downgrade from SDK 2.4.2 to SDK 1.9.1
We are working to updated the SDK to version 2.4.2 running on nRF5340 SoC. Current the firmware is working fine except when we tested to downgrade the firmware back with the firmware using SDK 1.9.1. After we OTA the firmware back, the netcore is not been downgrade to the firmware from SKD 1.9.1. The side effect is the BLE is not longer working.
The test steps are:
1 - Flask SDK 1.9.1 firmware using Jlink.
2 - OTA SDK 2.4.2 firmware.
3 - OTA SDK 1.9.1 firmware.
4 - OTA SDK 2.4.2 firmware.
The step 4 failed because the device is no longer sending BLE advertisement.
One of my colleges read the image and he saw that between the step 2 and 3 the netcore was not updated. Meaning, the netcode firmware on step 3 is the one built using SDK 2.4.2.
I tried to enable the MCU boot netcore logs, few times I saw the following message: E: Network core update failed.
The problem I'm facing to debug the problem is the logging via RTT almost never works. After 4 days working in this issue I saw the MCU boot messages only twice.
Parents Reply
  • Hi Leiser,
    Sigurd is away and I will take over the ticket in the mean time.
    So what happening here is that the controller has been updated from Zephyr controller in SDK v1.9.1 to Softdevice controller in v2.4.2 ?
    And when you try to revert it back it was not possible to downgrade ?
    I'm not so sure if it's actually feasible to downgrade the controller at all. There must be some logic need to be turned of to do so because it's normally not allowed to downgrade due to security reason. An attacker can try to downgrade the stack to exploit security holes in previous version of the stack.
