How to access the OTP(program security register 42h) in windbond flash ?
Hi
I have to access the OTP memory in winbond (W25Q128JW) NOR flash. Whenever i try access the program security register (42h), data is not written in the memory. I am using QUAD SPI protocol to communicate with flash. I use the nordic QSPI library. The General page write and read works fine whenever I try to access the OTP it will be no results.
Here I work with function
nrf_drv_qspi_cinstr_xfer to write and read commands. I attached the code for your reference.
1. How to access the security register in nrf52840?
2.Which function is to be used to get the output from the flash using qspi?
Thanks & Regards
Sriyogesh G
 * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup qspi_example_main main.c
 * @ingroup qspi_example
 * @brief QSPI Example Application main file.
 * This file contains the source code for a sample application using QSPI.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "nrf_drv_qspi.h"
#include "nrf_delay.h"
#include "app_error.h"
#include "boards.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "sdk_config.h"
#include "SEGGER_RTT.h"
#include "SEGGER_RTT_Conf.h"
#define QSPI_STD_CMD_WRSR   0x1
#define QSPI_STD_CMD_WRSR2   0x31
#define QSPI_STD_CMD_WRSR3   0x11
#define QSPI_STD_CMD_RSTEN  0x66
#define QSPI_STD_CMD_RST    0x99
#define WRITE_ENABLE        0x06
#define STATUS_REG1        0x05
#define READ_STATUS         0x35
#define READ_STATUS1         0x05
#define READ_STATUS3         0x15
#define SENDAA      0xAA
#define SEND55      0x55
#define MANUFATURER_ID      0x94
#define FLASH_CMD_READ_SECURITY_REG 0x48
#define FLASH_CMD_PROGRAM_SECURITY_REG 0x42
#define FLASH_CMD_ERASE_SECURITY_REG 0x44
#define READ_JDEC     0x9F
#define DEVICE_ADDRESS 0x002000
#define DEVICE_ADDRESS_READ 0x002000
void readStatusRegister(void);
#define QSPI_TEST_DATA_SIZE 256
#define DATA_MINIMUM        20
#define WAIT_FOR_PERIPH() do { \
        while (!m_finished) {} \
        m_finished = false;    \
    } while (0)
uint8_t initDeviceName[]={0x42,0x00,0x20,0x00,0X4E, 0X49, 0X56, 0X49};
uint8_t senddata[]={0x48,0x00,0x20,0x00,0xFF};
uint8_t deviceName[10]={0,0,0,0,0,0,0,0,0,0};
uint8_t sendBuffer[13];
uint32_t addree=0x002000;
uint8_t dummybyte[]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
static volatile bool m_finished = false;
static void qspi_handler(nrf_drv_qspi_evt_t event, void * p_context)
    UNUSED_PARAMETER(event);
    UNUSED_PARAMETER(p_context);
    m_finished = true;
     SEGGER_RTT_printf(0,"QSPI handler\r\n");
void otpEnable(void)
          uint32_t err_code;
          uint8_t send80=0x80;
        //   uint8_t status1;
          uint8_t sent55=0x55;
    nrf_qspi_cinstr_conf_t cinstr_cfg = {
        .opcode    =SENDAA,//AAh
        .length    = NRF_QSPI_CINSTR_LEN_2B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = false
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, &sent55, NULL);
    cinstr_cfg.opcode=QSPI_STD_CMD_WRSR;//01h
    cinstr_cfg.wren      = true;
    nrf_gpio_pin_clear( NRF_GPIO_PIN_MAP(0,16));
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, &send80, NULL);
        nrf_gpio_pin_set( NRF_GPIO_PIN_MAP(0,16));
void newwrite()
        uint32_t err_code;
        .opcode    =FLASH_CMD_PROGRAM_SECURITY_REG,
        .length    = NRF_QSPI_CINSTR_LEN_1B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = true
        m_finished = false;
        err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
    SEGGER_RTT_printf(0,"newwrite--%d",err_code);
    err_code = nrf_drv_qspi_write(&initDeviceName[0], 1, addree);
            SEGGER_RTT_printf(0,"newwrite--%d--%c\n",err_code,initDeviceName[0]);
void newRead()
        uint32_t err_code;
        uint8_t name=0;
        .opcode    =FLASH_CMD_READ_SECURITY_REG,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = false
            SEGGER_RTT_printf(0,"newread--%d",err_code);
    err_code = nrf_drv_qspi_read(&name, 1, addree);
            SEGGER_RTT_printf(0,"newread--%d--%X\n",err_code,name);
void flashwrite(void)
    ret_code_t err_code;
 m_finished = false;
        err_code = nrf_drv_qspi_write(&initDeviceName[0], 12, DEVICE_ADDRESS);
            WAIT_FOR_PERIPH();
                            readStatusRegister();
            SEGGER_RTT_printf(0,"device-%s-%d\n",initDeviceName,err_code);
void flashread(void)
     m_finished = false;
        err_code = nrf_drv_qspi_read(&deviceName[0], 12, DEVICE_ADDRESS);
    WAIT_FOR_PERIPH();
            SEGGER_RTT_printf(0,"device-%s-%c\n",deviceName,deviceName[0]);
            for(int i=0;i<10;i++)
                            SEGGER_RTT_printf(0,"%c",deviceName[i]);
    uint8_t read=0,read1=0,read2=0;
    uint32_t err_code;
        .opcode    = READ_STATUS,
        .length    = QSPI_CINSTRCONF_LENGTH_2B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = false
        err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, &read);
    cinstr_cfg.opcode=READ_STATUS1;
            err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, &read1);
        cinstr_cfg.opcode=READ_STATUS3;
            err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, &read2);
    // for(int i=0;i<3;i++)
        SEGGER_RTT_printf(0,"StatusRead-%X-%x-%X\n",read2,read,read1);
void writeEnableData(void)
            uint32_t err_code;
        .opcode    = WRITE_ENABLE,
        .length    = QSPI_CINSTRCONF_LENGTH_1B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = false
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL,NULL);
            nrf_delay_ms(100);
void ProgramSecurityRegister()
        uint32_t err_code;
    //     m_finished = false;
        uint8_t storeAddress[6];
        storeAddress[0]=0x00;
        storeAddress[1]=0x10;
        storeAddress[2]=0x01;
        storeAddress[4]=0x34;
        .opcode    = FLASH_CMD_PROGRAM_SECURITY_REG,
        .length    = QSPI_CINSTRCONF_LENGTH_5B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = true
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg,&storeAddress[0], NULL);
        //  nrf_delay_ms(100);
void ReadSecurityRegister()
            uint32_t err_code;
        uint8_t storeAddress[5];
        storeAddress[3]=0xFF;
    //     // uint8_t rxdata[4]={0,0,0,0};
        .opcode    = FLASH_CMD_READ_SECURITY_REG,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = false
        //    err_code= nrfx_qspi_lfm_start(&cinstr_cfg);
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg,&storeAddress[0],&deviceName[0]);
    for(int i=0;i<sizeof(deviceName);i++)
    SEGGER_RTT_printf(0,"device-%x\n",deviceName[i]);
void FlashOtpErase(void)
        m_finished = false;
         uint8_t address[4];
        .opcode    = FLASH_CMD_ERASE_SECURITY_REG,
        .length    = NRF_QSPI_CINSTR_LEN_4B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = true
    address[0]=0x00;
    address[1]=0x10;
    address[2]=0x01;
     err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, &address[0], NULL);
     SEGGER_RTT_printf(0,"errorcodeflasherase-%X",err_code);
void readJdec(void)
    uint32_t err_code;
    uint8_t read[4];
        .opcode    = READ_JDEC,
        .io2_level = false,
        .io3_level = false,
        .wipwait   = false,
        .wren      = false
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, &read[0]);
     SEGGER_RTT_printf(0,"errorcodeflasherase-%X\n",err_code);
     for(int i =0;i<4;i++)
             SEGGER_RTT_printf(0,"jdec-%X",read[i]);
void readuniqueid(void)
    uint32_t err_code;
    uint8_t readone[8];
        uint8_t sent[4]={0,0,0,0};
        .length    = NRF_QSPI_CINSTR_LEN_8B,
        .io2_level = false,
        .io3_level = false,
        .wipwait   = false,
        .wren      = false
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, &sent[0], &readone[0]);
     for(int i =0;i<8;i++)
             SEGGER_RTT_printf(0,"ubique-%X",readone[i]);
    // uint32_t i;
    uint32_t err_code;
    err_code = NRF_LOG_INIT(NULL);
    NRF_LOG_INFO(""
                 "QSPI write and read example using 24bit addressing mode");
        nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(0,16));
    nrf_drv_qspi_config_t config =
        .xip_offset = 0,
        .pins =
              .sck_pin = NRF_GPIO_PIN_MAP(0,19),
              .csn_pin = NRF_GPIO_PIN_MAP(0,16),
              .io0_pin = NRF_GPIO_PIN_MAP(0,14),
              .io1_pin = NRF_GPIO_PIN_MAP(0,23),
              .io2_pin = NRF_GPIO_PIN_MAP(1,15),
              .io3_pin = NRF_GPIO_PIN_MAP(0,13),
        .prot_if =
                  .readoc = NRF_QSPI_READOC_READ4O, // 0x6B read command
                  .writeoc = NRF_QSPI_WRITEOC_PP4O, // 0x32 write command
                  .addrmode = NRF_QSPI_ADDRMODE_24BIT,
                  .dpmconfig = false
        .phy_if =
              .sck_delay = 100,
              .dpmen = false,
              .spi_mode = NRF_QSPI_MODE_0,
              .sck_freq = NRF_QSPI_FREQ_32MDIV4, // start with low 2 Mhz speed
        .irq_priority = 3
    err_code = nrf_drv_qspi_init(&config, qspi_handler, NULL);
    NRF_LOG_INFO("QSPI example started.");
    SEGGER_RTT_printf(0,"QSPI Started\r\n");
        readJdec();
    ProgramSecurityRegister();
        ReadSecurityRegister();
while(1)
