nRF ios Provision localElements Publish setting
I am using nrf provision ios library to write an iOS app for our ble mesh nrf based device.
I have everything working, but to publish from the phone to the device, the local node has to be configured. The localElements of the MeshNetworkManager are not loaded with after reloading the saved network info. This makes it so that I have to repopulate the localElements on app load every time.
This is slow because I have to send Config messages for all my elements to my local node (on phone). Is there any way to set the publish values of the local elements without having to publish a message to the phone? It seems like the node.publish() setting is not accessible, even for the local node.
  • Let me put it this way, why is the Model.delegate property a `let` instead of `var`?
    Whenever I start my app I feel like I should only have to run:
        func repopulateElements(_ network: MeshNetwork) {
            print("Repopulating local elements")
            guard let localNode = network.localProvisioner?.node else {
                print("Local node is nil")
                return
            self.meshNetworkManager.localElements = localNode.elements
            // Update delegate for existing local Elements and Models
            for element in self.meshNetworkManager.localElements {
                for model in element.models {
                    let delegate: ModelDelegate?
                    switch model.modelIdentifier {
                    case .genericLevelClientModelId:
                        delegate = GenericLevelClientDelegate(meshNetworkManager: self.meshNetworkManager)
                    case .genericOnOffClientModelId:
                        delegate = GenericOnOffClientDelegate(meshNetworkManager: self.meshNetworkManager)
                        delegate = nil
                    model.delegate = delegate
    Instead I have to run this code:
                return
            var rebuiltElements: [Element] = []
            func rebuildModel(models: [Model]) -> [Model] {
                var rebuiltModels: [Model] = []
                for model in models {
                        continue
                    let rebuiltModel = Model(sigModelId: model.modelIdentifier, delegate: delegate)
                    rebuiltModels.append(rebuiltModel)
                return rebuiltModels
            // First, rebuild all Elements and Models
            for element in localNode.elements {
                let rebuiltModels = rebuildModel(models: element.models)
                if !rebuiltModels.isEmpty {
                    // Assuming you can create a new Element with models
                    let rebuiltElement = Element(name: element.name, location: .first, models: rebuiltModels)
                    rebuiltElements.append(rebuiltElement)
            self.meshNetworkManager.localElements = rebuiltElements
            _ = self.meshNetworkManager.save()
            // Function to run setup sequentially
            func runSequentialSetup(for models: [Model], completion: @escaping () -> Void) {
                var remainingModels = models
                func nextSetup() {
                    guard !remainingModels.isEmpty else {
                        completion()
                        return
                    let model = remainingModels.removeFirst()
                    guard let publicationAddress = model.publish?.publicationAddress else {
                        print("ERROR: no publish object found for model \(model.modelIdentifier)")
                        nextSetup() // Continue with the next model setup
                        return
                    print("Running setup for model \(model.modelIdentifier)")
                    let setup = GenericModelLocalClientSetup(
                        model: model,
                        publicationAddress: publicationAddress,
                        onSetupComplete: {
                            nextSetup() // Continue with the next model setup when this one is complete
                        manager: self.meshNetworkManager
                    self.storedDelegate = setup
                    self.meshNetworkManager.delegate = setup
                    setup.startSetup()
                nextSetup()
            // Run setup sequentially for each Element
            var remainingElements = rebuiltElements
            func runSetupForNextElement() {
                guard !remainingElements.isEmpty else {
                    print("Local Models/Elements rebuilt and setup")
                    return
                let element = remainingElements.removeFirst()
                runSequentialSetup(for: element.models) {
    class GenericModelLocalClientSetup: MeshNetworkDelegate {
        var onSetupComplete: (() -> Void)?
        private var address: MeshAddress
        private var model: Model
        private var manager: MeshNetworkManager
        init(model: Model, publicationAddress: MeshAddress, onSetupComplete: @escaping () -> Void, manager: MeshNetworkManager) {
            self.address = publicationAddress
            self.model = model
            self.onSetupComplete = onSetupComplete
            self.manager = manager
        func startSetup() {
            // NEED TO ADD THE MODEL TO THE PARENT ELEMENT BEFORE SENDING THESE
            let bind = ConfigModelAppBind(applicationKey: manager.meshNetwork!.applicationKeys.first!, to: model)!
            try! manager.sendToLocalNode(bind)
        func meshNetworkManager(_ manager: MeshNetworkManager,
                                didReceiveMessage message: MeshMessage,
                                sentFrom source: Address,
                                to destination: Address) {
            print("Generic Model Setup received message: " + String(message.opCode) + " ModelId " + String(self.model.modelId))
            switch message {
            case _  as ConfigModelAppStatus:
                let publicationMessage = ConfigModelPublicationSet(
                    Publish(
                        to: address,
                        using: manager.meshNetwork!.applicationKeys.first!,
                        usingFriendshipMaterial: false, ttl: 5,
                        period: .disabled,
                        retransmit: Publish.Retransmit(1, timesWithInterval: 0.2)
                    to: model)!
                try! manager.sendToLocalNode(publicationMessage)
            case _ as ConfigModelPublicationStatus:
                print("Completed local client model setup! ModelId " + String(self.model.modelId))
                onSetupComplete?()
                print("UNCHECKED MESSAGE")
            print(message)
                                failedToSendMessage message: MeshMessage,
                                from localElement: Element,
                                to destination: Address,
                                error: Error) {
            print("MESH NETWORK ERROR MESSAGE")
            print(message)
            print(error)
  • Hi.
    Forwarded your request to our mobile developers.
    Will get back to you when I receive some feedback from them.
    Br,
    Joakim
  • Hi.
    Sorry, I don't have anything for you yet. I'll ping our developers.
    Br,
    Joakim
