we are currently facing ann issue with the connection parameter update function.
wee initialized our connection parameters as following:
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(7.5 , UNIT_1_25_MS) /**< Minimum acceptable connection interval (7.5 ms). */ #define MAX_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Maximum acceptable connection interval (30 ms). */ #define SLAVE_LATENCY 0 /**< Slave latency. */ #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(2000, UNIT_10_MS) /**< Connection supervisory timeout (2 seconds). */ #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
connection parameters are set here:
static uint32_t gap_params_init(void) { ... } static uint32_t conn_params_init(void) { ... }
and updated in when we receive an event
case BLE_GAP_EVT_CONN_PARAM_UPDATE: { // Accepting parameters requested err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle, &p_gap_evt->params.conn_param_update.conn_params); APP_ERROR_CHECK(err_code); } break;
so we thought we'll set our parameters and if the other device sends other parameters we set and accept them. i think the slave is our bluetooth device and the master was an iphone.
we used the sniffer to check what's going on.
our device is requesting the connection parameters first:
No. Time Source Destination Protocol Length Info 236 9.589153 Slave_0x506573e6 Master_0x506573e6 L2CAP 42 Connection Parameter Update Request Frame 236: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface COM6-4.0, id 0 nRF Sniffer for Bluetooth LE Bluetooth Low Energy Link Layer Access Address: 0x506573e6 [Master Address: 55:11:5c:c4:15:5e (55:11:5c:c4:15:5e)] [Slave Address: fe:95:21:38:7b:d5 (fe:95:21:38:7b:d5)] Data Header .... ..10 = LLID: Start of an L2CAP message or a complete L2CAP message with no fragmentation (0x2) .... .0.. = Next Expected Sequence Number: 0 [ACK] .... 1... = Sequence Number: 1 [OK] ...0 .... = More Data: False ..0. .... = CTE Info: Not Present 00.. .... = RFU: 0 Length: 16 [L2CAP Index: 29] [Connection Parameters in: 58] CRC: 0x299bf1 Bluetooth L2CAP Protocol Length: 12 CID: Low Energy L2CAP Signaling Channel (0x0005) Command: Connection Parameter Update Request Command Code: Connection Parameter Update Request (0x12) Command Identifier: 0x03 Command Length: 8 Min. Interval: 6 (7.5 msec) Max. Interval: 6 (7.5 msec) Slave Latency: 0 LL Connection Events Timeout Multiplier: 200 (2 sec)
Then i think the iphone is responding with some other parameters:
No. Time Source Destination Protocol Length Info 237 9.618916 Master_0x506573e6 Slave_0x506573e6 LE LL 38 Control Opcode: LL_CONNECTION_UPDATE_IND Frame 237: 38 bytes on wire (304 bits), 38 bytes captured (304 bits) on interface COM6-4.0, id 0 nRF Sniffer for Bluetooth LE Bluetooth Low Energy Link Layer Access Address: 0x506573e6 [Master Address: 55:11:5c:c4:15:5e (55:11:5c:c4:15:5e)] [Slave Address: fe:95:21:38:7b:d5 (fe:95:21:38:7b:d5)] Data Header .... ..11 = LLID: Control PDU (0x3) .... .0.. = Next Expected Sequence Number: 0 [ACK] .... 0... = Sequence Number: 0 [OK] ...1 .... = More Data: True ..0. .... = CTE Info: Not Present 00.. .... = RFU: 0 Length: 12 Control Opcode: LL_CONNECTION_UPDATE_IND (0x00) Window Size: 3 (3.75 msec) Window Offset: 0 (0 msec) Interval: 24 (30 msec) Latency: 0 Timeout: 200 (2000 msec) Instant: 93 [Connection Parameters in: 58] CRC: 0x041631
then the master sends two times that the connection parameters were accepted:
No. Time Source Destination Protocol Length Info 239 9.619435 Master_0x506573e6 Slave_0x506573e6 L2CAP 36 Connection Parameter Update Response (Accepted) Frame 239: 36 bytes on wire (288 bits), 36 bytes captured (288 bits) on interface COM6-4.0, id 0 nRF Sniffer for Bluetooth LE Bluetooth Low Energy Link Layer Access Address: 0x506573e6 [Master Address: 55:11:5c:c4:15:5e (55:11:5c:c4:15:5e)] [Slave Address: fe:95:21:38:7b:d5 (fe:95:21:38:7b:d5)] Data Header .... ..10 = LLID: Start of an L2CAP message or a complete L2CAP message with no fragmentation (0x2) .... .1.. = Next Expected Sequence Number: 1 [ACK] .... 1... = Sequence Number: 1 [OK] ...0 .... = More Data: False ..0. .... = CTE Info: Not Present 00.. .... = RFU: 0 Length: 10 [L2CAP Index: 31] [Connection Parameters in: 58] CRC: 0x204260 Bluetooth L2CAP Protocol Length: 6 CID: Low Energy L2CAP Signaling Channel (0x0005) Command: Connection Parameter Update Response Command Code: Connection Parameter Update Response (0x13) Command Identifier: 0x03 Command Length: 2 Move Result: Accepted (0x0000) No. Time Source Destination Protocol Length Info 240 9.648916 Master_0x506573e6 Slave_0x506573e6 L2CAP 36 Connection Parameter Update Response (Accepted) Frame 240: 36 bytes on wire (288 bits), 36 bytes captured (288 bits) on interface COM6-4.0, id 0 nRF Sniffer for Bluetooth LE Bluetooth Low Energy Link Layer Access Address: 0x506573e6 [Master Address: 55:11:5c:c4:15:5e (55:11:5c:c4:15:5e)] [Slave Address: fe:95:21:38:7b:d5 (fe:95:21:38:7b:d5)] Data Header .... ..10 = LLID: Start of an L2CAP message or a complete L2CAP message with no fragmentation (0x2) .... .1.. = Next Expected Sequence Number: 1 [ACK] .... 1... = Sequence Number: 1 [Retransmit] ...0 .... = More Data: False ..0. .... = CTE Info: Not Present 00.. .... = RFU: 0 Length: 10 [L2CAP Index: 32] [Connection Parameters in: 58] CRC: 0x204260 Bluetooth L2CAP Protocol Length: 6 CID: Low Energy L2CAP Signaling Channel (0x0005) Command: Connection Parameter Update Response Command Code: Connection Parameter Update Response (0x13) Command Identifier: 0x03 Command Length: 2 Move Result: Accepted (0x0000)
Afterwards the slave sends update requests regularly, but all of them get rejected by the master.
No. Time Source Destination Protocol Length Info 255 9.859114 Slave_0x506573e6 Master_0x506573e6 L2CAP 42 Connection Parameter Update Request Frame 255: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface COM6-4.0, id 0 nRF Sniffer for Bluetooth LE Bluetooth Low Energy Link Layer Access Address: 0x506573e6 [Master Address: 55:11:5c:c4:15:5e (55:11:5c:c4:15:5e)] [Slave Address: fe:95:21:38:7b:d5 (fe:95:21:38:7b:d5)] Data Header .... ..10 = LLID: Start of an L2CAP message or a complete L2CAP message with no fragmentation (0x2) .... .1.. = Next Expected Sequence Number: 1 [ACK] .... 0... = Sequence Number: 0 [OK] ...0 .... = More Data: False ..0. .... = CTE Info: Not Present 00.. .... = RFU: 0 Length: 16 [L2CAP Index: 33] [Connection Parameters in: 237] CRC: 0xd15ede Bluetooth L2CAP Protocol Length: 12 CID: Low Energy L2CAP Signaling Channel (0x0005) Command: Connection Parameter Update Request Command Code: Connection Parameter Update Request (0x12) Command Identifier: 0x05 Command Length: 8 Min. Interval: 24 (30 msec) Max. Interval: 24 (30 msec) Slave Latency: 0 LL Connection Events Timeout Multiplier: 200 (2 sec) No. Time Source Destination Protocol Length Info 256 9.888921 Master_0x506573e6 Slave_0x506573e6 L2CAP 36 Connection Parameter Update Response (Rejected) Frame 256: 36 bytes on wire (288 bits), 36 bytes captured (288 bits) on interface COM6-4.0, id 0 nRF Sniffer for Bluetooth LE Bluetooth Low Energy Link Layer Access Address: 0x506573e6 [Master Address: 55:11:5c:c4:15:5e (55:11:5c:c4:15:5e)] [Slave Address: fe:95:21:38:7b:d5 (fe:95:21:38:7b:d5)] Data Header .... ..10 = LLID: Start of an L2CAP message or a complete L2CAP message with no fragmentation (0x2) .... .1.. = Next Expected Sequence Number: 1 [ACK] .... 1... = Sequence Number: 1 [OK] ...0 .... = More Data: False ..0. .... = CTE Info: Not Present 00.. .... = RFU: 0 Length: 10 [L2CAP Index: 34] [Connection Parameters in: 237] CRC: 0x6491d7 Bluetooth L2CAP Protocol Length: 6 CID: Low Energy L2CAP Signaling Channel (0x0005) Command: Connection Parameter Update Response Command Code: Connection Parameter Update Response (0x13) Command Identifier: 0x05 Command Length: 2 Move Result: Rejected (0x0001) No. Time Source Destination Protocol Length Info
so to us it looks like we're setting the parameters, the iphone accepts but sends other parameters. and as we try to set them from our device, the iphone always rejects the update. same happens with an android device. both times we used the nrf connect app to test.
here's the full wireshark log:
if we remove
in our event, then it looks like the device tries to change parameters 3 times and then it disconnects due to
we can set this number up, but that looks like a dirty fix to me and if we use the update in our event connection parameter changed is triggered multiple times a second, so i fear that it affects our data transmisson.
we use s112
