nRF700x: TCXO hardware configuration
The Commissioning and Characterization note for the nRF700x series (https://infocenter.nordicsemi.com/pdf/nan_043.pdf) says in section 2.1.2
An external temperature-controlled crystal oscillator can be used to avoid trimming. These devices are
typically more expensive, but this method avoids the need for executing the trimming algorithm on the
production line.
However I have been unable to find any information about how a TCXO should be connected to the modem.
The datasheet only mentions XOP and XON as analog inputs for a 40MHz crystal, and does not mention TCXO's at all.
The question is which pin should be connected to the TCXO output, and which pin should be connected to the TCXO power.
