Toolchain Manager not downloading Zephyr completely and failing silently
The nrf toolchain manager seems to fail silently when installing the zephyr sdk on some machines (Ubuntu 22.04), and installs it only partially. First try to install: Zephyr folder was completely empty. Second try: We thought we finally have a good install (first projects worked), but for a specific sample project we figured out that some module folders were still empty, so the zephyr folder is still only partially installed. For example, the ncs/v2.4.2/modules/tee/tf-m/tf-m-tests folder is empty, and thus a new sample project from https://github.com/zephyrproject-rtos/zephyr/blob/main//samples/subsys/mgmt/mcumgr/smp_svr/README.rst failed to compile because it depends on this folder.
As I said, first time to try to install zephyr SDK with toolchain manager UI, the folder ncs/v2.4.2 stayed completely empty but the UI did not show any error message at all.
