nrf5340 audio: How to remove dependence on 32k oscillator
We have a custom development board based on 5340 audio, and based on cost control, we want to remove the 32k oscillator.
But after removing it, the program cannot run normally. Is there any dependence on it in the nrf5340 audio demo? How should I remove it?
    Do you want to remove 32.678 KHz crystal X2 which is connected to XL1 and XL2 as shown in the chapter 3.3 of the nrf5340 audio dk hardware user guide?
    Could you describe what happens to your application after the removal of the crystal? Could you provide application log when program cannot run properly?
    Dejan
  • Hi, Dejan
    Yes, I want to tear them down.
    The current location is that when the external flash memory DFU function is started, the program cannot run (it should be that MCUBoot is waiting for the crystal oscillator device).
    But I don't know how to modify it, currently I added the following configuration to disable them.
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
    Reskyllr
  • Hi, there is new progress,
    I try to add the following config under mcuboot:
    The log begins to output, but the network core BLE cannot be enabled.
    On the development board with a crystal oscillator, it works normally, with the same hex.
    HL [00:00:00.201,385] <inf> fw_info:
       nRF5340 Audio nRF5340 Audio DK cpuapp
       NCS base version: 2.4.0
       Cmake run : Tue Sep 26 14:55:50 2023
    HL [00:00:00.201,385] <inf> fw_info: ------- DEBUG BUILD -------
    HL [00:00:00.201,385] <inf> fw_info: HEADSET left device
    HL [00:00:00.701,446] <err> ble: No response from NET core, check if NET core is programmed
    HL [00:00:00.701,446] <err> ble: ERR_CHK Err_code: [-5] @ line: 43
    HL [00:00:00.701,477] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000002  r2/a3:  0x00000001
    HL [00:00:00.701,477] <err> os: r3/a4:  0x00090a0f r12/ip:  0x00000010 r14/lr:  0x00090a99
    HL [00:00:00.701,477] <err> os:  xpsr:  0x41000025
    HL [00:00:00.701,507] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    HL [00:00:00.701,507] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    HL [00:00:00.701,538] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    HL [00:00:00.701,538] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
    HL [00:00:00.701,568] <err> os: fpscr:  0x00000000
    HL [00:00:00.701,568] <err> os: Faulting instruction address (r15/pc): 0x0001590a
    HL [00:00:00.701,599] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    HL [00:00:00.701,599] <err> os: Fault during interrupt handling
    HL [00:00:00.701,629] <err> os: Current thread: 0x20005658 (idle)
    HL [00:00:00.701,660] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
    You could try adding configuration options which specify that LFCLK will not be taken from 32.768 KHz crystal. Instead, it will be synthesized from 32 MHz clock.
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
    Dejan
    I added this to the subimage,work well.
    Reskyllr
