     CommandId = 0x1,
    [1694055309.638569][30046:30048] CHIP:DMG:                 },
    [1694055309.638597][30046:30048] CHIP:DMG:
    [1694055309.638616][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055309.638636][30046:30048] CHIP:DMG:                 {
    [1694055309.638656][30046:30048] CHIP:DMG:                     0x0 = [
    [1694055309.638814][30046:30048] CHIP:DMG:                             0x15, 0x31, 0x01, 0x1b, 0x02, 0x30, 0x82, 0x02, 0x17, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x82, 0x02, 0x08, 0x30, 0x82, 0x02, 0x04, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x82, 0x01, 0x70, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x82, 0x01, 0x61, 0x04, 0x82, 0x01, 0x5d, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0xf1, 0xff, 0x36, 0x02, 0x05, 0x00, 0x80, 0x05, 0x01, 0x80, 0x05, 0x02, 0x80, 0x05, 0x03, 0x80, 0x05, 0x04, 0x80, 0x05, 0x05, 0x80, 0x05, 0x06, 0x80, 0x05, 0x07, 0x80, 0x05, 0x08, 0x80, 0x05, 0x09, 0x80, 0x05, 0x0a, 0x80, 0x05, 0x0b, 0x80, 0x05, 0x0c, 0x80, 0x05, 0x0d, 0x80, 0x05, 0x0e, 0x80, 0x05, 0x0f, 0x80, 0x05, 0x10, 0x80, 0x05, 0x11, 0x80, 0x05, 0x12, 0x80, 0x05, 0x13, 0x80, 0x05, 0x14, 0x80, 0x05, 0x15, 0x80, 0x05, 0x16, 0x80, 0x05, 0x17, 0x80, 0x05, 0x18, 0x80, 0x05, 0x19, 0x80, 0x05, 0x1a, 0x80, 0x05, 0x1b, 0x80, 0x05, 0x1c, 0x80, 0x05, 0x1d, 0x80, 0x05, 0x1e, 0x80, 0x05, 0x1f, 0x80, 0x05, 0x20, 0x80, 0x05, 0x21, 0x80, 0x05, 0x22, 0x80, 0x05, 0x23, 0x80, 0x05, 0x24, 0x80, 0x05, 0x25, 0x80, 0x05, 0x26, 0x80, 0x05, 0x27, 0x80, 0x05, 0x28, 0x80, 0x05, 0x29, 0x80, 0x05, 0x2a, 0x80, 0x05, 0x2b, 0x80, 0x05, 0x2c, 0x80, 0x05, 0x2d, 0x80, 0x05, 0x2e, 0x80, 0x05, 0x2f, 0x80, 0x05, 0x30, 0x80, 0x05, 0x31, 0x80, 0x05, 0x32, 0x80, 0x05, 0x33, 0x80, 0x05, 0x34, 0x80, 0x05, 0x35, 0x80, 0x05, 0x36, 0x80, 0x05, 0x37, 0x80, 0x05, 0x38, 0x80, 0x05, 0x39, 0x80, 0x05, 0x3a, 0x80, 0x05, 0x3b, 0x80, 0x05, 0x3c, 0x80, 0x05, 0x3d, 0x80, 0x05, 0x3e, 0x80, 0x05, 0x3f, 0x80, 0x05, 0x40, 0x80, 0x05, 0x41, 0x80, 0x05, 0x42, 0x80, 0x05, 0x43, 0x80, 0x
    [1694055309.638917][30046:30048] CHIP:DMG:                     ] (583 bytes)
    [1694055309.638950][30046:30048] CHIP:DMG:                     0x1 = [
    [1694055309.639037][30046:30048] CHIP:DMG:                             0x51, 0x68, 0x55, 0xa8, 0x13, 0xe7, 0xc4, 0x4e, 0xdc, 0x9b, 0xc4, 0xa0, 0x29, 0x50, 0x9b, 0x65, 0x26, 0x3a, 0xa1, 0x7e, 0x47, 0x88, 0x94, 0xc0, 0xbf, 0xf2, 0xda, 0xe8, 0x61, 0x4b, 0x28, 0x5b, 0x83, 0xc1, 0xd7, 0x28, 0x60, 0xd5, 0xbc, 0x43, 0x98, 0x64, 0x62, 0x31, 0xfa, 0xa4, 0xa5, 0xd2, 0x7c, 0x7a, 0x45, 0x9a, 0xf0, 0xca, 0x24, 0x91, 0xd2, 0xdf, 0x86, 0xdf, 0xbe, 0x1c, 0xa3, 0xa2,
    [1694055309.639080][30046:30048] CHIP:DMG:                     ] (64 bytes)
    [1694055309.639113][30046:30048] CHIP:DMG:                 },
    [1694055309.639139][30046:30048] CHIP:DMG:             },
    [1694055309.639180][30046:30048] CHIP:DMG:
    [1694055309.639203][30046:30048] CHIP:DMG:         },
    [1694055309.639245][30046:30048] CHIP:DMG:
    [1694055309.639267][30046:30048] CHIP:DMG:     ],
    [1694055309.639311][30046:30048] CHIP:DMG:
    [1694055309.639334][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055309.639358][30046:30048] CHIP:DMG: },
    [1694055309.639459][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
    [1694055309.639499][30046:30048] CHIP:CTL: Received Attestation Information from the device
    [1694055309.639531][30046:30048] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
    [1694055309.639555][30046:30048] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 583/583
    [1694055309.639590][30046:30048] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
    [1694055309.639618][30046:30048] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
    [1694055309.639642][30046:30048] CHIP:CTL: Verifying attestation
    [1694055309.671082][30046:30048] CHIP:CR: mbedTLS error: ERROR - Generic error
    [1694055309.702299][30046:30048] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
    [1694055309.702321][30046:30048] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
    [1694055309.702327][30046:30048] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
    [1694055309.702338][30046:30048] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
    [1694055309.702346][30046:30048] CHIP:CTL: Sending CSR request to 0x7fba4c00cdb0 device
    [1694055309.702381][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055309.702390][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055309.702425][30046:30048] CHIP:EM: <<< [E:3662i S:28753 M:35424726] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055309.702438][30046:30048] CHIP:IN: (S) Sending msg 35424726 on secure session with LSID: 28753
    [1694055309.703140][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055309.703173][30046:30048] CHIP:CTL: Sent CSR request, waiting for the CSR
    [1694055309.703213][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055309.769339][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055309.952470][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055309.952642][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055310.041240][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055310.041415][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055310.041567][30046:30048] CHIP:EM: >>> [E:3662i S:28753 M:262639356] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055310.041614][30046:30048] CHIP:EM: Found matching exchange: 3662i, Delegate: 0x7fba5404b198
    [1694055310.041654][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055310.041719][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055310.041745][30046:30048] CHIP:DMG: {
    [1694055310.041768][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055310.041807][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055310.041859][30046:30048] CHIP:DMG:     [
    [1694055310.041890][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055310.041927][30046:30048] CHIP:DMG:         {
    [1694055310.041967][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055310.042004][30046:30048] CHIP:DMG:             {
    [1694055310.042036][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055310.042073][30046:30048] CHIP:DMG:                 {
    [1694055310.042113][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055310.042153][30046:30048] CHIP:DMG:                     ClusterId = 0x3e,
    [1694055310.042186][30046:30048] CHIP:DMG:                     CommandId = 0x5,
    [1694055310.042219][30046:30048] CHIP:DMG:                 },
    [1694055310.042254][30046:30048] CHIP:DMG:
    [1694055310.042280][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055310.042316][30046:30048] CHIP:DMG:                 {
    [1694055310.042347][30046:30048] CHIP:DMG:                     0x0 = [
    [1694055310.042547][30046:30048] CHIP:DMG:                             0x15, 0x30, 0x01, 0xcd, 0x30, 0x81, 0xca, 0x30, 0x70, 0x02, 0x01, 0x00, 0x30, 0x0e, 0x31, 0x0c, 0x30, 0x0a, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x03, 0x43, 0x53, 0x52, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x8c, 0xb8, 0xf8, 0xdc, 0xae, 0x36, 0xba, 0x3e, 0x76, 0x50, 0x3e, 0x57, 0x68, 0x0e, 0xba, 0x4e, 0xa4, 0xef, 0xd4, 0x52, 0x48, 0x2f, 0x68, 0xe9, 0x3c, 0xde, 0x4a, 0x9f, 0xae, 0xbc, 0x15, 0x63, 0x11, 0xac, 0x67, 0x5a, 0xa0, 0x51, 0x49, 0x93, 0x18, 0x78, 0x75, 0x82, 0x57, 0x9c, 0x02, 0xc5, 0x49, 0x21, 0xb8, 0x2b, 0x46, 0x68, 0xd5, 0x77, 0x41, 0xa8, 0xbb, 0x69, 0xdc, 0xf0, 0xa8, 0xf8, 0xa0, 0x00, 0x30, 0x0c, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x05, 0x00, 0x03, 0x48, 0x00, 0x30, 0x45, 0x02, 0x21, 0x00, 0x8a, 0x33, 0x28, 0xcd, 0x72, 0x3d, 0x55, 0x6e, 0x8b, 0xc7, 0xa9, 0xd1, 0x9d, 0x77, 0xcf, 0x0e, 0xc1, 0xba, 0x67, 0xdd, 0xc2, 0x44, 0x4b, 0x0d, 0x9f, 0x2e, 0x41, 0x36, 0x0a, 0x23, 0xb4, 0x34, 0x02, 0x20, 0x77, 0x20, 0x72, 0x01, 0x0f, 0xc6, 0x1e, 0x6b, 0x6e, 0x9d, 0x36, 0x59, 0x92, 0xfa, 0xa0, 0x0a, 0xaf, 0x4d, 0x5a, 0x8a, 0xd9, 0x75, 0x71, 0x01, 0xd6, 0x02, 0x67, 0xae, 0x7a, 0x06, 0x18, 0x20, 0x30, 0x02, 0x20, 0x5c, 0xf5, 0xb4, 0x5b, 0x2d, 0x2c, 0x64, 0x8d, 0xbc, 0xd2, 0x2b, 0xd2, 0x5c, 0x4e, 0x54, 0xf2, 0x5f, 0xa3, 0xf4, 0xab, 0x36, 0x04, 0x8b, 0xc0, 0x6a, 0xce, 0xc7, 0x7b, 0xbb, 0x5d, 0x29, 0xd0, 0x18,
    [1694055310.042610][30046:30048] CHIP:DMG:                     ] (245 bytes)
    [1694055310.042647][30046:30048] CHIP:DMG:                     0x1 = [
    [1694055310.042741][30046:30048] CHIP:DMG:                             0x5e, 0xbf, 0x2d, 0x48, 0x9f, 0x1c, 0x89, 0xb0, 0x5e, 0xe4, 0x15, 0xb0, 0x36, 0x70, 0x61, 0xee, 0x62, 0x25, 0xdf, 0x9b, 0xf6, 0x89, 0xb0, 0xe5, 0xb6, 0x00, 0xff, 0x3e, 0x02, 0x8a, 0x71, 0xf9, 0xab, 0x5f, 0x1d, 0x5d, 0x76, 0x20, 0x2b, 0xf6, 0x55, 0xf4, 0xc2, 0x37, 0xdf, 0xea, 0x4f, 0x52, 0xf1, 0x06, 0x4f, 0xb0, 0x1f, 0xe7, 0x58, 0xf1, 0xf2, 0x6b, 0x16, 0x87, 0xd4, 0xbf, 0x7f, 0x40,
    [1694055310.042781][30046:30048] CHIP:DMG:                     ] (64 bytes)
    [1694055310.042816][30046:30048] CHIP:DMG:                 },
    [1694055310.042844][30046:30048] CHIP:DMG:             },
    [1694055310.042890][30046:30048] CHIP:DMG:
    [1694055310.042917][30046:30048] CHIP:DMG:         },
    [1694055310.042960][30046:30048] CHIP:DMG:
    [1694055310.042987][30046:30048] CHIP:DMG:     ],
    [1694055310.043036][30046:30048] CHIP:DMG:
    [1694055310.043064][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055310.043090][30046:30048] CHIP:DMG: },
    [1694055310.043215][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
    [1694055310.043256][30046:30048] CHIP:CTL: Received certificate signing request from the device
    [1694055310.043293][30046:30048] CHIP:CTL: Successfully finished commissioning step 'SendOpCertSigningRequest'
    [1694055310.043324][30046:30048] CHIP:CTL: Commissioning stage next step: 'SendOpCertSigningRequest' -> 'ValidateCSR'
    [1694055310.043361][30046:30048] CHIP:CTL: Performing next commissioning step 'ValidateCSR'
    [1694055310.070010][30046:30048] CHIP:CTL: Successfully finished commissioning step 'ValidateCSR'
    [1694055310.070056][30046:30048] CHIP:CTL: Commissioning stage next step: 'ValidateCSR' -> 'GenerateNOCChain'
    [1694055310.070079][30046:30048] CHIP:CTL: Performing next commissioning step 'GenerateNOCChain'
    [1694055310.070090][30046:30048] CHIP:CTL: Getting certificate chain for the device from the issuer
    [1694055310.070135][30046:30048] CHIP:CTL: Verifying Certificate Signing Request
    [1694055310.080317][30046:30048] CHIP:CTL: Generating NOC
    [1694055310.084219][30046:30048] CHIP:CTL: Providing certificate chain to the commissioner
    [1694055310.084234][30046:30048] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
    [1694055310.084245][30046:30048] CHIP:CTL: Successfully finished commissioning step 'GenerateNOCChain'
    [1694055310.084312][30046:30048] CHIP:CTL: Performing next commissioning step 'SendTrustedRootCert'
    [1694055310.084320][30046:30048] CHIP:CTL: Sending root certificate to the device
    [1694055310.084355][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055310.084367][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055310.084407][30046:30048] CHIP:EM: <<< [E:3663i S:28753 M:35424727] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055310.084417][30046:30048] CHIP:IN: (S) Sending msg 35424727 on secure session with LSID: 28753
    [1694055310.084562][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055310.084576][30046:30048] CHIP:CTL: Sent root certificate to the device
    [1694055310.084716][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055310.173280][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055310.308396][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055310.356014][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055310.356310][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055310.356543][30046:30048] CHIP:EM: >>> [E:3663i S:28753 M:262639357] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055310.356599][30046:30048] CHIP:EM: Found matching exchange: 3663i, Delegate: 0x7fba5404b588
    [1694055310.356650][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055310.356727][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055310.356764][30046:30048] CHIP:DMG: {
    [1694055310.356792][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055310.356823][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055310.356868][30046:30048] CHIP:DMG:     [
    [1694055310.356895][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055310.356934][30046:30048] CHIP:DMG:         {
    [1694055310.356965][30046:30048] CHIP:DMG:             CommandStatusIB =
    [1694055310.356995][30046:30048] CHIP:DMG:             {
    [1694055310.357026][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055310.357056][30046:30048] CHIP:DMG:                 {
    [1694055310.357086][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055310.357121][30046:30048] CHIP:DMG:                     ClusterId = 0x3e,
    [1694055310.357147][30046:30048] CHIP:DMG:                     CommandId = 0xb,
    [1694055310.357169][30046:30048] CHIP:DMG:                 },
    [1694055310.357203][30046:30048] CHIP:DMG:
    [1694055310.357225][30046:30048] CHIP:DMG:                 StatusIB =
    [1694055310.357251][30046:30048] CHIP:DMG:                 {
    [1694055310.357276][30046:30048] CHIP:DMG:                     status = 0x00 (SUCCESS),
    [1694055310.357299][30046:30048] CHIP:DMG:                 },
    [1694055310.357325][30046:30048] CHIP:DMG:
    [1694055310.357346][30046:30048] CHIP:DMG:             },
    [1694055310.357388][30046:30048] CHIP:DMG:
    [1694055310.357411][30046:30048] CHIP:DMG:         },
    [1694055310.357450][30046:30048] CHIP:DMG:
    [1694055310.357469][30046:30048] CHIP:DMG:     ],
    [1694055310.357510][30046:30048] CHIP:DMG:
    [1694055310.357531][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055310.357556][30046:30048] CHIP:DMG: },
    [1694055310.357649][30046:30048] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
    [1694055310.357677][30046:30048] CHIP:CTL: Device confirmed that it has received the root certificate
    [1694055310.357710][30046:30048] CHIP:CTL: Successfully finished commissioning step 'SendTrustedRootCert'
    [1694055310.357736][30046:30048] CHIP:CTL: Commissioning stage next step: 'SendTrustedRootCert' -> 'SendNOC'
    [1694055310.357768][30046:30048] CHIP:CTL: Performing next commissioning step 'SendNOC'
    [1694055310.357837][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055310.357877][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055310.357987][30046:30048] CHIP:EM: <<< [E:3664i S:28753 M:35424728] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055310.358030][30046:30048] CHIP:IN: (S) Sending msg 35424728 on secure session with LSID: 28753
    [1694055310.358602][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055310.358641][30046:30048] CHIP:CTL: Sent operational certificate to the device
    [1694055310.358705][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055310.444037][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055310.578334][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055310.668398][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055310.805706][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055310.806002][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055310.806186][30046:30048] CHIP:EM: >>> [E:3664i S:28753 M:262639358] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055310.806247][30046:30048] CHIP:EM: Found matching exchange: 3664i, Delegate: 0x7fba5404b198
    [1694055310.806312][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055310.806383][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055310.806410][30046:30048] CHIP:DMG: {
    [1694055310.806435][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055310.806463][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055310.806502][30046:30048] CHIP:DMG:     [
    [1694055310.806519][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055310.806547][30046:30048] CHIP:DMG:         {
    [1694055310.806564][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055310.806584][30046:30048] CHIP:DMG:             {
    [1694055310.806601][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055310.806621][30046:30048] CHIP:DMG:                 {
    [1694055310.806653][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055310.806685][30046:30048] CHIP:DMG:                     ClusterId = 0x3e,
    [1694055310.806717][30046:30048] CHIP:DMG:                     CommandId = 0x8,
    [1694055310.806746][30046:30048] CHIP:DMG:                 },
    [1694055310.806779][30046:30048] CHIP:DMG:
    [1694055310.806798][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055310.806817][30046:30048] CHIP:DMG:                 {
    [1694055310.806838][30046:30048] CHIP:DMG:                     0x0 = 0,
    [1694055310.806858][30046:30048] CHIP:DMG:                     0x1 = 1,
    [1694055310.806879][30046:30048] CHIP:DMG:                 },
    [1694055310.806896][30046:30048] CHIP:DMG:             },
    [1694055310.806921][30046:30048] CHIP:DMG:
    [1694055310.806950][30046:30048] CHIP:DMG:         },
    [1694055310.806995][30046:30048] CHIP:DMG:
    [1694055310.807017][30046:30048] CHIP:DMG:     ],
    [1694055310.807061][30046:30048] CHIP:DMG:
    [1694055310.807084][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055310.807107][30046:30048] CHIP:DMG: },
    [1694055310.807210][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
    [1694055310.807251][30046:30048] CHIP:CTL: Device returned status 0 on receiving the NOC
    [1694055310.807272][30046:30048] CHIP:CTL: Operational credentials provisioned on device 0x7fba4c00cdb0
    [1694055310.807297][30046:30048] CHIP:TOO: Secure Pairing Success
    [1694055310.807318][30046:30048] CHIP:TOO: CASE establishment successful
    [1694055310.807347][30046:30048] CHIP:CTL: Successfully finished commissioning step 'SendNOC'
    [1694055310.807373][30046:30048] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
    [1694055310.807397][30046:30048] CHIP:CTL: Commissioning stage next step: 'SendNOC' -> 'ThreadNetworkSetup'
    [1694055310.807429][30046:30048] CHIP:CTL: Performing next commissioning step 'ThreadNetworkSetup'
    [1694055310.807495][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055310.807548][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055310.807636][30046:30048] CHIP:EM: <<< [E:3665i S:28753 M:35424729] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055310.807675][30046:30048] CHIP:IN: (S) Sending msg 35424729 on secure session with LSID: 28753
    [1694055310.808102][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055310.808195][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055310.893363][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055310.895509][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055310.895795][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055310.895975][30046:30048] CHIP:EM: >>> [E:3665i S:28753 M:262639359] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055310.896024][30046:30048] CHIP:EM: Found matching exchange: 3665i, Delegate: 0x7fba5404b588
    [1694055310.896081][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055310.896147][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055310.896170][30046:30048] CHIP:DMG: {
    [1694055310.896191][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055310.896211][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055310.896253][30046:30048] CHIP:DMG:     [
    [1694055310.896278][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055310.896370][30046:30048] CHIP:DMG:         {
    [1694055310.896402][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055310.896430][30046:30048] CHIP:DMG:             {
    [1694055310.896462][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055310.896491][30046:30048] CHIP:DMG:                 {
    [1694055310.896528][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055310.896576][30046:30048] CHIP:DMG:                     ClusterId = 0x31,
    [1694055310.896619][30046:30048] CHIP:DMG:                     CommandId = 0x5,
    [1694055310.896645][30046:30048] CHIP:DMG:                 },
    [1694055310.896666][30046:30048] CHIP:DMG:
    [1694055310.896702][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055310.896739][30046:30048] CHIP:DMG:                 {
    [1694055310.896778][30046:30048] CHIP:DMG:                     0x0 = 0,
    [1694055310.896820][30046:30048] CHIP:DMG:                     0x2 = 0,
    [1694055310.896856][30046:30048] CHIP:DMG:                 },
    [1694055310.896889][30046:30048] CHIP:DMG:             },
    [1694055310.896939][30046:30048] CHIP:DMG:
    [1694055310.896972][30046:30048] CHIP:DMG:         },
    [1694055310.897021][30046:30048] CHIP:DMG:
    [1694055310.897052][30046:30048] CHIP:DMG:     ],
    [1694055310.897103][30046:30048] CHIP:DMG:
    [1694055310.897135][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055310.897167][30046:30048] CHIP:DMG: },
    [1694055310.897284][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
    [1694055310.898485][30046:30048] CHIP:CTL: Received NetworkConfig response, networkingStatus=0
    [1694055310.898533][30046:30048] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkSetup'
    [1694055310.898555][30046:30048] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkSetup' -> 'FailsafeBeforeThreadEnable'
    [1694055310.898582][30046:30048] CHIP:CTL: Performing next commissioning step 'FailsafeBeforeThreadEnable'
    [1694055310.898620][30046:30048] CHIP:CTL: Arming failsafe (76 seconds)
    [1694055310.898690][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055310.898779][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055310.898916][30046:30048] CHIP:EM: <<< [E:3666i S:28753 M:35424730] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055310.898960][30046:30048] CHIP:IN: (S) Sending msg 35424730 on secure session with LSID: 28753
    [1694055310.899495][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055310.899600][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055310.983338][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055310.985749][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055310.986021][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055310.986195][30046:30048] CHIP:EM: >>> [E:3666i S:28753 M:262639360] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055310.986240][30046:30048] CHIP:EM: Found matching exchange: 3666i, Delegate: 0x7fba5404b198
    [1694055310.986283][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055310.986351][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055310.986379][30046:30048] CHIP:DMG: {
    [1694055310.986426][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055310.986447][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055310.986487][30046:30048] CHIP:DMG:     [
    [1694055310.986518][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055310.986560][30046:30048] CHIP:DMG:         {
    [1694055310.986588][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055310.986621][30046:30048] CHIP:DMG:             {
    [1694055310.986649][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055310.986681][30046:30048] CHIP:DMG:                 {
    [1694055310.986711][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055310.986744][30046:30048] CHIP:DMG:                     ClusterId = 0x30,
    [1694055310.986772][30046:30048] CHIP:DMG:                     CommandId = 0x1,
    [1694055310.986801][30046:30048] CHIP:DMG:                 },
    [1694055310.986838][30046:30048] CHIP:DMG:
    [1694055310.986864][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055310.986897][30046:30048] CHIP:DMG:                 {
    [1694055310.986929][30046:30048] CHIP:DMG:                     0x0 = 0,
    [1694055310.986962][30046:30048] CHIP:DMG:                     0x1 = "" (0 chars),
    [1694055310.986995][30046:30048] CHIP:DMG:                 },
    [1694055310.987020][30046:30048] CHIP:DMG:             },
    [1694055310.987061][30046:30048] CHIP:DMG:
    [1694055310.987084][30046:30048] CHIP:DMG:         },
    [1694055310.987125][30046:30048] CHIP:DMG:
    [1694055310.987147][30046:30048] CHIP:DMG:     ],
    [1694055310.987191][30046:30048] CHIP:DMG:
    [1694055310.987214][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055310.987237][30046:30048] CHIP:DMG: },
    [1694055310.987337][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1694055310.987380][30046:30048] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1694055310.987410][30046:30048] CHIP:CTL: Successfully finished commissioning step 'FailsafeBeforeThreadEnable'
    [1694055310.987435][30046:30048] CHIP:CTL: Commissioning stage next step: 'FailsafeBeforeThreadEnable' -> 'ThreadNetworkEnable'
    [1694055310.987469][30046:30048] CHIP:CTL: Performing next commissioning step 'ThreadNetworkEnable'
    [1694055310.987559][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055310.987596][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055310.987689][30046:30048] CHIP:EM: <<< [E:3667i S:28753 M:35424731] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055310.987733][30046:30048] CHIP:IN: (S) Sending msg 35424731 on secure session with LSID: 28753
    [1694055310.988090][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055310.988195][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055311.073494][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055312.290110][30046:30047] CHIP:DL: Indication received, conn = 0x7fba540481d0
    [1694055312.290410][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1694055312.290573][30046:30048] CHIP:EM: >>> [E:3667i S:28753 M:262639361] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055312.290636][30046:30048] CHIP:EM: Found matching exchange: 3667i, Delegate: 0x7fba5404b588
    [1694055312.290681][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055312.290754][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055312.290785][30046:30048] CHIP:DMG: {
    [1694055312.290817][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055312.290850][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055312.290900][30046:30048] CHIP:DMG:     [
    [1694055312.290927][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055312.290971][30046:30048] CHIP:DMG:         {
    [1694055312.291001][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055312.291038][30046:30048] CHIP:DMG:             {
    [1694055312.291065][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055312.291104][30046:30048] CHIP:DMG:                 {
    [1694055312.291140][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055312.291173][30046:30048] CHIP:DMG:                     ClusterId = 0x31,
    [1694055312.291206][30046:30048] CHIP:DMG:                     CommandId = 0x7,
    [1694055312.291236][30046:30048] CHIP:DMG:                 },
    [1694055312.291273][30046:30048] CHIP:DMG:
    [1694055312.291298][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055312.291330][30046:30048] CHIP:DMG:                 {
    [1694055312.291365][30046:30048] CHIP:DMG:                     0x0 = 0,
    [1694055312.291396][30046:30048] CHIP:DMG:                     0x2 = NULL
    [1694055312.291426][30046:30048] CHIP:DMG:                 },
    [1694055312.291456][30046:30048] CHIP:DMG:             },
    [1694055312.291498][30046:30048] CHIP:DMG:
    [1694055312.291527][30046:30048] CHIP:DMG:         },
    [1694055312.291561][30046:30048] CHIP:DMG:
    [1694055312.291581][30046:30048] CHIP:DMG:     ],
    [1694055312.291615][30046:30048] CHIP:DMG:
    [1694055312.291637][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055312.291656][30046:30048] CHIP:DMG: },
    [1694055312.291748][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
    [1694055312.291786][30046:30048] CHIP:CTL: Received ConnectNetwork response, networkingStatus=0
    [1694055312.291813][30046:30048] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkEnable'
    [1694055312.291836][30046:30048] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkEnable' -> 'FindOperational'
    [1694055312.291862][30046:30048] CHIP:CTL: Performing next commissioning step 'FindOperational'
    [1694055312.291882][30046:30048] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
    [1694055312.291904][30046:30048] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1694055312.291941][30046:30048] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    [1694055312.291970][30046:30048] CHIP:DIS: Resolving E6F06EAE27CA3AAD:0000000000000001 ...
    [1694055312.293632][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055312.492172][30046:30048] CHIP:DIS: Checking node lookup status after 200 ms
    [1694055314.594185][30046:30048] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:154: CHIP Error 0x00000032: Timeout
    [1694055314.746478][30046:30048] CHIP:DL: Avahi resolve found
    [1694055314.746560][30046:30048] CHIP:DIS: Node ID resolved for E6F06EAE27CA3AAD:0000000000000001
    [1694055314.746593][30046:30048] CHIP:DIS:     Hostname: B2900DF27857DC1A
    [1694055314.746621][30046:30048] CHIP:DIS:     IP Address #1: fd11:22::869f:b360:f73c:e91a
    [1694055314.746641][30046:30048] CHIP:DIS:     Port: 5540
    [1694055314.746660][30046:30048] CHIP:DIS:     Mrp Interval idle: 1000 ms
    [1694055314.746678][30046:30048] CHIP:DIS:     Mrp Interval active: 1000 ms
    [1694055314.746701][30046:30048] CHIP:DIS:     TCP Supported: 0
    [1694055314.747082][30046:30048] CHIP:DIS: Lookup clearing interface for non LL address
    [1694055314.747249][30046:30048] CHIP:DIS: UDP:[fd11:22::869f:b360:f73c:e91a%wlp5s0]:5540: new best score: 4
    [1694055314.747277][30046:30048] CHIP:DIS: Checking node lookup status after 2455 ms
    [1694055314.747327][30046:30048] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd11:22::869f:b360:f73c:e91a]:5540 while in state 2
    [1694055314.747352][30046:30048] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    [1694055314.747430][30046:30048] CHIP:IN: SecureSession[0x7fba4c020bb0]: Allocated Type:2 LSID:28754
    [1694055314.747472][30046:30048] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
    [1694055314.762355][30046:30048] CHIP:EM: <<< [E:3668i S:0 M:112192128] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1694055314.762475][30046:30048] CHIP:IN: (U) Sending msg 112192128 to IP address 'UDP:[fd11:22::869f:b360:f73c:e91a]:5540'
    [1694055314.762777][30046:30048] CHIP:SC: Sent Sigma1 msg
    [1694055314.762820][30046:30048] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    [1694055314.840963][30046:30048] CHIP:EM: >>> [E:3668i S:0 M:199762178 (Ack:112192128)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1694055314.841007][30046:30048] CHIP:EM: Found matching exchange: 3668i, Delegate: 0x7fba4c020928
    [1694055314.841038][30046:30048] CHIP:EM: Rxd Ack; Removing MessageCounter:112192128 from Retrans Table on exchange 3668i
    [1694055314.853039][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1694055315.115067][30046:30048] CHIP:EM: >>> [E:3668i S:0 M:199762179 (Ack:112192128)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    [1694055315.115094][30046:30048] CHIP:EM: Found matching exchange: 3668i, Delegate: 0x7fba4c020928
    [1694055315.115105][30046:30048] CHIP:EM: CHIP MessageCounter:112192128 not in RetransTable on exchange 3668i
    [1694055315.115125][30046:30048] CHIP:SC: Received Sigma2 msg
    [1694055315.115140][30046:30048] CHIP:SC: Peer assigned session session ID 6458
    [1694055315.164104][30046:30048] CHIP:SC: Found MRP parameters in the message
    [1694055315.164125][30046:30048] CHIP:SC: Sending Sigma3
    [1694055315.168782][30046:30048] CHIP:EM: <<< [E:3668i S:0 M:112192129 (Ack:199762179)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    [1694055315.168838][30046:30048] CHIP:IN: (U) Sending msg 112192129 to IP address 'UDP:[fd11:22::869f:b360:f73c:e91a%wlp5s0]:5540'
    [1694055315.168921][30046:30048] CHIP:SC: Sent Sigma3 msg
    [1694055315.255509][30046:30048] CHIP:EM: >>> [E:3668i S:0 M:199762180 (Ack:112192129)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1694055315.255559][30046:30048] CHIP:EM: Found matching exchange: 3668i, Delegate: 0x7fba4c020928
    [1694055315.255601][30046:30048] CHIP:EM: Rxd Ack; Removing MessageCounter:112192129 from Retrans Table on exchange 3668i
    [1694055315.666590][30046:30048] CHIP:EM: >>> [E:3668i S:0 M:199762181 (Ack:112192129)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1694055315.666648][30046:30048] CHIP:EM: Found matching exchange: 3668i, Delegate: 0x7fba4c020928
    [1694055315.666680][30046:30048] CHIP:EM: CHIP MessageCounter:112192129 not in RetransTable on exchange 3668i
    [1694055315.666745][30046:30048] CHIP:SC: Success status report received. Session was established
    [1694055315.669230][30046:30048] CHIP:SC: SecureSession[0x7fba4c020bb0]: Moving from state 'kEstablishing' --> 'kActive'
    [1694055315.669264][30046:30048] CHIP:IN: SecureSession[0x7fba4c020bb0]: Activated - Type:2 LSID:28754
    [1694055315.669294][30046:30048] CHIP:IN: New secure session activated for device <0000000000000001, 1>, LSID:28754 PSID:6458!
    [1694055315.669331][30046:30048] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 5
    [1694055315.669401][30046:30048] CHIP:CTL: Successfully finished commissioning step 'FindOperational'
    [1694055315.669425][30046:30048] CHIP:CTL: Commissioning stage next step: 'FindOperational' -> 'SendComplete'
    [1694055315.669465][30046:30048] CHIP:CTL: Performing next commissioning step 'SendComplete'
    [1694055315.669533][30046:30048] CHIP:DMG: ICR moving to [AddingComm]
    [1694055315.669562][30046:30048] CHIP:DMG: ICR moving to [AddedComma]
    [1694055315.669690][30046:30048] CHIP:EM: <<< [E:3669i S:28754 M:196322203] (S) Msg TX to 1:0000000000000001 [3AAD] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1694055315.669742][30046:30048] CHIP:IN: (S) Sending msg 196322203 on secure session with LSID: 28754
    [1694055315.669899][30046:30048] CHIP:DMG: ICR moving to [CommandSen]
    [1694055315.669980][30046:30048] CHIP:EM: <<< [E:3668i S:0 M:112192130 (Ack:199762181)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1694055315.670088][30046:30048] CHIP:IN: (U) Sending msg 112192130 to IP address 'UDP:[fd11:22::869f:b360:f73c:e91a%wlp5s0]:5540'
    [1694055315.670180][30046:30048] CHIP:EM: Flushed pending ack for MessageCounter:199762181 on exchange 3668i
    [1694055316.076829][30046:30048] CHIP:EM: >>> [E:3669i S:28754 M:42402055 (Ack:196322203)] (S) Msg RX from 1:0000000000000001 [3AAD] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1694055316.076901][30046:30048] CHIP:EM: Found matching exchange: 3669i, Delegate: 0x7fba5404b198
    [1694055316.076959][30046:30048] CHIP:EM: Rxd Ack; Removing MessageCounter:196322203 from Retrans Table on exchange 3669i
    [1694055316.077012][30046:30048] CHIP:DMG: ICR moving to [ResponseRe]
    [1694055316.077080][30046:30048] CHIP:DMG: InvokeResponseMessage =
    [1694055316.077116][30046:30048] CHIP:DMG: {
    [1694055316.077146][30046:30048] CHIP:DMG:     suppressResponse = false,
    [1694055316.077167][30046:30048] CHIP:DMG:     InvokeResponseIBs =
    [1694055316.077208][30046:30048] CHIP:DMG:     [
    [1694055316.077241][30046:30048] CHIP:DMG:         InvokeResponseIB =
    [1694055316.077285][30046:30048] CHIP:DMG:         {
    [1694055316.077316][30046:30048] CHIP:DMG:             CommandDataIB =
    [1694055316.077351][30046:30048] CHIP:DMG:             {
    [1694055316.077384][30046:30048] CHIP:DMG:                 CommandPathIB =
    [1694055316.077417][30046:30048] CHIP:DMG:                 {
    [1694055316.077456][30046:30048] CHIP:DMG:                     EndpointId = 0x0,
    [1694055316.077495][30046:30048] CHIP:DMG:                     ClusterId = 0x30,
    [1694055316.077543][30046:30048] CHIP:DMG:                     CommandId = 0x5,
    [1694055316.077579][30046:30048] CHIP:DMG:                 },
    [1694055316.077641][30046:30048] CHIP:DMG:
    [1694055316.077677][30046:30048] CHIP:DMG:                 CommandFields =
    [1694055316.077715][30046:30048] CHIP:DMG:                 {
    [1694055316.077756][30046:30048] CHIP:DMG:                     0x0 = 0,
    [1694055316.077797][30046:30048] CHIP:DMG:                     0x1 = "" (0 chars),
    [1694055316.077837][30046:30048] CHIP:DMG:                 },
    [1694055316.077873][30046:30048] CHIP:DMG:             },
    [1694055316.077916][30046:30048] CHIP:DMG:
    [1694055316.077947][30046:30048] CHIP:DMG:         },
    [1694055316.077988][30046:30048] CHIP:DMG:
    [1694055316.078012][30046:30048] CHIP:DMG:     ],
    [1694055316.078059][30046:30048] CHIP:DMG:
    [1694055316.078093][30046:30048] CHIP:DMG:     InteractionModelRevision = 1
    [1694055316.078122][30046:30048] CHIP:DMG: },
    [1694055316.078252][30046:30048] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0005
    [1694055316.078319][30046:30048] CHIP:CTL: Received CommissioningComplete response, errorCode=0
    [1694055316.078376][30046:30048] CHIP:CTL: Successfully finished commissioning step 'SendComplete'
    [1694055316.078408][30046:30048] CHIP:CTL: Commissioning stage next step: 'SendComplete' -> 'Cleanup'
    [1694055316.078456][30046:30048] CHIP:CTL: Performing next commissioning step 'Cleanup'
    [1694055316.078490][30046:30048] CHIP:DIS: Closing all BLE connections
    [1694055316.078525][30046:30048] CHIP:IN: Clearing BLE pending packets.
    [1694055316.079041][30046:30048] CHIP:BLE: Auto-closing end point's BLE connection.
    [1694055316.079087][30046:30048] CHIP:DL: Closing BLE GATT connection (con 0x7fba540481d0)
    [1694055316.079213][30046:30047] CHIP:DL: BluezDisconnect peer=EE:05:FD:CE:F6:42
    [1694055316.121599][30046:30048] CHIP:IN: SecureSession[0x7fba4c010d00]: MarkForEviction Type:1 LSID:28753
    [1694055316.121655][30046:30048] CHIP:SC: SecureSession[0x7fba4c010d00]: Moving from state 'kActive' --> 'kPendingEviction'
    [1694055316.121705][30046:30048] CHIP:IN: SecureSession[0x7fba4c010d00]: Released - Type:1 LSID:28753
    [1694055316.121749][30046:30048] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
    [1694055316.121782][30046:30048] CHIP:TOO: Device commissioning completed with success
    [1694055316.121918][30046:30048] CHIP:DMG: ICR moving to [AwaitingDe]
    [1694055316.122026][30046:30048] CHIP:EM: <<< [E:3669i S:28754 M:196322204 (Ack:42402055)] (S) Msg TX to 1:0000000000000001 [3AAD] --- Type 0000:10 (SecureChannel:StandaloneAck)
    [1694055316.122097][30046:30048] CHIP:IN: (S) Sending msg 196322204 on secure session with LSID: 28754
    [1694055316.122290][30046:30048] CHIP:EM: Flushed pending ack for MessageCounter:42402055 on exchange 3669i
    [1694055316.122347][30046:30048] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
    [1694055316.122387][30046:30048] CHIP:BLE: no endpoint for unsub complete
    [1694055316.122972][30046:30046] CHIP:CTL: Shutting down the commissioner
    [1694055316.123025][30046:30046] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1694055316.123059][30046:30046] CHIP:CTL: Shutting down the controller
    [1694055316.123088][30046:30046] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1694055316.123111][30046:30046] CHIP:IN: SecureSession[0x7fba4c020bb0]: MarkForEviction Type:2 LSID:28754
    [1694055316.123141][30046:30046] CHIP:SC: SecureSession[0x7fba4c020bb0]: Moving from state 'kActive' --> 'kPendingEviction'
    [1694055316.123165][30046:30046] CHIP:IN: SecureSession[0x7fba4c020bb0]: Released - Type:2 LSID:28754
    [1694055316.123201][30046:30046] CHIP:FP: Forgetting fabric 0x1
    [1694055316.123239][30046:30046] CHIP:TS: Pending Last Known Good Time: 2023-07-11T07:53:58
    [1694055316.123497][30046:30046] CHIP:TS: Previous Last Known Good Time: 2023-07-11T07:53:58
    [1694055316.123536][30046:30046] CHIP:TS: Reverted Last Known Good Time to previous value
    [1694055316.123582][30046:30046] CHIP:CTL: Shutting down the commissioner
    [1694055316.123609][30046:30046] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1694055316.123635][30046:30046] CHIP:CTL: Shutting down the controller
    [1694055316.123658][30046:30046] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1694055316.124061][30046:30047] CHIP:DL: Bluez disconnected
    [1694055316.124107][30046:30047] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
    [1694055316.125394][30046:30046] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1694055316.125513][30046:30046] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1694055316.125581][30046:30046] CHIP:FP: Shutting down FabricTable
    [1694055316.125613][30046:30046] CHIP:TS: Pending Last Known Good Time: 2023-07-11T07:53:58
    [1694055316.125811][30046:30046] CHIP:TS: Previous Last Known Good Time: 2023-07-11T07:53:58
    [1694055316.125834][30046:30046] CHIP:TS: Reverted Last Known Good Time to previous value
    [1694055316.126108][30046:30046] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-qwZs97)
    [1694055316.126728][30046:30046] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1694055316.126786][30046:30046] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1694055316.126815][30046:30046] CHIP:DL: Inet Layer shutdown
    [1694055316.126837][30046:30046] CHIP:DL: BLE shutdown
    [1694055316.128501][30046:30046] CHIP:DL: System Layer shutdown
