MCUBoot reverting slots immediately after image swap
OS: sdk-nRF 2.3.0
OTA slots: primary slot 0 on the uC; secondary slot 1 on external flash
Chip: nrf52840
Build OS: MacOs
Problem
We are using LwM2M to perform DFU which has been working fine until recently when we tweaked the partition locations. Aka we moved the settings partition to the end of flash (primary) and made it larger in size.
The firmware runs fine when flashing the "merged.hex" file.
When we perform a DFU the download to slot 1 goes fine. When executing the update MCUBoot swaps the content of slot 0 for 1 as expected. However as soon as this finishes it then reverts the slots back, see image below.
I'm lost as to why MCUBoot would revert the slots before the app as even attempted to load.
Debugging
In the past MCUBoot would load as such, with no secondary reboot/reverting.
I've also noticed when doing a "sys_boot()" the uC will actually reboot twice; which does not seem right.
However when boot the device up from cold / real world power cycle, it only reboots once:
The paritition.yml file can be seen here encase it helps: https://gist.github.com/motters/072ffe54c56c074a3fd96e907b973999
Let me know if i can provide anything else that will help.
Any help greatly appreciated.
Sam
