board nrf52832 does not connect anymore
I am following the BLE accademy course and flashing an exercise, the exercise did not perform as requested.
I could not flash anymore.
I clear the board from the switch button and then could not connect the board anymore even I coud see it by the JLINK or nrfConnect or Teraterm.
I tried several version of JLINK without success.
I then made a power ON with the IfBoot pressed and the board now act strangely.
The board led flash every second for a while and is visible on the USB but then flash rapidly and disapear from the USB.
Reading manuals I do not understand what to upload here, what file, how...
Some manual indicate the use of nrfGo which is obsolete... I am completly lost.
Thank you for some hints to start again.
JLINK 780c
nRF Connect 4.2.0
    Given that one of the LEDs are turned on, it might indicate that there's firmware running on your device.
    You can try two other options:
    * Use J-Link Commander to recover the device
    * Use a batch script that runs "nrfjprog --recover -f nrf52" in a loop
    Here's a way to use J-Link Commander (search in the start meny for it):
    device NRF52
    si 1
    speed 1000
    connect
    Here's an example of how it should look when it has been successfully found
    Type "connect" to establish a target connection, '?' for help
    J-Link>device nrf52
    J-Link>si 1
    Selecting SWD as current target interface.
    J-Link>speed 1000
    Selecting 1000 kHz as target interface speed
    J-Link>connect
    Device "NRF52" selected.
    Connecting to target via SWD
    InitTarget() start
    InitTarget() end
    Found SW-DP with ID 0x2BA01477
    DPIDR: 0x2BA01477
    CoreSight SoC-400 or earlier
    Scanning AP map to find all available APs
    AP[2]: Stopped AP scan as end of AP map has been reached
    AP[0]: AHB-AP (IDR: 0x24770011)
    AP[1]: JTAG-AP (IDR: 0x02880000)
    Iterating through AP map to find AHB-AP to use
    AP[0]: Core found
    AP[0]: AHB-AP ROM base: 0xE00FF000
    CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    Found Cortex-M4 r0p1, Little endian.
    FPUnit: 6 code (BP) slots and 2 literal slots
    CoreSight components:
    ROMTbl[0] @ E00FF000
    [0][0]: E000E000 CID B105E00D PID 000BB00C SCS-M7
    [0][1]: E0001000 CID B105E00D PID 003BB002 DWT
    [0][2]: E0002000 CID B105E00D PID 002BB003 FPB
    [0][3]: E0000000 CID B105E00D PID 003BB001 ITM
    [0][4]: E0040000 CID B105900D PID 000BB9A1 TPIU
    [0][5]: E0041000 CID B105900D PID 000BB925 ETM
    Cortex-M4 identified.
    And here is a batch-script which will run recover continuously:
     RE: nRF52832 not connected anymore after first trying to debug (Keil)
    Håkon
  •  you are the Boss :-D
    I had to do both.
    J-Link commander at connect was going thru well as listed in the example above up to the last line. But the last line rather to say "Cortex-M4 identifies it says "Could not connect".
    Then I ran "nrfjprog --recover -f nrf52" and it did connect. (last time it did not work).
    Now I am OK and VScode can see my board and flash.
    Now i have to find out why my code or the code suggested by the course does not work.
    When I flash it it goes again disconnect and then when I run connect with the J-Link commander it works, and all is fine.
    In any cases I know how to recover and I appreciate your excellent help.
  • Glad to hear that it worked out! :)
    If the firmware asserts early in the process, and the default behavior is to reset, it can be problematic to recover the board, as the firmware will effectively be in a reset-loop. This could have happened in your firmware.
    PS: I would still recommend that you get a newer DK version. It is OK to use for evaluation, but you want to use a production grade silicon for development.
    Håkon
