NB-IoT network connectivity issue
We successfully connected NB-IoT network on nRF9160 kit in NB-IoT simulation testing lab, but it disconnects with network after sometime. We disabled PSM mode and that improved the connection time but still after 2 – 3 minutes Nordic kit left the network automatically. We tried no. of times, but each time Nordic kit left the NB-IoT network after 2 -3 minutes.
We want to know the reason Why Nordic kit left the NB-IoT network after 2 -3 minutes even with PSM mode disabled? Is there any other sleep mode that creates this issue? Please suggest.
  • Hi Paresh,
    Please check the following suggestion.
    1) There is a high chance this is related to your NB-IoT callbox configuration. Make sure the lab has tested with standard NB-IoT to confirm this setup works. You can also test with a real NB-IoT network to confirm if the device causes the issue.
    2) If it is the issue of nRF9160DK, please share the HW, FW and MFW versions you are using. The log and modem traces are very important for failure analysis.
    Charlie
  • Hi Charlie,
    Thanks for your reply.
    Yes, the Lab has tested with standard NB-IoT setup and facing disconnectivity issue with nRF9160 DK, other NB-IoT supported devices are working well. We will test Nordic Kit with a real NB-IoT network and share the results, but it will take some time.
    HWVERSION Ver: nRF9160 SICA B1A
     FW Ver: +CGMRmfw_nrf9160_1.3.4
    Also find attached log file for your reference.
    2023-09-18T06:47:50.187Z DEBUG Application data folder: C:\Users\159023\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2023-09-18T06:47:50.361Z DEBUG App pc-nrfconnect-linkmonitor v2.0.4 local
    2023-09-18T06:47:50.362Z DEBUG App path: C:\Users\159023\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2023-09-18T06:47:50.362Z DEBUG nRFConnect 4.1.2, required by the app is (>=4.0.0)
    2023-09-18T06:47:50.363Z DEBUG nRFConnect path: C:\Users\159023\AppData\Local\Programs\nrfconnect\resources\app.asar
    2023-09-18T06:47:50.363Z DEBUG HomeDir: C:\Users\159023
    2023-09-18T06:47:50.363Z DEBUG TmpDir: C:\Users\159023\AppData\Local\Temp
    2023-09-18T06:47:51.055Z INFO Using nrf-device-lib-js version: 0.6.12
    2023-09-18T06:47:51.057Z INFO Using nrf-device-lib version: 0.15.3
    2023-09-18T06:47:51.058Z INFO Using nrfjprog DLL version: 10.19.1
    2023-09-18T06:47:51.060Z INFO Using JLink version: JLink_V7.80c
    2023-09-18T06:48:32.154Z INFO Modem port is opened
    2023-09-18T06:48:32.192Z DEBUG modem >> AT+CFUN?
    2023-09-18T06:48:32.249Z DEBUG modem << +CFUN: 1
    2023-09-18T06:48:32.259Z DEBUG modem << OK
    2023-09-18T06:48:32.301Z DEBUG modem >> AT+CGSN=1
    2023-09-18T06:48:32.329Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T06:48:32.341Z DEBUG modem << OK
    2023-09-18T06:48:32.368Z DEBUG modem >> AT+CGMI
    2023-09-18T06:48:32.391Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T06:48:32.399Z DEBUG modem << OK
    2023-09-18T06:48:32.425Z DEBUG modem >> AT+CGMM
    2023-09-18T06:48:32.450Z DEBUG modem << nRF9160-SICA
    2023-09-18T06:48:32.463Z DEBUG modem << OK
    2023-09-18T06:48:32.481Z DEBUG modem >> AT+CGMR
    2023-09-18T06:48:32.498Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T06:48:32.503Z DEBUG modem << OK
    2023-09-18T06:48:32.512Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T06:48:32.527Z DEBUG modem >> AT+CEMODE?
    2023-09-18T06:48:32.544Z DEBUG modem << +CEMODE: 0
    2023-09-18T06:48:32.549Z DEBUG modem << OK
    2023-09-18T06:48:32.584Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T06:48:32.618Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T06:48:32.629Z DEBUG modem << OK
    2023-09-18T06:48:32.665Z DEBUG modem >> AT+CMEE?
    2023-09-18T06:48:32.685Z DEBUG modem << +CMEE: 0
    2023-09-18T06:48:32.695Z DEBUG modem << OK
    2023-09-18T06:48:32.715Z DEBUG modem >> AT+CMEE=1
    2023-09-18T06:48:32.730Z DEBUG modem << OK
    2023-09-18T06:48:32.734Z DEBUG modem >> AT+CNEC?
    2023-09-18T06:48:32.752Z DEBUG modem << +CNEC: 16
    2023-09-18T06:48:32.760Z DEBUG modem << OK
    2023-09-18T06:48:32.783Z DEBUG modem >> AT+CNEC=24
    2023-09-18T06:48:32.799Z DEBUG modem << OK
    2023-09-18T06:48:32.804Z DEBUG modem >> AT+CGEREP?
    2023-09-18T06:48:32.829Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T06:48:32.837Z DEBUG modem << OK
    2023-09-18T06:48:32.854Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T06:48:32.868Z DEBUG modem << OK
    2023-09-18T06:48:32.894Z DEBUG modem >> AT+CEREG=5
    2023-09-18T06:48:32.917Z DEBUG modem << OK
    2023-09-18T06:48:32.931Z DEBUG modem >> AT+CEREG?
    2023-09-18T06:48:32.989Z DEBUG modem << +CEREG: 5,2,"0001","00000000",9
    2023-09-18T06:48:33.000Z DEBUG modem << OK
    2023-09-18T06:48:33.027Z DEBUG modem >> AT%CESQ=1
    2023-09-18T06:48:33.047Z DEBUG modem << OK
    2023-09-18T06:48:33.052Z DEBUG modem >> AT+CESQ
    2023-09-18T06:48:33.076Z DEBUG modem << +CESQ: 99,99,255,255,34,97
    2023-09-18T06:48:33.080Z DEBUG modem << OK
    2023-09-18T06:48:33.101Z DEBUG modem >> AT%XSIM=1
    2023-09-18T06:48:33.117Z DEBUG modem << OK
    2023-09-18T06:48:33.133Z DEBUG modem >> AT%XSIM?
    2023-09-18T06:48:33.152Z DEBUG modem << %XSIM: 1
    2023-09-18T06:48:33.181Z DEBUG modem << OK
    2023-09-18T06:48:33.217Z DEBUG modem >> AT+CPIN?
    2023-09-18T06:48:33.234Z DEBUG modem << +CPIN: READY
    2023-09-18T06:48:33.242Z DEBUG modem << OK
    2023-09-18T06:48:33.274Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T06:48:33.300Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T06:48:33.307Z DEBUG modem << OK
    2023-09-18T06:48:33.338Z DEBUG modem >> AT+CIMI
    2023-09-18T06:48:33.357Z DEBUG modem << 001010123456789
    2023-09-18T06:48:33.365Z DEBUG modem << OK
    2023-09-18T06:48:33.375Z INFO IMSIdentity: 001010123456789
    2023-09-18T06:49:01.247Z DEBUG modem >> AT%XSYSTEMMODE?
    2023-09-18T06:49:01.294Z DEBUG modem << %XSYSTEMMODE: 1,1,1,0
    2023-09-18T06:49:01.300Z DEBUG modem << OK
    2023-09-18T06:49:04.634Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T06:49:04.733Z DEBUG modem << +CEREG: 2
    2023-09-18T06:49:05.741Z DEBUG modem << [00:00:52.252,166] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T06:49:24.299Z DEBUG modem >> AT+CFUN?
    2023-09-18T06:49:24.327Z DEBUG modem << +CFUN: 1
    2023-09-18T06:49:24.373Z DEBUG modem << OK
    2023-09-18T06:49:24.383Z DEBUG modem >> AT+CGSN=1
    2023-09-18T06:49:24.413Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T06:49:24.417Z DEBUG modem << OK
    2023-09-18T06:49:24.452Z DEBUG modem >> AT+CGMI
    2023-09-18T06:49:24.490Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T06:49:24.499Z DEBUG modem << OK
    2023-09-18T06:49:24.526Z DEBUG modem >> AT+CGMM
    2023-09-18T06:49:24.552Z DEBUG modem << nRF9160-SICA
    2023-09-18T06:49:24.586Z DEBUG modem << OK
    2023-09-18T06:49:24.626Z DEBUG modem >> AT+CGMR
    2023-09-18T06:49:24.650Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T06:49:24.657Z DEBUG modem << OK
    2023-09-18T06:49:24.663Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T06:49:24.681Z DEBUG modem >> AT+CEMODE?
    2023-09-18T06:49:24.715Z DEBUG modem << +CEMODE: 0
    2023-09-18T06:49:24.718Z DEBUG modem << OK
    2023-09-18T06:49:24.770Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T06:49:24.836Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T06:49:24.847Z DEBUG modem << OK
    2023-09-18T06:49:24.877Z DEBUG modem >> AT+CMEE?
    2023-09-18T06:49:24.900Z DEBUG modem << +CMEE: 1
    2023-09-18T06:49:24.908Z DEBUG modem << OK
    2023-09-18T06:49:24.946Z DEBUG modem >> AT+CNEC?
    2023-09-18T06:49:24.972Z DEBUG modem << +CNEC: 24
    2023-09-18T06:49:24.992Z DEBUG modem << OK
    2023-09-18T06:49:25.027Z DEBUG modem >> AT+CGEREP?
    2023-09-18T06:49:25.061Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T06:49:25.070Z DEBUG modem << OK
    2023-09-18T06:49:25.100Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T06:49:25.135Z DEBUG modem << OK
    2023-09-18T06:49:25.171Z DEBUG modem >> AT+CEREG=5
    2023-09-18T06:49:25.199Z DEBUG modem << OK
    2023-09-18T06:49:25.229Z DEBUG modem >> AT+CEREG?
    2023-09-18T06:49:25.257Z DEBUG modem << +CEREG: 5,2
    2023-09-18T06:49:25.307Z DEBUG modem << OK
    2023-09-18T06:49:25.328Z DEBUG modem >> AT%CESQ=1
    2023-09-18T06:49:25.352Z DEBUG modem << OK
    2023-09-18T06:49:25.384Z DEBUG modem >> AT+CESQ
    2023-09-18T06:49:25.447Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T06:49:25.456Z DEBUG modem << OK
    2023-09-18T06:49:25.493Z DEBUG modem >> AT%XSIM=1
    2023-09-18T06:49:25.526Z DEBUG modem << OK
    2023-09-18T06:49:25.534Z DEBUG modem >> AT%XSIM?
    2023-09-18T06:49:25.574Z DEBUG modem << %XSIM: 1
    2023-09-18T06:49:25.578Z DEBUG modem << OK
    2023-09-18T06:49:25.602Z DEBUG modem >> AT+CPIN?
    2023-09-18T06:49:25.628Z DEBUG modem << +CPIN: READY
    2023-09-18T06:49:25.635Z DEBUG modem << OK
    2023-09-18T06:49:25.678Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T06:49:25.705Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T06:49:25.716Z DEBUG modem << OK
    2023-09-18T06:49:25.764Z DEBUG modem >> AT+CIMI
    2023-09-18T06:49:25.812Z DEBUG modem << 001010123456789
    2023-09-18T06:49:25.818Z DEBUG modem << OK
    2023-09-18T06:49:25.827Z INFO IMSIdentity: 001010123456789
    2023-09-18T06:49:49.051Z DEBUG modem >> at+cfun=0
    2023-09-18T06:49:49.068Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2023-09-18T06:49:49.098Z DEBUG modem << +CEREG: 0
    2023-09-18T06:49:49.117Z DEBUG modem << %XSIM: 0
    2023-09-18T06:49:49.263Z DEBUG modem << OK
    2023-09-18T06:50:02.796Z DEBUG modem >> AT%XSYSTEMMODE=0,1,1,2
    2023-09-18T06:50:02.834Z DEBUG modem << OK
    2023-09-18T06:50:06.928Z DEBUG modem >> AT+CFUN=1
    2023-09-18T06:50:06.970Z DEBUG modem << OK
    2023-09-18T06:50:14.039Z DEBUG modem << [00:02:01.512,664] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T06:50:14.086Z DEBUG modem << [00:02:01.513,336] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2023-09-18T06:50:14.093Z DEBUG modem << [00:02:01.514,190] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T06:50:14.098Z DEBUG modem << [00:02:01.531,677] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T06:50:14.104Z DEBUG modem << [00:02:01.531,707] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T06:50:14.110Z DEBUG modem << [00:02:01.531,768] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_NOT_READY[0m
    2023-09-18T06:50:14.148Z DEBUG modem << [00:02:01.541,473] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T06:50:14.153Z DEBUG modem << [00:02:01.541,503] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T06:50:14.158Z DEBUG modem << [00:02:01.541,564] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2023-09-18T06:50:14.163Z DEBUG modem << [00:02:01.551,239] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T06:50:14.200Z DEBUG modem << [00:02:01.551,269] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T06:50:14.204Z DEBUG modem << [00:02:01.551,361] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2023-09-18T06:50:18.324Z DEBUG modem << %NCELLMEAS: 0,"00000000","00101","0001",65535,1575,0,52,-28,125396,0
    2023-09-18T06:50:19.332Z DEBUG modem << [00:02:05.844,573] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2023-09-18T06:50:19.374Z DEBUG modem << [00:02:05.845,306] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T06:50:26.067Z DEBUG modem >> AT+CFUN=0
    2023-09-18T06:50:27.077Z ERROR Error: 'AT+CFUN=0
    ' timed out
    2023-09-18T06:50:27.425Z DEBUG modem << OK
    2023-09-18T06:50:37.400Z DEBUG modem >> AT%XSYSTEMMODE=0,1,1,2
    2023-09-18T06:50:37.428Z DEBUG modem << OK
    2023-09-18T06:50:42.969Z DEBUG modem >> AT+CFUN=1
    2023-09-18T06:50:43.014Z DEBUG modem << OK
    2023-09-18T06:50:50.177Z DEBUG modem >> AT%XSYSTEMMODE?
    2023-09-18T06:50:50.210Z DEBUG modem << %XSYSTEMMODE: 0,1,1,2
    2023-09-18T06:50:50.214Z DEBUG modem << OK
    2023-09-18T06:51:27.835Z DEBUG modem >> AT+COPS=?
    2023-09-18T06:51:28.841Z ERROR Error: 'AT+COPS=?
    ' timed out
    2023-09-18T06:52:14.995Z DEBUG modem << [00:04:01.512,664] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T06:52:15.022Z DEBUG modem << [00:04:01.513,336] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2023-09-18T06:52:15.028Z DEBUG modem << [00:04:01.514,160] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T06:52:22.634Z DEBUG modem >> AT+CFUN?
    2023-09-18T06:52:23.643Z ERROR Error: 'AT+CFUN?
    ' timed out
    2023-09-18T06:52:25.997Z DEBUG modem << [00:04:12.514,617] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T06:58:48.234Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T06:58:48.290Z INFO Modem port is opened
    2023-09-18T06:58:48.335Z DEBUG modem >> AT+CFUN?
    2023-09-18T06:58:48.420Z DEBUG modem << +CFUN: 1
    2023-09-18T06:58:48.426Z DEBUG modem << OK
    2023-09-18T06:58:48.495Z DEBUG modem >> AT+CGSN=1
    2023-09-18T06:58:48.585Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T06:58:48.593Z DEBUG modem << OK
    2023-09-18T06:58:48.681Z DEBUG modem >> AT+CGMI
    2023-09-18T06:58:48.758Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T06:58:48.768Z DEBUG modem << OK
    2023-09-18T06:58:48.840Z DEBUG modem >> AT+CGMM
    2023-09-18T06:58:48.961Z DEBUG modem << nRF9160-SICA
    2023-09-18T06:58:48.975Z DEBUG modem << OK
    2023-09-18T06:58:49.040Z DEBUG modem >> AT+CGMR
    2023-09-18T06:58:49.110Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T06:58:49.120Z DEBUG modem << OK
    2023-09-18T06:58:49.125Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T06:58:49.193Z DEBUG modem >> AT+CEMODE?
    2023-09-18T06:58:49.269Z DEBUG modem << +CEMODE: 0
    2023-09-18T06:58:49.277Z DEBUG modem << OK
    2023-09-18T06:58:49.357Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T06:58:49.493Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T06:58:49.499Z DEBUG modem << OK
    2023-09-18T06:58:49.544Z DEBUG modem >> AT+CMEE?
    2023-09-18T06:58:49.622Z DEBUG modem << +CMEE: 0
    2023-09-18T06:58:49.633Z DEBUG modem << OK
    2023-09-18T06:58:49.698Z DEBUG modem >> AT+CMEE=1
    2023-09-18T06:58:49.759Z DEBUG modem << OK
    2023-09-18T06:58:49.817Z DEBUG modem >> AT+CNEC?
    2023-09-18T06:58:49.871Z DEBUG modem << +CNEC: 16
    2023-09-18T06:58:49.875Z DEBUG modem << OK
    2023-09-18T06:58:49.936Z DEBUG modem >> AT+CNEC=24
    2023-09-18T06:58:50.009Z DEBUG modem << OK
    2023-09-18T06:58:50.074Z DEBUG modem >> AT+CGEREP?
    2023-09-18T06:58:50.136Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T06:58:50.142Z DEBUG modem << OK
    2023-09-18T06:58:50.216Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T06:58:50.309Z DEBUG modem << OK
    2023-09-18T06:58:50.363Z DEBUG modem >> AT+CEREG=5
    2023-09-18T06:58:50.482Z DEBUG modem << OK
    2023-09-18T06:58:50.496Z DEBUG modem >> AT+CEREG?
    2023-09-18T06:58:50.574Z DEBUG modem << +CEREG: 5,4
    2023-09-18T06:58:50.579Z DEBUG modem << OK
    2023-09-18T06:58:50.649Z DEBUG modem >> AT%CESQ=1
    2023-09-18T06:58:50.704Z DEBUG modem << OK
    2023-09-18T06:58:50.710Z DEBUG modem >> AT+CESQ
    2023-09-18T06:58:50.789Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T06:58:50.800Z DEBUG modem << OK
    2023-09-18T06:58:50.856Z DEBUG modem >> AT%XSIM=1
    2023-09-18T06:58:50.908Z DEBUG modem << OK
    2023-09-18T06:58:50.980Z DEBUG modem >> AT%XSIM?
    2023-09-18T06:58:51.059Z DEBUG modem << %XSIM: 1
    2023-09-18T06:58:51.067Z DEBUG modem << OK
    2023-09-18T06:58:51.123Z DEBUG modem >> AT+CPIN?
    2023-09-18T06:58:51.226Z DEBUG modem << +CPIN: READY
    2023-09-18T06:58:51.235Z DEBUG modem << OK
    2023-09-18T06:58:51.326Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T06:58:51.376Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T06:58:51.387Z DEBUG modem << OK
    2023-09-18T06:58:51.438Z DEBUG modem >> AT+CIMI
    2023-09-18T06:58:51.526Z DEBUG modem << 001010123456789
    2023-09-18T06:58:51.535Z DEBUG modem << OK
    2023-09-18T06:58:51.538Z INFO IMSIdentity: 001010123456789
    2023-09-18T06:58:58.700Z DEBUG modem << %CESQ: 97,4,27,3
    2023-09-18T06:58:58.802Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T06:58:58.871Z DEBUG modem << +CSCON: 1
    2023-09-18T06:58:59.809Z DEBUG modem << [00:00:13.504,211] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T06:59:00.828Z DEBUG modem << +CGEV: ME PDN ACT 0
    2023-09-18T06:59:00.875Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T06:59:00.970Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2023-09-18T06:59:00.974Z DEBUG modem << +CEREG: 1,"0001","00000000",9,,,"11100000","11100000"
    2023-09-18T06:59:01.090Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T06:59:01.093Z DEBUG modem << OK
    2023-09-18T06:59:01.107Z DEBUG modem >> AT+CGACT?
    2023-09-18T06:59:01.184Z DEBUG modem << +CIND: "service",1
    2023-09-18T06:59:01.191Z DEBUG modem << +CGACT: 0,1
    2023-09-18T06:59:01.195Z DEBUG modem << OK
    2023-09-18T06:59:01.836Z DEBUG modem << [00:00:15.530,578] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED[0m
    2023-09-18T06:59:01.844Z DEBUG modem << [00:00:15.531,829] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T06:59:01.891Z DEBUG modem << [00:00:15.531,829] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
    2023-09-18T06:59:01.895Z DEBUG modem << [00:00:15.531,951] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T06:59:01.902Z DEBUG modem << [00:00:15.533,447] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T06:59:01.905Z DEBUG modem << [00:00:15.885,620] [0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE[0m
    2023-09-18T06:59:02.569Z DEBUG modem << %CESQ: 91,4,29,4
    2023-09-18T06:59:02.767Z DEBUG modem << %CESQ: 84,4,29,4
    2023-09-18T06:59:02.895Z DEBUG modem << [00:00:16.590,820] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T06:59:02.938Z DEBUG modem << [00:00:16.591,094] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T06:59:02.945Z DEBUG modem << [00:00:16.591,094] [1;33m<wrn> date_time: Did not get time from any NTP server[0m
    2023-09-18T06:59:03.174Z DEBUG modem << %CESQ: 76,3,29,4
    2023-09-18T06:59:03.992Z DEBUG modem << %CESQ: 71,3,29,4
    2023-09-18T06:59:13.577Z DEBUG modem << +CGEV: IPV6 FAIL 0
    2023-09-18T06:59:13.622Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T06:59:13.676Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T06:59:13.681Z DEBUG modem << OK
    2023-09-18T06:59:13.741Z DEBUG modem >> AT+CGACT?
    2023-09-18T06:59:13.877Z DEBUG modem << +CGACT: 0,1
    2023-09-18T06:59:13.888Z DEBUG modem << OK
    2023-09-18T06:59:33.836Z DEBUG modem << [00:00:47.532,012] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T06:59:33.844Z DEBUG modem << [00:00:47.532,562] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T06:59:33.900Z DEBUG modem << [00:00:47.532,592] [1;33m<wrn> cloud_module: New connection attempt in 64 seconds if not successful[0m
    2023-09-18T06:59:33.904Z DEBUG modem << [00:00:47.532,745] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T06:59:33.908Z DEBUG modem << [00:00:47.533,599] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:00:13.846Z DEBUG modem << %CESQ: 80,4,27,3
    2023-09-18T07:00:14.051Z DEBUG modem << %CESQ: 87,4,27,3
    2023-09-18T07:00:14.253Z DEBUG modem << %CESQ: 93,4,28,4
    2023-09-18T07:00:37.836Z DEBUG modem << [00:01:51.532,745] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:00:37.843Z DEBUG modem << [00:01:51.533,294] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:00:37.879Z DEBUG modem << [00:01:51.533,325] [1;33m<wrn> cloud_module: New connection attempt in 128 seconds if not successful[0m
    2023-09-18T07:00:37.885Z DEBUG modem << [00:01:51.533,477] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:00:37.893Z DEBUG modem << [00:01:51.534,362] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:00:46.917Z DEBUG modem << [00:02:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:00:46.926Z DEBUG modem << [00:02:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2023-09-18T07:00:47.007Z DEBUG modem << [00:02:01.514,038] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:00:47.014Z DEBUG modem << [00:02:01.545,745] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:00:47.018Z DEBUG modem << [00:02:01.545,776] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:00:47.022Z DEBUG modem << [00:02:01.545,898] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY[0m
    2023-09-18T07:00:47.025Z DEBUG modem << [00:02:01.578,948] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:00:47.028Z DEBUG modem << [00:02:01.578,979] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:00:47.030Z DEBUG modem << [00:02:01.579,101] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2023-09-18T07:00:47.037Z DEBUG modem << [00:02:01.612,304] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:00:47.043Z DEBUG modem << [00:02:01.612,304] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:00:47.101Z DEBUG modem << [00:02:01.612,426] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2023-09-18T07:00:47.107Z DEBUG modem << %NCELLMEAS: 0,"00000000","00101","0001",0,1575,0,97,28,121085,121076
    2023-09-18T07:00:48.023Z DEBUG modem << [00:02:01.720,947] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2023-09-18T07:00:48.029Z DEBUG modem << [00:02:01.721,649] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:00:55.886Z DEBUG modem << +CSCON: 0
    2023-09-18T07:00:58.491Z DEBUG modem << %CESQ: 97,4,33,4
    2023-09-18T07:01:05.106Z DEBUG modem << %CESQ: 97,4,28,4
    2023-09-18T07:01:06.207Z DEBUG modem << %CESQ: 97,4,33,4
    2023-09-18T07:01:11.210Z DEBUG modem << %CESQ: 97,4,28,4
    2023-09-18T07:01:12.529Z DEBUG modem << %CESQ: 97,4,34,4
    2023-09-18T07:01:13.848Z DEBUG modem << %CESQ: 97,4,28,4
    2023-09-18T07:01:15.168Z DEBUG modem << %CESQ: 97,4,33,4
    2023-09-18T07:01:26.310Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:01:26.409Z DEBUG modem << +CEREG: 2
    2023-09-18T07:01:26.511Z DEBUG modem << +CIND: "service",0
    2023-09-18T07:01:27.518Z DEBUG modem << [00:02:41.218,109] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:01:39.894Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:01:39.981Z INFO Modem port is opened
    2023-09-18T07:01:39.999Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:01:40.058Z DEBUG modem << +CFUN: 1
    2023-09-18T07:01:40.068Z DEBUG modem << OK
    2023-09-18T07:01:40.138Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:01:40.339Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:01:40.348Z DEBUG modem << OK
    2023-09-18T07:01:40.443Z DEBUG modem >> AT+CGMI
    2023-09-18T07:01:40.546Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:01:40.557Z DEBUG modem << OK
    2023-09-18T07:01:40.638Z DEBUG modem >> AT+CGMM
    2023-09-18T07:01:40.721Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:01:40.728Z DEBUG modem << OK
    2023-09-18T07:01:40.803Z DEBUG modem >> AT+CGMR
    2023-09-18T07:01:40.896Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:01:40.904Z DEBUG modem << OK
    2023-09-18T07:01:40.912Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:01:40.949Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:01:41.094Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:01:41.161Z DEBUG modem <<
    2023-09-18T07:01:41.177Z DEBUG modem << OK
    2023-09-18T07:01:41.267Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:01:41.394Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:01:41.401Z DEBUG modem << OK
    2023-09-18T07:01:41.420Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:01:41.485Z DEBUG modem << +CMEE: 1
    2023-09-18T07:01:41.491Z DEBUG modem << OK
    2023-09-18T07:01:41.562Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:01:41.630Z DEBUG modem << +CNEC: 24
    2023-09-18T07:01:41.639Z DEBUG modem << OK
    2023-09-18T07:01:41.707Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:01:41.826Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:01:41.833Z DEBUG modem << OK
    2023-09-18T07:01:41.845Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:01:41.906Z DEBUG modem << OK
    2023-09-18T07:01:41.912Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:01:41.971Z DEBUG modem << OK
    2023-09-18T07:01:41.975Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:01:42.038Z DEBUG modem << +CEREG: 5,2
    2023-09-18T07:01:42.046Z DEBUG modem << OK
    2023-09-18T07:01:42.105Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:01:42.180Z DEBUG modem << OK
    2023-09-18T07:01:42.244Z DEBUG modem >> AT+CESQ
    2023-09-18T07:01:42.344Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:01:42.350Z DEBUG modem << OK
    2023-09-18T07:01:42.416Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:01:42.479Z DEBUG modem << OK
    2023-09-18T07:01:42.538Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:01:42.602Z DEBUG modem << %XSIM: 1
    2023-09-18T07:01:42.609Z DEBUG modem << OK
    2023-09-18T07:01:42.628Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:01:42.701Z DEBUG modem << +CPIN: READY
    2023-09-18T07:01:42.712Z DEBUG modem << OK
    2023-09-18T07:01:42.774Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:01:42.868Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:01:42.873Z DEBUG modem << OK
    2023-09-18T07:01:42.929Z DEBUG modem >> AT+CIMI
    2023-09-18T07:01:43.010Z DEBUG modem << 001010123456789
    2023-09-18T07:01:43.013Z DEBUG modem << OK
    2023-09-18T07:01:43.018Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:02:45.839Z DEBUG modem << [00:03:59.533,477] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:02:45.944Z DEBUG modem << [00:03:59.534,027] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:02:45.954Z DEBUG modem << [00:03:59.534,057] [1;33m<wrn> cloud_module: New connection attempt in 256 seconds if not successful[0m
    2023-09-18T07:02:46.082Z DEBUG modem << [00:03:59.534,210] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:02:46.094Z DEBUG modem << [00:03:59.535,064] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:02:47.029Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:02:47.127Z DEBUG modem << [00:04:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:02:47.132Z DEBUG modem << [00:04:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS)[0m
    2023-09-18T07:02:47.234Z DEBUG modem << [00:04:01.514,068] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:02:47.245Z DEBUG modem << [00:04:01.517,272] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:02:47.248Z DEBUG modem << [00:04:01.517,303] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:02:47.255Z DEBUG modem << [00:04:01.517,395] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2023-09-18T07:02:47.278Z DEBUG modem << [00:04:01.521,148] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:02:47.306Z DEBUG modem << [00:04:01.521,179] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:02:47.312Z DEBUG modem << [00:04:01.521,240] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2023-09-18T07:02:47.317Z DEBUG modem << [00:04:01.734,710] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:02:47.325Z DEBUG modem << [00:04:01.735,382] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:04:26.195Z DEBUG modem << %CESQ: 17,0,8,1
    2023-09-18T07:04:26.240Z DEBUG modem << +CEREG: 1,"0001","00000000",9,,,"11100000","11100000"
    2023-09-18T07:04:26.530Z DEBUG modem >> AT+COPS=3,2
    2023-09-18T07:04:26.793Z DEBUG modem << +CIND: "service",1
    2023-09-18T07:04:27.061Z DEBUG modem << OK
    2023-09-18T07:04:27.327Z DEBUG modem >> AT+COPS?
    2023-09-18T07:04:27.756Z DEBUG modem << [00:05:41.011,810] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:04:27.798Z DEBUG modem << [00:05:41.921,203] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:04:27.812Z DEBUG modem << [00:05:41.927,551] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:04:27.818Z DEBUG modem << [00:05:41.927,581] [1;33m<wrn> date_time: Did not get time from any NTP server[0m
    2023-09-18T07:04:27.828Z DEBUG modem << +COPS: 0,2,"00101",9
    2023-09-18T07:04:27.848Z DEBUG modem << OK
    2023-09-18T07:04:28.191Z DEBUG modem >> AT%XCBAND
    2023-09-18T07:04:28.619Z DEBUG modem << %XCBAND: 3
    2023-09-18T07:04:28.628Z DEBUG modem << OK
    2023-09-18T07:04:28.632Z DEBUG modem << %CESQ: 18,0,14,2
    2023-09-18T07:04:28.942Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:04:29.153Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:04:29.178Z DEBUG modem << OK
    2023-09-18T07:04:29.496Z DEBUG modem >> AT+CGACT?
    2023-09-18T07:04:29.799Z DEBUG modem << +CGACT: 0,1
    2023-09-18T07:04:29.824Z DEBUG modem << OK
    2023-09-18T07:04:30.359Z DEBUG modem << %CESQ: 18,0,9,1
    2023-09-18T07:04:43.927Z DEBUG modem << %CESQ: 15,0,4,0
    2023-09-18T07:04:45.246Z DEBUG modem << %CESQ: 16,0,13,1
    2023-09-18T07:04:46.882Z DEBUG modem << [00:06:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:04:46.948Z DEBUG modem << [00:06:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2023-09-18T07:04:47.016Z DEBUG modem << [00:06:01.518,615] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2023-09-18T07:04:47.024Z DEBUG modem << [00:06:01.519,073] [0m<inf> app_event_manager: GNSS_EVT_AGPS_NEEDED[0m
    2023-09-18T07:04:47.028Z DEBUG modem << [00:06:01.519,744] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:04:47.035Z DEBUG modem << [00:06:01.520,263] [1;33m<wrn> data_module: Failed to request A-GPS data, error: -13[0m
    2023-09-18T07:04:47.053Z DEBUG modem << [00:06:01.520,263] [1;33m<wrn> data_module: This is expected to fail if we are not in a connected state[0m
    2023-09-18T07:04:47.061Z DEBUG modem << [00:06:01.553,253] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:04:47.066Z DEBUG modem << [00:06:01.553,283] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:04:47.069Z DEBUG modem << [00:06:01.553,405] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2023-09-18T07:04:47.137Z DEBUG modem << [00:06:01.586,944] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:04:47.144Z DEBUG modem << [00:06:01.586,975] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:04:47.152Z DEBUG modem << [00:06:01.587,066] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2023-09-18T07:04:56.448Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:04:56.548Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:04:56.647Z DEBUG modem << +CEREG: 2
    2023-09-18T07:04:56.759Z DEBUG modem << +CIND: "service",0
    2023-09-18T07:04:57.558Z DEBUG modem << [00:06:11.261,138] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:04:57.567Z DEBUG modem << [00:06:11.463,195] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:05:51.516Z DEBUG modem >> at+cpsms?
    2023-09-18T07:05:51.613Z DEBUG modem << +CPSMS: 1,,,"11000001","00001010"
    2023-09-18T07:05:51.618Z DEBUG modem << OK
    2023-09-18T07:06:02.811Z DEBUG modem << [00:07:16.520,324] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:06:06.909Z DEBUG modem >> at+cpsms=0
    2023-09-18T07:06:06.916Z DEBUG modem << OK
    2023-09-18T07:06:12.098Z DEBUG modem >> at+cpsms?
    2023-09-18T07:06:12.146Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:06:12.149Z DEBUG modem << OK
    2023-09-18T07:06:23.566Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:06:23.673Z INFO Modem port is opened
    2023-09-18T07:06:23.683Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:06:23.968Z DEBUG modem << +CFUN: 1
    2023-09-18T07:06:23.978Z DEBUG modem << OK
    2023-09-18T07:06:24.118Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:06:24.310Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:06:24.321Z DEBUG modem << OK
    2023-09-18T07:06:24.425Z DEBUG modem >> AT+CGMI
    2023-09-18T07:06:24.543Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:06:24.548Z DEBUG modem << OK
    2023-09-18T07:06:24.615Z DEBUG modem >> AT+CGMM
    2023-09-18T07:06:24.674Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:06:24.678Z DEBUG modem << OK
    2023-09-18T07:06:24.772Z DEBUG modem >> AT+CGMR
    2023-09-18T07:06:24.876Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:06:24.882Z DEBUG modem << OK
    2023-09-18T07:06:24.886Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:06:25.004Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:06:25.216Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:06:25.224Z DEBUG modem << OK
    2023-09-18T07:06:25.334Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:06:25.437Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:06:25.448Z DEBUG modem << OK
    2023-09-18T07:06:25.553Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:06:25.647Z DEBUG modem << +CMEE: 1
    2023-09-18T07:06:25.654Z DEBUG modem << OK
    2023-09-18T07:06:25.722Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:06:26.397Z DEBUG modem << +CNEC: 24
    2023-09-18T07:06:26.403Z DEBUG modem << OK
    2023-09-18T07:06:26.494Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:06:26.588Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:06:26.593Z DEBUG modem << OK
    2023-09-18T07:06:26.637Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:06:26.694Z DEBUG modem << OK
    2023-09-18T07:06:26.698Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:06:26.753Z DEBUG modem << OK
    2023-09-18T07:06:26.756Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:06:26.764Z DEBUG modem << +CEREG: 5,2
    2023-09-18T07:06:26.767Z DEBUG modem << OK
    2023-09-18T07:06:26.833Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:06:26.914Z DEBUG modem << OK
    2023-09-18T07:06:26.985Z DEBUG modem >> AT+CESQ
    2023-09-18T07:06:27.071Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:06:27.076Z DEBUG modem << OK
    2023-09-18T07:06:27.137Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:06:27.214Z DEBUG modem << OK
    2023-09-18T07:06:27.225Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:06:27.314Z DEBUG modem << %XSIM: 1
    2023-09-18T07:06:27.318Z DEBUG modem << OK
    2023-09-18T07:06:27.387Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:06:27.444Z DEBUG modem << +CPIN: READY
    2023-09-18T07:06:27.450Z DEBUG modem << OK
    2023-09-18T07:06:27.519Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:06:27.597Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:06:27.607Z DEBUG modem << OK
    2023-09-18T07:06:27.675Z DEBUG modem >> AT+CIMI
    2023-09-18T07:06:27.760Z DEBUG modem << 001010123456789
    2023-09-18T07:06:27.767Z DEBUG modem << OK
    2023-09-18T07:06:27.772Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:06:28.176Z DEBUG modem >> at+cpsms?
    2023-09-18T07:06:28.183Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:06:28.186Z DEBUG modem << OK
    2023-09-18T07:06:33.744Z DEBUG modem >> at+cpsms?
    2023-09-18T07:06:33.750Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:06:33.809Z DEBUG modem << OK
    2023-09-18T07:06:36.609Z DEBUG modem >> at+cpsms?
    2023-09-18T07:06:36.615Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:06:36.701Z DEBUG modem << OK
    2023-09-18T07:06:40.679Z DEBUG modem >> at+cpsms?
    2023-09-18T07:06:40.739Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:06:40.745Z DEBUG modem << OK
    2023-09-18T07:06:46.813Z DEBUG modem << [00:08:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:06:46.903Z DEBUG modem << [00:08:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2023-09-18T07:06:46.909Z DEBUG modem << [00:08:01.513,244] [1;33m<wrn> gnss_module: GNSS search already active and will not be restarted[0m
    2023-09-18T07:06:46.915Z DEBUG modem << [00:08:01.513,244] [1;33m<wrn> gnss_module: Try setting a sample/publication interval greater[0m
    2023-09-18T07:06:46.917Z DEBUG modem << [00:08:01.513,275] [1;33m<wrn> gnss_module: than the GNSS search timeout.[0m
    2023-09-18T07:06:46.919Z DEBUG modem << [00:08:01.514,160] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:06:46.923Z DEBUG modem << [00:08:01.517,578] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:06:46.926Z DEBUG modem << [00:08:01.517,578] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:06:46.929Z DEBUG modem << [00:08:01.517,669] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2023-09-18T07:06:46.931Z DEBUG modem << [00:08:01.521,728] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:06:46.994Z DEBUG modem << [00:08:01.521,728] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:06:46.998Z DEBUG modem << [00:08:01.521,850] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2023-09-18T07:06:47.069Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:06:47.955Z DEBUG modem << [00:08:01.662,872] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:06:51.699Z DEBUG modem >> at+cpsms?
    2023-09-18T07:06:51.767Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:06:51.825Z DEBUG modem << OK
    2023-09-18T07:07:01.825Z DEBUG modem << [00:08:15.534,210] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:07:01.833Z DEBUG modem << [00:08:15.534,759] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:07:02.013Z DEBUG modem << [00:08:15.534,790] [1;33m<wrn> cloud_module: New connection attempt in 512 seconds if not successful[0m
    2023-09-18T07:07:02.021Z DEBUG modem << [00:08:15.534,942] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:07:02.027Z DEBUG modem << [00:08:15.535,827] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:07:13.007Z DEBUG modem >> at+cpsms?
    2023-09-18T07:07:13.014Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:07:13.017Z DEBUG modem << OK
    2023-09-18T07:07:45.232Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:07:45.334Z INFO Modem port is opened
    2023-09-18T07:07:45.344Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:07:45.499Z DEBUG modem << +CFUN: 1
    2023-09-18T07:07:45.652Z DEBUG modem << OK
    2023-09-18T07:07:45.786Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:07:45.963Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:07:45.969Z DEBUG modem << OK
    2023-09-18T07:07:46.039Z DEBUG modem >> AT+CGMI
    2023-09-18T07:07:46.114Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:07:46.120Z DEBUG modem << OK
    2023-09-18T07:07:46.210Z DEBUG modem >> AT+CGMM
    2023-09-18T07:07:46.294Z DEBUG modem << [00:00:01.511,871] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:07:46.404Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:07:46.418Z DEBUG modem << OK
    2023-09-18T07:07:46.508Z DEBUG modem >> AT+CGMR
    2023-09-18T07:07:46.588Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:07:46.593Z DEBUG modem << OK
    2023-09-18T07:07:46.597Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:07:46.597Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:07:46.694Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:07:46.797Z DEBUG modem << OK
    2023-09-18T07:07:46.896Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:07:47.004Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:07:47.011Z DEBUG modem << OK
    2023-09-18T07:07:47.099Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:07:47.195Z DEBUG modem << +CMEE: 0
    2023-09-18T07:07:47.201Z DEBUG modem << OK
    2023-09-18T07:07:47.297Z DEBUG modem >> AT+CMEE=1
    2023-09-18T07:07:47.422Z DEBUG modem << OK
    2023-09-18T07:07:47.533Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:07:47.630Z DEBUG modem << +CNEC: 16
    2023-09-18T07:07:47.638Z DEBUG modem << OK
    2023-09-18T07:07:47.718Z DEBUG modem >> AT+CNEC=24
    2023-09-18T07:07:47.794Z DEBUG modem << OK
    2023-09-18T07:07:47.798Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:07:47.871Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:07:47.874Z DEBUG modem << OK
    2023-09-18T07:07:47.952Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:07:48.037Z DEBUG modem << OK
    2023-09-18T07:07:48.099Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:07:48.169Z DEBUG modem << OK
    2023-09-18T07:07:48.238Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:07:48.306Z DEBUG modem << +CEREG: 5,4
    2023-09-18T07:07:48.309Z DEBUG modem << OK
    2023-09-18T07:07:48.323Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:07:48.388Z DEBUG modem << OK
    2023-09-18T07:07:48.394Z DEBUG modem >> AT+CESQ
    2023-09-18T07:07:48.402Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:07:48.466Z DEBUG modem << OK
    2023-09-18T07:07:48.476Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:07:48.541Z DEBUG modem << OK
    2023-09-18T07:07:48.549Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:07:48.619Z DEBUG modem << %XSIM: 1
    2023-09-18T07:07:48.625Z DEBUG modem << OK
    2023-09-18T07:07:48.696Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:07:48.770Z DEBUG modem << +CPIN: READY
    2023-09-18T07:07:48.776Z DEBUG modem << OK
    2023-09-18T07:07:48.846Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:07:48.916Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:07:48.920Z DEBUG modem << OK
    2023-09-18T07:07:48.988Z DEBUG modem >> AT+CIMI
    2023-09-18T07:07:49.056Z DEBUG modem << 001010123456789
    2023-09-18T07:07:49.061Z DEBUG modem << OK
    2023-09-18T07:07:49.065Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:07:49.375Z DEBUG modem >> at+cpsms?
    2023-09-18T07:07:49.506Z DEBUG modem << +CPSMS: 1,,,"11000001","00001010"
    2023-09-18T07:07:49.511Z DEBUG modem << OK
    2023-09-18T07:08:00.226Z DEBUG modem >> at+cpsms?
    2023-09-18T07:08:00.292Z DEBUG modem << +CPSMS: 1,,,"11000001","00001010"
    2023-09-18T07:08:00.297Z DEBUG modem << OK
    2023-09-18T07:08:04.802Z DEBUG modem >> at+cpsms=0
    2023-09-18T07:08:04.869Z DEBUG modem << OK
    2023-09-18T07:08:09.594Z DEBUG modem >> at+cpsmS?
    2023-09-18T07:08:09.645Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:08:09.649Z DEBUG modem << OK
    2023-09-18T07:08:33.610Z DEBUG modem << %MDMEV: SEARCH STATUS 1
    2023-09-18T07:09:22.619Z DEBUG modem >> AT+CFUN=1
    2023-09-18T07:09:22.729Z DEBUG modem << OK
    2023-09-18T07:09:42.969Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:09:43.098Z DEBUG modem << +CFUN: 1
    2023-09-18T07:09:43.111Z DEBUG modem << OK
    2023-09-18T07:09:43.186Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:09:43.271Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:09:43.275Z DEBUG modem << OK
    2023-09-18T07:09:43.357Z DEBUG modem >> AT+CGMI
    2023-09-18T07:09:43.503Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:09:43.509Z DEBUG modem << OK
    2023-09-18T07:09:43.584Z DEBUG modem >> AT+CGMM
    2023-09-18T07:09:43.669Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:09:43.674Z DEBUG modem << OK
    2023-09-18T07:09:43.758Z DEBUG modem >> AT+CGMR
    2023-09-18T07:09:43.878Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:09:43.883Z DEBUG modem << OK
    2023-09-18T07:09:43.888Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:09:43.997Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:09:44.124Z DEBUG modem << +CEMODE: 2
    2023-09-18T07:09:44.128Z DEBUG modem << OK
    2023-09-18T07:09:44.236Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:09:44.460Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66)
    2023-09-18T07:09:44.470Z DEBUG modem << OK
    2023-09-18T07:09:44.568Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:09:44.655Z DEBUG modem << +CMEE: 1
    2023-09-18T07:09:44.659Z DEBUG modem << OK
    2023-09-18T07:09:44.775Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:09:44.901Z DEBUG modem << +CNEC: 24
    2023-09-18T07:09:44.910Z DEBUG modem << OK
    2023-09-18T07:09:44.998Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:09:45.089Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:09:45.096Z DEBUG modem << OK
    2023-09-18T07:09:45.193Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:09:45.317Z DEBUG modem << [00:02:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:09:45.321Z DEBUG modem << [00:02:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2023-09-18T07:09:45.325Z DEBUG modem << [00:02:01.514,099] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:09:45.328Z DEBUG modem << [00:02:01.516,510] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:09:45.330Z DEBUG modem << [00:02:01.516,540] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:09:45.334Z DEBUG modem << [00:02:01.516,601] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_NOT_READY[0m
    2023-09-18T07:09:45.337Z DEBUG modem << [00:02:01.519,592] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:09:45.344Z DEBUG modem << [00:02:01.519,622] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:09:45.347Z DEBUG modem << [00:02:01.519,683] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2023-09-18T07:09:45.351Z DEBUG modem << [00:02:01.522,674] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:09:45.354Z DEBUG modem << [00:02:01.522,705] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:09:45.358Z DEBUG modem << [00:02:01.522,796] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2023-09-18T07:09:45.362Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:09:45.452Z DEBUG modem << +CEREG: 2
    2023-09-18T07:09:45.563Z DEBUG modem << OK
    2023-09-18T07:09:45.568Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:09:45.657Z DEBUG modem << OK
    2023-09-18T07:09:45.780Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:09:45.920Z DEBUG modem << +CEREG: 5,2
    2023-09-18T07:09:45.937Z DEBUG modem << OK
    2023-09-18T07:09:46.037Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:09:46.138Z DEBUG modem << OK
    2023-09-18T07:09:46.232Z DEBUG modem >> AT+CESQ
    2023-09-18T07:09:46.398Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:09:46.405Z DEBUG modem << OK
    2023-09-18T07:09:46.409Z DEBUG modem << [00:02:01.651,977] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:09:46.412Z DEBUG modem << [00:02:01.652,709] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:09:46.414Z DEBUG modem << [00:02:01.851,287] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:09:46.499Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:09:46.605Z DEBUG modem << OK
    2023-09-18T07:09:46.694Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:09:46.852Z DEBUG modem << %XSIM: 1
    2023-09-18T07:09:46.859Z DEBUG modem << OK
    2023-09-18T07:09:46.971Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:09:47.100Z DEBUG modem << +CPIN: READY
    2023-09-18T07:09:47.113Z DEBUG modem << OK
    2023-09-18T07:09:47.219Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:09:47.352Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:09:47.357Z DEBUG modem << OK
    2023-09-18T07:09:47.451Z DEBUG modem >> AT+CIMI
    2023-09-18T07:09:47.543Z DEBUG modem << 001010123456789
    2023-09-18T07:09:47.547Z DEBUG modem << OK
    2023-09-18T07:09:47.551Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:10:14.209Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2023-09-18T07:10:14.319Z DEBUG modem << +CEREG: 2
    2023-09-18T07:10:47.380Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:10:47.500Z INFO Modem port is opened
    2023-09-18T07:10:47.666Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:10:47.890Z DEBUG modem << +CFUN: 1
    2023-09-18T07:10:47.904Z DEBUG modem << OK
    2023-09-18T07:10:48.059Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:10:48.194Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:10:48.200Z DEBUG modem << OK
    2023-09-18T07:10:48.206Z DEBUG modem >> AT+CGMI
    2023-09-18T07:10:49.184Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:10:49.190Z DEBUG modem << OK
    2023-09-18T07:10:49.285Z DEBUG modem >> AT+CGMM
    2023-09-18T07:10:49.391Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:10:49.397Z DEBUG modem << OK
    2023-09-18T07:10:49.557Z DEBUG modem >> AT+CGMR
    2023-09-18T07:10:49.772Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:10:49.779Z DEBUG modem << OK
    2023-09-18T07:10:49.783Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:10:49.785Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:10:49.971Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:10:49.977Z DEBUG modem << OK
    2023-09-18T07:10:50.115Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:10:50.288Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:10:50.294Z DEBUG modem << OK
    2023-09-18T07:10:50.385Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:10:50.480Z DEBUG modem << +CMEE: 1
    2023-09-18T07:10:50.590Z DEBUG modem << OK
    2023-09-18T07:10:50.600Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:10:50.751Z DEBUG modem << +CNEC: 24
    2023-09-18T07:10:50.755Z DEBUG modem << OK
    2023-09-18T07:10:50.852Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:10:50.948Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:10:50.955Z DEBUG modem << OK
    2023-09-18T07:10:51.068Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:10:51.221Z DEBUG modem << OK
    2023-09-18T07:10:51.226Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:10:51.237Z DEBUG modem << OK
    2023-09-18T07:10:51.338Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:10:51.440Z DEBUG modem << +CEREG: 5,2
    2023-09-18T07:10:51.448Z DEBUG modem << OK
    2023-09-18T07:10:51.594Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:10:51.755Z DEBUG modem << OK
    2023-09-18T07:10:51.901Z DEBUG modem >> AT+CESQ
    2023-09-18T07:10:52.054Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:10:52.060Z DEBUG modem << OK
    2023-09-18T07:10:52.168Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:10:52.271Z DEBUG modem << OK
    2023-09-18T07:10:52.400Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:10:52.558Z DEBUG modem << %XSIM: 1
    2023-09-18T07:10:52.571Z DEBUG modem << OK
    2023-09-18T07:10:52.681Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:10:52.796Z DEBUG modem << +CPIN: READY
    2023-09-18T07:10:52.801Z DEBUG modem << OK
    2023-09-18T07:10:52.820Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:10:52.951Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:10:52.956Z DEBUG modem << OK
    2023-09-18T07:10:53.067Z DEBUG modem >> AT+CIMI
    2023-09-18T07:10:53.178Z DEBUG modem << 001010123456789
    2023-09-18T07:10:53.185Z DEBUG modem << OK
    2023-09-18T07:10:53.188Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:11:15.991Z DEBUG modem << %CESQ: 97,4,34,4
    2023-09-18T07:11:16.130Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T07:11:16.287Z DEBUG modem << +CSCON: 1
    2023-09-18T07:11:16.805Z DEBUG modem << %CESQ: 97,4,28,4
    2023-09-18T07:11:17.102Z DEBUG modem << [00:03:32.389,251] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:11:18.096Z DEBUG modem << +CGEV: ME PDN ACT 0
    2023-09-18T07:11:18.214Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:11:18.348Z DEBUG modem << +CEREG: 1,"0001","00000000",9,,,"11100000","11100000"
    2023-09-18T07:11:18.499Z DEBUG modem << +CIND: "service",1
    2023-09-18T07:11:18.506Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:11:18.515Z DEBUG modem << OK
    2023-09-18T07:11:18.654Z DEBUG modem >> AT+CGACT?
    2023-09-18T07:11:18.831Z DEBUG modem << +CGACT: 0,1
    2023-09-18T07:11:18.838Z DEBUG modem << OK
    2023-09-18T07:11:19.213Z DEBUG modem << [00:03:34.601,348] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED[0m
    2023-09-18T07:11:19.219Z DEBUG modem << [00:03:34.601,959] [0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE[0m
    2023-09-18T07:11:19.328Z DEBUG modem << [00:03:34.603,240] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:11:19.333Z DEBUG modem << [00:03:34.603,271] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
    2023-09-18T07:11:19.336Z DEBUG modem << [00:03:34.603,424] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:11:19.341Z DEBUG modem << [00:03:34.604,766] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:11:19.352Z DEBUG modem << [00:03:35.496,582] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:11:19.356Z DEBUG modem << [00:03:35.496,856] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:11:19.361Z DEBUG modem << [00:03:35.496,887] [1;33m<wrn> date_time: Did not get time from any NTP server[0m
    2023-09-18T07:11:30.648Z DEBUG modem >> at+cpsms?
    2023-09-18T07:11:30.656Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:11:30.788Z DEBUG modem << OK
    2023-09-18T07:11:30.939Z DEBUG modem << +CGEV: IPV6 FAIL 0
    2023-09-18T07:11:31.063Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:11:31.170Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:11:31.174Z DEBUG modem << OK
    2023-09-18T07:11:31.314Z DEBUG modem >> AT+CGACT?
    2023-09-18T07:11:31.499Z DEBUG modem << +CGACT: 0,1
    2023-09-18T07:11:31.504Z DEBUG modem << OK
    2023-09-18T07:11:45.224Z DEBUG modem << [00:04:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:11:45.346Z DEBUG modem << [00:04:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2023-09-18T07:11:45.350Z DEBUG modem << [00:04:01.514,099] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:11:45.356Z DEBUG modem << [00:04:01.546,356] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:11:45.366Z DEBUG modem << [00:04:01.546,386] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:11:45.374Z DEBUG modem << [00:04:01.546,508] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY[0m
    2023-09-18T07:11:45.378Z DEBUG modem << [00:04:01.579,559] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:11:45.381Z DEBUG modem << [00:04:01.579,589] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:11:45.386Z DEBUG modem << [00:04:01.579,711] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2023-09-18T07:11:45.389Z DEBUG modem << [00:04:01.612,854] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:11:45.394Z DEBUG modem << [00:04:01.612,854] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:11:45.397Z DEBUG modem << [00:04:01.612,976] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2023-09-18T07:11:45.400Z DEBUG modem << %NCELLMEAS: 0,"00000000","00101","0001",0,1575,0,97,28,241064,241047
    2023-09-18T07:11:46.333Z DEBUG modem << [00:04:01.721,313] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2023-09-18T07:11:46.339Z DEBUG modem << [00:04:01.722,045] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:11:51.213Z DEBUG modem << [00:04:06.603,424] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:11:51.345Z DEBUG modem << [00:04:06.603,973] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:11:51.515Z DEBUG modem << [00:04:06.604,003] [1;33m<wrn> cloud_module: New connection attempt in 64 seconds if not successful[0m
    2023-09-18T07:11:51.531Z DEBUG modem << [00:04:06.604,156] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:11:51.534Z DEBUG modem << [00:04:06.605,163] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:12:55.214Z DEBUG modem << [00:05:10.604,156] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:12:55.223Z DEBUG modem << [00:05:10.604,705] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:12:55.338Z DEBUG modem << [00:05:10.604,736] [1;33m<wrn> cloud_module: New connection attempt in 128 seconds if not successful[0m
    2023-09-18T07:12:55.489Z DEBUG modem << [00:05:10.604,888] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:12:55.497Z DEBUG modem << [00:05:10.605,895] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:13:13.138Z DEBUG modem << +CSCON: 0
    2023-09-18T07:13:15.702Z DEBUG modem << %CESQ: 97,4,33,4
    2023-09-18T07:13:18.340Z DEBUG modem << %CESQ: 97,4,28,4
    2023-09-18T07:13:19.664Z DEBUG modem << %CESQ: 97,4,34,4
    2023-09-18T07:13:20.981Z DEBUG modem << %CESQ: 97,4,28,4
    2023-09-18T07:13:25.867Z DEBUG modem << %CESQ: 97,4,34,4
    2023-09-18T07:13:28.500Z DEBUG modem << %CESQ: 97,4,28,4
    2023-09-18T07:13:29.820Z DEBUG modem << %CESQ: 97,4,34,4
    2023-09-18T07:13:31.138Z DEBUG modem << %CESQ: 97,4,29,4
    2023-09-18T07:13:34.623Z DEBUG modem << %CESQ: 97,4,34,4
    2023-09-18T07:13:34.769Z DEBUG modem >> at+cpsms?
    2023-09-18T07:13:34.881Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:13:34.889Z DEBUG modem << OK
    2023-09-18T07:13:43.580Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:13:43.713Z DEBUG modem << +CEREG: 2
    2023-09-18T07:13:43.855Z DEBUG modem << +CIND: "service",0
    2023-09-18T07:13:44.787Z DEBUG modem << [00:06:00.181,182] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:13:45.134Z DEBUG modem << [00:06:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:13:45.248Z DEBUG modem << [00:06:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2023-09-18T07:13:45.254Z DEBUG modem << [00:06:01.518,371] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2023-09-18T07:13:45.257Z DEBUG modem << [00:06:01.518,829] [0m<inf> app_event_manager: GNSS_EVT_AGPS_NEEDED[0m
    2023-09-18T07:13:45.260Z DEBUG modem << [00:06:01.519,592] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:13:45.273Z DEBUG modem << [00:06:01.520,019] [1;33m<wrn> data_module: Failed to request A-GPS data, error: -13[0m
    2023-09-18T07:13:45.276Z DEBUG modem << [00:06:01.520,019] [1;33m<wrn> data_module: This is expected to fail if we are not in a connected state[0m
    2023-09-18T07:13:45.281Z DEBUG modem << [00:06:01.523,101] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:13:45.285Z DEBUG modem << [00:06:01.523,132] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:13:45.288Z DEBUG modem << [00:06:01.523,193] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2023-09-18T07:13:45.292Z DEBUG modem << [00:06:01.527,252] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:13:45.296Z DEBUG modem << [00:06:01.527,282] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:13:45.299Z DEBUG modem << [00:06:01.527,374] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2023-09-18T07:13:46.444Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:13:47.452Z DEBUG modem << [00:06:02.844,329] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:14:08.682Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:14:08.974Z INFO Modem port is opened
    2023-09-18T07:14:09.023Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:14:09.255Z DEBUG modem << +CFUN: 1
    2023-09-18T07:14:09.491Z DEBUG modem <<
    2023-09-18T07:14:09.500Z DEBUG modem << OK
    2023-09-18T07:14:09.753Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:14:10.635Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:14:10.639Z DEBUG modem << OK
    2023-09-18T07:14:10.791Z DEBUG modem >> AT+CGMI
    2023-09-18T07:14:10.926Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:14:10.932Z DEBUG modem << OK
    2023-09-18T07:14:10.940Z DEBUG modem >> AT+CGMM
    2023-09-18T07:14:11.103Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:14:11.109Z DEBUG modem << OK
    2023-09-18T07:14:11.269Z DEBUG modem >> AT+CGMR
    2023-09-18T07:14:11.466Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:14:11.471Z DEBUG modem << OK
    2023-09-18T07:14:11.473Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:14:11.622Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:14:11.968Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:14:11.978Z DEBUG modem << OK
    2023-09-18T07:14:12.002Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:14:12.127Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:14:12.136Z DEBUG modem << OK
    2023-09-18T07:14:12.263Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:14:12.429Z DEBUG modem << +CMEE: 1
    2023-09-18T07:14:12.600Z DEBUG modem << OK
    2023-09-18T07:14:12.733Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:14:12.857Z DEBUG modem << +CNEC: 24
    2023-09-18T07:14:13.022Z DEBUG modem << OK
    2023-09-18T07:14:13.191Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:14:13.380Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:14:13.385Z DEBUG modem << OK
    2023-09-18T07:14:13.389Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:14:13.516Z DEBUG modem << OK
    2023-09-18T07:14:13.520Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:14:13.650Z DEBUG modem << OK
    2023-09-18T07:14:13.689Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:14:13.856Z DEBUG modem << +CEREG: 5,2
    2023-09-18T07:14:13.866Z DEBUG modem << OK
    2023-09-18T07:14:14.012Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:14:14.167Z DEBUG modem << OK
    2023-09-18T07:14:14.173Z DEBUG modem >> AT+CESQ
    2023-09-18T07:14:14.383Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:14:14.391Z DEBUG modem << OK
    2023-09-18T07:14:14.568Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:14:14.751Z DEBUG modem << OK
    2023-09-18T07:14:14.940Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:14:15.141Z DEBUG modem << %XSIM: 1
    2023-09-18T07:14:15.308Z DEBUG modem <<
    2023-09-18T07:14:15.317Z DEBUG modem << OK
    2023-09-18T07:14:15.456Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:14:15.605Z DEBUG modem << +CPIN: READY
    2023-09-18T07:14:15.608Z DEBUG modem << OK
    2023-09-18T07:14:15.792Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:14:15.988Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:14:15.995Z DEBUG modem << OK
    2023-09-18T07:14:16.176Z DEBUG modem >> AT+CIMI
    2023-09-18T07:14:16.403Z DEBUG modem << 001010123456789
    2023-09-18T07:14:16.409Z DEBUG modem << OK
    2023-09-18T07:14:16.413Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:15:01.123Z DEBUG modem << [00:07:16.520,080] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:15:03.208Z DEBUG modem << [00:07:18.604,888] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:15:03.407Z DEBUG modem << [00:07:18.605,438] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:15:03.421Z DEBUG modem << [00:07:18.605,468] [1;33m<wrn> cloud_module: New connection attempt in 256 seconds if not successful[0m
    2023-09-18T07:15:03.426Z DEBUG modem << [00:07:18.605,621] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:15:03.433Z DEBUG modem << [00:07:18.606,475] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:15:08.155Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:15:08.325Z DEBUG modem << +CFUN: 1
    2023-09-18T07:15:08.366Z DEBUG modem << OK
    2023-09-18T07:15:08.605Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:15:08.838Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:15:08.849Z DEBUG modem << OK
    2023-09-18T07:15:09.006Z DEBUG modem >> AT+CGMI
    2023-09-18T07:15:09.281Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:15:09.288Z DEBUG modem << OK
    2023-09-18T07:15:09.293Z DEBUG modem >> AT+CGMM
    2023-09-18T07:15:09.743Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:15:09.831Z DEBUG modem << OK
    2023-09-18T07:15:10.215Z DEBUG modem >> AT+CGMR
    2023-09-18T07:15:10.605Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:15:10.611Z DEBUG modem << OK
    2023-09-18T07:15:10.622Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:15:10.852Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:15:11.498Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:15:11.506Z DEBUG modem << OK
    2023-09-18T07:15:11.744Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:15:12.017Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:15:12.023Z DEBUG modem << OK
    2023-09-18T07:15:12.042Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:15:12.219Z DEBUG modem << +CMEE: 1
    2023-09-18T07:15:12.226Z DEBUG modem <<
    2023-09-18T07:15:12.233Z DEBUG modem << OK
    2023-09-18T07:15:12.384Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:15:12.617Z DEBUG modem << +CNEC: 24
    2023-09-18T07:15:12.621Z DEBUG modem << OK
    2023-09-18T07:15:12.816Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:15:13.000Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:15:13.004Z DEBUG modem << OK
    2023-09-18T07:15:13.007Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:15:13.241Z DEBUG modem << OK
    2023-09-18T07:15:13.393Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:15:13.572Z DEBUG modem << OK
    2023-09-18T07:15:13.759Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:15:14.054Z DEBUG modem << +CEREG: 5,2
    2023-09-18T07:15:14.063Z DEBUG modem << OK
    2023-09-18T07:15:14.308Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:15:14.574Z DEBUG modem << OK
    2023-09-18T07:15:14.808Z DEBUG modem >> AT+CESQ
    2023-09-18T07:15:15.102Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:15:15.106Z DEBUG modem << OK
    2023-09-18T07:15:15.118Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:15:15.286Z DEBUG modem << OK
    2023-09-18T07:15:15.470Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:15:15.709Z DEBUG modem << %XSIM: 1
    2023-09-18T07:15:15.717Z DEBUG modem << OK
    2023-09-18T07:15:15.917Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:15:16.102Z DEBUG modem << +CPIN: READY
    2023-09-18T07:15:16.110Z DEBUG modem << OK
    2023-09-18T07:15:16.276Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:15:16.517Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:15:16.522Z DEBUG modem << OK
    2023-09-18T07:15:16.939Z DEBUG modem >> AT+CIMI
    2023-09-18T07:15:17.208Z DEBUG modem << 001010123456789
    2023-09-18T07:15:17.220Z DEBUG modem << OK
    2023-09-18T07:15:17.225Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:15:45.124Z DEBUG modem << [00:08:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:15:45.354Z DEBUG modem << [00:08:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2023-09-18T07:15:45.358Z DEBUG modem << [00:08:01.513,244] [1;33m<wrn> gnss_module: GNSS search already active and will not be restarted[0m
    2023-09-18T07:15:45.361Z DEBUG modem << [00:08:01.513,244] [1;33m<wrn> gnss_module: Try setting a sample/publication interval greater[0m
    2023-09-18T07:15:45.369Z DEBUG modem << [00:08:01.513,275] [1;33m<wrn> gnss_module: than the GNSS search timeout.[0m
    2023-09-18T07:15:45.372Z DEBUG modem << [00:08:01.514,068] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:15:45.374Z DEBUG modem << [00:08:01.517,364] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:15:45.377Z DEBUG modem << [00:08:01.517,364] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:15:45.381Z DEBUG modem << [00:08:01.517,456] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2023-09-18T07:15:45.384Z DEBUG modem << [00:08:01.521,240] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:15:45.388Z DEBUG modem << [00:08:01.521,240] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:15:45.393Z DEBUG modem << [00:08:01.521,331] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2023-09-18T07:16:22.174Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:16:23.121Z DEBUG modem << [00:08:38.501,251] [0m<inf> app_event_manager: GNSS_EVT_TIMEOUT[0m
    2023-09-18T07:16:23.128Z DEBUG modem << [00:08:38.501,739] [0m<inf> app_event_manager: GNSS_EVT_INACTIVE[0m
    2023-09-18T07:16:23.423Z DEBUG modem << [00:08:38.580,230] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:16:23.431Z DEBUG modem << [00:08:38.580,902] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:17:20.714Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:17:21.119Z INFO Modem port is opened
    2023-09-18T07:17:21.682Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:17:22.471Z DEBUG modem << +CGEV: ME PDN ACT 0
    2023-09-18T07:17:22.493Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2023-09-18T07:17:22.511Z DEBUG modem << +CEREG: 1,"0001","00000000",9,,,"11100000","11100000"
    2023-09-18T07:17:22.533Z DEBUG modem << +CFUN: 1
    2023-09-18T07:17:22.550Z DEBUG modem << OK
    2023-09-18T07:17:22.960Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:17:23.958Z DEBUG modem << [00:00:04.277,221] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED[0m
    2023-09-18T07:17:23.961Z DEBUG modem << [00:00:04.278,472] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:17:23.964Z DEBUG modem << [00:00:04.278,472] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
    2023-09-18T07:17:23.971Z DEBUG modem << [00:00:04.278,594] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:17:23.975Z DEBUG modem << [00:00:04.280,090] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:17:23.979Z DEBUG modem << [00:00:04.383,911] [0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE[0m
    2023-09-18T07:17:23.984Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:17:23.992Z DEBUG modem << OK
    2023-09-18T07:17:23.996Z DEBUG modem << [00:00:05.383,880] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:17:24.004Z DEBUG modem << [00:00:05.384,155] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:17:24.011Z DEBUG modem << [00:00:05.384,155] [1;33m<wrn> date_time: Did not get time from any NTP server[0m
    2023-09-18T07:17:24.173Z DEBUG modem >> AT+CGMI
    2023-09-18T07:17:24.369Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:17:24.382Z DEBUG modem << OK
    2023-09-18T07:17:24.627Z DEBUG modem >> AT+CGMM
    2023-09-18T07:17:24.972Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:17:24.980Z DEBUG modem << OK
    2023-09-18T07:17:25.172Z DEBUG modem >> AT+CGMR
    2023-09-18T07:17:25.434Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:17:25.445Z DEBUG modem << OK
    2023-09-18T07:17:25.456Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:17:25.704Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:17:26.243Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:17:26.260Z DEBUG modem << OK
    2023-09-18T07:17:26.532Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:17:26.891Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:17:26.907Z DEBUG modem << OK
    2023-09-18T07:17:27.345Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:17:27.632Z DEBUG modem << +CMEE: 0
    2023-09-18T07:17:27.642Z DEBUG modem << OK
    2023-09-18T07:17:28.056Z DEBUG modem >> AT+CMEE=1
    2023-09-18T07:17:28.327Z DEBUG modem << OK
    2023-09-18T07:17:28.585Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:17:28.950Z DEBUG modem << +CNEC: 16
    2023-09-18T07:17:28.955Z DEBUG modem << OK
    2023-09-18T07:17:29.132Z DEBUG modem >> AT+CNEC=24
    2023-09-18T07:17:29.329Z DEBUG modem << OK
    2023-09-18T07:17:29.339Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:17:29.588Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:17:29.884Z DEBUG modem << OK
    2023-09-18T07:17:30.157Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:17:30.460Z DEBUG modem << OK
    2023-09-18T07:17:30.724Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:17:31.015Z DEBUG modem << OK
    2023-09-18T07:17:31.040Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:17:31.334Z DEBUG modem << +CEREG: 5,1,"0001","00000000",9,,,"11100000","11100000"
    2023-09-18T07:17:31.342Z DEBUG modem << OK
    2023-09-18T07:17:31.548Z DEBUG modem >> AT+COPS=3,2
    2023-09-18T07:17:31.766Z DEBUG modem << OK
    2023-09-18T07:17:31.782Z DEBUG modem >> AT+COPS?
    2023-09-18T07:17:32.109Z DEBUG modem << +COPS: 0,2,"00101",9
    2023-09-18T07:17:32.117Z DEBUG modem << OK
    2023-09-18T07:17:32.138Z DEBUG modem >> AT%XCBAND
    2023-09-18T07:17:32.335Z DEBUG modem << %XCBAND: 3
    2023-09-18T07:17:32.551Z DEBUG modem << OK
    2023-09-18T07:17:32.877Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:17:33.210Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:17:33.226Z DEBUG modem << OK
    2023-09-18T07:17:33.437Z DEBUG modem >> AT+CGACT?
    2023-09-18T07:17:33.687Z DEBUG modem << +CGACT: 0,1
    2023-09-18T07:17:33.698Z DEBUG modem << OK
    2023-09-18T07:17:33.982Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:17:34.345Z DEBUG modem << OK
    2023-09-18T07:17:34.606Z DEBUG modem >> AT+CESQ
    2023-09-18T07:17:34.966Z DEBUG modem << +CGEV: IPV6 FAIL 0
    2023-09-18T07:17:34.977Z DEBUG modem << +CESQ: 99,99,255,255,29,97
    2023-09-18T07:17:34.989Z DEBUG modem << OK
    2023-09-18T07:17:35.329Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:17:35.605Z DEBUG modem << OK
    2023-09-18T07:17:35.959Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:17:36.238Z DEBUG modem << %XSIM: 1
    2023-09-18T07:17:36.519Z DEBUG modem << OK
    2023-09-18T07:17:36.861Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:17:37.161Z DEBUG modem << +CPIN: READY
    2023-09-18T07:17:37.506Z DEBUG modem << OK
    2023-09-18T07:17:37.789Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:17:38.073Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:17:38.079Z DEBUG modem << OK
    2023-09-18T07:17:38.268Z DEBUG modem >> AT+CIMI
    2023-09-18T07:17:38.463Z DEBUG modem << 001010123456789
    2023-09-18T07:17:38.475Z DEBUG modem << OK
    2023-09-18T07:17:38.483Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:17:54.649Z DEBUG modem << [00:00:36.278,656] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:17:54.784Z DEBUG modem << [00:00:36.279,205] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:17:54.789Z DEBUG modem << [00:00:36.279,235] [1;33m<wrn> cloud_module: New connection attempt in 64 seconds if not successful[0m
    2023-09-18T07:17:54.796Z DEBUG modem << [00:00:36.279,388] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:17:54.807Z DEBUG modem << [00:00:36.280,303] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:17:54.940Z DEBUG modem >> at+cpsms?
    2023-09-18T07:17:55.103Z DEBUG modem << +CPSMS: 1,,,"11000001","00001010"
    2023-09-18T07:17:55.109Z DEBUG modem << OK
    2023-09-18T07:18:00.764Z DEBUG modem >> at+cpsms=0
    2023-09-18T07:18:00.903Z DEBUG modem << OK
    2023-09-18T07:18:06.629Z DEBUG modem >> at+cpsms?
    2023-09-18T07:18:06.805Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:18:06.809Z DEBUG modem << OK
    2023-09-18T07:18:58.647Z DEBUG modem << [00:01:40.279,388] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:18:58.857Z DEBUG modem << [00:01:40.279,937] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:18:59.068Z DEBUG modem << [00:01:40.279,968] [1;33m<wrn> cloud_module: New connection attempt in 128 seconds if not successful[0m
    2023-09-18T07:18:59.075Z DEBUG modem << [00:01:40.280,120] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:18:59.078Z DEBUG modem << [00:01:40.280,975] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:19:16.697Z DEBUG modem << +CSCON: 0
    2023-09-18T07:19:19.055Z DEBUG modem << [00:02:01.512,542] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:19:19.286Z DEBUG modem << [00:02:01.513,214] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2023-09-18T07:19:19.292Z DEBUG modem << [00:02:01.514,068] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:19:19.297Z DEBUG modem << [00:02:01.572,937] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:19:19.302Z DEBUG modem << [00:02:01.572,967] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:19:19.307Z DEBUG modem << [00:02:01.573,089] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY[0m
    2023-09-18T07:19:19.312Z DEBUG modem << [00:02:01.630,737] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:19:19.316Z DEBUG modem << [00:02:01.630,737] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:19:19.319Z DEBUG modem << [00:02:01.630,889] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2023-09-18T07:19:19.323Z DEBUG modem << [00:02:01.688,476] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:19:19.326Z DEBUG modem << [00:02:01.688,507] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:19:19.329Z DEBUG modem << [00:02:01.688,629] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2023-09-18T07:19:19.468Z DEBUG modem << %CESQ: 97,4,33,4
    2023-09-18T07:19:25.900Z DEBUG modem << %CESQ: 97,4,28,4
    2023-09-18T07:19:27.019Z DEBUG modem << %CESQ: 97,4,33,4
    2023-09-18T07:19:30.880Z DEBUG modem << [00:02:12.514,526] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:19:34.659Z DEBUG modem << %CESQ: 97,4,28,4
    2023-09-18T07:19:37.099Z DEBUG modem << %CESQ: 97,4,33,4
    2023-09-18T07:19:47.103Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:19:47.324Z DEBUG modem << +CEREG: 2
    2023-09-18T07:19:47.352Z DEBUG modem << +CIND: "service",0
    2023-09-18T07:19:48.311Z DEBUG modem << [00:02:29.944,885] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:19:58.357Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:19:59.363Z DEBUG modem << [00:02:40.997,192] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:20:44.574Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:20:44.933Z INFO Modem port is opened
    2023-09-18T07:20:44.966Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:20:44.977Z DEBUG modem << [00:00:01.511,840] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:20:44.985Z DEBUG modem << [00:00:02.268,554] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:20:45.355Z DEBUG modem << +CFUN: 1
    2023-09-18T07:20:45.363Z DEBUG modem << OK
    2023-09-18T07:20:45.600Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:20:46.257Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:20:46.262Z DEBUG modem << OK
    2023-09-18T07:20:46.420Z DEBUG modem >> AT+CGMI
    2023-09-18T07:20:46.622Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:20:46.628Z DEBUG modem << OK
    2023-09-18T07:20:46.819Z DEBUG modem >> AT+CGMM
    2023-09-18T07:20:47.033Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:20:47.039Z DEBUG modem << OK
    2023-09-18T07:20:47.051Z DEBUG modem >> AT+CGMR
    2023-09-18T07:20:47.239Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:20:47.244Z DEBUG modem << OK
    2023-09-18T07:20:47.247Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:20:47.247Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:20:47.363Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:20:47.663Z DEBUG modem << OK
    2023-09-18T07:20:47.836Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:20:48.046Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:20:48.052Z DEBUG modem << OK
    2023-09-18T07:20:48.189Z DEBUG modem >> at+cpsms?
    2023-09-18T07:20:48.345Z DEBUG modem << +CPSMS: 1,,,"11000001","00001010"
    2023-09-18T07:20:48.359Z DEBUG modem << OK
    2023-09-18T07:20:48.511Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:20:48.746Z DEBUG modem << +CMEE: 0
    2023-09-18T07:20:48.751Z DEBUG modem << OK
    2023-09-18T07:20:48.755Z DEBUG modem >> AT+CMEE=1
    2023-09-18T07:20:48.879Z DEBUG modem << OK
    2023-09-18T07:20:49.030Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:20:49.231Z DEBUG modem << +CNEC: 16
    2023-09-18T07:20:49.235Z DEBUG modem << OK
    2023-09-18T07:20:49.239Z DEBUG modem >> AT+CNEC=24
    2023-09-18T07:20:49.247Z DEBUG modem << OK
    2023-09-18T07:20:49.374Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:20:49.520Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:20:49.526Z DEBUG modem << OK
    2023-09-18T07:20:49.530Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:20:49.708Z DEBUG modem << OK
    2023-09-18T07:20:49.892Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:20:50.070Z DEBUG modem << OK
    2023-09-18T07:20:50.241Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:20:50.429Z DEBUG modem << +CEREG: 5,2,"0001","00000000",9
    2023-09-18T07:20:50.436Z DEBUG modem << OK
    2023-09-18T07:20:50.447Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:20:50.584Z DEBUG modem << OK
    2023-09-18T07:20:50.713Z DEBUG modem >> AT+CESQ
    2023-09-18T07:20:50.995Z DEBUG modem << +CESQ: 99,99,255,255,34,96
    2023-09-18T07:20:51.002Z DEBUG modem << OK
    2023-09-18T07:20:51.129Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:20:51.309Z DEBUG modem << OK
    2023-09-18T07:20:51.481Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:20:51.758Z DEBUG modem << %XSIM: 1
    2023-09-18T07:20:52.105Z DEBUG modem << OK
    2023-09-18T07:20:52.402Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:20:52.677Z DEBUG modem << +CPIN: READY
    2023-09-18T07:20:52.681Z DEBUG modem << OK
    2023-09-18T07:20:52.875Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:20:53.076Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:20:53.082Z DEBUG modem << OK
    2023-09-18T07:20:53.235Z DEBUG modem >> AT+CIMI
    2023-09-18T07:20:53.455Z DEBUG modem << 001010123456789
    2023-09-18T07:20:53.459Z DEBUG modem << OK
    2023-09-18T07:20:53.462Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:20:55.442Z DEBUG modem >> at+cpsmS=0
    2023-09-18T07:20:55.604Z DEBUG modem << OK
    2023-09-18T07:20:57.392Z DEBUG modem >> at+cpsmS=0
    2023-09-18T07:20:57.560Z DEBUG modem << OK
    2023-09-18T07:21:00.874Z DEBUG modem >> at+cpsmS=0
    2023-09-18T07:21:01.132Z DEBUG modem << OK
    2023-09-18T07:21:06.755Z DEBUG modem >> at+cpsmS?
    2023-09-18T07:21:06.904Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:21:06.909Z DEBUG modem << OK
    2023-09-18T07:21:24.830Z DEBUG modem << %CESQ: 16,0,0,0
    2023-09-18T07:21:34.608Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:21:34.848Z DEBUG modem << +CEREG: 2
    2023-09-18T07:21:35.715Z DEBUG modem << [00:00:52.564,239] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:22:26.381Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:22:26.505Z DEBUG modem << +CGDCONT: 0,"","","",0,0
    2023-09-18T07:22:26.522Z DEBUG modem << OK
    2023-09-18T07:22:41.198Z DEBUG modem << %MDMEV: SEARCH STATUS 1
    2023-09-18T07:22:43.673Z DEBUG modem << [00:02:01.512,481] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:22:43.823Z DEBUG modem << [00:02:01.513,153] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2023-09-18T07:22:43.828Z DEBUG modem << [00:02:01.514,007] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:22:43.832Z DEBUG modem << [00:02:01.517,089] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:22:43.837Z DEBUG modem << [00:02:01.517,089] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:22:43.845Z DEBUG modem << [00:02:01.517,181] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_NOT_READY[0m
    2023-09-18T07:22:43.848Z DEBUG modem << [00:02:01.520,599] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:22:43.853Z DEBUG modem << [00:02:01.520,629] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:22:43.858Z DEBUG modem << [00:02:01.520,690] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2023-09-18T07:22:43.861Z DEBUG modem << [00:02:01.524,108] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:22:43.864Z DEBUG modem << [00:02:01.524,139] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:22:43.870Z DEBUG modem << [00:02:01.524,230] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2023-09-18T07:22:44.043Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:22:44.849Z DEBUG modem << [00:02:01.699,981] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:22:45.002Z DEBUG modem << [00:02:01.700,714] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:22:47.063Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:22:47.196Z DEBUG modem << +CFUN: 1
    2023-09-18T07:22:47.221Z DEBUG modem << OK
    2023-09-18T07:22:47.382Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:22:47.614Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:22:47.624Z DEBUG modem << OK
    2023-09-18T07:22:47.779Z DEBUG modem >> AT+CGMI
    2023-09-18T07:22:48.001Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:22:48.012Z DEBUG modem << OK
    2023-09-18T07:22:48.211Z DEBUG modem >> AT+CGMM
    2023-09-18T07:22:48.416Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:22:48.423Z DEBUG modem << OK
    2023-09-18T07:22:48.614Z DEBUG modem >> AT+CGMR
    2023-09-18T07:22:48.799Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:22:48.808Z DEBUG modem << OK
    2023-09-18T07:22:48.815Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:22:48.970Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:22:49.331Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:22:49.339Z DEBUG modem << OK
    2023-09-18T07:22:49.512Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:22:49.759Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:22:49.768Z DEBUG modem << OK
    2023-09-18T07:22:49.938Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:22:50.116Z DEBUG modem << +CMEE: 1
    2023-09-18T07:22:50.339Z DEBUG modem <<
    2023-09-18T07:22:50.345Z DEBUG modem << OK
    2023-09-18T07:22:50.505Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:22:50.695Z DEBUG modem << +CNEC: 24
    2023-09-18T07:22:50.926Z DEBUG modem <<
    2023-09-18T07:22:50.933Z DEBUG modem << OK
    2023-09-18T07:22:51.113Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:22:51.369Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:22:51.375Z DEBUG modem << OK
    2023-09-18T07:22:51.379Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:22:51.505Z DEBUG modem << OK
    2023-09-18T07:22:51.641Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:22:51.875Z DEBUG modem << OK
    2023-09-18T07:22:52.044Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:22:52.240Z DEBUG modem << +CEREG: 5,2
    2023-09-18T07:22:52.455Z DEBUG modem <<
    2023-09-18T07:22:52.461Z DEBUG modem << OK
    2023-09-18T07:22:52.633Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:22:52.844Z DEBUG modem << OK
    2023-09-18T07:22:53.020Z DEBUG modem >> AT+CESQ
    2023-09-18T07:22:53.247Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:22:53.255Z DEBUG modem << OK
    2023-09-18T07:22:53.439Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:22:53.634Z DEBUG modem << OK
    2023-09-18T07:22:53.812Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:22:54.054Z DEBUG modem << %XSIM: 1
    2023-09-18T07:22:54.060Z DEBUG modem << OK
    2023-09-18T07:22:54.215Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:22:54.445Z DEBUG modem << +CPIN: READY
    2023-09-18T07:22:54.450Z DEBUG modem << OK
    2023-09-18T07:22:54.576Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:22:54.776Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:22:54.781Z DEBUG modem << OK
    2023-09-18T07:22:54.929Z DEBUG modem >> AT+CIMI
    2023-09-18T07:22:55.145Z DEBUG modem << 001010123456789
    2023-09-18T07:22:55.149Z DEBUG modem << OK
    2023-09-18T07:22:55.155Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:23:47.854Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:23:48.022Z INFO Modem port is opened
    2023-09-18T07:23:48.045Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:23:48.058Z DEBUG modem << +CSCON: 1
    2023-09-18T07:23:48.480Z DEBUG modem << +CFUN: 1
    2023-09-18T07:23:48.496Z DEBUG modem << OK
    2023-09-18T07:23:48.700Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:23:48.960Z DEBUG modem << [00:00:01.511,871] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:23:48.980Z DEBUG modem << [00:00:01.887,542] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:23:49.655Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:23:49.661Z DEBUG modem << OK
    2023-09-18T07:23:49.872Z DEBUG modem >> AT+CGMI
    2023-09-18T07:23:50.225Z DEBUG modem << +CGEV: ME PDN ACT 0
    2023-09-18T07:23:50.230Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2023-09-18T07:23:50.234Z DEBUG modem << +CEREG: 1,"0001","00000000",9,,,"11100000","11100000"
    2023-09-18T07:23:50.240Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:23:50.243Z DEBUG modem << OK
    2023-09-18T07:23:50.393Z DEBUG modem >> AT+CGMM
    2023-09-18T07:23:50.616Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:23:50.622Z DEBUG modem << OK
    2023-09-18T07:23:50.764Z DEBUG modem >> AT+CGMR
    2023-09-18T07:23:50.921Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:23:50.929Z DEBUG modem << OK
    2023-09-18T07:23:50.933Z DEBUG modem << [00:00:03.913,787] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED[0m
    2023-09-18T07:23:50.936Z DEBUG modem << [00:00:03.915,039] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:23:50.944Z DEBUG modem << [00:00:03.915,039] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
    2023-09-18T07:23:50.948Z DEBUG modem << [00:00:03.915,161] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:23:50.952Z DEBUG modem << [00:00:03.916,656] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:23:50.956Z DEBUG modem << [00:00:04.035,339] [0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE[0m
    2023-09-18T07:23:50.960Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:23:51.128Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:23:51.465Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:23:51.669Z DEBUG modem <<
    2023-09-18T07:23:51.680Z DEBUG modem << OK
    2023-09-18T07:23:51.893Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:23:52.147Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:23:52.153Z DEBUG modem << OK
    2023-09-18T07:23:52.157Z DEBUG modem << [00:00:04.958,465] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:23:52.160Z DEBUG modem << [00:00:04.958,862] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:23:52.163Z DEBUG modem << [00:00:04.958,892] [1;33m<wrn> date_time: Did not get time from any NTP server[0m
    2023-09-18T07:23:52.301Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:23:52.462Z DEBUG modem << +CMEE: 0
    2023-09-18T07:23:52.480Z DEBUG modem << OK
    2023-09-18T07:23:52.647Z DEBUG modem >> AT+CMEE=1
    2023-09-18T07:23:52.963Z DEBUG modem << OK
    2023-09-18T07:23:53.091Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:23:53.455Z DEBUG modem << +CNEC: 16
    2023-09-18T07:23:53.459Z DEBUG modem << OK
    2023-09-18T07:23:53.581Z DEBUG modem >> AT+CNEC=24
    2023-09-18T07:23:53.763Z DEBUG modem << OK
    2023-09-18T07:23:53.987Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:23:54.212Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:23:54.216Z DEBUG modem << OK
    2023-09-18T07:23:54.371Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:23:54.643Z DEBUG modem << OK
    2023-09-18T07:23:54.841Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:23:55.038Z DEBUG modem << OK
    2023-09-18T07:23:55.210Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:23:55.427Z DEBUG modem << +CEREG: 5,1,"0001","00000000",9,,,"11100000","11100000"
    2023-09-18T07:23:55.438Z DEBUG modem << OK
    2023-09-18T07:23:55.747Z DEBUG modem >> AT+COPS=3,2
    2023-09-18T07:23:56.130Z DEBUG modem << OK
    2023-09-18T07:23:56.283Z DEBUG modem >> AT+COPS?
    2023-09-18T07:23:56.538Z DEBUG modem << +COPS: 0,2,"00101",9
    2023-09-18T07:23:56.545Z DEBUG modem << OK
    2023-09-18T07:23:56.721Z DEBUG modem >> AT%XCBAND
    2023-09-18T07:23:56.890Z DEBUG modem << %XCBAND: 3
    2023-09-18T07:23:56.905Z DEBUG modem << OK
    2023-09-18T07:23:57.096Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:23:57.407Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:23:57.414Z DEBUG modem << OK
    2023-09-18T07:23:57.661Z DEBUG modem >> AT+CGACT?
    2023-09-18T07:23:57.986Z DEBUG modem << +CGACT: 0,1
    2023-09-18T07:23:57.996Z DEBUG modem << OK
    2023-09-18T07:23:58.173Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:23:58.303Z DEBUG modem << OK
    2023-09-18T07:23:58.316Z DEBUG modem >> AT+CESQ
    2023-09-18T07:23:58.496Z DEBUG modem << +CESQ: 99,99,255,255,28,95
    2023-09-18T07:23:58.501Z DEBUG modem << OK
    2023-09-18T07:23:58.678Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:23:58.820Z DEBUG modem << OK
    2023-09-18T07:23:59.203Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:23:59.350Z DEBUG modem << %XSIM: 1
    2023-09-18T07:23:59.357Z DEBUG modem << OK
    2023-09-18T07:23:59.497Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:23:59.827Z DEBUG modem << +CPIN: READY
    2023-09-18T07:23:59.832Z DEBUG modem << OK
    2023-09-18T07:23:59.963Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:24:00.116Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:24:00.124Z DEBUG modem << OK
    2023-09-18T07:24:00.329Z DEBUG modem >> AT+CIMI
    2023-09-18T07:24:00.557Z DEBUG modem << 001010123456789
    2023-09-18T07:24:00.562Z DEBUG modem << OK
    2023-09-18T07:24:00.566Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:24:00.723Z DEBUG modem >> AT+CPSMS=0
    2023-09-18T07:24:01.045Z DEBUG modem << OK
    2023-09-18T07:24:02.391Z DEBUG modem >> AT+CPSMS=0
    2023-09-18T07:24:02.588Z DEBUG modem << OK
    2023-09-18T07:24:02.802Z DEBUG modem << +CGEV: IPV6 FAIL 0
    2023-09-18T07:24:03.001Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:24:03.201Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:24:03.208Z DEBUG modem << OK
    2023-09-18T07:24:03.371Z DEBUG modem >> AT+CGACT?
    2023-09-18T07:24:03.587Z DEBUG modem << +CGACT: 0,1
    2023-09-18T07:24:03.596Z DEBUG modem << OK
    2023-09-18T07:24:09.036Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:24:09.223Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:24:09.240Z DEBUG modem << OK
    2023-09-18T07:24:22.879Z DEBUG modem << [00:00:35.915,222] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:24:23.208Z DEBUG modem << [00:00:35.915,771] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:24:23.215Z DEBUG modem << [00:00:35.915,802] [1;33m<wrn> cloud_module: New connection attempt in 64 seconds if not successful[0m
    2023-09-18T07:24:23.221Z DEBUG modem << [00:00:35.915,954] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:24:23.227Z DEBUG modem << [00:00:35.916,870] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:24:47.568Z DEBUG modem >> AT#XPING="www.google.com",45,5000,5,1000
    2023-09-18T07:24:47.763Z DEBUG modem << +CME ERROR: 0
    2023-09-18T07:24:47.768Z ERROR Error: AT#XPING="www.google.com",45,5000,5,1000
     failed: phone failure
    2023-09-18T07:25:16.664Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:25:16.825Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:25:16.848Z DEBUG modem << OK
    2023-09-18T07:25:26.878Z DEBUG modem << [00:01:39.915,954] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:25:27.142Z DEBUG modem << [00:01:39.916,503] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:25:27.465Z DEBUG modem << [00:01:39.916,534] [1;33m<wrn> cloud_module: New connection attempt in 128 seconds if not successful[0m
    2023-09-18T07:25:27.477Z DEBUG modem << [00:01:39.916,687] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:25:27.483Z DEBUG modem << [00:01:39.917,541] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:25:44.929Z DEBUG modem << +CSCON: 0
    2023-09-18T07:25:45.153Z DEBUG modem << %CESQ: 96,4,25,3
    2023-09-18T07:25:46.217Z DEBUG modem << %CESQ: 97,4,31,4
    2023-09-18T07:25:47.594Z DEBUG modem << [00:02:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:25:47.818Z DEBUG modem << [00:02:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2023-09-18T07:25:47.823Z DEBUG modem << [00:02:01.514,038] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:25:47.827Z DEBUG modem << [00:02:01.554,107] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:25:47.831Z DEBUG modem << [00:02:01.554,107] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:25:47.835Z DEBUG modem << [00:02:01.554,229] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY[0m
    2023-09-18T07:25:47.841Z DEBUG modem << [00:02:01.586,883] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:25:47.844Z DEBUG modem << [00:02:01.586,914] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:25:47.847Z DEBUG modem << [00:02:01.587,036] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2023-09-18T07:25:47.849Z DEBUG modem << [00:02:01.631,622] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:25:47.857Z DEBUG modem << [00:02:01.631,622] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:25:47.860Z DEBUG modem << [00:02:01.631,744] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2023-09-18T07:25:59.475Z DEBUG modem << [00:02:12.514,495] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:26:15.333Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:26:15.645Z DEBUG modem << +CEREG: 2
    2023-09-18T07:26:15.668Z DEBUG modem << +CIND: "service",0
    2023-09-18T07:26:16.542Z DEBUG modem << [00:02:29.581,542] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:26:28.147Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:26:29.162Z DEBUG modem << [00:02:42.193,939] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:27:34.877Z DEBUG modem << [00:03:47.916,687] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:27:35.271Z DEBUG modem << [00:03:47.917,236] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:27:35.652Z DEBUG modem << [00:03:47.917,266] [1;33m<wrn> cloud_module: New connection attempt in 256 seconds if not successful[0m
    2023-09-18T07:27:35.661Z DEBUG modem << [00:03:47.917,419] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:27:35.667Z DEBUG modem << [00:03:47.926,727] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:27:47.634Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:27:47.808Z DEBUG modem << [00:04:01.512,512] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:27:47.814Z DEBUG modem << [00:04:01.513,183] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS)[0m
    2023-09-18T07:27:47.819Z DEBUG modem << [00:04:01.514,068] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:27:47.825Z DEBUG modem << [00:04:01.517,303] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:27:47.833Z DEBUG modem << [00:04:01.517,303] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:27:47.837Z DEBUG modem << [00:04:01.517,395] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2023-09-18T07:27:47.841Z DEBUG modem << [00:04:01.521,148] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:27:47.848Z DEBUG modem << [00:04:01.521,179] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:27:47.852Z DEBUG modem << [00:04:01.521,270] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2023-09-18T07:27:47.857Z DEBUG modem << [00:04:01.683,288] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:27:47.860Z DEBUG modem << [00:04:01.683,990] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:29:37.237Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:29:37.608Z INFO Modem port is opened
    2023-09-18T07:29:38.027Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:29:38.453Z DEBUG modem << +CFUN: 1
    2023-09-18T07:29:38.913Z DEBUG modem << OK
    2023-09-18T07:29:39.821Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:29:40.247Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:29:40.254Z DEBUG modem << OK
    2023-09-18T07:29:40.446Z DEBUG modem >> AT+CGMI
    2023-09-18T07:29:40.709Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:29:40.713Z DEBUG modem << OK
    2023-09-18T07:29:40.716Z DEBUG modem >> AT+CGMM
    2023-09-18T07:29:40.879Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:29:40.885Z DEBUG modem << OK
    2023-09-18T07:29:40.890Z DEBUG modem >> AT+CGMR
    2023-09-18T07:29:41.166Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:29:41.170Z DEBUG modem << OK
    2023-09-18T07:29:41.174Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:29:41.323Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:29:41.726Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:29:41.976Z DEBUG modem << OK
    2023-09-18T07:29:42.190Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:29:42.454Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:29:42.460Z DEBUG modem << OK
    2023-09-18T07:29:42.640Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:29:42.849Z DEBUG modem << +CMEE: 0
    2023-09-18T07:29:43.061Z DEBUG modem << OK
    2023-09-18T07:29:43.096Z DEBUG modem >> AT+CMEE=1
    2023-09-18T07:29:43.301Z DEBUG modem << OK
    2023-09-18T07:29:43.499Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:29:43.769Z DEBUG modem << +CNEC: 16
    2023-09-18T07:29:43.774Z DEBUG modem << OK
    2023-09-18T07:29:43.778Z DEBUG modem >> AT+CNEC=24
    2023-09-18T07:29:43.930Z DEBUG modem << OK
    2023-09-18T07:29:43.936Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:29:44.172Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:29:44.182Z DEBUG modem << OK
    2023-09-18T07:29:44.334Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:29:44.524Z DEBUG modem << OK
    2023-09-18T07:29:44.755Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:29:44.992Z DEBUG modem << OK
    2023-09-18T07:29:45.175Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:29:45.417Z DEBUG modem << +CEREG: 5,2,"0001","00000000",9
    2023-09-18T07:29:45.422Z DEBUG modem << OK
    2023-09-18T07:29:45.612Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:29:45.866Z DEBUG modem << OK
    2023-09-18T07:29:46.056Z DEBUG modem >> AT+CESQ
    2023-09-18T07:29:46.289Z DEBUG modem << +CESQ: 99,99,255,255,33,96
    2023-09-18T07:29:46.300Z DEBUG modem << OK
    2023-09-18T07:29:46.501Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:29:46.733Z DEBUG modem << OK
    2023-09-18T07:29:46.953Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:29:47.197Z DEBUG modem << %XSIM: 1
    2023-09-18T07:29:47.205Z DEBUG modem << OK
    2023-09-18T07:29:47.468Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:29:47.713Z DEBUG modem << +CPIN: READY
    2023-09-18T07:29:47.717Z DEBUG modem << OK
    2023-09-18T07:29:47.901Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:29:48.143Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:29:48.148Z DEBUG modem << OK
    2023-09-18T07:29:48.327Z DEBUG modem >> AT+CIMI
    2023-09-18T07:29:48.572Z DEBUG modem << 001010123456789
    2023-09-18T07:29:48.581Z DEBUG modem << OK
    2023-09-18T07:29:48.584Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:29:54.330Z DEBUG modem >> AT+Cpsms=0
    2023-09-18T07:29:54.524Z DEBUG modem << OK
    2023-09-18T07:29:57.414Z DEBUG modem >> AT+Cpsms?
    2023-09-18T07:29:57.422Z DEBUG modem << +CPSMS: 0
    2023-09-18T07:29:57.429Z DEBUG modem << OK
    2023-09-18T07:30:26.780Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:30:27.033Z DEBUG modem << +CEREG: 2
    2023-09-18T07:30:27.885Z DEBUG modem << [00:00:52.470,642] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:32:13.321Z INFO Auto Reconnecting Device SN: 000960084074
    2023-09-18T07:32:13.530Z INFO Modem port is opened
    2023-09-18T07:32:13.824Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:32:13.842Z DEBUG modem << %CESQ: 96,4,24,3
    2023-09-18T07:32:14.668Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T07:32:14.674Z DEBUG modem << +CSCON: 1
    2023-09-18T07:32:14.683Z DEBUG modem << +CFUN: 1
    2023-09-18T07:32:14.688Z DEBUG modem << OK
    2023-09-18T07:32:14.954Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:32:14.977Z DEBUG modem << [00:00:04.069,122] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:32:15.396Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:32:15.424Z DEBUG modem << OK
    2023-09-18T07:32:15.698Z DEBUG modem >> AT+CGMI
    2023-09-18T07:32:16.015Z DEBUG modem << +CGEV: ME PDN ACT 0
    2023-09-18T07:32:16.023Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2023-09-18T07:32:16.030Z DEBUG modem << +CEREG: 1,"0001","00000000",9,,,"11100000","11100000"
    2023-09-18T07:32:16.034Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:32:16.039Z DEBUG modem << OK
    2023-09-18T07:32:16.046Z DEBUG modem << %CESQ: 96,4,30,4
    2023-09-18T07:32:16.233Z DEBUG modem >> AT+CGMM
    2023-09-18T07:32:16.425Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:32:16.441Z DEBUG modem << OK
    2023-09-18T07:32:16.652Z DEBUG modem >> AT+CGMR
    2023-09-18T07:32:16.888Z DEBUG modem << [00:00:06.095,275] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED[0m
    2023-09-18T07:32:16.895Z DEBUG modem << [00:00:06.096,527] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:32:16.904Z DEBUG modem << [00:00mfw_nrf9160_1.3.4
    2023-09-18T07:32:16.908Z DEBUG modem << OK
    2023-09-18T07:32:16.914Z DEBUG modem << :06.096,527] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
    2023-09-18T07:32:16.917Z DEBUG modem << [00:00:06.096,649] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:32:16.920Z DEBUG modem << [00:00:06.098,144] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:32:16.923Z DEBUG modem << [00:00:06.297,149] [0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE[0m
    2023-09-18T07:32:16.929Z INFO Nordic Semiconductor ASA nRF9160-SICA [[00:00mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:32:17.300Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:32:18.067Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:32:18.084Z DEBUG modem << OK
    2023-09-18T07:32:18.093Z DEBUG modem << %CESQ: 88,4,29,4
    2023-09-18T07:32:18.112Z DEBUG modem << %CESQ: 81,4,28,4
    2023-09-18T07:32:18.123Z DEBUG modem << [00:00:07.202,239] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:32:18.129Z DEBUG modem << [00:00:07.202,514] [1;33m<wrn> date_time: getaddrinfo, error: -2[0m
    2023-09-18T07:32:18.134Z DEBUG modem << [00:00:07.202,514] [1;33m<wrn> date_time: Did not get time from any NTP server[0m
    2023-09-18T07:32:18.139Z DEBUG modem << %CESQ: 76,3,28,4
    2023-09-18T07:32:18.329Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:32:18.674Z DEBUG modem << %CESQ: 69,3,28,4
    2023-09-18T07:32:18.679Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:32:18.682Z DEBUG modem << OK
    2023-09-18T07:32:18.698Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:32:18.870Z DEBUG modem << +CMEE: 0
    2023-09-18T07:32:18.874Z DEBUG modem << OK
    2023-09-18T07:32:19.051Z DEBUG modem >> AT+Cpsms=0
    2023-09-18T07:32:19.314Z DEBUG modem << OK
    2023-09-18T07:32:19.554Z DEBUG modem >> AT+CMEE=1
    2023-09-18T07:32:19.773Z DEBUG modem << OK
    2023-09-18T07:32:20.005Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:32:20.289Z DEBUG modem << +CNEC: 16
    2023-09-18T07:32:20.502Z DEBUG modem << OK
    2023-09-18T07:32:20.702Z DEBUG modem >> AT+CNEC=24
    2023-09-18T07:32:20.920Z DEBUG modem << OK
    2023-09-18T07:32:20.941Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:32:21.231Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:32:21.241Z DEBUG modem << OK
    2023-09-18T07:32:21.390Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:32:21.602Z DEBUG modem << OK
    2023-09-18T07:32:21.862Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:32:22.093Z DEBUG modem << OK
    2023-09-18T07:32:22.108Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:32:22.343Z DEBUG modem << +CEREG: 5,1,"0001","00000000",9,,,"11100000","11100000"
    2023-09-18T07:32:22.350Z DEBUG modem << OK
    2023-09-18T07:32:22.365Z DEBUG modem >> AT+COPS=3,2
    2023-09-18T07:32:22.515Z DEBUG modem << OK
    2023-09-18T07:32:22.740Z DEBUG modem >> AT+COPS?
    2023-09-18T07:32:23.026Z DEBUG modem << +COPS: 0,2,"00101",9
    2023-09-18T07:32:23.042Z DEBUG modem << OK
    2023-09-18T07:32:23.243Z DEBUG modem >> AT%XCBAND
    2023-09-18T07:32:23.498Z DEBUG modem << %XCBAND: 3
    2023-09-18T07:32:23.504Z DEBUG modem << OK
    2023-09-18T07:32:23.527Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:32:23.752Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:32:23.756Z DEBUG modem << OK
    2023-09-18T07:32:23.922Z DEBUG modem >> AT+CGACT?
    2023-09-18T07:32:24.120Z DEBUG modem << +CGACT: 0,1
    2023-09-18T07:32:24.125Z DEBUG modem << OK
    2023-09-18T07:32:24.395Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:32:24.619Z DEBUG modem << OK
    2023-09-18T07:32:24.829Z DEBUG modem >> AT+CESQ
    2023-09-18T07:32:25.060Z DEBUG modem << +CESQ: 99,99,255,255,28,66
    2023-09-18T07:32:25.073Z DEBUG modem << OK
    2023-09-18T07:32:25.304Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:32:25.536Z DEBUG modem << OK
    2023-09-18T07:32:25.728Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:32:25.988Z DEBUG modem << %XSIM: 1
    2023-09-18T07:32:25.996Z DEBUG modem << OK
    2023-09-18T07:32:26.209Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:32:26.479Z DEBUG modem << +CPIN: READY
    2023-09-18T07:32:26.483Z DEBUG modem << OK
    2023-09-18T07:32:26.493Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:32:26.652Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:32:26.657Z DEBUG modem << OK
    2023-09-18T07:32:26.854Z DEBUG modem >> AT+CIMI
    2023-09-18T07:32:27.069Z DEBUG modem << 001010123456789
    2023-09-18T07:32:27.079Z DEBUG modem << OK
    2023-09-18T07:32:27.090Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:32:28.401Z DEBUG modem << +CGEV: IPV6 FAIL 0
    2023-09-18T07:32:28.681Z DEBUG modem >> AT+CGDCONT?
    2023-09-18T07:32:28.948Z DEBUG modem << +CGDCONT: 0,"IPV4V6","www.anritsu.com","192.168.20.11 0000:0000:0000:0000:0000:0000:0000:0001",0,0
    2023-09-18T07:32:28.955Z DEBUG modem << OK
    2023-09-18T07:32:29.118Z DEBUG modem >> AT+CGACT?
    2023-09-18T07:32:29.426Z DEBUG modem << +CGACT: 0,1
    2023-09-18T07:32:29.436Z DEBUG modem << OK
    2023-09-18T07:32:37.966Z DEBUG modem << %CESQ: 64,3,28,4
    2023-09-18T07:32:48.661Z DEBUG modem << [00:00:38.096,710] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:32:49.027Z DEBUG modem << [00:00:38.097,259] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:32:49.037Z DEBUG modem << [00:00:38.097,290] [1;33m<wrn> cloud_module: New connection attempt in 64 seconds if not successful[0m
    2023-09-18T07:32:49.042Z DEBUG modem << [00:00:38.097,442] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:32:49.047Z DEBUG modem << [00:00:38.098,297] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:33:15.353Z DEBUG modem >> AT%XMONITOR
    2023-09-18T07:33:15.508Z DEBUG modem << %XMONITOR: 1,"","","00101","0001",9,3,"00000000",0,1575,67,48,"","11100000","11100000","11100000"
    2023-09-18T07:33:15.519Z DEBUG modem << OK
    2023-09-18T07:33:52.658Z DEBUG modem << [00:01:42.097,442] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:33:52.861Z DEBUG modem << [00:01:42.097,991] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:33:53.108Z DEBUG modem << [00:01:42.098,022] [1;33m<wrn> cloud_module: New connection attempt in 128 seconds if not successful[0m
    2023-09-18T07:33:53.123Z DEBUG modem << [00:01:42.098,175] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:33:53.132Z DEBUG modem << [00:01:42.099,029] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:34:10.709Z DEBUG modem << +CSCON: 0
    2023-09-18T07:34:10.948Z DEBUG modem << %CESQ: 81,4,24,3
    2023-09-18T07:34:11.186Z DEBUG modem << %CESQ: 66,3,28,4
    2023-09-18T07:34:11.386Z DEBUG modem << [00:02:01.520,080] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:34:11.407Z DEBUG modem << [00:02:01.520,751] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2023-09-18T07:34:11.416Z DEBUG modem << [00:02:01.521,667] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:34:11.620Z DEBUG modem << [00:02:01.553,833] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:34:11.629Z DEBUG modem << [00:02:01.553,863] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:34:11.640Z DEBUG modem << [00:02:01.553,985] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY[0m
    2023-09-18T07:34:11.646Z DEBUG modem << [00:02:01.586,639] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:34:11.657Z DEBUG modem << [00:02:01.586,669] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:34:11.665Z DEBUG modem << [00:02:01.586,791] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2023-09-18T07:34:11.669Z DEBUG modem << [00:02:01.620,269] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2023-09-18T07:34:11.673Z DEBUG modem << [00:02:01.620,269] [1;31m<err> modem_info_params: Could not get time, error: -5[0m
    2023-09-18T07:34:11.680Z DEBUG modem << [00:02:01.620,391] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2023-09-18T07:34:13.315Z DEBUG modem << %CESQ: 66,3,33,4
    2023-09-18T07:34:15.955Z DEBUG modem << %CESQ: 80,4,27,3
    2023-09-18T07:34:17.273Z DEBUG modem << %CESQ: 95,4,34,4
    2023-09-18T07:34:19.922Z DEBUG modem << %CESQ: 94,4,29,4
    2023-09-18T07:34:22.711Z DEBUG modem >> AT%XMONITOR
    2023-09-18T07:34:22.993Z DEBUG modem << %XMONITOR: 1,"","","00101","0001",9,3,"00000000",0,1575,95,49,"","11100000","11100000","11100000"
    2023-09-18T07:34:22.997Z DEBUG modem << OK
    2023-09-18T07:34:23.194Z DEBUG modem << [00:02:12.522,186] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:34:23.442Z DEBUG modem << %CESQ: 96,4,34,4
    2023-09-18T07:34:26.034Z DEBUG modem << %CESQ: 96,4,28,4
    2023-09-18T07:34:27.358Z DEBUG modem << %CESQ: 96,4,34,4
    2023-09-18T07:34:28.672Z DEBUG modem << %CESQ: 94,4,29,4
    2023-09-18T07:34:33.476Z DEBUG modem << %CESQ: 97,4,34,4
    2023-09-18T07:34:41.112Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:34:41.307Z DEBUG modem << +CEREG: 2
    2023-09-18T07:34:41.558Z DEBUG modem << +CIND: "service",0
    2023-09-18T07:34:42.321Z DEBUG modem << [00:02:31.761,535] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:34:52.927Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:34:53.935Z DEBUG modem << [00:02:43.375,183] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:35:43.776Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:35:44.028Z DEBUG modem << +CFUN: 1
    2023-09-18T07:35:44.308Z DEBUG modem << OK
    2023-09-18T07:35:44.534Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:35:44.779Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:35:44.798Z DEBUG modem << OK
    2023-09-18T07:35:45.039Z DEBUG modem >> AT+CGMI
    2023-09-18T07:35:45.298Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:35:45.303Z DEBUG modem << OK
    2023-09-18T07:35:45.492Z DEBUG modem >> AT+CGMM
    2023-09-18T07:35:45.726Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:35:45.742Z DEBUG modem << OK
    2023-09-18T07:35:45.969Z DEBUG modem >> AT+CGMR
    2023-09-18T07:35:46.241Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:35:46.249Z DEBUG modem << OK
    2023-09-18T07:35:46.252Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:35:46.480Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:35:46.955Z DEBUG modem << +CEMODE: 2
    2023-09-18T07:35:46.963Z DEBUG modem << OK
    2023-09-18T07:35:47.199Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:35:47.447Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66)
    2023-09-18T07:35:47.455Z DEBUG modem << OK
    2023-09-18T07:35:47.694Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:35:47.938Z DEBUG modem << +CMEE: 1
    2023-09-18T07:35:48.211Z DEBUG modem << OK
    2023-09-18T07:35:48.439Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:35:48.709Z DEBUG modem << +CNEC: 24
    2023-09-18T07:35:48.718Z DEBUG modem << OK
    2023-09-18T07:35:48.937Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:35:49.175Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:35:49.193Z DEBUG modem << OK
    2023-09-18T07:35:49.422Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:35:49.677Z DEBUG modem << OK
    2023-09-18T07:35:49.941Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:35:50.193Z DEBUG modem << OK
    2023-09-18T07:35:50.431Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:35:50.675Z DEBUG modem << +CEREG: 5,2
    2023-09-18T07:35:50.692Z DEBUG modem << OK
    2023-09-18T07:35:50.935Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:35:51.194Z DEBUG modem << OK
    2023-09-18T07:35:51.447Z DEBUG modem >> AT+CESQ
    2023-09-18T07:35:51.727Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:35:51.743Z DEBUG modem << OK
    2023-09-18T07:35:51.982Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:35:52.253Z DEBUG modem << OK
    2023-09-18T07:35:52.499Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:35:52.773Z DEBUG modem << %XSIM: 1
    2023-09-18T07:35:52.782Z DEBUG modem << OK
    2023-09-18T07:35:53.014Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:35:53.258Z DEBUG modem << +CPIN: READY
    2023-09-18T07:35:53.269Z DEBUG modem << OK
    2023-09-18T07:35:53.516Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:35:53.793Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:35:53.805Z DEBUG modem << OK
    2023-09-18T07:35:54.049Z DEBUG modem >> AT+CIMI
    2023-09-18T07:35:54.321Z DEBUG modem << 001010123456789
    2023-09-18T07:35:54.329Z DEBUG modem << OK
    2023-09-18T07:35:54.340Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:36:00.655Z DEBUG modem << [00:03:50.098,175] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2023-09-18T07:36:00.823Z DEBUG modem << [00:03:50.098,724] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2023-09-18T07:36:00.831Z DEBUG modem << [00:03:50.098,754] [1;33m<wrn> cloud_module: New connection attempt in 256 seconds if not successful[0m
    2023-09-18T07:36:00.836Z DEBUG modem << [00:03:50.098,907] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:36:00.839Z DEBUG modem << [00:03:50.099,792] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2023-09-18T07:36:03.075Z DEBUG modem << +CEREG: 2
    2023-09-18T07:36:11.257Z DEBUG modem << %NCELLMEAS: 1
    2023-09-18T07:36:11.773Z DEBUG modem << [00:04:01.520,080] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2023-09-18T07:36:11.797Z DEBUG modem << [00:04:01.520,751] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS)[0m
    2023-09-18T07:36:12.808Z DEBUG modem << [00:04:01.521,575] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2023-09-18T07:36:12.816Z DEBUG modem << [00:04:01.539,245] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:36:12.830Z DEBUG modem << [00:04:01.539,276] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:36:12.840Z DEBUG modem << [00:04:01.539,337] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2023-09-18T07:36:12.852Z DEBUG modem << [00:04:01.548,675] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2023-09-18T07:36:12.857Z DEBUG modem << [00:04:01.548,675] [1;31m<err> modem_module: modem_info_params_get, error: -22[0m
    2023-09-18T07:36:12.861Z DEBUG modem << [00:04:01.548,767] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2023-09-18T07:36:12.867Z DEBUG modem << [00:04:01.703,491] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2023-09-18T07:36:12.872Z DEBUG modem << [00:04:01.704,193] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2023-09-18T07:36:15.804Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:36:15.814Z DEBUG modem << Attempting to boot slot 0.
    2023-09-18T07:36:16.057Z DEBUG modem << Attempting to boot from address 0x8200.
    2023-09-18T07:36:16.069Z DEBUG modem << Verifying signature against key 0.
    2023-09-18T07:36:16.077Z DEBUG modem << Hash: 0x91...10
    2023-09-18T07:36:16.374Z DEBUG modem << Firmware signature verified.
    2023-09-18T07:36:16.384Z DEBUG modem << Firmware version 1
    2023-09-18T07:36:16.387Z DEBUG modem << Booting (0x8200).
    2023-09-18T07:36:16.733Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:36:16.778Z DEBUG modem << I: Starting bootloader
    2023-09-18T07:36:16.793Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:36:16.799Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:36:16.803Z DEBUG modem << I: Boot source: none
    2023-09-18T07:36:16.807Z DEBUG modem << I: Swap type: none
    2023-09-18T07:36:16.812Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:36:16.821Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:36:16.826Z DEBUG modem << I: Boot source: none
    2023-09-18T07:36:16.837Z DEBUG modem << I: Swap type: none
    2023-09-18T07:36:16.847Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2023-09-18T07:36:16.851Z DEBUG modem << I: Jumping to the first image slot
    2023-09-18T07:36:17.194Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:36:18.088Z DEBUG modem << [00:00:00.492,553] [0m<inf> app_event_manager: APP_EVT_START[0m
    2023-09-18T07:36:18.516Z DEBUG modem << [00:00:00.493,713] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2023-09-18T07:36:18.535Z DEBUG modem << [00:00:00.558,197] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2023-09-18T07:36:19.257Z DEBUG modem << %CESQ: 94,4,34,4
    2023-09-18T07:36:19.307Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T07:36:19.414Z DEBUG modem << [00:00:01.511,779] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:36:19.426Z DEBUG modem << [00:00:02.160,797] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:36:43.717Z DEBUG modem << %CESQ: 96,4,28,4
    2023-09-18T07:36:45.036Z DEBUG modem << %CESQ: 96,4,34,4
    2023-09-18T07:37:08.884Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:37:10.005Z DEBUG modem << +CEREG: 2
    2023-09-18T07:37:10.842Z DEBUG modem << [00:00:52.356,170] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:37:36.277Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:37:36.290Z DEBUG modem << Attempting to boot slot 0.
    2023-09-18T07:37:36.296Z DEBUG modem << Attempting to boot from address 0x8200.
    2023-09-18T07:37:36.304Z DEBUG modem << Verifying signature against key 0.
    2023-09-18T07:37:36.311Z DEBUG modem << Hash: 0x91...10
    2023-09-18T07:37:36.647Z DEBUG modem << Firmware signature verified.
    2023-09-18T07:37:36.656Z DEBUG modem << Firmware version 1
    2023-09-18T07:37:36.661Z DEBUG modem << Booting (0x8200).
    2023-09-18T07:37:37.060Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:37:37.068Z DEBUG modem << I: Starting bootloader
    2023-09-18T07:37:37.073Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:37:37.077Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:37:37.080Z DEBUG modem << I: Boot source: none
    2023-09-18T07:37:37.085Z DEBUG modem << I: Swap type: none
    2023-09-18T07:37:37.089Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:37:37.093Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:37:37.097Z DEBUG modem << I: Boot source: none
    2023-09-18T07:37:37.111Z DEBUG modem << I: Swap type: none
    2023-09-18T07:37:37.117Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2023-09-18T07:37:37.121Z DEBUG modem << I: Jumping to the first image slot
    2023-09-18T07:37:37.540Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:37:38.609Z DEBUG modem << [00:00:00.492,553] [0m<inf> app_event_manager: APP_EVT_START[0m
    2023-09-18T07:37:38.635Z DEBUG modem << [00:00:00.493,682] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2023-09-18T07:37:38.648Z DEBUG modem << [00:00:00.558,135] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2023-09-18T07:37:39.283Z DEBUG modem << %CESQ: 96,4,27,3
    2023-09-18T07:37:39.535Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T07:37:39.829Z DEBUG modem << [00:00:01.511,749] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:37:39.839Z DEBUG modem << [00:00:02.337,066] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:37:40.315Z DEBUG modem << %CESQ: 96,4,33,4
    2023-09-18T07:38:04.352Z DEBUG modem << %CESQ: 96,4,28,4
    2023-09-18T07:38:05.671Z DEBUG modem << %CESQ: 96,4,34,4
    2023-09-18T07:38:29.479Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:38:29.756Z DEBUG modem << +CEREG: 2
    2023-09-18T07:38:30.586Z DEBUG modem << [00:00:52.532,470] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:38:49.476Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:38:49.480Z DEBUG modem << Attempting to boot slot 0.
    2023-09-18T07:38:49.825Z DEBUG modem << Attempting to boot from address 0x8200.
    2023-09-18T07:38:49.836Z DEBUG modem << Verifying signature against key 0.
    2023-09-18T07:38:49.840Z DEBUG modem << Hash: 0x91...10
    2023-09-18T07:38:50.213Z DEBUG modem << Firmware signature verified.
    2023-09-18T07:38:50.222Z DEBUG modem << Firmware version 1
    2023-09-18T07:38:50.226Z DEBUG modem << Booting (0x8200).
    2023-09-18T07:38:50.591Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:38:50.622Z DEBUG modem << I: Starting bootloader
    2023-09-18T07:38:50.639Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:38:50.645Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:38:50.659Z DEBUG modem << I: Boot source: none
    2023-09-18T07:38:50.667Z DEBUG modem << I: Swap type: none
    2023-09-18T07:38:50.689Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:38:50.696Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:38:50.702Z DEBUG modem << I: Boot source: none
    2023-09-18T07:38:50.707Z DEBUG modem << I: Swap type: none
    2023-09-18T07:38:50.717Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2023-09-18T07:38:50.724Z DEBUG modem << I: Jumping to the first image slot
    2023-09-18T07:38:51.093Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:38:51.760Z DEBUG modem << [00:00:00.492,584] [0m<inf> app_event_manager: APP_EVT_START[0m
    2023-09-18T07:38:52.457Z DEBUG modem << [00:00:00.493,713] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2023-09-18T07:38:52.473Z DEBUG modem << [00:00:00.558,166] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2023-09-18T07:38:53.272Z DEBUG modem << %CESQ: 95,4,34,4
    2023-09-18T07:38:53.310Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T07:38:53.663Z DEBUG modem << [00:00:01.511,779] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:38:53.695Z DEBUG modem << [00:00:02.083,709] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:39:42.438Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:39:42.780Z DEBUG modem << +CEREG: 2
    2023-09-18T07:39:43.545Z DEBUG modem << [00:00:52.279,113] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:39:52.786Z DEBUG modem >> AT+CFUN=1
    2023-09-18T07:39:53.068Z DEBUG modem << OK
    2023-09-18T07:40:00.245Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:40:00.531Z DEBUG modem << +CFUN: 1
    2023-09-18T07:40:00.549Z DEBUG modem << OK
    2023-09-18T07:40:00.827Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:40:01.133Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:40:01.146Z DEBUG modem << OK
    2023-09-18T07:40:01.411Z DEBUG modem >> AT+CGMI
    2023-09-18T07:40:01.681Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:40:01.702Z DEBUG modem << OK
    2023-09-18T07:40:01.978Z DEBUG modem >> AT+CGMM
    2023-09-18T07:40:02.246Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:40:02.259Z DEBUG modem << OK
    2023-09-18T07:40:02.547Z DEBUG modem >> AT+CGMR
    2023-09-18T07:40:02.823Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:40:02.839Z DEBUG modem << OK
    2023-09-18T07:40:02.843Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:40:03.139Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:40:03.776Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:40:03.788Z DEBUG modem << OK
    2023-09-18T07:40:04.060Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:40:04.338Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:40:04.355Z DEBUG modem << OK
    2023-09-18T07:40:04.645Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:40:04.912Z DEBUG modem << +CMEE: 0
    2023-09-18T07:40:04.916Z DEBUG modem << OK
    2023-09-18T07:40:05.194Z DEBUG modem >> AT+CMEE=1
    2023-09-18T07:40:05.502Z DEBUG modem << OK
    2023-09-18T07:40:05.778Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:40:06.047Z DEBUG modem << +CNEC: 16
    2023-09-18T07:40:06.070Z DEBUG modem << OK
    2023-09-18T07:40:06.321Z DEBUG modem >> AT+CNEC=24
    2023-09-18T07:40:06.563Z DEBUG modem << OK
    2023-09-18T07:40:06.881Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:40:07.181Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:40:07.195Z DEBUG modem << OK
    2023-09-18T07:40:07.464Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:40:07.798Z DEBUG modem << OK
    2023-09-18T07:40:08.050Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:40:08.329Z DEBUG modem << OK
    2023-09-18T07:40:08.590Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:40:08.899Z DEBUG modem << +CEREG: 5,2
    2023-09-18T07:40:08.913Z DEBUG modem << OK
    2023-09-18T07:40:09.145Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:40:09.495Z DEBUG modem << OK
    2023-09-18T07:40:09.743Z DEBUG modem >> AT+CESQ
    2023-09-18T07:40:10.064Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2023-09-18T07:40:10.074Z DEBUG modem << OK
    2023-09-18T07:40:10.407Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:40:10.731Z DEBUG modem << OK
    2023-09-18T07:40:11.019Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:40:11.280Z DEBUG modem << %XSIM: 1
    2023-09-18T07:40:11.303Z DEBUG modem << OK
    2023-09-18T07:40:11.558Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:40:11.837Z DEBUG modem << +CPIN: READY
    2023-09-18T07:40:11.856Z DEBUG modem << OK
    2023-09-18T07:40:12.106Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:40:12.418Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:40:12.425Z DEBUG modem << OK
    2023-09-18T07:40:12.445Z DEBUG modem >> AT+CIMI
    2023-09-18T07:40:12.747Z DEBUG modem << 001010123456789
    2023-09-18T07:40:12.757Z DEBUG modem << OK
    2023-09-18T07:40:12.760Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:40:26.873Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:40:26.878Z DEBUG modem << Attempting to boot slot 0.
    2023-09-18T07:40:26.881Z DEBUG modem << Attempting to boot from address 0x8200.
    2023-09-18T07:40:26.887Z DEBUG modem << Verifying signature against key 0.
    2023-09-18T07:40:26.891Z DEBUG modem << Hash: 0x91...10
    2023-09-18T07:40:27.178Z DEBUG modem << Firmware signature verified.
    2023-09-18T07:40:27.191Z DEBUG modem << Firmware version 1
    2023-09-18T07:40:27.197Z DEBUG modem << Booting (0x8200).
    2023-09-18T07:40:27.511Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:40:27.517Z DEBUG modem << I: Starting bootloader
    2023-09-18T07:40:27.524Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:40:27.528Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:40:27.533Z DEBUG modem << I: Boot source: none
    2023-09-18T07:40:27.538Z DEBUG modem << I: Swap type: none
    2023-09-18T07:40:27.542Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:40:27.546Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:40:27.554Z DEBUG modem << I: Boot source: none
    2023-09-18T07:40:27.562Z DEBUG modem << I: Swap type: none
    2023-09-18T07:40:27.571Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2023-09-18T07:40:27.587Z DEBUG modem << I: Jumping to the first image slot
    2023-09-18T07:40:28.142Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:40:29.148Z DEBUG modem << [00:00:00.492,462] [0m<inf> app_event_manager: APP_EVT_START[0m
    2023-09-18T07:40:29.471Z DEBUG modem << [00:00:00.493,621] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2023-09-18T07:40:29.799Z DEBUG modem << [00:00:00.558,044] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2023-09-18T07:40:30.108Z DEBUG modem << %CESQ: 96,4,30,4
    2023-09-18T07:40:30.145Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T07:40:30.446Z DEBUG modem << [00:00:01.511,688] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:40:30.458Z DEBUG modem << [00:00:01.973,205] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:41:10.146Z DEBUG modem >> AT%XMONITOR
    2023-09-18T07:41:10.396Z DEBUG modem << %XMONITOR: 2
    2023-09-18T07:41:10.405Z DEBUG modem << OK
    2023-09-18T07:41:19.723Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:41:20.046Z DEBUG modem << +CEREG: 2
    2023-09-18T07:41:20.824Z DEBUG modem << [00:00:52.168,640] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:41:39.639Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:41:39.644Z DEBUG modem << Attempting to boot slot 0.
    2023-09-18T07:41:39.648Z DEBUG modem << Attempting to boot from address 0x8200.
    2023-09-18T07:41:40.071Z DEBUG modem << Verifying signature against key 0.
    2023-09-18T07:41:40.080Z DEBUG modem << Hash: 0x91...10
    2023-09-18T07:41:40.468Z DEBUG modem << Firmware signature verified.
    2023-09-18T07:41:40.480Z DEBUG modem << Firmware version 1
    2023-09-18T07:41:40.485Z DEBUG modem << Booting (0x8200).
    2023-09-18T07:41:40.492Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:41:40.496Z DEBUG modem << I: Starting bootloader
    2023-09-18T07:41:40.500Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:41:40.511Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:41:40.515Z DEBUG modem << I: Boot source: none
    2023-09-18T07:41:40.521Z DEBUG modem << I: Swap type: none
    2023-09-18T07:41:40.531Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:41:40.538Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:41:40.544Z DEBUG modem << I: Boot source: none
    2023-09-18T07:41:40.549Z DEBUG modem << I: Swap type: none
    2023-09-18T07:41:41.028Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2023-09-18T07:41:41.038Z DEBUG modem << I: Jumping to the first image slot
    2023-09-18T07:41:41.429Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:41:42.029Z DEBUG modem << [00:00:00.492,492] [0m<inf> app_event_manager: APP_EVT_START[0m
    2023-09-18T07:41:42.053Z DEBUG modem << [00:00:00.493,652] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2023-09-18T07:41:42.061Z DEBUG modem << [00:00:00.558,044] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2023-09-18T07:41:42.548Z DEBUG modem << %CESQ: 96,4,34,4
    2023-09-18T07:41:42.792Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T07:41:43.173Z DEBUG modem << [00:00:01.511,749] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:41:43.179Z DEBUG modem << [00:00:02.166,015] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:42:07.557Z DEBUG modem << %CESQ: 96,4,28,4
    2023-09-18T07:42:08.912Z DEBUG modem << %CESQ: 96,4,34,4
    2023-09-18T07:42:30.398Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:42:30.557Z DEBUG modem << +CEREG: 5,2,"0001","00000000",9
    2023-09-18T07:42:30.569Z DEBUG modem << OK
    2023-09-18T07:42:32.677Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:42:32.880Z DEBUG modem << +CEREG: 2
    2023-09-18T07:42:33.784Z DEBUG modem << [00:00:52.361,450] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:43:22.283Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:43:22.612Z DEBUG modem << Attempting to boot slot 0.
    2023-09-18T07:43:22.653Z DEBUG modem << Attempting to boot from address 0x8200.
    2023-09-18T07:43:22.662Z DEBUG modem << Verifying signature against key 0.
    2023-09-18T07:43:23.072Z DEBUG modem << Hash: 0x91...10
    2023-09-18T07:43:23.094Z DEBUG modem << Firmware signature verified.
    2023-09-18T07:43:23.098Z DEBUG modem << Firmware version 1
    2023-09-18T07:43:23.103Z DEBUG modem << Booting (0x8200).
    2023-09-18T07:43:23.533Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:43:23.541Z DEBUG modem << I: Starting bootloader
    2023-09-18T07:43:23.547Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:43:23.557Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:43:23.563Z DEBUG modem << I: Boot source: none
    2023-09-18T07:43:23.568Z DEBUG modem << I: Swap type: none
    2023-09-18T07:43:23.586Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:43:23.592Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:43:23.597Z DEBUG modem << I: Boot source: none
    2023-09-18T07:43:23.607Z DEBUG modem << I: Swap type: none
    2023-09-18T07:43:23.613Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2023-09-18T07:43:23.617Z DEBUG modem << I: Jumping to the first image slot
    2023-09-18T07:43:23.982Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:43:24.571Z DEBUG modem << [00:00:00.492,553] [0m<inf> app_event_manager: APP_EVT_START[0m
    2023-09-18T07:43:24.577Z DEBUG modem << [00:00:00.493,713] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2023-09-18T07:43:24.584Z DEBUG modem << [00:00:00.558,135] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2023-09-18T07:43:24.880Z DEBUG modem << %CESQ: 96,4,25,3
    2023-09-18T07:43:25.188Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T07:43:25.591Z DEBUG modem << [00:00:01.511,779] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:43:25.597Z DEBUG modem << [00:00:01.909,820] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:43:25.924Z DEBUG modem << %CESQ: 96,4,33,4
    2023-09-18T07:43:31.648Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:43:31.844Z DEBUG modem << +CEREG: 5,2,"0001","00000000",9
    2023-09-18T07:43:31.858Z DEBUG modem << OK
    2023-09-18T07:43:49.956Z DEBUG modem << %CESQ: 95,4,28,4
    2023-09-18T07:43:51.275Z DEBUG modem << %CESQ: 95,4,34,4
    2023-09-18T07:44:15.269Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:44:15.310Z DEBUG modem << +CEREG: 2
    2023-09-18T07:44:16.183Z DEBUG modem << [00:00:52.105,255] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:44:40.073Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:44:40.079Z DEBUG modem << Attempting to boot slot 0.
    2023-09-18T07:44:40.086Z DEBUG modem << Attempting to boot from address 0x8200.
    2023-09-18T07:44:40.415Z DEBUG modem << Verifying signature against key 0.
    2023-09-18T07:44:40.427Z DEBUG modem << Hash: 0x91...10
    2023-09-18T07:44:40.441Z DEBUG modem << Firmware signature verified.
    2023-09-18T07:44:40.447Z DEBUG modem << Firmware version 1
    2023-09-18T07:44:40.457Z DEBUG modem << Booting (0x8200).
    2023-09-18T07:44:40.833Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:44:40.843Z DEBUG modem << I: Starting bootloader
    2023-09-18T07:44:40.847Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:44:40.851Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:44:40.858Z DEBUG modem << I: Boot source: none
    2023-09-18T07:44:40.866Z DEBUG modem << I: Swap type: none
    2023-09-18T07:44:40.870Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:44:40.876Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2023-09-18T07:44:40.879Z DEBUG modem << I: Boot source: none
    2023-09-18T07:44:40.895Z DEBUG modem << I: Swap type: none
    2023-09-18T07:44:40.899Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2023-09-18T07:44:40.903Z DEBUG modem << I: Jumping to the first image slot
    2023-09-18T07:44:41.358Z DEBUG modem << *** Booting Zephyr OS build v3.1.99-ncs1  ***
    2023-09-18T07:44:42.361Z DEBUG modem << [00:00:00.492,492] [0m<inf> app_event_manager: APP_EVT_START[0m
    2023-09-18T07:44:42.367Z DEBUG modem << [00:00:00.493,652] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2023-09-18T07:44:42.617Z DEBUG modem << [00:00:00.558,074] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2023-09-18T07:44:42.967Z DEBUG modem << %CESQ: 96,4,30,4
    2023-09-18T07:44:43.230Z DEBUG modem << +CEREG: 2,"0001","00000000",9
    2023-09-18T07:44:43.638Z DEBUG modem << [00:00:01.511,718] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2023-09-18T07:44:43.647Z DEBUG modem << [00:00:02.200,469] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2023-09-18T07:44:56.732Z DEBUG modem >> AT+CFUN?
    2023-09-18T07:44:56.967Z DEBUG modem << +CFUN: 1
    2023-09-18T07:44:57.282Z DEBUG modem << OK
    2023-09-18T07:44:57.589Z DEBUG modem >> AT+CGSN=1
    2023-09-18T07:44:57.920Z DEBUG modem << +CGSN: "351901930753730"
    2023-09-18T07:44:57.935Z DEBUG modem << OK
    2023-09-18T07:44:58.200Z DEBUG modem >> AT+CGMI
    2023-09-18T07:44:58.500Z DEBUG modem << Nordic Semiconductor ASA
    2023-09-18T07:44:58.516Z DEBUG modem << OK
    2023-09-18T07:44:58.821Z DEBUG modem >> AT+CGMM
    2023-09-18T07:44:59.116Z DEBUG modem << nRF9160-SICA
    2023-09-18T07:44:59.133Z DEBUG modem << OK
    2023-09-18T07:44:59.439Z DEBUG modem >> AT+CGMR
    2023-09-18T07:44:59.854Z DEBUG modem << mfw_nrf9160_1.3.4
    2023-09-18T07:44:59.860Z DEBUG modem << OK
    2023-09-18T07:44:59.863Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.4] SerNr: 351901930753730
    2023-09-18T07:45:00.076Z DEBUG modem >> AT+CEMODE?
    2023-09-18T07:45:00.620Z DEBUG modem << +CEMODE: 0
    2023-09-18T07:45:00.636Z DEBUG modem << OK
    2023-09-18T07:45:00.918Z DEBUG modem >> AT%XCBAND=?
    2023-09-18T07:45:01.219Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2023-09-18T07:45:01.239Z DEBUG modem << OK
    2023-09-18T07:45:01.545Z DEBUG modem >> AT+CMEE?
    2023-09-18T07:45:01.852Z DEBUG modem << +CMEE: 0
    2023-09-18T07:45:01.873Z DEBUG modem << OK
    2023-09-18T07:45:02.147Z DEBUG modem >> AT+CMEE=1
    2023-09-18T07:45:02.448Z DEBUG modem << OK
    2023-09-18T07:45:02.739Z DEBUG modem >> AT+CNEC?
    2023-09-18T07:45:03.082Z DEBUG modem << +CNEC: 16
    2023-09-18T07:45:03.099Z DEBUG modem << OK
    2023-09-18T07:45:03.378Z DEBUG modem >> AT+CNEC=24
    2023-09-18T07:45:03.697Z DEBUG modem << OK
    2023-09-18T07:45:04.007Z DEBUG modem >> AT+CGEREP?
    2023-09-18T07:45:04.336Z DEBUG modem << +CGEREP: 1,0
    2023-09-18T07:45:04.652Z DEBUG modem <<
    2023-09-18T07:45:04.678Z DEBUG modem << OK
    2023-09-18T07:45:04.961Z DEBUG modem >> AT+CIND=1,1,1
    2023-09-18T07:45:05.278Z DEBUG modem << OK
    2023-09-18T07:45:05.609Z DEBUG modem >> AT+CEREG=5
    2023-09-18T07:45:05.914Z DEBUG modem << OK
    2023-09-18T07:45:06.237Z DEBUG modem >> AT+CEREG?
    2023-09-18T07:45:06.569Z DEBUG modem << +CEREG: 5,2,"0001","00000000",9
    2023-09-18T07:45:06.580Z DEBUG modem << OK
    2023-09-18T07:45:06.874Z DEBUG modem >> AT%CESQ=1
    2023-09-18T07:45:07.174Z DEBUG modem << OK
    2023-09-18T07:45:07.533Z DEBUG modem >> AT+CESQ
    2023-09-18T07:45:07.876Z DEBUG modem << +CESQ: 99,99,255,255,34,96
    2023-09-18T07:45:07.881Z DEBUG modem << OK
    2023-09-18T07:45:07.901Z DEBUG modem >> AT%XSIM=1
    2023-09-18T07:45:08.180Z DEBUG modem << OK
    2023-09-18T07:45:08.467Z DEBUG modem >> AT%XSIM?
    2023-09-18T07:45:08.794Z DEBUG modem << %XSIM: 1
    2023-09-18T07:45:08.812Z DEBUG modem << OK
    2023-09-18T07:45:09.101Z DEBUG modem >> AT+CPIN?
    2023-09-18T07:45:09.478Z DEBUG modem << +CPIN: READY
    2023-09-18T07:45:09.485Z DEBUG modem << OK
    2023-09-18T07:45:09.764Z DEBUG modem >> AT+CPINR="SIM PIN"
    2023-09-18T07:45:10.166Z DEBUG modem << +CPINR: "SIM PIN",3
    2023-09-18T07:45:10.173Z DEBUG modem << OK
    2023-09-18T07:45:10.382Z DEBUG modem >> AT+CIMI
    2023-09-18T07:45:10.763Z DEBUG modem << 001010123456789
    2023-09-18T07:45:10.767Z DEBUG modem << OK
    2023-09-18T07:45:10.774Z INFO IMSIdentity: 001010123456789
    2023-09-18T07:45:33.157Z DEBUG modem << %CESQ: 255,0,255,0
    2023-09-18T07:45:33.500Z DEBUG modem << +CEREG: 2
    2023-09-18T07:45:34.263Z DEBUG modem << [00:00:52.395,904] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    Let us know if you need more details.
    Paresh Patel
  • HI Paresh,
    Are you using Anritsu MT8821C? Could you make sure "scenarios 6 and 7" selection RLC AM is used, RLC UM is a different matter (related to CMW500).
    Charlie
  • Hi Charlie,
    I'm not sure the NB-IoT setup is Anritsu MT8821C or other. I don't know about  "scenarios 6 and 7" selection RLC AM.
    We are testing nRF9160 DK in USA and we are successfully connected with LTE-M network, now we are facing some issue on PSM and eDRX mode and we created other ticket and conversation on this thread is going on.
    Paresh
  • Thanks for the update. I will close this case then.
    Charlie
