NCS disconnect with reason 0x08 connection timeout when using bluetooth peripheral uart application
We are using  NCS NRF connect SDK 2.4 with bluetooth peripheral uart sample application.
We see sometimes disconnect call back is called with reason 0x08. After this device is not broadcasting.
Could you please clarify the below.
1: Reason for this disconnect call back callled, is this because of local host or remote host?.
2: Is there anyway we can increase the connection time out value?.
3: What action needs to be done to make sure device broadcasts the manufacturing data in this scenario?.
    The error code 0x08 is Connection Timeout Error code. This indicates that either the link supervision timeout has expired for a given connection or that the synchronization timeout has expired for a given broadcast.
    You can set the supervision time by using config option: CONFIG_BT_PERIPHERAL_PREF_TIMEOUT
    You can restart advertising when disconnection happens.
    BR
  • Thanks for the reply.  How do we make sure the synchronization timeout not to expire?.
    Also what API needs to be called to stop broadcasting the advertising packet. We are using the sample bluetooth peripheral application.
    Apologies for delayed response.
    The synchronization timeout is a feature of extended periodic advertisement.
    Regarding the advertising, you can use:
    bt_le_adv_stop() and bt_le_adv_start() from bluetooth API.
    BR, Naeem
  • Thanks for the response. I am using bt_le_adv_stop()() before the advertisement start.  After setting the below connection parameters in the example sample perupheral_uart code, we are still seeing the connection timeout with error code 8.
    # Use connection parameters that ensure quick data transfer
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=6
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=6
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=99
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400
    This is seen in the remote host as well. Looks like remote host is using IOS app and unable to set this supervision timeout.
    1: Is there anyway that remote host central (IOS based mobile app) can request for these parameters and we can send the same by sending through GATT server. If we do this can you share the example code that I can refer to implement the GATT connection in the peripheral.
     2: Is this connection timeout caused because of the remote host central (scanner mobile app) not set for the supervision timeout?
  • Hi
    Naeem asked me to take over this case as he's currently otherwise engaged.
    You say you're still seeing a connection timeout, after how long do you see this timeout error occur? The preferred timeout you've set is 4 seconds (400 * 10 ms), so if this timeout is used, the timeout will occur of ~4 seconds after a connection. If you set the CONFIG_BT_PERIPHERAL_PREF_TIMEOUT = 65535, that will represent no specific value.
    If you could provide a sniffer trace of what's happening on the air when connecting that might give us a better idea of what exactly is causing this issue here. You can use a dedicated BLE sniffer or a spare nRF52 DK and the nRF Sniffer in Wireshark to get a sniffer trace of the BLE connection.
    Simon
