I want to play a .wav audio file on nRF5340 audio dk.
I convert the wav file into raw data and store it in an array.
After that, I play it using nrfx_i2s_start, but the output sound is very noisy.
Here is my code:
uint8_t raw_data[] = {/*RAW DATA*/}
const int raw_size = sizeof(raw_data);
const nrfx_i2s_buffers_t i2s_buf = { .p_rx_buffer = (uint32_t *)raw_data,
.p_tx_buffer = (uint32_t *)raw_data};
nrfx_i2s_start(&i2s_buf, raw_size, 0);
The PCM raw data size is about 100000 bytes, I am not sure whether nrfx_i2s_start has a buffer size limit.
In addition, I found that the sound is worse if p_rx_buffer is set to NULL.
Since I only want to play once, I did not use nrfx_i2s_next_buffers_set to set the buffer for the next transmission.
I'm very confused about the process of I2S transmission now. If there are any suggestions, I would be very grateful.
