nrf-connect.boardRoots does not work. Custom board are not picked up.
Hi, in the video you can see:
1. Me first removing/re-adding the application by editing .vscode/settings.json just to verify the plugin is picking up the settings.json file.
2. Then I try to create a new build configuration, but my custom boards are not there.
3. I show the folder structure that I have boards in app/boards correctly.
I have also tried using the "Create a new board", but those are not either picked up.
Also tried on Linux, but same there. Attached generated support info.
Tried re-installing the plugin.
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro N",
    "osKernel": "10.0.19045",
    "vscode": "1.82.1",
    "electron": "25.8.0",
    "node": "v18.15.0"
  "system": {
    "date": "2023-09-13T23:20:42.266Z",
    "vscodeRoot": "c:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:21:18",
    "osUptime": "119:12:40",
    "cpu": {
      "model": "Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz",
      "speed": "4000 MHz",
      "count": 4
    "memory": {
      "total": "15.94 GB",
      "free": "5.05 GB"
  "workspace": {
    "name": "ZSWatch",
    "workspaceFile": null,
    "folders": [
      "g:\\projects\\ZSWatch"
  "extensions": {
    "internal": {
        "version": "2023.9.169",
        "path": "c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.9.169-win32-x64",
        "isActive": true
        "version": "2023.9.29",
        "path": "c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2023.9.29",
        "isActive": true
        "version": "2023.9.57",
        "path": "c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2023.9.57",
        "isActive": true
        "version": "2023.9.31",
        "path": "c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2023.9.31",
        "isActive": true
    "external": {
      "marus25.cortex-debug": "1.12.0",
      "ms-vscode.cpptools": "1.17.5",
      "ms-vscode-remote.remote-wsl-recommender": "0.0.19",
      "ms-vscode.js-debug": "1.82.0",
      "ms-vscode.js-debug-companion": "1.1.2",
      "ms-vscode.vscode-js-profile-table": "1.0.3",
      "donjayamanne.githistory": "0.6.20",
      "espressif.esp-idf-extension": "1.6.4",
      "GitHub.copilot": "1.111.404",
      "leizongmin.node-module-intellisense": "1.5.0",
      "mark-wiemer.vscode-autohotkey-plus-plus": "5.0.3",
      "mcu-debug.debug-tracker-vscode": "0.0.15",
      "mcu-debug.memory-view": "0.0.24",
      "mcu-debug.peripheral-viewer": "1.4.6",
      "mcu-debug.rtos-views": "0.0.7",
      "platformio.platformio-ide": "3.3.1",
      "trond-snekvik.gnu-mapfiles": "1.1.0"
  "tools": {
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.0",
    "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.88d",
    "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.19.0",
    "nrfutil": "Not found",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\cmake.exe": "3.20.5",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\Scripts\\west.exe": "1.0.0",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\python.exe": "3.8.2",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\ninja.exe": "1.9.0",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\gperf.exe": "3.1",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\dtc.exe": "1.4.7",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\gn.exe": "2105",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "gdbPath": "g:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
  "sdks": [
      "version": "2.0.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.0.0"
      "version": "2.1.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.1.0"
      "version": "2.1.2",
      "path": "g:\\nRF-Connect-SDKs\\v2.1.2"
      "version": "2.2.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.2.0"
      "version": "2.3.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.3.0"
      "version": "2.4.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.4.0"
      "version": "2.4.2",
      "path": "g:\\nRF-Connect-SDKs\\v2.4.2"
      "version": "2.4.2",
      "path": "g:\\projects\\ZSWatch"
  "toolchains": [
      "version": "2.0.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.0.0"
      "version": "2.1.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.1.0"
      "version": "2.1.2",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.1.2"
      "version": "2.2.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.2.0"
      "version": "2.3.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.3.0"
      "version": "2.4.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\31f4403e35"
  "connectedDevices": [],
  "deviceProvider": "nrfutil",
  "config": {
      "topdir": "",
      "toolchain": {
        "path": ""
      "ozonePath": "",
      "applications": [
        "${workspaceFolder}\\app"
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig",
        "executeInDefaultShell": false
      "welcome": {
        "showOnStartup": true
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [
      "taskBindings": {},
      "debugging": {
        "flash": true,
        "bindings": {}
      "enableTelemetry": true,
      "thirdpartyIntegration": {},
      "toolchainManager": {
        "indexURL": null,
        "installDirectory": null
      "nrfutil": {
        "home": null
      "terminalMode": "character"
    "marus25.cortex-debug": {
      "variableUseNaturalFormat": true,
      "liveWatchRefreshRate": "300",
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "dbgServerLogfile": null
  "environment": {
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "C:\\Users\\ijakk_000",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\ijakk_000",
      "PATH": "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\mingw64\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\Scripts;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\nanopb\\generator-bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.9.169-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;D:\\Oculus\\Support\\oculus-runtime;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files\\PuTTY\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;\";C:\\Program Files\\dotnet\\;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs\";C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files (x86)\\astyle;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;G:\\Programs\\incscape\\bin;",
      "ZEPHYR_BASE": "g:\\projects\\ZSWatch\\zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk",
      "PYTHONPATH": "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\Lib;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\Lib\\site-packages"
    "inherited": {
      "HOMEDRIVE": "C:",
      "Path": "D:\\Oculus\\Support\\oculus-runtime;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files\\PuTTY\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;\";C:\\Program Files\\dotnet\\;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs\";C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files (x86)\\astyle;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;G:\\Programs\\incscape\\bin;",
      "PATH": "D:\\Oculus\\Support\\oculus-runtime;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files\\PuTTY\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;\";C:\\Program Files\\dotnet\\;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs\";C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files (x86)\\astyle;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;G:\\Programs\\incscape\\bin;"
    "toolchainPath": "g:\\nRF-Connect-SDKs\\toolchains\\31f4403e35",
    "toolchainBinPath": "g:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
    "toolchainVersion": "2.4.0"
  "terminal": {
    "defaultProfile": null
