nrf_modem_lib_init timeout
Hi
I am working on a custom board and have hit an issue with the software part. When the nrf_modem_lib_init function is invoked, it always ends with a timeout (errno -116). Same code works with the dev kit (nrf9160dk).  Are there any common pitfalls, that could causes this issue?
Best Regards
Casper Mogensen
  • Hi again
    Little follow up, it turned out to be a hardware issue. I soldered a new device to my board and now everything works.
    Best regards
    Casper Mogensen
  • Hi Casper, thanks for informing!
    Øyvind
  • Did you happen to find out what was the hardware issue?
    We see this behaviour on 3 out of 20 prototypes of a revised product (custom PCB). See below the log trace produced by attached code (calling nrf_modem_lib_init):
       5426 1731337418.120 1 rx *** Booting MCUboot v2.1.0-dev-daf2946a0f07 ***
       5427 1731337418.120 1 rx *** Using nRF Connect SDK v2.7.0-5cb85570ca43 ***
       5428 1731337418.123 1 rx *** Using Zephyr OS v3.6.99-100befc70c74 ***
       5429 1731337418.124 1 rx I: Starting bootloader
       5430 1731337418.124 1 rx I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
       5431 1731337418.124 x tt 1731337418.124  2024-11-11T16:03:38.123639
       5432 1731337418.124 1 rx I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
       5433 1731337418.124 1 rx I: Boot source: none
       5434 1731337418.125 1 rx I: Image index: 0, Swap type: none
       5435 1731337418.125 1 rx I: Bootloader chainload address offset: 0x10000
       5436 1731337418.712 1 rx I: Jumping to the first image slot
    *** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
       5437 1731337418.713 1 rx *** Using Zephyr OS v3.6.99-100befc70c74 ***
       5438 1731337418.713 1 rx [00:00:00.254,882] <wrn> net_config: No auto-started network interface - network-bound app initialization skipped.
       5439 1731337418.713 1 rx Hello, world
       5440 1731337418.713 1 rx 0
       5441 1731337420.715 1 rx 1
       5442 1731337420.715 1 rx 2
       5443 1731337422.715 1 rx 3
       5444 1731337422.715 1 rx 4
       5445 1731337422.718 0 dp COM23 30:30:F9:BC:BA:40
       5446 1731337422.718 0 op
       5447 1731337424.721 1 rx 5
       5448 1731337424.721 1 rx 6
       5449 1731337426.712 1 rx 7
       5450 1731337426.712 1 rx 8
       5451 1731337428.124 x tt 1731337428.124  2024-11-11T16:03:48.123912
       5452 1731337428.716 1 rx 9
       5453 1731337428.716 1 rx [00:00:10.256,896] <inf> nrf_modem: Initializing libmodem 2.7.0-cellular-28f48961a8dc
       5454 1731337428.719 1 rx [00:00:10.257,324] <dbg> nrf_modem: Control region at 0x20008000 (0x4e8 bytes)
       5455 1731337428.720 1 rx [00:00:10.257,385] <dbg> nrf_modem: TX region at 0x200084e8 (0x2000 bytes)
       5456 1731337428.720 1 rx [00:00:10.257,415] <dbg> nrf_modem: RX region at 0x2000a568 (0x2000 bytes)
       5457 1731337428.720 1 rx [00:00:10.257,446] <dbg> nrf_modem: Trace region at 0x2000c568 (0x4000 bytes)
       5458 1731337429.916 1 rx [00:00:10.434,265] <dbg> nrf_modem: IPC trace ready
       5459 1731337438.224 x tt 1731337438.224  2024-11-11T16:03:58.224192
       5460 1731337448.312 x tt 1731337448.312  2024-11-11T16:04:08.312444
       5461 1731337458.424 x tt 1731337458.424  2024-11-11T16:04:18.423607
       5462 1731337468.521 x tt 1731337468.521  2024-11-11T16:04:28.521142
       5463 1731337478.615 x tt 1731337478.615  2024-11-11T16:04:38.614545
       5464 1731337488.615 x tt 1731337488.615  2024-11-11T16:04:48.615181
       5465 1731337498.626 x tt 1731337498.626  2024-11-11T16:04:58.625960
       5466 1731337508.627 x tt 1731337508.627  2024-11-11T16:05:08.626704
       5467 1731337518.715 x tt 1731337518.715  2024-11-11T16:05:18.715142
       5468 1731337528.725 x tt 1731337528.725  2024-11-11T16:05:28.725108
       5469 1731337538.817 x tt 1731337538.817  2024-11-11T16:05:38.817073
       5470 1731337548.924 x tt 1731337548.924  2024-11-11T16:05:48.923729
       5471 1731337558.925 x tt 1731337558.925  2024-11-11T16:05:58.924871
       5472 1731337569.026 x tt 1731337569.026  2024-11-11T16:06:09.026002
       5473 1731337578.811 1 rx main: err=-116
       5474 1731337578.812 1 rx [00:02:40.258,056] <dbg> nrf_modem: Power off
       5475 1731337578.814 1 rx [00:02:40.258,117] <err> nrf_modem: Modem library initialization failed, err -116
       5476 1731337578.815 1 rx trace_backend_init
       5477 1731337578.815 1 rx [00:02:40.258,148] <inf> nrf_modem_lib_trace: Trace thread ready
       5478 1731337578.815 1 rx [00:02:40.258,178] <err> nrf_modem_lib_trace: Failed to set trace level, err: -1
       5479 1731337578.815 1 rx [00:02:40.258,178] <inf> nrf_modem_lib_trace: Trace level override: 2
       5480 1731337578.816 1 rx [00:02:40.258,209] <err> nrf_modem_lib_trace: Failed to start tracing, err -8
       5481 1731337578.816 1 rx [00:02:40.258,209] <err> nrf_modem: Unable to obtain modem FW version (ERR: -16711681, ERR TYPE: 255)
       5482 1731337578.816 1 rx [00:02:40.258,239] <err> nrf_modem: Unable to obtain modem FW UUID (ERR: -16711681, ERR TYPE: 255)
       5483 1731337578.817 1 rx
       5484 1731337578.817 1 rx [00:02:40.258,270] <dbg> nrf_modem: nrf_modem_lib_init: Modem init callback: 0x24f91
       5485 1731337578.817 1 rx [00:02:40.258,300] <dbg> nrf_modem: nrf_modem_lib_init: Modem init callback: 0x2619d
       5486 1731337578.817 1 rx [00:02:40.258,300] <dbg> nrf_modem: nrf_modem_lib_init: Modem init callback: 0x32717
       5487 1731337578.817 1 rx zzz
       5488 1731337578.818 1 rx trace_backend_write len=5 efbe300063
       5489 1731337578.818 1 rx trace_backend_write len=48 b007b007b007b007b007b007b007b0070404180003000000010000006000000000800000ffffffff0000000000000000
       5490 1731337578.818 1 rx [00:02:40.260,101] <inf> nrf_modem_lib_trace: Modem was turned off, no more traces
       5491 1731337578.818 x tt 1731337578.818  2024-11-11T16:06:18.817976
       5492 1731337578.818 1 rx trace_backend_deinit
       5493 1731337580.712 1 rx zzz
    #include <arpa/inet.h>
    #include <stdio.h>
    #include <string.h>
    #include <zephyr/kernel.h>
    #include <zephyr/drivers/clock_control.h>
    #include <zephyr/drivers/clock_control/nrf_clock_control.h>
    #include <nrf_modem.h>
    #include <modem/nrf_modem_lib.h>
    #include <modem/nrf_modem_lib_trace.h>
    #include <modem/trace_backend.h>
    /* To strictly comply with UART timing, enable external XTAL oscillator */
    static void enable_xtal(void)
        struct onoff_manager *clk_mgr;
        static struct onoff_client cli = {};
        clk_mgr = z_nrf_clock_control_get_onoff(CLOCK_CONTROL_NRF_SUBSYS_HF);
        sys_notify_init_spinwait(&cli.notify);
        (void)onoff_request(clk_mgr, &cli);
    static trace_backend_processed_cb trace_processed_callback;
    int trace_backend_init(trace_backend_processed_cb processed)
        /* initialize transport backend here */
        printk("%s\n", __func__);
        trace_processed_callback = processed;
        return 0;
    int trace_backend_deinit(void)
        /* optional deinitialization code here */
        return 0;
    static void dump_buffer(const void *buf, uint32_t length)
        for (uint32_t i = 0; i < length; ) {
            if (!((int)buf & 0x3) && length - i >= 8) {
                printk("%08x%08x", htonl(*((const uint32_t *)(const void *)((const uint8_t *)buf + i))), htonl(*((const uint32_t *)(const void *)((const uint8_t *)buf + i + 4))));
                i += 8;
            } else {
                printk("%02x", *((uint8_t *)buf + i));
                i++;
    int trace_backend_write(const void *data, size_t len)
        printk("%s len=%d ", __func__, len);
        dump_buffer(data, len);
        printk("\n");
        int r = len;
        int err = trace_processed_callback(r);
        if (err) {
            printk("%s err=%d\n", __func__, err);
            return err;
        return r;
    struct nrf_modem_lib_trace_backend trace_backend = {
       .init = trace_backend_init,
       .deinit = trace_backend_deinit,
       .write = trace_backend_write,
       .data_size = NULL,
       .read = NULL,
       .clear = NULL,
    void nrf_modem_fault_handler(struct nrf_modem_fault_info *fault_info)
        printk(":<Mfh t=%u reason=%u pc=%08x\n", k_uptime_get_32(), fault_info->reason, fault_info->program_counter);
     * Application entry point: initialization and main loop.
    void main(void)
        enable_xtal();
        printk("Hello, world\n");
        uint32_t i;
        for (i = 0; i < 10; i++) {
            printk("%d\n", i);
            k_sleep(K_MSEC(1000));
        int err = nrf_modem_lib_init();
        printf("main: err=%d\n", err);
        while (1) {
            printk("zzz\n");
    /* End */
    I have not found any abnormal voltages on the board. Visually there is no indication of any problem.
    Product: nRF9160-SICA-B1 (Device identified as NRF9160_xxAA_REV2)
    The SDK version was v2.3.0 at the time of first testing, now it is updated to v2.7.0.
    The modem core FW version is v1.3.6. I tried downgrading to v1.3.5, v1.3.3 and v1.2.1. Applying firmware updates still works as for old PCBs (for some reason, after updating pynrfjprog I do have to pass reset=HighLevel.ResetAction.RESET_PIN or RESET_DEBUG to bypass error -90 NOT_AVAILABLE_BECAUSE_PROTECTION).
    We noticed the affected devices in this series all have the same production mark (2227RY), but so do the devices that work normally.
    I think there is either a hardware issue, or the modem core has reached a nonfunctioning state.
    Is there any way to trigger a factory reset before the modem library is initialized?
    Any suggestions on how to troubleshoot further?
    Kind regards, Hermen
  • Hi
    I just exchanged the nRF9160 on my board and that fixed it. Don't know if the actual problem was a bad chip or soldering
    Best Regards
    Casper
