Hi there,
I am trying to monitor the charging current of a battery cell. For this I am using the PPK2 in ampere mode, a bench power supply at 4V as source which limits the current to 0.8A. I am measuring the current with the Power Profiler 3.1.3 through the PPK2.
The issue I have is that the Power Profiler shows an exponentially decreasing current (as shown in the screenshot below) while the current should be constant (as measured by the bench power supply and an external ampere meter). The current measurement then settels at 50mA while the actual current is at 0.8A. What could be the cause of this?
My set up is as the following picture indicates:
I am on a MacBook Pro running macOS High Sierra 10.13.5.
I am using nRF Connect v3.7.2 running Power Profiler v3.1.3
On the PPK2 it says: PCA63100, 1.1.0, 2023.12, DB2E2D24
Any help is greatly appreciated!
best,
Lukas
