Connection request failed
Dear Nordic,
I would like to inquire about a technical issue regarding the nRF7002DK. I am attempting to run the WiFi Shell example on the development board, but I am encountering a "Connection request failed" problem. I have searched online for solutions, but have been unable to find any. I would like to ask for your insights on the possible cause of this issue and any potential solutions.
Here are the details of my development environment:
SDK version: nRF Connect SDK v2.4.0
Toolchain version: nRF Connect SDK Toolchain v2.4.0
Development environment: Windows 11
Development tool: Visual Studio Code
Development board: nRF7002DK nrf7002dk_nrf5340_cpuapp
Example project path: v2.4.0\nrf\samples\wifi\shell
Here is the result of my attempt to run the example:
Compilation completed and the board was successfully flashed and reset.
uart:~$ DJ[00:00:00.290,496] <inf> wifi_nrf: Firmware (v1.2.8.1) booted successfully
uart:~$ DJ[00:00:00.426,208] <inf> fs_nvs: 6 Sectors of 4096 bytes
uart:~$ DJ[00:00:00.426,239] <inf> fs_nvs: alloc wra: 0, fe8
uart:~$ DJ[00:00:00.426,239] <inf> fs_nvs: data wra: 0, 0
uart:~$ DJ*** Booting Zephyr OS build v3.3.99-ncs1 ***
uart:~$ DJStarting nrf7002dk_nrf5340_cpuapp with CPU frequency: 128 MHz
Sent the WiFi scan command.
wifi scan
Scan requested
uart:~$ DJ
Num  | SSID                             (len) | Chan (Band)   | RSSI | Security        | BSSID             | MFP
uart:~$ DJ1    | NETGEAR                          7     | 6    (2.4GHz) | -17  | WPA2-PSK        | DA:4F:D1:C1:94:53 | Disable
uart:~$ DJ2    | NETGEAR89                        9     | 13   (2.4GHz) | -21  | WPA2-PSK        | A0:36:BC:75:00:58 | Disable
uart:~$ DJ3    |                                  0     | 11   (2.4GHz) | -24  | OPEN            | 08:79:8C:29:F9:BF | Disable
uart:~$ DJ4    | ChinaNet-NtA7                    13    | 11   (2.4GHz) | -27  | WPA2-PSK        | 08:79:8C:29:F9:BC | Disable
uart:~$ DJ5    | NETGEAR89                        9     | 149  (5GHz  ) | -28  | WPA2-PSK        | A0:36:BC:75:00:5C | Disable
uart:~$ DJ6    | ChinaNet-NtA7                    13    | 36   (5GHz  ) | -29  | WPA2-PSK        | 00:6B:6F:EF:99:40 | Disable
uart:~$ DJ7    | ChinaNet-NtA7                    13    | 36   (5GHz  ) | -36  | WPA2-PSK        | 08:79:8C:29:F9:C0 | Disable
uart:~$ DJ8    |                                  0     | 36   (5GHz  ) | -36  | OPEN            | 08:79:8C:29:F9:C3 | Disable
uart:~$ DJ9    | ChinaNet-NtA7                    13    | 6    (2.4GHz) | -39  | WPA2-PSK        | 00:6B:6F:EF:99:3C | Disable
uart:~$ DJ10   | 608                              3     | 11   (2.4GHz) | -58  | WPA2-PSK        | AC:E3:42:53:52:E4 | Disable
uart:~$ DJ11   | ES-740948                        9     | 11   (2.4GHz) | -59  | WPA2-PSK        | 58:48:49:09:93:A0 | Disable
uart:~$ DJ12   | 708                              3     | 1    (2.4GHz) | -59  | WPA2-PSK        | 8C:A6:DF:01:B5:6E | Disable
uart:~$ DJ13   | 704                              3     | 2    (2.4GHz) | -68  | WPA2-PSK        | 78:D3:8D:C5:59:88 | Disable
uart:~$ DJ14   | LC                               2     | 8    (2.4GHz) | -70  | WPA-PSK         | D4:DA:21:93:4C:84 | Disable
uart:~$ DJScan request done
Attempted to connect to a WiFi network.
uart:~$ wifi connect NETGEAR 12345678q
Connection request failed.
I suspect that there might be an issue with my development board, but I couldn't find any similar reports online. Therefore, I would appreciate your insights on the possible cause of this problem and any potential solutions.
Thank you very much for your assistance!
Liang
