Range Finding, nrf_dm won't build cleanly or at all.
I can't get "nrf_dm" to build cleanly. I don't see anything in the readme that indicates I have to do anything special/additional... nrf5340dk might work  (I have to order 2x nrf5340dk's), but it generates enough Warnings to be concerning... Eventually I will need to program SoC nrf5340 on a custom PCB and that doesn't compile at all.
  1. Board: nrf5340dk generations a number of warnings.
  2. Board/SoC: thingy53_nrf5340_cpuapp fails spectacularly...
Also, which may be related, I can't seem to be able to select a "kit" and have "No Kit Selected" in the bottom toolbar. I "repaired" the "nrf-command-line-tools-10.23.0-x64" installation, but no improvement. None of the Kit options: Scan, Let Cmake guess, gcc... improve my results.
I assume my problem is in my VSCode setup? I am a new user, w/new nrf_connect install. I have spent weeks trying to get the nrf connect environment working in VSCode with little, but some, success.
I attached my nrf_dm files, support info, etc...
board nrf5340dk (PRISTINE BUILD) WARNINGS:
"resource": "/../../../CMakeLists.txt",
"owner": "nrf-connect",
"severity": 4,
"message": "CMake Warning at ../../../CMakeLists.txt:839 (message):",
"source": "cmake",
"startLineNumber": 839,
"startColumn": 1,
"endLineNumber": 839,
"endColumn": 2147483647
"resource": "/c:/ncs/v2.4.2/nrf/subsys/dm/dm.c",
"owner": "cpptools",
"severity": 4,
"message": "#warning \"The ncs,dm-timer chosen node is not set; defaulting to TIMER2\" [-Wcpp]",
"source": "gcc",
"startLineNumber": 43,
"startColumn": 2,
"endLineNumber": 43,
"endColumn": 2
"resource": "/c:/ncs/v2.4.2/zephyr/CMakeLists.txt",
"severity": 4,
"message": "CMake Warning at C:/ncs/v2.4.2/zephyr/CMakeLists.txt:839 (message):",
"source": "cmake",
"startColumn": 1,
"severity": 4,
"message": "CMake Warning at C:/ncs/v2.4.2/zephyr/CMakeLists.txt:1865 (message):",
"source": "cmake",
"startLineNumber": 1865,
"startColumn": 1,
"endLineNumber": 1865,
"resource": "/c:/ncs/v2.4.2/zephyr/subsys/random/CMakeLists.txt",
"severity": 4,
"message": "CMake Warning at C:/ncs/v2.4.2/zephyr/subsys/random/CMakeLists.txt:11 (message):",
"source": "cmake",
"startLineNumber": 11,
"startColumn": 1,
"endLineNumber": 11,
"resource": "/c:/nordic/myApps/nrf_dm_3/child_image/hci_rpmsg.conf",
"owner": "kconfig0",
"severity": 4,
"message": "MAIN_STACK_SIZE set more than once. Old value \"512\", new value \"680\".",
"startLineNumber": 20,
"startColumn": 1,
"endLineNumber": 20,
"endColumn": 27,
"relatedInformation": [
"startLineNumber": 6,
"startColumn": 1,
"endLineNumber": 6,
"endColumn": 23,
"message": "Already set to \"512\" here",
"resource": "/c:/ncs/v2.4.2/zephyr/samples/bluetooth/hci_rpmsg/prj.conf"
Thingy53_nrf5340_cpuapp (PRISTINE BUILD) WARNINGS:
"resource": "/c:/ncs/v2.4.2/zephyr/include/zephyr/device.h",
"severity": 8,
"message": "'__device_dts_ord_DT_N_NODELABEL_ipc1_ORD' undeclared (first use in this function)",
"source": "gcc",
"startLineNumber": 84,
"startColumn": 41,
"endLineNumber": 84,
"endColumn": 41
"resource": "/c:/ncs/v2.4.2/zephyr/include/zephyr/devicetree.h",
"severity": 8,
"message": "'DT_N_NODELABEL_dm_ranging_P_gpios_IDX_0_VAL_pin' undeclared here (not in a function)",
"source": "gcc",
"startLineNumber": 192,
"startColumn": 36,
"endLineNumber": 192,
"endColumn": 36
"resource": "/c:/ncs/v2.4.2/zephyr/include/zephyr/toolchain/gcc.h",
"severity": 8,
"message": "static assertion failed: \"You must set the gpios property in the /dm_gpio/dm-add-request node to enable GPIO Debug.\"",
"source": "gcc",
"startLineNumber": 81,
"startColumn": 36,
"endLineNumber": 81,
"endColumn": 36
"severity": 4,
"message": "No SOURCES given to Zephyr library: lib__libc__common",
"source": "cmake",
"startColumn": 1,
"resource": "/subsys/logging/Kconfig.filtering",
"severity": 4,
"message": "LOG_DEFAULT_LEVEL (defined at subsys/logging\\Kconfig.filtering:13) was assigned the value",
"source": "kconfig",
"startLineNumber": 13,
"startColumn": 1,
"endLineNumber": 13,
"resource": "/subsys/logging/Kconfig.mode",
"severity": 4,
"message": "The choice symbol LOG_MODE_MINIMAL (defined at subsys/logging\\Kconfig.mode:28) was selected",
"startLineNumber": 28,
"startColumn": 1,
"endLineNumber": 28,
"resource": "/c:/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr/boards/thingy53_nrf5340_cpuapp.conf",
"severity": 4,
"message": "CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE couldn't be set. Missing dependencies:\n(NORDIC_QSPI_NOR && NCS_SAMPLE_MCUMGR_BT_OTA_DFU) || (NORDIC_QSPI_NOR && FLASH)",
"startLineNumber": 31,
"startColumn": 1,
"endLineNumber": 31,
"endColumn": 47
"severity": 4,
"message": "CONFIG_USB_CDC_ACM was assigned the value y, but got the value n. Missing dependencies:\n(BOARD_SERIAL_BACKEND_CDC_ACM && (BOARD_THINGY53_NRF5340_CPUAPP || BOARD_THINGY53_NRF5340_CPUAPP_NS)) || (SERIAL && DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED && USB_DEVICE_STACK)",
"startColumn": 1,
"endColumn": 19
"severity": 4,
"message": "CONSOLE set more than once. Old value \"y\", new value \"n\".",
"startLineNumber": 49,
"startColumn": 1,
"endLineNumber": 49,
"endColumn": 17,
"startColumn": 1,
"endColumn": 15,
"message": "Already set to \"y\" here",
"resource": "/c:/ncs/v2.4.2/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpuapp_defconfig"
"severity": 4,
"message": "LOG set more than once. Old value \"y\", new value \"n\".",
"startLineNumber": 53,
"startColumn": 1,
"endLineNumber": 53,
"endColumn": 13,
"startColumn": 1,
"endColumn": 11,
"resource": "/c:/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr/prj.conf"
"severity": 4,
"message": "BOOT_UPGRADE_ONLY set more than once. Old value \"n\", new value \"y\".",
"startLineNumber": 64,
"startColumn": 1,
"endLineNumber": 64,
"endColumn": 27,
"startColumn": 1,
"endColumn": 25,
"message": "Already set to \"n\" here",
"severity": 4,
"message": "CONFIG_FLASH_SIMULATOR was assigned the value y, but got the value n. Missing dependencies:\nDT_HAS_ZEPHYR_SIM_FLASH_ENABLED",
"startLineNumber": 67,
"startColumn": 1,
"endLineNumber": 67,
"endColumn": 23
"severity": 4,
"message": "CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES was assigned the value y, but got the value n. Missing dependencies:\nFLASH_SIMULATOR",
"startLineNumber": 68,
"startColumn": 1,
"endLineNumber": 68,
"endColumn": 37
"resource": "/c:/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr/prj.conf",
"severity": 4,
"message": "CONFIG_LOG_MODE_MINIMAL was assigned the value y, but got the value n. Missing dependencies:\n<choice LOG_MODE>",
"startLineNumber": 32,
"startColumn": 1,
"endLineNumber": 32,
"endColumn": 24
"severity": 4,
"message": "CONFIG_LOG_DEFAULT_LEVEL couldn't be set. Missing dependencies:\nLOG",
"startLineNumber": 34,
"startColumn": 1,
"endLineNumber": 34,
"endColumn": 25
"severity": 4,
"source": "gcc",
"startColumn": 2,
"endColumn": 2
"resource": "/c:/ncs/v2.4.2/nrfxlib/mpsl/Kconfig",
"severity": 4,
"message": "MPSL (defined at C:/ncs/v2.4.2/nrfxlib\\mpsl/Kconfig:7) was assigned the value 'y' but got",
"startLineNumber": 7,
"startColumn": 1,
"endLineNumber": 7,
"severity": 4,
"source": "cmake",
"startColumn": 1,
"severity": 4,
"message": "__ASSERT() statements are globally ENABLED",
"source": "cmake",
"startColumn": 1,
"resource": "/c:/nordic/myApps/nrf_dm_4/child_image/hci_rpmsg.conf",
"severity": 4,
"startColumn": 1,
"endColumn": 27,
"startColumn": 1,
"endLineNumber": 6,
"endColumn": 23,
"resource": "/c:/nordic/myApps/nrf_dm_4/prj.conf",
"severity": 4,
"message": "CONFIG_MPSL was assigned the value y, but got the value n. Missing dependencies:\nSOC_SERIES_BSIM_NRFXX || SOC_SERIES_NRF52X || SOC_NRF5340_CPUNET",
"startLineNumber": 30,
"startColumn": 1,
"endLineNumber": 30,
"endColumn": 12
Thingy53_nrf5340_cpuapp (PRISTINE BUILD) TERMINAL MESSAGES:
Loaded configuration 'C:/ncs/v2.4.2/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpunet_defconfig'
Merged configuration 'C:/ncs/v2.4.2/nrf/samples/nrf5340/netboot/prj.conf'
Merged configuration 'C:/ncs/v2.4.2/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Configuration saved to 'C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/hci_rpmsg/b0n/zephyr/.config'
Kconfig header saved to 'C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/hci_rpmsg/b0n/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
Excluding target from build.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/hci_rpmsg/b0n
=== child image b0n - CPUNET (inherited) end ===
CMake Warning at C:/ncs/v2.4.2/nrf/subsys/bootloader/cmake/debug_keys.cmake:36 (message):
--- WARNING: Using generated NSIB public/private key-pair. ---
--- It should not be used for production. ---
--- See CONFIG_SB_SIGNING_KEY_FILE ---
C:/ncs/v2.4.2/nrf/subsys/bootloader/cmake/provision_hex.cmake:37 (include)
C:/ncs/v2.4.2/nrf/subsys/CMakeLists.txt:17 (include)
-- libmetal version: 1.3.0 (C:/ncs/v2.4.2/zephyr/samples/bluetooth/hci_rpmsg)
-- Build type:
-- Host: Windows/AMD64
-- Target: Generic/arm
-- Machine: arm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.3.0 (C:/ncs/v2.4.2/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS : -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Configuring done
-- Generating done
=== child image hci_rpmsg - CPUNET end ===
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/mcuboot/child_image_preload.cmake
-- Application: C:/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr
-- CMake version: 3.20.5
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.4.2/zephyr/.cache
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.2/zephyr)
-- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
-- Board: thingy53_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/31f4403e35/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.4.2/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpuapp.dts
-- Found devicetree overlay: C:/ncs/v2.4.2/nrf/modules/mcuboot/flash_sim.overlay
-- Generated zephyr.dts: C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/mcuboot/zephyr/dts.cmake
Parsing C:/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.4.2/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr/boards/thingy53_nrf5340_cpuapp.conf'
Merged configuration 'C:/ncs/v2.4.2/nrf/subsys/pcd/pcd.conf'
Merged configuration 'C:/ncs/v2.4.2/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
Merged configuration 'C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/mcuboot/zephyr/include/generated/autoconf.h'
warning: LOG_DEFAULT_LEVEL (defined at subsys/logging\Kconfig.filtering:13) was assigned the value
'0' but got the value ''. Check these unsatisfied dependencies: LOG (=n). See
docs.zephyrproject.org/.../kconfig.html and/or look up
LOG_DEFAULT_LEVEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: The choice symbol LOG_MODE_MINIMAL (defined at subsys/logging\Kconfig.mode:28) was selected
(set =y), but no symbol ended up as the choice selection. See
LOG_MODE_MINIMAL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
-- Found partition manager static configuration: C:/ncs/v2.4.2/zephyr/boards/arm/thingy53_nrf5340/pm_static_thingy53_nrf5340_cpuapp.yml
MCUBoot bootloader key file: C:/ncs/v2.4.2/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/mcuboot
=== child image mcuboot - end ===
CMake Warning at C:/ncs/v2.4.2/nrf/modules/mcuboot/CMakeLists.txt:310 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
-- libmetal version: 1.3.0 (C:/nordic/myApps/nrf_dm_4)
-- Build type:
-- Machine: arm
-- Machine: arm
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_1' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary_1' is not included in the dynamic resolving since it is statically defined.
Partition 'pcd_sram' is not included in the dynamic resolving since it is statically defined.
-- Configuring done
-- Generating done
[1/503] Generating include/generated/version.h
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.2/zephyr), build: v3.3.99-ncs1-1
[2/503] Creating directories for 'hci_rpmsg_subimage'
[3/503] Creating directories for 'mcuboot_subimage'
[4/503] No download step for 'hci_rpmsg_subimage'
[5/503] No download step for 'mcuboot_subimage'
[6/503] No update step for 'hci_rpmsg_subimage'
[7/503] No update step for 'mcuboot_subimage'
[8/503] No patch step for 'hci_rpmsg_subimage'
[9/503] No patch step for 'mcuboot_subimage'
[10/503] No configure step for 'hci_rpmsg_subimage'
[10/503] Performing build step for 'hci_rpmsg_subimage'
[0/456] Generating signing key
[1/456] Generating include/generated/version.h
[2/456] Creating public key from private key used for signing
[5/456] No update step for 'b0n_subimage'
[6/456] Creating data to be provisioned to the Bootloader, storing to provision.hex
[8/456] No configure step for 'b0n_subimage'
[9/456] Performing build step for 'b0n_subimage'
[1/156] Generating include/generated/version.h
[2/156] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/156] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/156] Generating include/generated/driver-validation.h
[5/156] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[6/156] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/156] Generating include/generated/offsets.h
[8/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[9/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[10/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[11/156] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[12/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[13/156] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[14/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[15/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[16/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[17/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[18/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[19/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[20/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[21/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[22/156] Generating linker_zephyr_pre0.cmd
[23/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[24/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[25/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[26/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[27/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[28/156] Generating ../../../include/generated/libc/minimal/strerror_table.h
[29/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[30/156] Linking C static library zephyr\arch\common\libisr_tables.a
[31/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[32/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[33/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[34/156] Building C object CMakeFiles/app.dir/src/main.c.obj
[35/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[36/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[37/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[38/156] Linking C static library zephyr\arch\common\libarch__common.a
[39/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[40/156] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[41/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[42/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[43/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[44/156] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[45/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[46/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[47/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[48/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[49/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[50/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[51/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[52/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[53/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[54/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[55/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[56/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[57/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[58/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[59/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[60/156] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[61/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[62/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[63/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[64/156] Linking C static library app\libapp.a
[65/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[66/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[67/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[68/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[69/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[70/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[71/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[72/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[73/156] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[74/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[75/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[76/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[77/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[78/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[79/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[80/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[81/156] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[82/156] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[83/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[84/156] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[85/156] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[86/156] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[87/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[88/156] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[89/156] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[90/156] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[91/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[92/156] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
[93/156] Generating linker_zephyr_pre1.cmd
[94/156] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
[95/156] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[96/156] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[97/156] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[98/156] Building C object modules/nrf/subsys/bootloader/bl_storage/CMakeFiles/..__nrf__subsys__bootloader__bl_storage.dir/bl_storage.c.obj
[99/156] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[100/156] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[101/156] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[102/156] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[103/156] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[104/156] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[105/156] Linking C static library zephyr\libzephyr.a
[106/156] Linking C static library modules\nrf\subsys\bootloader\bl_storage\lib..__nrf__subsys__bootloader__bl_storage.a
[107/156] Building C object modules/nrf/subsys/bootloader/bl_boot/CMakeFiles/..__nrf__subsys__bootloader__bl_boot.dir/bl_boot.c.obj
[108/156] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj
[109/156] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[110/156] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_oberon_hash.c.obj
[111/156] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[112/156] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[113/156] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto.c.obj
[114/156] Linking C static library modules\nrf\subsys\bootloader\bl_boot\lib..__nrf__subsys__bootloader__bl_boot.a
[115/156] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[116/156] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[117/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.2/modules/hal/nordic/nrfx/mdk/system_nrf5340_network.c.obj
[118/156] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[119/156] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[120/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[121/156] Building C object modules/nrf/subsys/pcd/CMakeFiles/..__nrf__subsys__pcd.dir/src/pcd.c.obj
[122/156] Building C object modules/nrf/subsys/bootloader/bl_validation/CMakeFiles/..__nrf__subsys__bootloader__bl_validation.dir/bl_validation.c.obj
[123/156] Linking C static library modules\nrf\subsys\bootloader\bl_crypto\lib..__nrf__subsys__bootloader__bl_crypto.a
[124/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[125/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[126/156] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[127/156] Linking C static library modules\nrf\subsys\bootloader\bl_validation\lib..__nrf__subsys__bootloader__bl_validation.a
[128/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[129/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[130/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[131/156] Linking C static library modules\nrf\subsys\pcd\lib..__nrf__subsys__pcd.a
[132/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[133/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[134/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[135/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[136/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[137/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[138/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[139/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[140/156] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[141/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[142/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[143/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[144/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[145/156] Linking C static library zephyr\kernel\libkernel.a
[146/156] Linking C executable zephyr\zephyr_pre0.elf
[147/156] Generating dev_handles.c
[148/156] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[149/156] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[150/156] Linking C executable zephyr\zephyr_pre1.elf
[151/156] Generating linker.cmd
[152/156] Generating isr_tables.c, isrList.bin
[153/156] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[154/156] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[155/156] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[156/156] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 21588 B 34176 B 63.17%
RAM: 3416 B 64 KB 5.21%
SRAM1: 0 GB 64 KB 0.00%
IDT_LIST: 0 GB 2 KB 0.00%
[46/456] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/rpc/host/dm_rpc_host.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/rpc/host/dm_rpc_host.c.obj
C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DARM_ALL_FAST_TABLES -DARM_ALL_FFT_TABLES -DARM_DSP_CONFIG_TABLES -DARM_FAST_ALLOW_TABLES -DARM_FFT_ALLOW_TABLES -DARM_TABLE_BITREVIDX_FLT64_1024 -DARM_TABLE_BITREVIDX_FLT64_128 -DARM_TABLE_BITREVIDX_FLT64_16 -DARM_TABLE_BITREVIDX_FLT64_2048 -DARM_TABLE_BITREVIDX_FLT64_256 -DARM_TABLE_BITREVIDX_FLT64_32 -DARM_TABLE_BITREVIDX_FLT64_4096 -DARM_TABLE_BITREVIDX_FLT64_512 -DARM_TABLE_BITREVIDX_FLT64_64 -DARM_TABLE_BITREVIDX_FLT_1024 -DARM_TABLE_BITREVIDX_FLT_128 -DARM_TABLE_BITREVIDX_FLT_16 -DARM_TABLE_BITREVIDX_FLT_2048 -DARM_TABLE_BITREVIDX_FLT_256 -DARM_TABLE_BITREVIDX_FLT_32 -DARM_TABLE_BITREVIDX_FLT_4096 -DARM_TABLE_BITREVIDX_FLT_512 -DARM_TABLE_BITREVIDX_FLT_64 -DARM_TABLE_BITREVIDX_FXT_1024 -DARM_TABLE_BITREVIDX_FXT_128 -DARM_TABLE_BITREVIDX_FXT_16 -DARM_TABLE_BITREVIDX_FXT_2048 -DARM_TABLE_BITREVIDX_FXT_256 -DARM_TABLE_BITREVIDX_FXT_32 -DARM_TABLE_BITREVIDX_FXT_4096 -DARM_TABLE_BITREVIDX_FXT_512 -DARM_TABLE_BITREVIDX_FXT_64 -DARM_TABLE_BITREV_1024 -DARM_TABLE_DCT4_F32_128 -DARM_TABLE_DCT4_F32_2048 -DARM_TABLE_DCT4_F32_512 -DARM_TABLE_DCT4_F32_8192 -DARM_TABLE_DCT4_Q15_128 -DARM_TABLE_DCT4_Q15_2048 -DARM_TABLE_DCT4_Q15_512 -DARM_TABLE_DCT4_Q15_8192 -DARM_TABLE_DCT4_Q31_128 -DARM_TABLE_DCT4_Q31_2048 -DARM_TABLE_DCT4_Q31_512 -DARM_TABLE_DCT4_Q31_8192 -DARM_TABLE_REALCOEF_F32 -DARM_TABLE_REALCOEF_Q15 -DARM_TABLE_REALCOEF_Q31 -DARM_TABLE_RECIP_Q15 -DARM_TABLE_RECIP_Q31 -DARM_TABLE_SIN_F32 -DARM_TABLE_SIN_Q15 -DARM_TABLE_SIN_Q31 -DARM_TABLE_TWIDDLECOEF_F16_1024 -DARM_TABLE_TWIDDLECOEF_F16_128 -DARM_TABLE_TWIDDLECOEF_F16_16 -DARM_TABLE_TWIDDLECOEF_F16_2048 -DARM_TABLE_TWIDDLECOEF_F16_256 -DARM_TABLE_TWIDDLECOEF_F16_32 -DARM_TABLE_TWIDDLECOEF_F16_4096 -DARM_TABLE_TWIDDLECOEF_F16_512 -DARM_TABLE_TWIDDLECOEF_F16_64 -DARM_TABLE_TWIDDLECOEF_F32_1024 -DARM_TABLE_TWIDDLECOEF_F32_128 -DARM_TABLE_TWIDDLECOEF_F32_16 -DARM_TABLE_TWIDDLECOEF_F32_2048 -DARM_TABLE_TWIDDLECOEF_F32_256 -DARM_TABLE_TWIDDLECOEF_F32_32 -DARM_TABLE_TWIDDLECOEF_F32_4096 -DARM_TABLE_TWIDDLECOEF_F32_512 -DARM_TABLE_TWIDDLECOEF_F32_64 -DARM_TABLE_TWIDDLECOEF_F64_1024 -DARM_TABLE_TWIDDLECOEF_F64_128 -DARM_TABLE_TWIDDLECOEF_F64_16 -DARM_TABLE_TWIDDLECOEF_F64_2048 -DARM_TABLE_TWIDDLECOEF_F64_256 -DARM_TABLE_TWIDDLECOEF_F64_32 -DARM_TABLE_TWIDDLECOEF_F64_4096 -DARM_TABLE_TWIDDLECOEF_F64_512 -DARM_TABLE_TWIDDLECOEF_F64_64 -DARM_TABLE_TWIDDLECOEF_Q15_1024 -DARM_TABLE_TWIDDLECOEF_Q15_128 -DARM_TABLE_TWIDDLECOEF_Q15_16 -DARM_TABLE_TWIDDLECOEF_Q15_2048 -DARM_TABLE_TWIDDLECOEF_Q15_256 -DARM_TABLE_TWIDDLECOEF_Q15_32 -DARM_TABLE_TWIDDLECOEF_Q15_4096 -DARM_TABLE_TWIDDLECOEF_Q15_512 -DARM_TABLE_TWIDDLECOEF_Q15_64 -DARM_TABLE_TWIDDLECOEF_Q31_1024 -DARM_TABLE_TWIDDLECOEF_Q31_128 -DARM_TABLE_TWIDDLECOEF_Q31_16 -DARM_TABLE_TWIDDLECOEF_Q31_2048 -DARM_TABLE_TWIDDLECOEF_Q31_256 -DARM_TABLE_TWIDDLECOEF_Q31_32 -DARM_TABLE_TWIDDLECOEF_Q31_4096 -DARM_TABLE_TWIDDLECOEF_Q31_512 -DARM_TABLE_TWIDDLECOEF_Q31_64 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_128 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_32 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_4096 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_64 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_128 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_32 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_4096 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_64 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_128 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_32 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_4096 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_64 -DDISABLEFLOAT16 -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DNRF5340_XXAA_NETWORK -DUSE_PARTITION_MANAGER=1 -DVALIDATION_INFO_MAGIC=0x281ee6de,0x86518483,79106 -DVALIDATION_POINTER_MAGIC=0x281ee6de,0x6919b47e,79106 -DZCBOR_STOP_ON_ERROR -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.4.2/zephyr/kernel/include -IC:/ncs/v2.4.2/zephyr/arch/arm/include -IC:/ncs/v2.4.2/nrf/drivers/mpsl/clock_control -IC:/ncs/v2.4.2/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/ncs/v2.4.2/zephyr/lib/libc/newlib/include -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.4.2/zephyr/subsys/bluetooth -IC:/ncs/v2.4.2/nrf/include -IC:/ncs/v2.4.2/nrf/lib/multithreading_lock/. -IC:/ncs/v2.4.2/nrf/subsys/bluetooth/controller/. -IC:/ncs/v2.4.2/nrf/subsys/nrf_rpc/include -IC:/ncs/v2.4.2/nrf/tests/include -IC:/ncs/v2.4.2/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.4.2/modules/hal/cmsis/CMSIS/DSP/Include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.4.2/zephyr/modules/hal_nordic/nrfx/. -Imodules/libmetal/libmetal/lib/include -IC:/ncs/v2.4.2/modules/lib/open-amp/open-amp/lib/include -IC:/ncs/v2.4.2/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.4.2/modules/lib/zcbor/include -IC:/ncs/v2.4.2/nrfxlib/mpsl/include -IC:/ncs/v2.4.2/nrfxlib/mpsl/include/protocol -IC:/ncs/v2.4.2/nrfxlib/nrf_rpc/include -IC:/ncs/v2.4.2/nrfxlib/nrf_dm/include -IC:/ncs/v2.4.2/nrfxlib/softdevice_controller/include -fno-strict-aliasing -Os -imacros C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/hci_rpmsg/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33+nodsp -mthumb -mabi=aapcs --sysroot=C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.4.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ncs/v2.4.2/zephyr/samples/bluetooth/hci_rpmsg=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.4.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.4.2=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/rpc/host/dm_rpc_host.c.obj -MF zephyr\CMakeFiles\zephyr.dir\C_\ncs\v2.4.2\nrf\subsys\dm\rpc\host\dm_rpc_host.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/rpc/host/dm_rpc_host.c.obj -c C:/ncs/v2.4.2/nrf/subsys/dm/rpc/host/dm_rpc_host.c
In file included from C:\ncs\v2.4.2\zephyr\include\zephyr\toolchain\gcc.h:92,
from C:\ncs\v2.4.2\zephyr\include\zephyr\toolchain.h:50,
from C:\ncs\v2.4.2\zephyr\include\zephyr\kernel_includes.h:19,
from C:\ncs\v2.4.2\zephyr\include\zephyr\kernel.h:17,
from C:\ncs\v2.4.2\nrf\subsys\dm\rpc\host\dm_rpc_host.c:7:
C:/ncs/v2.4.2/nrf/subsys/dm/rpc/host/dm_rpc_host.c: In function 'ipc_init':
C:\ncs\v2.4.2\zephyr\include\zephyr\device.h:84:41: error: '__device_dts_ord_DT_N_NODELABEL_ipc1_ORD' undeclared (first use in this function)
84 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
C:\ncs\v2.4.2\zephyr\include\zephyr\toolchain\common.h:132:26: note: in definition of macro '_DO_CONCAT'
132 | #define _DO_CONCAT(x, y) x ## y
C:\ncs\v2.4.2\zephyr\include\zephyr\device.h:84:33: note: in expansion of macro '_CONCAT'
C:\ncs\v2.4.2\zephyr\include\zephyr\device.h:210:37: note: in expansion of macro 'DEVICE_NAME_GET'
210 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
C:\ncs\v2.4.2\zephyr\include\zephyr\device.h:227:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
227 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
C:\ncs\v2.4.2\nrf\subsys\dm\rpc\host\dm_rpc_host.c:132:24: note: in expansion of macro 'DEVICE_DT_GET'
132 | ipc_instance = DEVICE_DT_GET(DT_NODELABEL(ipc1));
C:\ncs\v2.4.2\zephyr\include\zephyr\device.h:84:41: note: each undeclared identifier is reported only once for each function it appears in
[47/456] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/dm.c.obj
C:\ncs\v2.4.2\nrf\subsys\dm\dm.c:43:2: warning: #warning "The ncs,dm-timer chosen node is not set; defaulting to TIMER2" [-Wcpp]
43 | #warning "The ncs,dm-timer chosen node is not set; defaulting to TIMER2"
[50/456] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/dm_io.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/dm_io.c.obj
C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DARM_ALL_FAST_TABLES -DARM_ALL_FFT_TABLES -DARM_DSP_CONFIG_TABLES -DARM_FAST_ALLOW_TABLES -DARM_FFT_ALLOW_TABLES -DARM_TABLE_BITREVIDX_FLT64_1024 -DARM_TABLE_BITREVIDX_FLT64_128 -DARM_TABLE_BITREVIDX_FLT64_16 -DARM_TABLE_BITREVIDX_FLT64_2048 -DARM_TABLE_BITREVIDX_FLT64_256 -DARM_TABLE_BITREVIDX_FLT64_32 -DARM_TABLE_BITREVIDX_FLT64_4096 -DARM_TABLE_BITREVIDX_FLT64_512 -DARM_TABLE_BITREVIDX_FLT64_64 -DARM_TABLE_BITREVIDX_FLT_1024 -DARM_TABLE_BITREVIDX_FLT_128 -DARM_TABLE_BITREVIDX_FLT_16 -DARM_TABLE_BITREVIDX_FLT_2048 -DARM_TABLE_BITREVIDX_FLT_256 -DARM_TABLE_BITREVIDX_FLT_32 -DARM_TABLE_BITREVIDX_FLT_4096 -DARM_TABLE_BITREVIDX_FLT_512 -DARM_TABLE_BITREVIDX_FLT_64 -DARM_TABLE_BITREVIDX_FXT_1024 -DARM_TABLE_BITREVIDX_FXT_128 -DARM_TABLE_BITREVIDX_FXT_16 -DARM_TABLE_BITREVIDX_FXT_2048 -DARM_TABLE_BITREVIDX_FXT_256 -DARM_TABLE_BITREVIDX_FXT_32 -DARM_TABLE_BITREVIDX_FXT_4096 -DARM_TABLE_BITREVIDX_FXT_512 -DARM_TABLE_BITREVIDX_FXT_64 -DARM_TABLE_BITREV_1024 -DARM_TABLE_DCT4_F32_128 -DARM_TABLE_DCT4_F32_2048 -DARM_TABLE_DCT4_F32_512 -DARM_TABLE_DCT4_F32_8192 -DARM_TABLE_DCT4_Q15_128 -DARM_TABLE_DCT4_Q15_2048 -DARM_TABLE_DCT4_Q15_512 -DARM_TABLE_DCT4_Q15_8192 -DARM_TABLE_DCT4_Q31_128 -DARM_TABLE_DCT4_Q31_2048 -DARM_TABLE_DCT4_Q31_512 -DARM_TABLE_DCT4_Q31_8192 -DARM_TABLE_REALCOEF_F32 -DARM_TABLE_REALCOEF_Q15 -DARM_TABLE_REALCOEF_Q31 -DARM_TABLE_RECIP_Q15 -DARM_TABLE_RECIP_Q31 -DARM_TABLE_SIN_F32 -DARM_TABLE_SIN_Q15 -DARM_TABLE_SIN_Q31 -DARM_TABLE_TWIDDLECOEF_F16_1024 -DARM_TABLE_TWIDDLECOEF_F16_128 -DARM_TABLE_TWIDDLECOEF_F16_16 -DARM_TABLE_TWIDDLECOEF_F16_2048 -DARM_TABLE_TWIDDLECOEF_F16_256 -DARM_TABLE_TWIDDLECOEF_F16_32 -DARM_TABLE_TWIDDLECOEF_F16_4096 -DARM_TABLE_TWIDDLECOEF_F16_512 -DARM_TABLE_TWIDDLECOEF_F16_64 -DARM_TABLE_TWIDDLECOEF_F32_1024 -DARM_TABLE_TWIDDLECOEF_F32_128 -DARM_TABLE_TWIDDLECOEF_F32_16 -DARM_TABLE_TWIDDLECOEF_F32_2048 -DARM_TABLE_TWIDDLECOEF_F32_256 -DARM_TABLE_TWIDDLECOEF_F32_32 -DARM_TABLE_TWIDDLECOEF_F32_4096 -DARM_TABLE_TWIDDLECOEF_F32_512 -DARM_TABLE_TWIDDLECOEF_F32_64 -DARM_TABLE_TWIDDLECOEF_F64_1024 -DARM_TABLE_TWIDDLECOEF_F64_128 -DARM_TABLE_TWIDDLECOEF_F64_16 -DARM_TABLE_TWIDDLECOEF_F64_2048 -DARM_TABLE_TWIDDLECOEF_F64_256 -DARM_TABLE_TWIDDLECOEF_F64_32 -DARM_TABLE_TWIDDLECOEF_F64_4096 -DARM_TABLE_TWIDDLECOEF_F64_512 -DARM_TABLE_TWIDDLECOEF_F64_64 -DARM_TABLE_TWIDDLECOEF_Q15_1024 -DARM_TABLE_TWIDDLECOEF_Q15_128 -DARM_TABLE_TWIDDLECOEF_Q15_16 -DARM_TABLE_TWIDDLECOEF_Q15_2048 -DARM_TABLE_TWIDDLECOEF_Q15_256 -DARM_TABLE_TWIDDLECOEF_Q15_32 -DARM_TABLE_TWIDDLECOEF_Q15_4096 -DARM_TABLE_TWIDDLECOEF_Q15_512 -DARM_TABLE_TWIDDLECOEF_Q15_64 -DARM_TABLE_TWIDDLECOEF_Q31_1024 -DARM_TABLE_TWIDDLECOEF_Q31_128 -DARM_TABLE_TWIDDLECOEF_Q31_16 -DARM_TABLE_TWIDDLECOEF_Q31_2048 -DARM_TABLE_TWIDDLECOEF_Q31_256 -DARM_TABLE_TWIDDLECOEF_Q31_32 -DARM_TABLE_TWIDDLECOEF_Q31_4096 -DARM_TABLE_TWIDDLECOEF_Q31_512 -DARM_TABLE_TWIDDLECOEF_Q31_64 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_128 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_32 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_4096 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_64 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_128 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_32 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_4096 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_64 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_128 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_32 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_4096 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_64 -DDISABLEFLOAT16 -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DNRF5340_XXAA_NETWORK -DUSE_PARTITION_MANAGER=1 -DVALIDATION_INFO_MAGIC=0x281ee6de,0x86518483,79106 -DVALIDATION_POINTER_MAGIC=0x281ee6de,0x6919b47e,79106 -DZCBOR_STOP_ON_ERROR -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.4.2/zephyr/kernel/include -IC:/ncs/v2.4.2/zephyr/arch/arm/include -IC:/ncs/v2.4.2/nrf/drivers/mpsl/clock_control -IC:/ncs/v2.4.2/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/ncs/v2.4.2/zephyr/lib/libc/newlib/include -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.4.2/zephyr/subsys/bluetooth -IC:/ncs/v2.4.2/nrf/include -IC:/ncs/v2.4.2/nrf/lib/multithreading_lock/. -IC:/ncs/v2.4.2/nrf/subsys/bluetooth/controller/. -IC:/ncs/v2.4.2/nrf/subsys/nrf_rpc/include -IC:/ncs/v2.4.2/nrf/tests/include -IC:/ncs/v2.4.2/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.4.2/modules/hal/cmsis/CMSIS/DSP/Include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.4.2/zephyr/modules/hal_nordic/nrfx/. -Imodules/libmetal/libmetal/lib/include -IC:/ncs/v2.4.2/modules/lib/open-amp/open-amp/lib/include -IC:/ncs/v2.4.2/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.4.2/modules/lib/zcbor/include -IC:/ncs/v2.4.2/nrfxlib/mpsl/include -IC:/ncs/v2.4.2/nrfxlib/mpsl/include/protocol -IC:/ncs/v2.4.2/nrfxlib/nrf_rpc/include -IC:/ncs/v2.4.2/nrfxlib/nrf_dm/include -IC:/ncs/v2.4.2/nrfxlib/softdevice_controller/include -fno-strict-aliasing -Os -imacros C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/hci_rpmsg/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33+nodsp -mthumb -mabi=aapcs --sysroot=C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.4.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ncs/v2.4.2/zephyr/samples/bluetooth/hci_rpmsg=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.4.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.4.2=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/dm_io.c.obj -MF zephyr\CMakeFiles\zephyr.dir\C_\ncs\v2.4.2\nrf\subsys\dm\dm_io.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/dm_io.c.obj -c C:/ncs/v2.4.2/nrf/subsys/dm/dm_io.c
In file included from C:\ncs\v2.4.2\zephyr\include\zephyr\toolchain.h:50,
from C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.h:10,
from C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.c:7:
C:\ncs\v2.4.2\zephyr\include\zephyr\toolchain\gcc.h:81:36: error: static assertion failed: "You must set the gpios property in the /dm_gpio/dm-ranging node to enable GPIO Debug."
81 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.c:15:1: note: in expansion of macro 'BUILD_ASSERT'
15 | BUILD_ASSERT(HAS_ADD_REQUEST_GPIO,
C:\ncs\v2.4.2\zephyr\include\zephyr\toolchain\gcc.h:81:36: error: static assertion failed: "You must set the gpios property in the /dm_gpio/dm-add-request node to enable GPIO Debug."
C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.c:17:1: note: in expansion of macro 'BUILD_ASSERT'
17 | BUILD_ASSERT(HAS_RANGING_GPIO,
In file included from C:\ncs\v2.4.2\zephyr\include\zephyr\toolchain\gcc.h:92:
C:\ncs\v2.4.2\zephyr\include\zephyr\device.h:84:41: error: '__device_dts_ord_DT_N_NODELABEL_dm_ranging_P_gpios_IDX_0_PH_ORD' undeclared here (not in a function)
C:\ncs\v2.4.2\zephyr\include\zephyr\drivers\gpio.h:331:25: note: in expansion of macro 'DEVICE_DT_GET'
331 | .port = DEVICE_DT_GET(DT_GPIO_CTLR_BY_IDX(node_id, prop, idx)),\
C:\ncs\v2.4.2\zephyr\include\zephyr\drivers\gpio.h:367:9: note: in expansion of macro 'GPIO_DT_SPEC_GET_BY_IDX'
367 | GPIO_DT_SPEC_GET_BY_IDX(node_id, prop, 0)
C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.c:23:50: note: in expansion of macro 'GPIO_DT_SPEC_GET'
23 | static const struct gpio_dt_spec dm_io_ranging = GPIO_DT_SPEC_GET(DM_IO_RANGING_NODE, gpios);
In file included from C:\ncs\v2.4.2\zephyr\include\zephyr\arch\arm\aarch32\arch.h:20,
from C:\ncs\v2.4.2\zephyr\include\zephyr\arch\cpu.h:19,
from C:\ncs\v2.4.2\zephyr\include\zephyr\kernel_includes.h:33:
C:\ncs\v2.4.2\zephyr\include\zephyr\devicetree.h:192:36: error: 'DT_N_NODELABEL_dm_ranging_P_gpios_IDX_0_VAL_pin' undeclared here (not in a function)
192 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
C:\ncs\v2.4.2\zephyr\include\zephyr\devicetree.h:4060:9: note: in definition of macro 'DT_CAT7'
4060 | a1 ## a2 ## a3 ## a4 ## a5 ## a6 ## a7
C:\ncs\v2.4.2\zephyr\include\zephyr\devicetree\gpio.h:164:9: note: in expansion of macro 'DT_PHA_BY_IDX'
164 | DT_PHA_BY_IDX(node_id, gpio_pha, idx, pin)
C:\ncs\v2.4.2\zephyr\include\zephyr\drivers\gpio.h:332:24: note: in expansion of macro 'DT_GPIO_PIN_BY_IDX'
332 | .pin = DT_GPIO_PIN_BY_IDX(node_id, prop, idx), \
C:\ncs\v2.4.2\zephyr\include\zephyr\devicetree.h:192:29: note: in expansion of macro 'DT_CAT'
C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.c:20:33: note: in expansion of macro 'DT_NODELABEL'
20 | #define DM_IO_RANGING_NODE DT_NODELABEL(dm_ranging)
C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.c:23:67: note: in expansion of macro 'DM_IO_RANGING_NODE'
C:\ncs\v2.4.2\zephyr\include\zephyr\device.h:84:41: error: '__device_dts_ord_DT_N_NODELABEL_dm_add_request_P_gpios_IDX_0_PH_ORD' undeclared here (not in a function)
C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.c:25:46: note: in expansion of macro 'GPIO_DT_SPEC_GET'
25 | GPIO_DT_SPEC_GET(DM_IO_ADD_REQUEST_NODE, gpios);
C:\ncs\v2.4.2\zephyr\include\zephyr\devicetree.h:192:36: error: 'DT_N_NODELABEL_dm_add_request_P_gpios_IDX_0_VAL_pin' undeclared here (not in a function)
C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.c:21:33: note: in expansion of macro 'DT_NODELABEL'
21 | #define DM_IO_ADD_REQUEST_NODE DT_NODELABEL(dm_add_request)
C:\ncs\v2.4.2\nrf\subsys\dm\dm_io.c:25:63: note: in expansion of macro 'DM_IO_ADD_REQUEST_NODE'
[54/456] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
[61/503] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/dm.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/dm.c.obj
C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DARM_ALL_FAST_TABLES -DARM_ALL_FFT_TABLES -DARM_DSP_CONFIG_TABLES -DARM_FAST_ALLOW_TABLES -DARM_FFT_ALLOW_TABLES -DARM_TABLE_BITREVIDX_FLT64_1024 -DARM_TABLE_BITREVIDX_FLT64_128 -DARM_TABLE_BITREVIDX_FLT64_16 -DARM_TABLE_BITREVIDX_FLT64_2048 -DARM_TABLE_BITREVIDX_FLT64_256 -DARM_TABLE_BITREVIDX_FLT64_32 -DARM_TABLE_BITREVIDX_FLT64_4096 -DARM_TABLE_BITREVIDX_FLT64_512 -DARM_TABLE_BITREVIDX_FLT64_64 -DARM_TABLE_BITREVIDX_FLT_1024 -DARM_TABLE_BITREVIDX_FLT_128 -DARM_TABLE_BITREVIDX_FLT_16 -DARM_TABLE_BITREVIDX_FLT_2048 -DARM_TABLE_BITREVIDX_FLT_256 -DARM_TABLE_BITREVIDX_FLT_32 -DARM_TABLE_BITREVIDX_FLT_4096 -DARM_TABLE_BITREVIDX_FLT_512 -DARM_TABLE_BITREVIDX_FLT_64 -DARM_TABLE_BITREVIDX_FXT_1024 -DARM_TABLE_BITREVIDX_FXT_128 -DARM_TABLE_BITREVIDX_FXT_16 -DARM_TABLE_BITREVIDX_FXT_2048 -DARM_TABLE_BITREVIDX_FXT_256 -DARM_TABLE_BITREVIDX_FXT_32 -DARM_TABLE_BITREVIDX_FXT_4096 -DARM_TABLE_BITREVIDX_FXT_512 -DARM_TABLE_BITREVIDX_FXT_64 -DARM_TABLE_BITREV_1024 -DARM_TABLE_DCT4_F32_128 -DARM_TABLE_DCT4_F32_2048 -DARM_TABLE_DCT4_F32_512 -DARM_TABLE_DCT4_F32_8192 -DARM_TABLE_DCT4_Q15_128 -DARM_TABLE_DCT4_Q15_2048 -DARM_TABLE_DCT4_Q15_512 -DARM_TABLE_DCT4_Q15_8192 -DARM_TABLE_DCT4_Q31_128 -DARM_TABLE_DCT4_Q31_2048 -DARM_TABLE_DCT4_Q31_512 -DARM_TABLE_DCT4_Q31_8192 -DARM_TABLE_REALCOEF_F32 -DARM_TABLE_REALCOEF_Q15 -DARM_TABLE_REALCOEF_Q31 -DARM_TABLE_RECIP_Q15 -DARM_TABLE_RECIP_Q31 -DARM_TABLE_SIN_F32 -DARM_TABLE_SIN_Q15 -DARM_TABLE_SIN_Q31 -DARM_TABLE_TWIDDLECOEF_F16_1024 -DARM_TABLE_TWIDDLECOEF_F16_128 -DARM_TABLE_TWIDDLECOEF_F16_16 -DARM_TABLE_TWIDDLECOEF_F16_2048 -DARM_TABLE_TWIDDLECOEF_F16_256 -DARM_TABLE_TWIDDLECOEF_F16_32 -DARM_TABLE_TWIDDLECOEF_F16_4096 -DARM_TABLE_TWIDDLECOEF_F16_512 -DARM_TABLE_TWIDDLECOEF_F16_64 -DARM_TABLE_TWIDDLECOEF_F32_1024 -DARM_TABLE_TWIDDLECOEF_F32_128 -DARM_TABLE_TWIDDLECOEF_F32_16 -DARM_TABLE_TWIDDLECOEF_F32_2048 -DARM_TABLE_TWIDDLECOEF_F32_256 -DARM_TABLE_TWIDDLECOEF_F32_32 -DARM_TABLE_TWIDDLECOEF_F32_4096 -DARM_TABLE_TWIDDLECOEF_F32_512 -DARM_TABLE_TWIDDLECOEF_F32_64 -DARM_TABLE_TWIDDLECOEF_F64_1024 -DARM_TABLE_TWIDDLECOEF_F64_128 -DARM_TABLE_TWIDDLECOEF_F64_16 -DARM_TABLE_TWIDDLECOEF_F64_2048 -DARM_TABLE_TWIDDLECOEF_F64_256 -DARM_TABLE_TWIDDLECOEF_F64_32 -DARM_TABLE_TWIDDLECOEF_F64_4096 -DARM_TABLE_TWIDDLECOEF_F64_512 -DARM_TABLE_TWIDDLECOEF_F64_64 -DARM_TABLE_TWIDDLECOEF_Q15_1024 -DARM_TABLE_TWIDDLECOEF_Q15_128 -DARM_TABLE_TWIDDLECOEF_Q15_16 -DARM_TABLE_TWIDDLECOEF_Q15_2048 -DARM_TABLE_TWIDDLECOEF_Q15_256 -DARM_TABLE_TWIDDLECOEF_Q15_32 -DARM_TABLE_TWIDDLECOEF_Q15_4096 -DARM_TABLE_TWIDDLECOEF_Q15_512 -DARM_TABLE_TWIDDLECOEF_Q15_64 -DARM_TABLE_TWIDDLECOEF_Q31_1024 -DARM_TABLE_TWIDDLECOEF_Q31_128 -DARM_TABLE_TWIDDLECOEF_Q31_16 -DARM_TABLE_TWIDDLECOEF_Q31_2048 -DARM_TABLE_TWIDDLECOEF_Q31_256 -DARM_TABLE_TWIDDLECOEF_Q31_32 -DARM_TABLE_TWIDDLECOEF_Q31_4096 -DARM_TABLE_TWIDDLECOEF_Q31_512 -DARM_TABLE_TWIDDLECOEF_Q31_64 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_128 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_32 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_4096 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F16_64 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_128 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_32 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_4096 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F32_64 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_1024 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_128 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_2048 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_256 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_32 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_4096 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_512 -DARM_TABLE_TWIDDLECOEF_RFFT_F64_64 -DDISABLEFLOAT16 -DKERNEL -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.4.2/zephyr/kernel/include -IC:/ncs/v2.4.2/zephyr/arch/arm/include -IC:/ncs/v2.4.2/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/ncs/v2.4.2/zephyr/lib/libc/newlib/include -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.4.2/zephyr/subsys/usb/device -IC:/ncs/v2.4.2/zephyr/subsys/bluetooth -IC:/ncs/v2.4.2/nrf/include -IC:/ncs/v2.4.2/nrf/tests/include -IC:/ncs/v2.4.2/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.4.2/modules/hal/cmsis/CMSIS/DSP/Include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.4.2/zephyr/modules/hal_nordic/nrfx/. -Imodules/libmetal/libmetal/lib/include -IC:/ncs/v2.4.2/modules/lib/open-amp/open-amp/lib/include -IC:/ncs/v2.4.2/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.4.2/nrfxlib/nrf_dm/include -IC:/ncs/v2.4.2/nrfxlib/softdevice_controller/include -isystem C:/ncs/v2.4.2/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros C:/nordic/myApps/nrf_dm_4/build_thingy53_nrf5340_cpuapp/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard --sysroot=C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.4.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/nordic/myApps/nrf_dm_4=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.4.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.4.2=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/dm.c.obj -MF zephyr\CMakeFiles\zephyr.dir\C_\ncs\v2.4.2\nrf\subsys\dm\dm.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrf/subsys/dm/dm.c.obj -c C:/ncs/v2.4.2/nrf/subsys/dm/dm.c
C:\ncs\v2.4.2\nrf\subsys\dm\dm.c:14:10: fatal error: mpsl_timeslot.h: No such file or directory
14 | #include <mpsl_timeslot.h>
compilation terminated.
[69/503] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/modules/crypto/tinycrypt/lib/source/cmac_mode.c.obj
FAILED: modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-build hci_rpmsg/zephyr/zephyr.hex hci_rpmsg/zephyr/zephyr.elf hci_rpmsg/zephyr/merged_CPUNET.hex
cmd.exe /C "cd /D C:\nordic\myApps\nrf_dm_4\build_thingy53_nrf5340_cpuapp\hci_rpmsg && C:\ncs\toolchains\31f4403e35\opt\bin\cmake.exe --build . --"
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\31f4403e35\opt\bin\cmake.EXE' --build 'C:\nordic\myApps\nrf_dm_4\build_thingy53_nrf5340_cpuapp'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Home",
    "osKernel": "10.0.22621",
    "vscode": "1.82.2",
    "electron": "25.8.1",
    "node": "v18.15.0"
  "system": {
    "date": "2023-09-16T01:42:25.325Z",
    "vscodeRoot": "c:\\Users\\mej\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:01:54",
    "osUptime": "28:43:22",
    "cpu": {
      "model": "11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz",
      "speed": "2803 MHz",
      "count": 4
    "memory": {
      "total": "15.68 GB",
      "free": "5.86 GB"
  "workspace": {
    "name": "nrf_dm",
    "workspaceFile": null,
    "folders": [
      "c:\\ncs\\v2.4.2\\nrf\\samples\\bluetooth\\nrf_dm"
  "extensions": {
    "internal": {
        "version": "2023.9.169",
        "path": "c:\\Users\\mej\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.9.169-win32-x64",
        "isActive": true
        "version": "2023.9.29",
        "path": "c:\\Users\\mej\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2023.9.29",
        "isActive": true
        "version": "2023.9.57",
        "path": "c:\\Users\\mej\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2023.9.57",
        "isActive": true
        "version": "2023.9.31",
        "path": "c:\\Users\\mej\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2023.9.31",
        "isActive": true
    "external": {
      "marus25.cortex-debug": "1.12.1",
      "ms-vscode.cpptools": "1.17.5",
      "ms-vscode-remote.remote-wsl-recommender": "0.0.19",
      "ms-vscode.js-debug": "1.82.0",
      "ms-vscode.js-debug-companion": "1.1.2",
      "ms-vscode.vscode-js-profile-table": "1.0.3",
      "cschlosser.doxdocgen": "1.4.0",
      "Dart-Code.dart-code": "3.72.2",
      "Dart-Code.flutter": "3.72.0",
      "emmanuelbeziat.vscode-great-icons": "2.1.98",
      "FernandoKuteken.verbatim-tools": "0.0.1",
      "jeff-hykin.better-cpp-syntax": "1.17.2",
      "mcu-debug.debug-tracker-vscode": "0.0.15",
      "mcu-debug.memory-view": "0.0.24",
      "mcu-debug.peripheral-viewer": "1.4.6",
      "mcu-debug.rtos-views": "0.0.7",
      "mrverdant13.esp32-pm": "0.1.0",
      "ms-dotnettools.csharp": "2.1.2",
      "ms-dotnettools.vscode-dotnet-runtime": "1.7.3",
      "ms-python.isort": "2023.10.1",
      "ms-python.python": "2023.16.0",
      "ms-python.vscode-pylance": "2023.9.10",
      "ms-toolsai.jupyter": "2023.8.1002501831",
      "ms-toolsai.jupyter-keymap": "1.1.2",
      "ms-toolsai.jupyter-renderers": "1.0.17",
      "ms-toolsai.vscode-jupyter-cell-tags": "0.1.8",
      "ms-toolsai.vscode-jupyter-slideshow": "0.1.5",
      "ms-vscode.cmake-tools": "1.15.31",
      "ms-vscode.vscode-serial-monitor": "0.10.0",
      "pdconsec.vscode-print": "0.11.15",
      "twxs.cmake": "0.0.17",
      "vsciot-vscode.vscode-arduino": "0.6.0",
      "vscjava.vscode-gradle": "3.12.7"
  "tools": {
    "C:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.0",
    "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.88j",
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.23.0",
    "nrfutil": "Not found",
    "C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\cmake.exe": "3.20.5",
    "C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\Scripts\\west.exe": "1.0.0",
    "C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\python.exe": "3.8.2",
    "C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\ninja.exe": "1.9.0",
    "C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\gperf.exe": "3.1",
    "C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\dtc.exe": "1.4.7",
    "C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\gn.exe": "2105",
    "C:\\ncs\\toolchains\\31f4403e35\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "gdbPath": "c:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
  "sdks": [
      "version": "2.4.2",
      "path": "c:\\ncs\\v2.4.2"
  "toolchains": [
      "version": "2.4.2",
      "path": "c:\\ncs\\toolchains\\31f4403e35"
  "connectedDevices": [],
  "deviceProvider": "nrfutil",
  "config": {
      "topdir": "${nrf-connect.sdk:2.4.1}",
      "toolchain": {
        "path": "${nrf-connect.toolchain:2.4.2}"
      "ozonePath": "",
      "applications": [],
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig",
        "executeInDefaultShell": false
      "welcome": {
        "showOnStartup": false
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "taskBindings": {},
      "debugging": {
        "flash": true,
        "bindings": {}
      "enableTelemetry": false,
      "thirdpartyIntegration": {},
      "toolchainManager": {
        "indexURL": null,
        "installDirectory": null
      "nrfutil": {
        "home": null
      "terminalMode": "character"
    "marus25.cortex-debug": {
      "variableUseNaturalFormat": true,
      "liveWatchRefreshRate": "300",
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "enableTelemetry": true,
      "dbgServerLogfile": null
  "environment": {
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "C:\\Users\\mej",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\mej",
      "PATH": "C:\\ncs\\toolchains\\31f4403e35;C:\\ncs\\toolchains\\31f4403e35\\mingw64\\bin;C:\\ncs\\toolchains\\31f4403e35\\bin;C:\\ncs\\toolchains\\31f4403e35\\opt\\bin;C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\31f4403e35\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;C:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;C:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\Users\\mej\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.9.169-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Microchip\\xc8\\v2.41\\bin;C:\\Program Files\\Microchip\\xc32\\v4.21\\bin;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\CMake\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\mej\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\mej\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Users\\mej\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\mej\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\mej\\AppData\\Local\\Programs\\Git\\cmd;C:\\Program Files\\CMake\\bin;",
      "ZEPHYR_BASE": "c:\\ncs\\v2.4.2\\zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk",
      "PYTHONPATH": "C:\\ncs\\toolchains\\31f4403e35\\opt\\bin;C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\Lib;C:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\Lib\\site-packages"
    "inherited": {
      "HOMEDRIVE": "C:",
      "Path": "C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Microchip\\xc8\\v2.41\\bin;C:\\Program Files\\Microchip\\xc32\\v4.21\\bin;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\CMake\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\mej\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\mej\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Users\\mej\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\mej\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\mej\\AppData\\Local\\Programs\\Git\\cmd;C:\\Program Files\\CMake\\bin;",
      "PATH": "C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Microchip\\xc8\\v2.41\\bin;C:\\Program Files\\Microchip\\xc32\\v4.21\\bin;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\CMake\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\mej\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\mej\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Users\\mej\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\mej\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\mej\\AppData\\Local\\Programs\\Git\\cmd;C:\\Program Files\\CMake\\bin;"
    "toolchainPath": "c:\\ncs\\toolchains\\31f4403e35",
    "toolchainBinPath": "c:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
    "toolchainVersion": "2.4.2"
  "terminal": {
    "defaultProfile": null
 nrf_dm attempts.zip
  • I have nrf_dm running on two nrf52832dk boards working perfectly. I can read the information in the UART. But I need help interpreting the BLE data.
    I can see the 3 characteristics that return measurements:
    /** @brief UUID of the Distance Measurement Characteristic. **/
    #define BT_UUID_DDFS_DISTANCE_MEAS_VAL \
    BT_UUID_128_ENCODE(0x21490001, 0x494a, 0x4573, 0x98af, 0xf126af76f490)
    /** @brief UUID of the Azimuth Measurement Characteristic. **/
    #define BT_UUID_DDFS_AZIMUTH_MEAS_VAL \
    BT_UUID_128_ENCODE(0x21490002, 0x494a, 0x4573, 0x98af, 0xf126af76f490)
    /** @brief UUID of the Elevation Measurement Characteristic. **/
    #define BT_UUID_DDFS_ELEVATION_MEAS_VAL \
    BT_UUID_128_ENCODE(0x21490003, 0x494a, 0x4573, 0x98af, 0xf126af76f490)
    From the 3 different notifies I get BLE data such as:
    DISTANCE_MEAS_VAL: 0x020082BA2E1FAEC601050009000C000500
    AZIMUTH_MEAS_VAL: 0x0000FFEEDDCCBBAA011401
    ELEVATION_MEAS_VAL: 0x0002FFEEDDCCBBAA01F5
    I assume the above is meant to be read into an application and not just used/required for the distance measurement firmware? If so, I need help on how to turn the above into decimal information. thanks!
