I am using the NRF52840 with NCS 2.4 and I have hit the internal flash limit. I am running multiple ble peripheral/central with some graphics libraries for a display. The Zephyr stack seems to take up a lot of more space than the old NRF5 stack.
I want to offload some graphics fonts/images to an external QSPI.
2 questions:
1.) How should I modify this example to work with the NRF52840?
https://github.com/zephyrproject-rtos/zephyr/tree/main/samples/application_development/code_relocation_nocopy
This includes an ext_mem_init.c for the NRF5340, is there an NRF52840 version of this or a different way to enable XIP for the 5240?
When I try to modify the example for the 5240, I get an invalid hex error:
[error] [ Worker] - Program image can not have data in FICR. ERROR: The file specified is not a valid hex file, has data outside valid areas ERROR: or does not have data in valid areas.
2.) How can I do this so it is compatible with MCUBoot? When I add MCUboot to the code relocation example, this overflows the image size limits:
Error: Image size (0xfff0298) + trailer (0x630) exceeds requested size 0x78000
This makes sense since now the whole image includes the XIP data located on external flash.
Perhaps there is a way I can create a new image/partition that has the graphics data? I would think I would need to link to a fixed flash address to then access this data from the main application partition. Then I could independently update each partition, the main app, and the external data files...
Is there a recommended way to include external flash data and still allow updates via MCUBoot?
Perhaps I should include this using a file system?
Luke
