eddystone message at receiver andriod app nrf connect
Hi All!
I am using nrf52833Dk, NCS Version 2.3.0, and Added a coded phy connectable beacon feature in the "Uart Peripheral" example . It worked fine when I tested it with another nrf52833DK.
I am sending the following Eddystone packet .But on nrf connect andriod app unable to view the Eddystone format. Andriod nrf connect app image also attached.
uint8_t  raw_adv_data[] = {
       0x02, 0x01, 0x06,
       0x03, 0x03, 0xaa, 0xfe, 0x17, 0x16, 0xaa, 0xfe,
       0x00, 0x12, 0xDE, 0x33,
       0x00,
       0xA1,
       0x2D,0x0D,0x29,0x67,0xA1,0x31,0x6C,
       0xF0,                                                     //Tank Level 0
       0xAA,                                                     //Tank Level 1
       0xFF,                                                     //Vbat
       0x00, 0x00,
       0x00, 0x00                                                //Device ID B Always 0000
Nrf connect andriod app images
My main.c code is
 * Copyright (c) 2018 Nordic Semiconductor ASA
/** @file
 *  @brief Nordic UART Bridge Service (NUS) sample
#include "uart_async_adapter.h"
#include <zephyr/types.h>
#include <zephyr/kernel.h>
#include <zephyr/drivers/uart.h>
#include <zephyr/usb/usb_device.h>
#include <zephyr/device.h>
#include <soc.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/hci.h>
#include <bluetooth/services/nus.h>
#include <dk_buttons_and_leds.h>
#include <zephyr/settings/settings.h>
#include <stdio.h>
#include <zephyr/drivers/spi.h>
#include<zephyr/devicetree.h>
//.............................  code added .................................
#include <zephyr/drivers/i2c.h>
#include <stdio.h>
#include "Tlv493d.h"
#include "Loading_Events.h"
#include "Timers.h"
#define SLEEP_TIME_MS 1000
#define I2C0_NODE DT_NODELABEL(mysensor)   // line added
#define my_stack_size 512
#define priority 5
#define LOG_MODULE_NAME peripheral_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME,LOG_LEVEL_DBG);
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED2
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
#define SPI_DEV_NAME "spi_3"
#define cs  DT_ALIAS(led1)// 11 for nrf52833
#define pdn DT_ALIAS(led2)// 28 for nrf52833
static struct k_work start_advertising_worker;
static struct bt_le_ext_adv *adv;
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
static struct k_work_delayable uart_work;
struct uart_data_t {
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
#if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
#else
static const struct device *const async_adapter;
///////////////////////////////  code added /////////////////////////////////////////
const struct device * spi_dev;
static struct spi_config spi_cfg = {
	.operation = SPI_WORD_SET(8)
	         | SPI_OP_MODE_MASTER
             | SPI_TRANSFER_MSB
            // | SPI_MODE_CPOL
            // | SPI_MODE_CPHA
	.frequency = 4000000,
	.slave = 0,
	//.cs=NULL,
static const struct gpio_dt_spec cs_low = GPIO_DT_SPEC_GET(cs, gpios);
static const struct gpio_dt_spec pdn_high = GPIO_DT_SPEC_GET(pdn, gpios);
static struct spi_buf rx;
const struct spi_buf_set rx_bufs = {
	.buffers = &rx,
	.count = 1
static struct spi_buf tx;
const struct spi_buf_set tx_bufs = {
	.buffers = &tx,
	.count = 1
static void spi_init(void)
	spi_dev = device_get_binding(SPI_DEV_NAME);
    // code added
	   if (!spi_dev) {
        printk("SPI device not found\n");
        return;
void Nrf21540_Write_Register()
		int err,ret;
	static uint8_t tx_buffer[2] = {0xC0, 0x7D};   //  0x7D = 31 ,0x45 = 11 , 0x05  ,// write command to confreg0 (1100 0000 /0xC0) , 0x7D = Tx_En =1 , Mode =0 , Tx gain 11111
		tx.buf = tx_buffer;
		tx.len = sizeof(tx_buffer);
		static uint8_t rx_buffer[2];
		rx.buf = rx_buffer;
		rx.len = sizeof(rx_buffer);
		ret = gpio_pin_set_dt(&cs_low,0);  // low
			if (ret < 0) {
				return;
//err = spi_transceive(spi_dev, &spi_cfg, &tx_bufs, &rx_bufs);   //rx_bufs
	err =  spi_write(spi_dev,&spi_cfg,&tx_bufs);
			if (err < 0) {
				printf("SPI error: %d\n", err);
			} else {
	   printf("write successfully : %d\n", err);
		for (int i = 0; i <2; i++){
			printf(" %x",rx_buffer[i]);
    printf("\n");
    ret = gpio_pin_set_dt(&cs_low,1);   // high
		if (ret < 0) {
			return;
void Nrf21540_Read_Register()
    int err,ret;
    static uint8_t tx_buffer[2] = {0x80, 0x00};   //  0x80 for reading register confreg0 ,0x8 1000 0000 for reading
    tx.buf = tx_buffer;
	rx.buf = rx_buffer;
		if (ret < 0) {
			return;
 //err =  spi_write(spi_dev,&spi_cfg,&tx_bufs);
//err =  spi_read(spi_dev,&spi_cfg,&rx_bufs);
	if (err < 0) {
		printk("SPI error: %d\n", err);
	} else if (err==0){
	    printf("Read successfully : %d\n", err);
    printf("\n");
		if (ret < 0) {
			return;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static size_t aborted_len;
	struct uart_data_t *buf;
	static uint8_t *aborted_buf;
	static bool disable_req;
	switch (evt->type) {
	case UART_TX_DONE:
		LOG_DBG("UART_TX_DONE");
		if ((evt->data.tx.len == 0) ||
		    (!evt->data.tx.buf)) {
			return;
		if (aborted_buf) {
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
					   data);
			aborted_buf = NULL;
			aborted_len = 0;
		} else {
			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
					   data);
		k_free(buf);
		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		if (!buf) {
			return;
		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
			LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		LOG_DBG("UART_RX_RDY");
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		if (disable_req) {
			return;
		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
		    (evt->data.rx.buf[buf->len - 1] == '\r')) {
			disable_req = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		LOG_DBG("UART_RX_DISABLED");
		disable_req = false;
		buf = k_malloc(sizeof(*buf));
		if (buf) {
			buf->len = 0;
		} else {
			LOG_WRN("Not able to allocate UART receive buffer");
			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
			       UART_WAIT_FOR_RX);
	case UART_RX_BUF_REQUEST:
		LOG_DBG("UART_RX_BUF_REQUEST");
		if (buf) {
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
		} else {
	case UART_RX_BUF_RELEASED:
		LOG_DBG("UART_RX_BUF_RELEASED");
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
				   data);
		if (buf->len > 0) {
			k_fifo_put(&fifo_uart_rx_data, buf);
		} else {
			k_free(buf);
	case UART_TX_ABORTED:
		LOG_DBG("UART_TX_ABORTED");
		if (!aborted_buf) {
			aborted_buf = (uint8_t *)evt->data.tx.buf;
		aborted_len += evt->data.tx.len;
				   data);
		uart_tx(uart, &buf->data[aborted_len],
			buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf) {
		buf->len = 0;
	} else {
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
static bool uart_test_async_api(const struct device *dev)
	const struct uart_driver_api *api =
			(const struct uart_driver_api *)dev->api;
	return (api->callback_set != NULL);
static int uart_init(void)
	int err;
	int pos;
	struct uart_data_t *rx;
	struct uart_data_t *tx;
	if (!device_is_ready(uart)) {
		return -ENODEV;
	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
		err = usb_enable(NULL);
		if (err) {
			LOG_ERR("Failed to enable USB");
			return err;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx->len = 0;
	} else {
		return -ENOMEM;
	k_work_init_delayable(&uart_work, uart_work_handler);
	if (IS_ENABLED(CONFIG_BT_NUS_UART_ASYNC_ADAPTER) && !uart_test_async_api(uart)) {
		/* Implement API adapter */
		uart_async_adapter_init(async_adapter, uart);
		uart = async_adapter;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		LOG_ERR("Cannot initialize UART callback");
		return err;
	if (IS_ENABLED(CONFIG_UART_LINE_CTRL)) {
		LOG_INF("Wait for DTR");
		while (true) {
			uint32_t dtr = 0;
			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &dtr);
			if (dtr) {
			/* Give CPU resources to low priority threads. */
			k_sleep(K_MSEC(100));
		LOG_INF("DTR set");
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
		if (err) {
			LOG_WRN("Failed to set DCD, ret code %d", err);
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
		if (err) {
			LOG_WRN("Failed to set DSR, ret code %d", err);
	tx = k_malloc(sizeof(*tx));
	if (tx) {
		pos = snprintf(tx->data, sizeof(tx->data),
			       "Starting Nordic UART service example\r\n");
		if ((pos < 0) || (pos >= sizeof(tx->data))) {
			k_free(tx);
			LOG_ERR("snprintf returned %d", pos);
			return -ENOMEM;
		tx->len = pos;
	} else {
		return -ENOMEM;
	err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
	if (err) {
		LOG_ERR("Cannot display welcome message (err: %d)", err);
		return err;
	return uart_rx_enable(uart, rx->data, sizeof(rx->data), 50);
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		LOG_ERR("Connection failed (err %u)", err);
		return;
	LOG_INF("Connected %s", addr);
	current_conn = bt_conn_ref(conn);
	dk_set_led_on(CON_STATUS_LED);
	LOG_INF("Disconnected: %s (reason %u)", addr, reason);
	if (auth_conn) {
		bt_conn_unref(auth_conn);
		auth_conn = NULL;
	if (current_conn) {
		bt_conn_unref(current_conn);
		current_conn = NULL;
		dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		LOG_INF("Security changed: %s level %u", addr,
			level);
	} else {
		LOG_WRN("Security failed: %s level %u err %d", addr,
			level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected    = connected,
	.disconnected = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	LOG_INF("Passkey for %s: %06u", addr, passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
	auth_conn = bt_conn_ref(conn);
	LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", addr,
		bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_INF("Pairing failed conn: %s, reason %d", addr,
		reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.passkey_confirm = auth_passkey_confirm,
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
			  uint16_t len)
	int err;
	char addr[BT_ADDR_LE_STR_LEN] = {0};
	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
	LOG_INF("Received data from: %s", addr);
	for (uint16_t pos = 0; pos != len;) {
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx) {
			LOG_WRN("Not able to allocate UART send data buffer");
			return;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) - 1;
		if ((len - pos) > tx_data_size) {
			tx->len = tx_data_size;
		} else {
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r')) {
			tx->data[tx->len] = '\n';
			tx->len++;
		if (err) {
			k_fifo_put(&fifo_uart_tx_data, tx);
static struct bt_nus_cb nus_cb = {
	.received = bt_receive_cb,
void error(void)
	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
	while (true) {
		/* Spin for ever */
		k_sleep(K_MSEC(1000));
static void num_comp_reply(bool accept)
	if (accept) {
		bt_conn_auth_passkey_confirm(auth_conn);
		LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
	} else {
		bt_conn_auth_cancel(auth_conn);
		LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
	auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
	uint32_t buttons = button_state & has_changed;
	if (auth_conn) {
		if (buttons & KEY_PASSKEY_ACCEPT) {
			num_comp_reply(true);
		if (buttons & KEY_PASSKEY_REJECT) {
			num_comp_reply(false);
#endif /* CONFIG_BT_NUS_SECURITY_ENABLED */
static void configure_gpio(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		LOG_ERR("Cannot init buttons (err: %d)", err);
	err = dk_leds_init();
	if (err) {
		LOG_ERR("Cannot init LEDs (err: %d)", err);
static void start_advertising_coded(struct k_work *item)
	int err;
	err = bt_le_ext_adv_start(adv, NULL);
	if (err) {
		printk("Failed to start advertising set (%d)\n", err);
		return;
	printk("Advertiser %p set started\n", adv);
static int create_advertising_coded(void)
	int err;
	struct bt_le_adv_param param =
		BT_LE_ADV_PARAM_INIT(BT_LE_ADV_OPT_CONNECTABLE |
				     BT_LE_ADV_OPT_EXT_ADV |
					 BT_LE_ADV_OPT_USE_TX_POWER |
				     BT_LE_ADV_OPT_CODED,
				     BT_GAP_ADV_FAST_INT_MIN_2,
				     BT_GAP_ADV_FAST_INT_MAX_2,
				     NULL);
	err = bt_le_ext_adv_create(&param, NULL, &adv);
	if (err) {
		printk("Failed to create advertiser set (%d)\n", err);
		return err;
	printk("Created adv: %p\n", adv);
	err = bt_le_ext_adv_set_data(adv, ad, ARRAY_SIZE(ad), NULL, 0);
	if (err) {
		printk("Failed to set advertising data (%d)\n", err);
		return err;
	return 0;
static void bt_ready(void)
	int err = 0;
	printk("Bluetooth initialized\n");
	k_work_init(&start_advertising_worker, start_advertising_coded);
	err = create_advertising_coded();
	if (err) {
		printk("Advertising failed to create (err %d)\n", err);
		return;
	k_work_submit(&start_advertising_worker);
//static const struct gpio_dt_spec pdn_high = GPIO_DT_SPEC_GET(pdn, gpios);
static const struct i2c_dt_spec dev_i2c = I2C_DT_SPEC_GET(I2C0_NODE);
//struct k_timer my_timer;     // timer struct defined
//struct k_work_q tlv493d_work_q;
extern float * Average_Values;
extern float  AverageX,AverageY;
extern void mytimer_cb(struct k_timer *dummy);
extern void tlv493D_work_cb(struct k_work_q * work);
K_WORK_DEFINE(tlv493d_work,tlv493D_work_cb);
K_TIMER_DEFINE(my_timer,mytimer_cb,NULL);
void main(void)
	int blink_status = 0;
	int err = 0;
	int ret;
	configure_gpio();
  	err = uart_init();
	if (err) {
		error();
//..................................... code added .......................................................
    spi_init();
	if (!device_is_ready(cs_low.port)) {
		return;
	ret = gpio_pin_configure_dt(&cs_low, GPIO_OUTPUT_ACTIVE);
	ret = gpio_pin_configure_dt(&pdn_high ,GPIO_OUTPUT_ACTIVE);
	if (ret < 0) {
		return;
 ret = gpio_pin_set_dt(&pdn_high,1);  // 0.28 nrf21540 always high
		if (ret < 0) {
			return;
         printk("PDN high at start up ...\n");
	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
		err = bt_conn_auth_cb_register(&conn_auth_callbacks);
		if (err) {
			printk("Failed to register authorization callbacks.\n");
			return;
		err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
		if (err) {
			printk("Failed to register authorization info callbacks.\n");
			return;
	err = bt_enable(NULL);
	if (err) {
		error();
	LOG_INF("Bluetooth initialized");
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
   bt_ready();
	err = bt_nus_init(&nus_cb);
	if (err) {
		LOG_ERR("Failed to initialize UART service (err: %d)", err);
		return;
	/*err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
			      ARRAY_SIZE(sd));
	if (err) {
		LOG_ERR("Advertising failed to start (err %d)", err);
		printk("Advertising failed to start (err %d)", err);
		return;
    Nrf21540_Write_Register();
    k_msleep(100);
    Nrf21540_Read_Register();
     k_msleep(100);
	if(!device_is_ready(dev_i2c.bus)){
		printf("i2c_dev not ready\n");
		return;
 /* ret = i2c_reg_write_byte_dt(&dev_i2c,0x00,0x01);   // added 7/12/2023
	if(ret != 0){
	printk("Failed to write/read I2C device address %x at Reg. %x \r\n", dev_i2c.addr,0x00);
k_timer_start(&my_timer,K_SECONDS(5),K_SECONDS(1));
  /* Average_Values= Read_Sensor_Calc_Average();
   AverageX= *(Average_Values);
   AverageY= *(Average_Values+1);
  Raw_Avg_Data_To_Angle(AverageX , AverageY);
 // k_msleep(SLEEP_TIME_MS);
/*	for (;;) {
	//	dk_set_led(led0, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
void ble_write_thread(void)
	/* Don't go any further until BLE is initialized */
	k_sem_take(&ble_init_ok, K_FOREVER);
	for (;;) {
		/* Wait indefinitely for data to be sent over bluetooth */
		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
						     K_FOREVER);
        for(int i=0; i<buf->len; i++)
		printk("%c",buf->data[i]);
		if (bt_nus_send(NULL, buf->data, buf->len)) {
			LOG_WRN("Failed to send data over BLE connection");
		k_free(buf);
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
		NULL, PRIORITY, 0, 0);
code for sending the packet
   error1=bt_nus_send(NULL,raw_adv_data,sizeof(raw_adv_data));
   if(error1<0) {
		//LOG_WRN("Failed to send data over BLE connection");
    printf("Failed to send data over BLE connection, error is for DK is ... %d", error1);
    //  LOG_WRN("Failed to set DSR, ret code %d", error1);
Can you please help me with what I am doing wrong?
Thanks & Regards,
Muhammad Usman
