I've noticed that the bootloader no longer prints messages on the UART at boot.
For example, take the very simple hello-world sample project. It has a simple prj.conf with:
# Print a banner on the UART on startup. CONFIG_BOOT_BANNER=y # Enable console and printk() CONFIG_PRINTK=y CONFIG_STDOUT_CONSOLE=y # Enable Zephyr application to be booted by MCUboot CONFIG_BOOTLOADER_MCUBOOT=y
If the project is built with version 2.3.0 then the following is printed on boot:
*** Booting Zephyr OS build v3.2.99-ncs2 *** I: Starting bootloader I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 I: Boot source: none I: Swap type: none I: Bootloader chainload address offset: 0xc000
However, if you take the exact same project and only change it to build wit 2.4.0 you only see the "Booting Zephyr OS build"
How do I get the bootloader to print logs in 2.4.0?
Thanks!
